Author Topic: Am I going crazy???  (Read 4714 times)
Offline Mr JTopic starter
    • Facebook mjssvt
Am I going crazy???
« on: August 24, 2016, 12:22:25 pm »
Hi everyone,
I was just going over some class materials for the Boyscout Radio Merit Badge and found an oscillator schematic on page 32 that looks like it will not work. I am going crazy or is there no feedback loop to keep the oscillator going?
Offline Whales
    • Halestrom
Re: Am I going crazy???
« Reply #1 on: August 24, 2016, 12:33:37 pm »
Hmm.
Current entering the base will pull the top of the crystal down.  Then eventually the voltage at the top of the 10K resistor drops, prohibiting the transistor from conducting.  After the inductor collapses the top of the 10K resistor charges up again, also pulling the top of the crystal and base up.  Repeat.
    • Facebook mjssvt
« Reply #2 on: August 24, 2016, 12:36:16 pm »
here is a close one that I breadboard and does work, look like the one on the top is missing a cap between Base and Emitter????
Online Andy Watson
« Reply #3 on: August 24, 2016, 12:40:29 pm »
Capacitance between the collector and base provide the feedback.
Online JimRemington
« Reply #4 on: August 24, 2016, 05:51:56 pm »
Try breadboarding the original. I'll bet it works too.
Online PA0PBZ
« Reply #5 on: August 24, 2016, 06:06:21 pm »
The breadboard will take care of the feedback for you.
Offline StillTrying
  • Country: Broken Britain
« Reply #6 on: August 24, 2016, 07:47:07 pm »
Is that positive or negative feedback?
Online Andy Watson
« Reply #7 on: August 24, 2016, 09:17:04 pm »
"Feedback" was probably a poor choice of word. The collector-base capacitance couples the output tuned-circuit back to the input tuned-circuit, i.e. the crystal. Try searching for "tuned plate tuned grid oscillator".
Offline Cyberdragon
« Reply #8 on: August 25, 2016, 12:59:06 am »
It's a Miller crystal oscillator.
*BZZZZZZAAAAAP*
Voltamort strikes again!
Offline StillTrying
« Reply #9 on: August 25, 2016, 02:32:13 am »
After looking at 100s of oscillator circuits I've not been able to convince myself that the effect between a valve's anode and grid is the same as that between a transistor's collector an base.
"Therefore, if the plate is slightly more positive, the voltage induced on the grid (the opposite plate of this small "capacitor) will be negative."
http://electronicstheory.com/COURSES/ELECTRONICS/e101-58.htm
Offline Cyberdragon
« Reply #10 on: August 25, 2016, 02:58:12 am »
There is only one way to find out, datasheet time! ;D
EDIT: Emitter-Base = 25pF
           Collector-Base = 8pF
« Last Edit: August 25, 2016, 03:02:40 am by Cyberdragon »
*BZZZZZZAAAAAP*
    • Facebook mjssvt
« Reply #11 on: August 25, 2016, 12:50:46 pm »
Thats it!!!! thanks Cyber
