Author Topic: Binary Full Adder  (Read 918 times)
Offline printingcrewTopic starter
Binary Full Adder
« on: November 15, 2025, 04:51:51 pm »
I'm new to this forum, thought I'd share something I made a few weeks ago.
I decided to investigate computing at the most basic level: transistors. To do this, I decided to make an 8 bit full adder using 144 of them!
After covering my table in breadboards I wanted something more compact. I considered veroboard, but in the end I decided on some custom PCBs once I realised you can send your files off to China and get something back within 2 weeks!
After soldering everything (and then correcting all the mistakes I made while soldering!) it worked! The whole thing runs off a pair of AA batteries, but I added a USB port compatibility too.
The whole thing is modular so I could test one board at a time.
Here are some photos!
Re: Binary Full Adder
« Reply #1 on: November 15, 2025, 05:03:19 pm »
Any ideas on what I can do with this? Should I make one for subtracting, multiplying and division?
Online themadhippy
« Reply #2 on: November 15, 2025, 05:42:27 pm »
keep adding to it until you end up with a transistor only computer
Offline Doctorandus_P
« Reply #3 on: November 15, 2025, 05:44:47 pm »
What is your age?
Offline pcprogrammer
« Reply #4 on: November 15, 2025, 05:49:21 pm »
Nice and most of all fun.
To make it smaller you can look into SMD. With sot-23 transistors and 0805 resistors and capacitors you could shrink it quite a bit.
Subtraction is simple and uses the same full adder setup by using two complements. Multiplication and division will be a lot harder and need a lot of transistors.
As a fun project turning it into a transistor based CPU might be an option. Has already been done for a 6502 CPU though. See: https://monster6502.com/
Offline microvia
« Reply #5 on: November 15, 2025, 06:19:53 pm »
There are interesting examples of 16-bit computers made with transistors (except maybe for the RAM and EPROM).
One example here: https://www.hackster.io/news/tranor-s-diy-transistor-computer-has-a-cpu-design-containing-2-495-discrete-transistors-483fde19662d.
Offline brucehoult
« Reply #6 on: November 16, 2025, 12:43:54 am »
Nice work!
Subtraction is trivial. Just invert one input and feed a 1 carry into the LSB instead of a 0 carry.
18 transistors per 1 bit full-adder is a lot.
You can do each bit with fourteen 2-input NAND gates using either RTL or DTL, or six 3-input NAND gates plus 4 inverters. Each gate or inverter needs one transistor in any case.
« Last Edit: November 16, 2025, 12:45:34 am by brucehoult »
