Author Topic: DC Voltage References Battle - Overview of market  (Read 34585 times)
Offline TiNTopic starter
  • Country: ua
    • xDevs.com
« on: October 01, 2015, 04:39:29 am »
Hi all,
Friend of mine asked me recently to check his DC voltage reference, cheap AD584KH-based module, and provide calibration if needed. I went on EEVBlog to check, if anyone already tested or reviewed reference he had, found bunch of threads, but not a single source with all data in one place. This brought me an idea, what if we summary all available boards from different people, and make overall spreadsheet with their specs/cost/performance level?
Yes, it sounds like "we have 14 standards, let's make one common standard. Now we have 15 standards", so feel free to blame me on it.
We have bunch of threads about LTZ1000, LM399-based designs, but I think they are time-consuming and overkill for someone who just want pick a ref to calibrate their gear, within given budget.
Summary
PhotoModule nameTypeBased solutionOutput voltageAccuracyTempcoCostNotes
AD584KH TaobaoZener IC, non-ovenizedAnalog Devices AD584KH2.5, 5.0, 7.5, 10.0 VDC+/-500ppm?+/-30ppm15$External power, low cost
HP 3458A A9 board (STD)Super-zener, ovenizedLinear LTZ1000A7.2 direct VDC2%+/-8ppm$100-700Available from Keysight
HP 3458A A9 board (002)Super-zener, ovenizedLinear LTZ1000A7.2 direct VDC2%+/-4ppm$984Available from Keysight
N/A
HP 3458A A9 board (HFL)Super-zener, ovenizedLinear LTZ1000A7.2 direct VDC2%+/-2ppm$2195Orderable from Keysight
Reviews
AD584KH quad-voltage reference - TiN's review - in works
« Last Edit: October 01, 2015, 01:23:18 pm by TiN »
The following users thanked this post: EmmanuelFaure
Offline Vgkid
Re: DC Voltage References Battle - Overview of market
« Reply #1 on: October 01, 2015, 04:52:02 am »
I look forward to more additions, subscribed.
Offline BravoV
  • +++ ATH1
« Reply #2 on: October 01, 2015, 05:11:04 am »
Thanks, subbed.  :-+
Side note, wonder why the MAX6350 is not oftenly discussed here in this forum. From the spec sheet, with TC of 1 ppm/C , initial accuracy 0.02% and 30ppm/1000hr longterm stability, not too shabby right ?
« Last Edit: October 01, 2015, 05:12:54 am by BravoV »
Offline Mr.B
« Reply #3 on: October 01, 2015, 05:17:04 am »
Bookmark.
Thanks for your effort TiN.
Offline crispy_tofu
« Reply #4 on: October 01, 2015, 06:04:01 am »
This is going to be helpful, also subbed  ;) :popcorn:
Offline ez24
  • L.D.A.
« Reply #5 on: October 01, 2015, 06:48:49 am »
Crispy - are you going to offer Dave some stinky tofu when he delivers the meter?  I miss it.
To OP - do you mean components or completed circuit boards that people sell?  No mention of price range if this matters.
Offline TSL
« Reply #6 on: October 01, 2015, 07:15:50 am »
These little standards are handy...
http://www.voltagestandard.com/
I have one of their DMM check units that I'm very happy with.
VK2XAX :: QF56if :: BMARC :: WIA :: AMSATVK
The following users thanked this post: Synthtech
Offline ez24
  • L.D.A.
« Reply #7 on: October 01, 2015, 07:54:32 am »
me too
Offline eas
    • Tech Obsessed
« Reply #8 on: October 01, 2015, 08:03:58 am »
I have collected too many of these.
I have the plexi cased AD584KH reference from the same maker as the bare board you reviewed, TiN. I also have yet another bare PCB AD584LH reference, an AD588BQ board, an uncalibrated/untrimmed Geller, and a DMMCheck+
What I don't have is a traceably calibrated meter or a calibrated reference beyond the DMMCheck+ which only gives 5 digits.
