EEVblog® Electronics Community Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
Flyback LED Driver Signal
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Flyback LED Driver Signal (Read 3781 times)
jman
Contributor
on:
December 10, 2014, 12:41:16 pm »
Hi Guys,
anyone can pin point whats wrong with this Signal
Thanks in advance
Logged
jman
Contributor
Re: Flyback LED Driver Signal
Reply #1 on:
December 10, 2014, 07:28:49 pm »
Thanks for the reply
yes its a DCM controller but i really want to get rid of the ringing its very high.
I have a RCD snubber across the primary
C=4.7nF
R = 33K
it seems that the ringing its not fully dumped.
Any suggestion for the transformer?
Im using EFD30 ferrite
Logged
rbola35618
Frequent Contributor
Country:
Reply #2 on:
December 11, 2014, 03:33:48 am »
Actually there are two ringing frequencies in the waveform. The leading edge has the higher frequency which is the resonant of the Leakage and the Cmosfet. The lower frequency happens when the transformer reset and its frequency is determined by Lprimary and the Cmosfet. You would need to separate snubbers to damp the ringing. The resistor values should be around Zdamp=Squareroot(Linductor/Cmosfet).
Here is a video that I made a while ago where I damp the higher frequency (12:20)
Hope this helps.
Robert
Logged
jman
Contributor
Reply #3 on:
December 11, 2014, 09:08:08 am »
thank you for your replies help allot..
Logged
jman
Contributor
Reply #4 on:
December 14, 2014, 04:05:47 am »
hey guys here is the new waveform after adding RC snubber and keeping the RCD
Logged
rbola35618
Country:
Reply #5 on:
December 15, 2014, 02:45:04 pm »
Hi Jman,
The plots show that the waveform is properly damped. This looks good.
Robert
Logged
T3sl4co1l
Super Contributor
Country:
Expert, Analog Electronics, PCB Layout, EMC
Reply #6 on:
December 15, 2014, 03:13:58 pm »
That looks well damped, but I would be concerned if the damping components are getting quite hot.
Seems like the transformer could use higher inductance (or the controller to a higher frequency), and lower leakage (to reduce the spike).
Logged
Seven Transistor Labs, LLC
Bringing a project to life? Send me a message!
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog® Main Site
EEVblog® on Youtube
EEVblog® on Twitter
EEVblog® on Facebook
EEVblog® on Odysee
