Quote from: KerimF on October 18, 2023, 12:16:49 pmAn SMPS supply (24V/2A for example), working from 100Vac up to about 240Vac, may not be important to most engineers. On my side, I use it to supply most of the controller boards in my products. I mean it is not really relevant to the issue of limiting maximum voltage. If you are trying to supply power to a device that will take between 100 and 240 V and you want to prevent the mains 230V going over voltage then you can put a transformer (or autotransformer) that will reduce the voltage from 230V nominal to, say, 160V. That way you are sure to never go over voltage.
Is there a valid reason for you to not just develop your own SMPS capable of doing exactly what you need? Switcher with integrated 700V rated MOSFET's are available for peanuts.
Quote from: soldar on October 18, 2023, 12:39:17 pmQuote from: KerimF on October 18, 2023, 12:16:49 pmAn SMPS supply (24V/2A for example), working from 100Vac up to about 240Vac, may not be important to most engineers. On my side, I use it to supply most of the controller boards in my products. I mean it is not really relevant to the issue of limiting maximum voltage. If you are trying to supply power to a device that will take between 100 and 240 V and you want to prevent the mains 230V going over voltage then you can put a transformer (or autotransformer) that will reduce the voltage from 230V nominal to, say, 160V. That way you are sure to never go over voltage.In this case, let us calculate the acceptable minimum mains voltage:Vmin = 100V [minimum for SMPS] * 230 / 160 = 143.75 VAnd let us calculate the acceptable maximum mains voltage:Vmax = 250 [typical maximum for SMPS] * 230 / 160 =359.375VIn general, these two limits look reasonable.The problem is that local consumers used to buy mains stabilizers working from 110V up to 290V (16-step model by using 4 relays). And above 290V, the saturation high current of their transformer opens their main breaker. These stabilizers don't use an external DC supply. Their controller is supplied by a low AC voltage taken from their main power transformer. Therefore, their protecting power relay has to be at the output, not input (hot line).To compete in the local market, I let my controllers and their display work normally from 100V to 400V. The input of the stabilizer, excluding its SMPS, is isolated completely from mains by a protecting power relay if the Vac > 290V or below 110V). Things will return back to normal when the mains voltage returns back within limits (no need to switch/close an open mechanical breaker after a mains overvoltage). For instance, ordering or making a special small transformer is not economical on my side.
I realize there is a bit of a language problem but I think I am only now beginning to understand what you want to do. You are not explaining it very clearly.You want a device that is connected to the mains and disconnects the load when voltage is under a voltage V1 or over another voltage V2 and connects the load when the voltage is between these values. Is this what you want to do?
I reI cannot imagine living somewhere where the mains voltage is so unstable. That has to damage all sorts of appliances and electronics.
...its just a matter of doing things properly with official and reliable tools, they exists and doesn't cost a fortune
you did receive very good answers, and telling you are in say dire position monetary / political / other ... and not telling the full story is not helping you ... i can understand you but here right now, you ask for advise / help and you are still mysterious or vague in some instance(s)
you play with voltages and or currents, this is or may be a safety concern
to have huge voltages swings in ac network / main voltages is not good BUT you need voltage conditioning / limitters, once again you did receive some answers and it seems you don't want to acknowledge them https://www.amazon.ca/Automatic-Protector-Reconnect-Reliable-Adjustable/dp/B08RJ6JSZDhttps://www.amazon.com/Protection-Adjustable-Automatic-Reconnect-Protector/dp/B07TQH19KQ?th=1https://www.walmart.ca/en/ip/adjustable-delay-protector-automatic-relay-protector-automatic-reconnect-for-voltage-protector-home/PRD15VKYMJO27WZhttps://www.walmart.ca/en/ip/Protection-Relay-Automatic-Protector-Over-Under-Voltage-Recovery-2P-40A/PRD4CHY6XXFF2Z6and this onehttps://www.automationdirect.com/adc/overview/catalog/relays_-z-_timers/voltage_monitoring_relays
With all the time and money you may lost trying to build something similar, try some already made solutions, to buy one, or try to get them shipped to you unless your country is totally isolated from the planet
Could you not power the SMPS from the output of the stabilizer? Kind of like a reverse "bootstrap" configuration.ie: The stabilizer's default mode is passthrough and it powers both the SMPS and the load.
"These stabilizers (not designed by me) don't use an external DC supply.
You could make some sort of high voltage linear regulator, so that the transistor acts as a series resistor.
The easiest solution to your problem is a source follower. Just a bridge rectifier, a zener, a couple resistors and a MOSFET and some inrush current limiter.I can't seem to come up with a better schematic than this one:https://electronics.stackexchange.com/questions/553703/source-follower-large-signal-analysis-as-level-shifterVin is derived from the mains supply with a zener diodes and a resistor. The voltage across Rs (your SMPS) will be at 2...5 V below the zener voltage.
Still no way you're clamping the mains, forget that idea right now.What's the power of the smps?You could make some sort of high voltage linear regulator, so that the transistor acts as a series resistor.This will create a lot of heat, so meant for short durations events only (spikes, sudden changes). A proper solution? A PFC circuit that produces stable DC output over a wide range of input voltages, then feed this DC to your smps.
Quote from: KerimF on October 18, 2023, 06:06:11 pm"These stabilizers (not designed by me) don't use an external DC supply. No.. Using your "stabilizer" to power your SMPS which powers your "stabilizer"...ie: On startup, and if input line voltage is lower than 250VAC, the SMPS is connected to the line input via a DPDT relay. The SMPS powers your stabilizer and after a delay, the DPDT relay switches over so the SMPS is now powered by the output of your stabilizer. Now, your line voltage can vary up and down while your stabilizer keeps the voltage on the load and SMPS steady.If the input voltage goes too high, your system shuts off, but the SMPS does not get reconnected to the line until the input voltage drops below 250VAC. So the input voltage has to drop below 250VAC before the system will auto restart.
If I'm understanding right what OP is after is a sort of preregulator for the control circuit PSU of a whole house mains tap changer voltage stabilizer. So they can use an available supply that can't handle more than 240V. They cannot use the output of the stabilizer because they want the power supply live full time, so the tap changer can connect and disconnect from the grid as the voltage goes in and out of the limits of the tap changer's transformer, rather than put the transformer into saturation and trip the breaker feeding it as their competitor's designs do. I think the easiest solution is probably to rectify and buck down the mains to a reasonable value, then feed that DC to the SMPS, not sure that quite qualifies as PFC as DavidAlfa suggested, but it should work and the inductor is much simpler.
What about just a solid state switch that is on when the instantaneous voltage is less than 360V or so and off when above? I have seen a similar design to make a small 120V only switching supply able to run on both 120V and 240V. Very little dissipation and almost zero switching losses.