« Last Edit: October 01, 2015, 03:46:59 pm by eas »
Offline BravoV
  • +++ ATH1
« Reply #9 on: October 01, 2015, 08:38:35 am »
Complementing this thread, there is an excel file converted into PDF by Dave that contains all known voltage reference chips (heated and unheated) that is compiled by JBeale -> Voltage Reference Chips (2013)
« Last Edit: October 01, 2015, 09:08:29 am by BravoV »
Offline crispy_tofu
« Reply #10 on: October 02, 2015, 07:01:00 am »
Lol, I wish... the meter was delivered (thanks Dave!) but I was away at the time and my parents said no anyway  :-// :palm:
Offline HighVoltage
« Reply #11 on: October 02, 2015, 07:34:42 am »
Great idea.
I have a few to contribute.
Offline ez24
  • L.D.A.
« Reply #12 on: October 02, 2015, 07:40:18 am »
Great idea.
?  A few of what?
- tofu
- meters
- chips (IC or potato ?)
- something else
Right now I would like some stinky tofu
Offline tszaboo
« Reply #13 on: October 02, 2015, 10:25:03 am »
And then, there is this.
Offline ralphd
    • Nerd Ralph
« Reply #14 on: October 02, 2015, 12:14:46 pm »
Thanks, subbed.  :-+
Or the 6126 with 20ppm/1000hr?
After some searching around on Aliexpress I found I can get them for $3.  So less than double the cost of a REF5050.  No tout like the ref5050 though, but I'm still thinking of ordering a couple.
Unthinking respect for authority is the greatest enemy of truth. Einstein
Offline nctnico
« Reply #15 on: October 02, 2015, 12:50:01 pm »
You can also buy PLC calibrators on Ebay. These have an adjustable voltage and current. The more expensive ones claim an accuracy of 0.01% (100ppm).
Offline Andreas
« Reply #16 on: October 02, 2015, 07:38:52 pm »
Thanks, subbed.  :-+
Hello,
according to my own measurements the (typical) datasheet values have nothing to do with the real world.
The ageing numbers are only valid (if at all) for the first 1000 hours after production or first soldering.
(some datasheets specify the second 1000 hours to keep the number comparable to the usual 20-30 ppm/kHr).
A really good (buried zener) reference will settle after around 6-12 month to a ageing rate below 10ppm/year.
e.g. around 2 ppm/year at room temperature.
The MAX6350 has a low T.C. but my 2 samples have a constant ageing rate of 10ppm/year. (over 3 years).
Whereas other buried zeners (AD586LQ) go down to the 2 ppm/year after initial drift.
https://www.eevblog.com/forum/projects/newbie-precision-reference-calibrated-with-the-3478a-dinosaur/msg538036/#msg538036
The MAX6126 (and REF5050) is a bandgap reference. So even when specced with 20ppm/kHr it will be
outperformed by a buried zener reference.
The housing of the reference plays a large role in stability.
Metal can or ceramic hermetically packages give much more stability than a DIP8 housing.
A dip 8 housing gives up to factor 3 more stability against a SO-8. (found in a MAXIM datasheet).
The long term stability of the MSOP package is specced factor 5 worse than SO-8 for the MAX6126.
So size matters.
So my personal ranking for references is
hermetically sealed:
1. LTZ1000/LTZ1000A
2. LM399
3. AD587UQ/AD586LQ
(3.5 LT1027CCH/BCH: unobtanium)
4. LT1236AILS8
plastic:
5. AD586MNZ
6. LT1027CCN8 (low ageing but large humidity drift)
7. MAX6350CPA/MAX6250ACPA (low humidity but large ageing drift)
And after that all the other references.
with best regards
Andreas
« Last Edit: October 02, 2015, 07:40:37 pm by Andreas »
Offline Alex Nikitin
  • Femtoampnut and Tapehead.
    • A.N.T. Audio
« Reply #17 on: October 02, 2015, 08:39:11 pm »
Hi Andreas,
Do you have any experience/opinion on the ADR01/02BRZ and ADR3450ARJZ?
