Author Topic: Ultra Precision Reference LTZ1000  (Read 2231501 times)
0 Members and 276 Guests are viewing this topic.
Offline dietert1
  • Country: br
    • CADT Homepage
Re: Ultra Precision Reference LTZ1000
« Reply #3300 on: May 22, 2024, 08:29:47 pm »
Isn't the broken one an invitation to break others in order to confirm they are hollow? I mean the device is already ruined anyway.
The following users thanked this post: MiDi
Offline MiDi
« Reply #3301 on: May 22, 2024, 10:50:25 pm »
Those are Soda Lime Solid Glass Microspheres - SLGMS-2.5 90-106 for $133.37.
Thermal conductivity: ~1 W/mK
Specific heat: ~0.9 kJ/kgK
« Last Edit: May 22, 2024, 10:59:35 pm by MiDi »
Offline KT88
« Reply #3302 on: May 22, 2024, 11:03:09 pm »
The density of the cospheric sphered is stated as 2.5g/cc which is the density of (solid) glass.
Offline Noopy
    • Richis-Lab
« Reply #3303 on: May 23, 2024, 04:41:27 am »
Scratching over the material didn't really break bubbles. But I was not sure if I had put enough force into the material.
Thank you, now that is clear.  :-+
Offline floobydust
« Reply #3304 on: May 23, 2024, 04:44:41 am »
Does anyone know the history of die-attach compounds with the glass/ceramic balls/spheres? It looks like a Linear Technology Secret Sauce?
Not seen on any older heated-die references like LM399 I think.
Perusing patents on this for more information, I found a little:
"Die structure using microspheres as a stress buffer for integrated circuit prototypes" Clear Logic {1998} US 6,020,648
Linear Technology Patent US 4,888,634 {1989} (expired)  "... improving the uniformity of operating temperature of packaged integrated circuit chips." Carl Nelson not mentioned in a relevant (die-attach) patent.
I think any voids are not a good sign. "Voids are the small areas in the Die Attach area that are filled with a mixture of gases and other environmental variables, such as, air, moisture and dust. After the die placement, there could be a significant amount of waiting time before the subsequent curing process. It can result in a high level of moisture absorption in the Die Attach pastes. While the organic substrates may absorb moisture, moisture may also be present on the metal leadframe surface.  As the temperature increases during curing, absorbed moisture will evolve as steam to cause a void."
https://oricus-semicon.com/common-issues-of-die-attach
What happens when you buy or copy high technology or outsource it- the Secret Sauce gets bungled. I've seen it happen 1000x.
I fully expect ADI to have problems transplanting fab and packaging. They probably haven't even noticed, laid off all the important LT staff that would.
The following users thanked this post: Mickle T., 2N3055, TUMEMBER, Noopy
Offline MiDi
« Reply #3305 on: May 23, 2024, 06:35:06 am »
ADR1001 seems to use glass microspheres, ADR1000 not.
from Richi´s Lab
Offline Noopy
    • Richis-Lab
« Reply #3306 on: June 12, 2024, 07:50:01 pm »
I have taken a closer look at the LTZ1000A die attach and some other similar die attach materials:
LTZ1000: https://www.richis-lab.de/REF03.htm
LTZ1000A: https://www.richis-lab.de/REF44.htm
ADR1000: https://www.richis-lab.de/REF19.htm
ADR1001 Engineering Sample: https://www.richis-lab.de/REF29.htm
ADR1001: https://www.richis-lab.de/REF45.htm
LT1088: https://www.richis-lab.de/LT1088.htm
As we have seen the beads in the LTZ1000A have quite different diameters.
The PCN shows that the new beads are solid glass. We don´t know much about the old material we see in this LTZ1000A.
Now let´s take a look at the specifications and the different die attach materials.
The LTZ1000 is specified with a thermal resistance of 80K/W. In the LTZ1000A, it was possible to increase the thermal resistance to 400K/W. The mass used here as the attachment must therefore have an additional thermal resistance of 320K/W. With the known dimensions and the estimated thickness of the die attach material, it can be calculated that the thermal conductivity of the die attach must not be higher than 0,08W/Km.
The table below shows the thermal conductivities of various materials. Epoxy is in the range of 0,14W/Km. There are epoxy mixtures that offer a higher value, but it is not easy to reduce the thermal conductivity. This explains why the ADR1000 has a slightly lower thermal resistance. The newer versions of the LTZ1000A contain solid glass beads from Cospheric. This type of glass has a thermal conductivity of 1,46W/Km. Even though these are spheres and not a solid block, the conductivity is initially far too high to achieve the thermal resistance of 400K/W.
