When looking into the generated .fit file from WinCupl, the default is Pin_keep_mode = ON & Output_fast = OFF (see attached code).
To change the default, the following lines need to be inserted before any assignments in the PLD file:
PROPERTY ATMEL { OUTPUT_FAST = ON };
PROPERTY ATMEL { PIN_KEEP = OFF };
Have you checked if there is any difference between fast/slow slew rate?
Would not expect any difference with PIN_KEEP turned off.
Atmel ATF1502AS Fitter Version 1.8.7.8 ,running Thu Oct 23 21:18:45 2025
fit1502 C:\WINCUPL\U180.tt2 -CUPL -dev P1502T44 -JTAG ON
****** Initial fitting strategy and property ******
Pla_in_file = U180.tt2
Pla_out_file = U180.tt3
Jedec_file = U180.jed
Vector_file = U180.tmv
verilog_file = U180.vt
Time_file =
Log_file = U180.fit
err_file =
Device_name = TQFP44
Module_name =
Package_type = TQFP
Preassign_file =
Property_file =
Sleep_mode =
Preassignment =
Security_mode = OFF
Pin_keep_mode = ON
Dedicated_input_clock =
Dedicated_input_reset =
Dedicated_input_oe =
supporter = CUPL
optimize = ON
Soft_buffer =
Xor_synthesis = OFF
Foldback_logic = on
Expander =
Cascade_logic = OFF
Dedicated_input =
Output_fast = OFF
Power down pin 1 = OFF
Power down pin 2 = OFF
power_reset = OFF
JTAG = ON
TDI pullup = OFF
TMS pullup = OFF
MC_power = OFF
Open_collector = OFF
ITD0 = ON
ITD1 = ON
ITD2 = ON
Fast_inlatch = off
Fitter_Pass 1, Preassign = KEEP, LOGIC_DOUBLING : OFF
Performing global Output Enable pin assignments ...
Performing global pin assignments ...
Final global control pins assignment (if applicable)...
CLK assigned to pin 37
Performing input pin pre-assignments ...
Attempt to place floating signals ...
TDI is placed at pin 1 (MC 4)
TMS is placed at pin 7 (MC 9)
PR1 is placed at pin 10 (MC 11)
PS1 is placed at pin 11 (MC 12)
NS1 is placed at pin 12 (MC 13)
NR1 is placed at pin 13 (MC 14)
RUSN2 is placed at pin 14 (MC 15)
LADSN is placed at pin 15 (MC 16)
RUSN1 is placed at pin 35 (MC 17)
RUSN3 is placed at pin 34 (MC 18)
SLA is placed at pin 33 (MC 19)
TDO is placed at pin 32 (MC 20)
SLB is placed at pin 31 (MC 21)
RUZ is placed at pin 30 (MC 22)
RUS is placed at pin 28 (MC 23)
ENS is placed at pin 27 (MC 24)
TCK is placed at pin 26 (MC 25)
RUR is placed at pin 25 (MC 26)
ENR is placed at pin 23 (MC 27)
NR2 is placed at pin 22 (MC 28)
NS2 is placed at pin 21 (MC 29)
ZERO is placed at pin 20 (MC 30)
PS2 is placed at pin 19 (MC 31)
PR2 is placed at pin 18 (MC 32)
R R
U U
V C G S S
C L N N N
C K D 1 3
____________________________________
/ 44 43 42 41 40 39 38 37 36 35 34 \
TDI | 1 33 | SLA
| 2 32 | TDO
| 3 31 | SLB
GND | 4 30 | RUZ
| 5 29 | VCC
| 6 ATF1502 28 | RUS
TMS | 7 44-Lead TQFP 27 | ENS
| 8 26 | TCK
VCC | 9 25 | RUR
PR1 | 10 24 | GND
PS1 | 11 23 | ENR
| 12 13 14 15 16 17 18 19 20 21 22 |
\____________________________________/
N N R L G V P P Z N N
S R U A N C R S E S R
1 1 S D D C 2 2 R 2 2
N S O
2 N
VCC = Supply Voltage pin which must be connected to (5.0V or 3.0V)
GND = GND pin which must be connected to ground
TMS,TDI,TDO,TDI = JTAG pins which must reserved for the JTAG interface
NC = Unused I/O pins which must be unconnected on the board
Universal-Interconnect-Multiplexer assignments
FanIn assignment for block A [6]
ENS,ENR,
RUZ,RUS,RUR,
SLA,
Multiplexer assignment for block A
RUZ (MC3 P) : MUX 0 Ref (B22p)
RUS (MC2 P) : MUX 4 Ref (B23p)
ENS (MC5 P) : MUX 6 Ref (B24p)
SLA (MC6 P) : MUX 14 Ref (B19p)
ENR (MC4 P) : MUX 31 Ref (B27p)
RUR (MC1 P) : MUX 34 Ref (B26p)
FanIn assignment for block B [6]
ENS,ENR,
RUZ,RUS,RUR,
SLB,
Multiplexer assignment for block B
SLB (MC6 P) : MUX 8 Ref (B21p)
Creating JEDEC file C:\WINCUPL\U180.jed ...