Cheers
Alex
Offline pelule
  • What is business? It’s other people’s money
« Reply #18 on: October 02, 2015, 09:17:35 pm »
Hi Andreas,
Do you have any experience/opinion on the AD588BQ/AD588AQ?
http://www.analog.com/media/en/technical-documentation/data-sheets/AD588.pdf
BR
PeLuLe
You will learn something new every single day
Offline PA4TIM
« Reply #19 on: October 02, 2015, 10:05:17 pm »
I build standards using a LM399, one with a LT1027B and 3 versions with 4x431 parallel. Those performed well. Also used a LT1021 -10. I builded those standards only because I wanted to build some to learn more about Vrefs. I have no real need for it because I have more standards like a Guildline standard cell cabinet with full history, a Fluke 731, 750, 760, 720, 332, 510, an ESI decavider and a Philips PM2480 standard. Besides those some Tektronix scope calibration stuff, time standards and passive standards (LCR)
I miss a temperature standard (but I repaired several from my customers so I can check my gear against those  )
How do you know the Vrefs are still correct. My LM399 drifted over 100 uV the first six months, powered 24/7 connected permanent to a 7,5 digit meter the first months.  Short time drift was influenced most by relative humidity in my lab.
Offline Andreas
« Reply #20 on: October 02, 2015, 10:11:24 pm »
Hello,
the only test in this range (XFET) was (only 1 new sample) ADR4550 (violett = ADC18)
against two (aged) LT1027 in plastic DIP (ADC4 + ADC8)
and one (aged) AD586LQ (ADC13) in CERDIP
All measuring a LTZ1000A with a precision 2:1 divider (LTC1043).
I think it gets clear why I did not try a 2nd sample.
nearly 100 ppm drift over 300 days and not calming down to a sub 10ppm level.
no experience.
Opinion: should behave similar to AD586LQ/AD587UQ
With best regards
Andreas
Offline eas
    • Tech Obsessed
« Reply #21 on: October 03, 2015, 04:15:53 am »
no experience.
Andreas
I have a cheap Chinese board with an AD588BQ as well as some cheap bare chips that are either NOS, or pulls from sockets in old equipment. I have a week or two of data on the board, but haven't done anything with it. Not super useful either, given that I didn't have a temperature record for the period.  I have an AD +-15V PSU module that I plan to use to do a long term test the bare ICs.
One intriguing thing about the AD588 is that it has a couple of uncommitted low-dift, low-offset buffer amplifiers that can be used for kelvin sense of the output, making a precision current source (10mA, max), or...
Offline pelule
« Reply #22 on: October 03, 2015, 08:47:59 am »
I assume it is one of these offers from China, I have looked to also:
http://www.ebay.de/itm/252001708799?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
http://www.ebay.de/itm/251943908859?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I have daubt, this are really BQ version, as just the chip cost > 22 USD in higher volumes. Just assume this are "refreshed" JQ or AQ types.
Offline pelule
« Reply #23 on: October 03, 2015, 09:03:25 am »
EDIT: forgot to tell, it is offered for US $14,92 including shipment.
I despite my daubts I have ordered, I have the original BQ and this offer is cheaper, than routing/ordering your own PCB. I don't care regarding the mounted chips. If this are real BQs great.
I plan to mount that board into a temp. controlled chamber 35°C (+/- 0.01°K) and to do long term drift measures. Plan to post that results than.
Offline Gyro
« Reply #24 on: October 03, 2015, 09:45:48 am »
I have an AD588BQ that I've only played with fairly briefly so far. Having the on-chip opamps for Kelvin sensing etc is very useful. The only downside is that it all adds to the device dissipation (needing +/- 15V supply) and is compounded by any loading. The increased temperature rise exaggerates it's TC, although of course the temperature will stabilize at some point if the load is constant.
Blessed are those lucky enough to have bought one of Joe Geller's AD587LQ based SVR-T while he was still producing them.
EDIT: Just had an idea - I wonder if one of the opamps could used to implement a simple on-die oven  :-\
« Last Edit: October 03, 2015, 09:49:01 am by Gyro »
Best Regards, Chris
