Afternoon folks,
Yet another question regarding RC receivers, albeit loosely :-)
I've discovered that the RC receiver I'm using outputs a bipolar PWM signal depending on user input. If the joystick is moved "forwards", we get a positive voltage, and if it's moved "backwards" we get a negative voltage.
Since Arduinos and MCUs generally can't detect negative voltages, I thought of using a pair of optocouplers to detect the two signals - one for detecting the positive voltage, the other to detect the negative voltage. Does this sound like a reasonable solution?
Cheers
Daniel
