Thanks, subbed.
Side note, wonder why the MAX6350 is not oftenly discussed here in this forum. From the spec sheet, with TC of 1 ppm/C , initial accuracy 0.02% and 30ppm/1000hr longterm stability, not too shabby right ?
Or the 6126 with 20ppm/1000hr?
After some searching around on Aliexpress I found I can get them for $3. So less than double the cost of a REF5050. No tout like the ref5050 though, but I'm still thinking of ordering a couple.
Hello,
according to my own measurements the (typical) datasheet values have nothing to do with the real world.
The ageing numbers are only valid (if at all) for the first 1000 hours after production or first soldering.
(some datasheets specify the second 1000 hours to keep the number comparable to the usual 20-30 ppm/kHr).
A really good (buried zener) reference will settle after around 6-12 month to a ageing rate below 10ppm/year.
e.g. around 2 ppm/year at room temperature.
The MAX6350 has a low T.C. but my 2 samples have a constant ageing rate of 10ppm/year. (over 3 years).
Whereas other buried zeners (AD586LQ) go down to the 2 ppm/year after initial drift.
https://www.eevblog.com/forum/projects/newbie-precision-reference-calibrated-with-the-3478a-dinosaur/msg538036/#msg538036The MAX6126 (and REF5050) is a bandgap reference. So even when specced with 20ppm/kHr it will be
outperformed by a buried zener reference.
The housing of the reference plays a large role in stability.
Metal can or ceramic hermetically packages give much more stability than a DIP8 housing.
A dip 8 housing gives up to factor 3 more stability against a SO-8. (found in a MAXIM datasheet).
The long term stability of the MSOP package is specced factor 5 worse than SO-8 for the MAX6126.
So size matters.
So my personal ranking for references is
hermetically sealed:
1. LTZ1000/LTZ1000A
2. LM399
3. AD587UQ/AD586LQ
(3.5 LT1027CCH/BCH: unobtanium)
4. LT1236AILS8
plastic:
5. AD586MNZ
6. LT1027CCN8 (low ageing but large humidity drift)
7. MAX6350CPA/MAX6250ACPA (low humidity but large ageing drift)
And after that all the other references.
with best regards
Andreas
