Ok. How about increasing the number of transistors to make the improved mirrors? I remember a text book had many.
What situations is it dangerous for the 6181C though? Because I don't want to fry it. Though, for the start I can use some 9V powered 317 regulator current source, I don't care if it breaks, just needs a good setup to ensure HV safety (neat), for first developments
I can set the voltage on the keithley to 1V accuracy BTW, so that is kind of 'ranging' I think. So I can set the supply of the mirror to any voltage.
I thought to put a MOV across the current source too, so if the HV gets into the left side, it should be limited to the MOV voltage and prevent it from getting dangerously energized by the HV supply? And a neon light to show HV fault (it won't glow unless its zapped)
I think I will try it. All the resistors and switches etc... I need to see how accurate it is in the most basic form, I had enough wires for the rest of this year... I was hoping all the hardware inside of those test equipment might let me get away with making this part simpler. I will make a plastic rod to adjust the LM317 with in the test prototype for safety reasons