Air conducts heat very poorly. This explains how the high thermal resistance of the LT1088 could be achieved. Assuming that the thermal resistance of the package is similar to that of the LTZ1000, the additional measure must have a thermal conductivity of 0,08W/Km to 0,22W/Km. The foam shown in the LT1088 can represent this value. Hollow glass spheres, such as those produced by 3M, are another way of achieving such low thermal conductivity.
As we have seen at the edge there is a hole in the die attach material.
Removing the die reveals that the special material was only applied to the outer areas. This means that the necessary thermal resistance can also be achieved with solid glass spheres. A large part of the area is insulated by the air cushion.
The cavity probably also explains the opening on the left edge. It enables gas exchange, which could be necessary during production. In addition, a sealed gas volume under the die could be problematic in the event of temperature changes. Mechanical stresses caused by pressure differences can have a noticeable effect on such an accurate reference stress source.
A few glass spheres are broken open and expose a cavity. In this picture there is such a sphere at the top left.
There is a glass sphere under the die, where it is clearly visible that hollow spheres were used. This is surprising. The aforementioned PCN describes a conversion to solid glass spheres, but does not indicate that the previous material contained hollow spheres. Even if the material is only applied to the edge area, it can be assumed that the thermal conductivity does change somewhat.
When using hollow spheres, it should be possible to apply the material over the entire area. This would reduce the risk of undefined contact surfaces leading to mechanical stresses in the die. Such stresses, which may be temperature-dependent, can have a problematic effect on a high-precision reference. In general, the question must be asked whether the advantage of the higher thermal resistance compensates for the potential disadvantages of a somewhat undefined mounting of the die. Just my two cents...
 :-/O
Offline dietert1
  • Country: br
    • CADT Homepage
« Reply #3307 on: June 12, 2024, 08:40:07 pm »
For me these pictures look like the die attach is handmade and an ad-hoc solution. Wouldn't an expensive reference chip deserve something better, e.g. a clean, machined support made of teflon or a metal clamp with three fingers?
Also i am wondering about the ADR1399, as it runs pretty hot. Won't the epoxy outgas into the hermetic enclosure each time the heater turns on?
Regards, Dieter
Offline iMo
  • Country: li
« Reply #3308 on: June 13, 2024, 07:48:57 am »
The "opening on the left edge" is definitely a random stuff. Nothing to do with intentionally made hole for escaping the gases, imho.
Or, perhaps, an insect (bug) made it while trying to escape from his cave during the initial burn-in process  :D
Offline Noopy
    • Richis-Lab
« Reply #3309 on: June 13, 2024, 10:04:30 am »
I´m not sure about that. We have seen such openings twice. Just the engineering sample of the ADR1001 doesn´t have it. In my view such an opening would make sense. A closed volume under the die doesn´t sound very good.
Perhaps the opening emerges as a byproduct in a final process step before closing the package. Perhaps there is some vacuum before filling the package with dry nitrogen or something like that. If the polymer is not cured completely in this process step the opening can occur by itself.
Of course I´m just speculating...
Offline iMo
  • Country: li
« Reply #3310 on: June 13, 2024, 03:34:30 pm »
Frankly, I really doubt that is something of an intentional nature. They would do it in a different way if planned. It could be after they apply the caviar, put the die on it and cure it somehow with an UV blink, then after bonding they solder the upper lid on, the high temperature creates pressure below the die where the residual gases may escape through the polymer where it is the weakest with a "puff"  ;D.
The process of applying the caviar paste looks rather random to me, indeed..
Offline Noopy
    • Richis-Lab
« Reply #3311 on: June 13, 2024, 07:14:47 pm »
Perhaps you are right. Either way I don´t like the idea of an undefined gas volume under a voltage reference...  :-\
Offline floobydust
« Reply #3312 on: June 13, 2024, 07:55:11 pm »
How do they attach the bonding wires without breaking or straining the die if it's lightly supported?
I thought you'd need to press down with force for wire bonding (ultrasonic weld?).
I've also read common die attach could be a B-phase epoxy, which has a second thermal curing possible.
I think automated dispensing would require a dedicated machine and nozzle for the special caviar. For an ISO9001 company, it's looking pretty hokey.
You could figure out what compound they're using.
Shin-Etsu Die Attach Material
Henkel Die attach adhesives
The following users thanked this post: TUMEMBER
Offline Noopy
    • Richis-Lab
« Reply #3313 on: June 14, 2024, 03:34:43 am »
I´m no expert for bonding but in my view looking at the whole die the force of the bond process is quite small. You have to be careful not to damage the bondpad but the crystal itself is quite strong.