TQFP44 programmed logic:
NR1.D = (ENR & !SLA);
LADSN.D = ((RUR & RUS)
# (RUZ & RUS)
# (RUR & RUZ));
NR2.D = (ENR & !SLB);
NS1.D = (ENS & !SLA);
NS2.D = (ENS & !SLB);
PR2.D = (ENR & SLB);
PR1.D = (ENR & SLA);
PS1.D = (ENS & SLA);
PS2.D = (ENS & SLB);
RUSN1.D = (RUR & !RUS & !RUZ);
RUSN3.D = (!RUR & RUS & !RUZ);
RUSN2.D = (!RUR & !RUS & RUZ);
ZERO.D = (!ENR & !ENS & !RUR & !RUS & !RUZ);
NR1.C = !CLK;
LADSN.C = !CLK;
NR2.C = !CLK;
NS1.C = !CLK;
NS2.C = !CLK;
PR2.C = !CLK;
PR1.C = !CLK;
PS1.C = !CLK;
PS2.C = !CLK;
RUSN1.C = !CLK;
RUSN3.C = !CLK;
RUSN2.C = !CLK;
ZERO.C = !CLK;
TQFP44 Pin/Node Placement:
Pin 1 = TDI; /* MC 4 */
Pin 7 = TMS; /* MC 9 */
Pin 10 = PR1; /* MC 11 */
Pin 11 = PS1; /* MC 12 */
Pin 12 = NS1; /* MC 13 */
Pin 13 = NR1; /* MC 14 */
Pin 14 = RUSN2; /* MC 15 */
Pin 15 = LADSN; /* MC 16 */
Pin 18 = PR2; /* MC 32 */
Pin 19 = PS2; /* MC 31 */
Pin 20 = ZERO; /* MC 30 */
Pin 21 = NS2; /* MC 29 */
Pin 22 = NR2; /* MC 28 */
Pin 23 = ENR; /* MC 27 */
Pin 25 = RUR; /* MC 26 */
Pin 26 = TCK; /* MC 25 */
Pin 27 = ENS; /* MC 24 */
Pin 28 = RUS; /* MC 23 */
Pin 30 = RUZ; /* MC 22 */
Pin 31 = SLB; /* MC 21 */
Pin 32 = TDO; /* MC 20 */
Pin 33 = SLA; /* MC 19 */
Pin 34 = RUSN3; /* MC 18 */
Pin 35 = RUSN1; /* MC 17 */
Pin 37 = CLK;
** Resource Usage **
DCERP Field = Summary of Allocations.
|||||_Preset [p,-] == p = PT preset, - No Preset.
||||__Reset [g,r,-] == g= Global AR, r = PT reset, - No reset.
|||___Clock Enable [e,-] == e = Product Term, - always enabled, - none.
||____Clock [c,g,-], == c = Product term, g = Global term, - No Clock.
|_____Type [C,D,L,T], == Register type C= combin, D=dff, L=latch, T=tff.
For input only = INPUT.
MCell Pin# Oe PinDrive DCERP FBDrive DCERP Foldback CascadeOut TotPT output_slew
MC1 42 -- -- -- -- 0 slow
MC2 43 -- -- -- -- 0 slow
MC3 44 -- -- -- -- 0 slow
MC4 1 -- TDI INPUT -- -- -- 0 slow
MC5 2 -- -- -- -- 0 slow
MC6 3 -- -- -- -- 0 slow
MC7 5 -- -- -- -- 0 slow
MC8 6 -- -- -- -- 0 slow
MC9 7 -- TMS INPUT -- -- -- 0 slow
MC10 8 -- -- -- -- 0 slow
MC11 10 on PR1 Dg--- -- -- -- 1 slow
MC12 11 on PS1 Dg--- -- -- -- 1 slow
MC13 12 on NS1 Dg--- -- -- -- 1 slow
MC14 13 on NR1 Dg--- -- -- -- 1 slow
MC15 14 on RUSN2 Dg--- -- -- -- 1 slow
MC16 15 on LADSN Dg--- -- -- -- 3 slow
MC17 35 on RUSN1 Dg--- -- -- -- 1 slow
MC18 34 on RUSN3 Dg--- -- -- -- 1 slow
MC19 33 -- SLA INPUT -- -- -- 0 slow
MC20 32 -- TDO INPUT -- -- -- 0 slow
MC21 31 -- SLB INPUT -- -- -- 0 slow
MC22 30 -- RUZ INPUT -- -- -- 0 slow
MC23 28 -- RUS INPUT -- -- -- 0 slow
MC24 27 -- ENS INPUT -- -- -- 0 slow
MC25 26 -- TCK INPUT -- -- -- 0 slow
MC26 25 -- RUR INPUT -- -- -- 0 slow
MC27 23 -- ENR INPUT -- -- -- 0 slow
MC28 22 on NR2 Dg--- -- -- -- 1 slow
MC29 21 on NS2 Dg--- -- -- -- 1 slow
MC30 20 on ZERO Dg--- -- -- -- 1 slow
MC31 19 on PS2 Dg--- -- -- -- 1 slow
MC32 18 on PR2 Dg--- -- -- -- 1 slow
MC0 40 -- -- -- -- 0 slow
MC0 39 -- -- -- -- 0 slow
MC0 38 -- -- -- -- 0 slow
MC0 37 CLK INPUT -- -- -- 0 slow
Logic Array Block Logic Cells I/O Pins Foldbacks TotalPT FanIN Cascades
A: LC1 - LC16 6/16(37%) 8/16(50%) 0/16(0%) 8/80(10%) (6) 0
B: LC17 - LC32 7/16(43%) 16/16(100%) 0/16(0%) 7/80(8%) (6) 0
Total dedicated input used: 1/4 (25%)
Total I/O pins used 24/32 (75%)
Total Logic cells used 13/32 (40%)
Total Flip-Flop used 13/32 (40%)
Total Foldback logic used 0/32 (0%)
Total Nodes+FB/MCells 13/32 (40%)
Total cascade used 0
Total input pins 12
Total output pins 13
Total Pts 15
Creating pla file C:\WINCUPL\U180.tt3 with 0 inputs 0 outputs, 0 pins 0 nodes and 0 pterms...
---------------- End fitter, Design FITS
$Device TQFP44 fits
FIT1502 completed in 0.00 seconds
