Author Topic: Flyback LED Driver Signal  (Read 3789 times)
Offline jmanTopic starter
« on: December 10, 2014, 12:41:16 pm »
Hi Guys,
anyone can pin point whats wrong with this Signal
Thanks in advance
Re: Flyback LED Driver Signal
« Reply #1 on: December 10, 2014, 07:28:49 pm »
Thanks for the reply
yes its a DCM controller but i really want to get rid of the ringing its very high.
I have a RCD snubber across the primary
C=4.7nF
R = 33K
it seems that the ringing its not fully dumped.
Any suggestion for the transformer?
Im using EFD30 ferrite
Offline rbola35618
« Reply #2 on: December 11, 2014, 03:33:48 am »
Actually there are two ringing frequencies in the waveform. The leading edge has the higher frequency which is the resonant of the Leakage and the Cmosfet. The lower frequency happens when the transformer reset and its frequency is determined by Lprimary and the Cmosfet. You would need to separate snubbers to damp the ringing. The resistor values should be around Zdamp=Squareroot(Linductor/Cmosfet).
Here is a video that I made a while ago where I damp the higher frequency (12:20)
Hope this helps.
Robert
« Reply #3 on: December 11, 2014, 09:08:08 am »
thank you for your replies help allot..
« Reply #4 on: December 14, 2014, 04:05:47 am »
hey guys here is the new waveform after adding RC snubber and keeping the RCD
Offline rbola35618
« Reply #5 on: December 15, 2014, 02:45:04 pm »
Hi Jman,
The plots show that the waveform is properly damped. This looks good.
Robert
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #6 on: December 15, 2014, 03:13:58 pm »
That looks well damped, but I would be concerned if the damping components are getting quite hot.
Seems like the transformer could use higher inductance (or the controller to a higher frequency), and lower leakage (to reduce the spike).
Seven Transistor Labs, LLC