Dispensing for sure isn´t easy especially this mixture of different diameters we see in this LTZ1000A.
Would be hard to find the exact die attach material.
It is interesting that they mix the compound by themself...
Offline iMo
  • Country: li
« Reply #3314 on: June 14, 2024, 05:35:27 am »
..Either way I don´t like the idea of an undefined gas volume under a voltage reference...  :-\
Absolutely. That would require a process where the escape tunnel(s) will be well defined. While looking at the pictures I doubt it is. You would need a "spacer" which gets removed after curing the polymer in the caviar. And a subsequent test in a pressure chamber.
Offline rigrunner
« Reply #3315 on: January 10, 2025, 12:04:16 am »
I haven't purchased an LTZ1000CH for a while. When did the case style change?
Internet of Things: A solution desperately trying to find its problem
Offline Andreas
« Reply #3316 on: January 10, 2025, 06:40:11 am »
Hmm,
shure that you got genuine parts from official distributors?
According to data sheet the package height should be between 165 - 185 mils (4.2-4.7 mm)
I also saw no PCN regarding the package height.
with best regards
Andreas
Offline Noopy
    • Richis-Lab
« Reply #3317 on: January 10, 2025, 07:07:49 am »
Let's take a look inside...  ;D
Offline rigrunner
« Reply #3318 on: January 10, 2025, 07:16:33 pm »
Hmm,
I would hope it is a genuine part. Arrived from Mouser yesterday.
Measuring the metal part of the case only, and with ancient calipers:
                            New      Old
total height         4.3mm   4.8mm
above lip             3.6mm   4.1mm
lip height               .8mm     .7mm
lip diameter         9.4mm   9.4mm
body diameter     8.4mm  8.4mm  (just above lip)
If you order another from Mouser i'll pay half toward it?
« Last Edit: January 10, 2025, 07:59:30 pm by rigrunner »
Offline Noopy
    • Richis-Lab
« Reply #3319 on: January 10, 2025, 08:05:05 pm »
I asume it´s just a change which needed no PCN since it´s still more or less in the range of the tolerance.
The marking looks like the marking on the LTZ1000 I have taken a closer look:
I don´t know if it´s dubious enough to check a new one. Can you check if the performance is like it should be?
Offline rigrunner
« Reply #3320 on: January 10, 2025, 08:13:02 pm »
More or less is the exact accuracy of the old calipers I used. They are good enough to give a comparison but I would not trust their absolute accuracy at all.
I won't be using it immediately, but I will be able to compare it to other references at some point.
Offline Noopy
    • Richis-Lab
« Reply #3321 on: January 11, 2025, 03:59:08 am »
If there are doubts emerging I will take a closer look.  :-/O
Offline Dr. Frank
  • Got a lot of time now - and very low uncertainty
« Reply #3322 on: January 11, 2025, 06:15:28 am »
They need to send/publish a PCN whenever they change critical dimensions, even if this would be inside the specification margin.
I this case, automatic Pick & Place would not work properly any more.
See also the Automotive PCN DeQuMa: https://www.zvei.org/en/subjects/product-process-change-notification-method-in-automotive-electronics,
=> PCN-Delta-Qualification-Matrix Rev. 5_1_8
Case SEM-PA-01 is a Board Level change, i.e. critical for manufacturing.
I don't remember that they changed the package recently, therefore it's necessary to check thoroughly.
Frank
There's this PCN:
Oct 30, 2020 - 20_0324
ADI Philippines as an assembly plant to replace ADI Hillview for commercial hermetic products in TO5, TO39 and Sidebrazed Packages
But it does not include a case change.
« Last Edit: January 11, 2025, 06:25:55 am by Dr. Frank »
Offline Noopy
    • Richis-Lab
« Reply #3323 on: January 11, 2025, 06:26:09 am »
I know the automotive requirements very well but outside the automotive area you can't be sure what you get (unless you are in another special field like military or you have special contracts).
TO-5 is not the typical pick and place part.  ;D
Is there an automotive qualified LTZ1000? The 7,5 digit DMM in the trunk...  ;D
« Last Edit: January 11, 2025, 06:55:52 am by Noopy »
Offline Dr. Frank
« Reply #3324 on: January 11, 2025, 06:40:34 am »
I expect that ADI generally treats any changes on any component following the Automotive rules, as their QA processes will not distinguish between the commercial and automotive business.
You're right, it would be difficult to assemble this package automatically, but the change of the height would negatively affect the thermal construction, when you need a defined length of the legs, and use an outer thermal shield.
Are you also working @ Automotive?
Frank
« Last Edit: January 11, 2025, 06:45:07 am by Dr. Frank »
