Author Topic: high voltage current source (mirror)  (Read 7546 times)
Offline coppercone2Topic starter
  • √Y√... 📎
« on: November 03, 2024, 10:18:19 pm »
I am still looking for a high voltage circuit that can be used with the 1200V keithley power supply (voltage source) to regulate constant current.
Maybe its the wrong way to go about it, but is some kind of current mirror possible?
i.e. circuit 1 : 1-10mA current source (HP lab equipment)
circuit 2 : power by 1200V keithley power supply, mimics the current of circuit #1
The full output of the keithley is 10mA @ 1200V roughly.
It would be for biasing resistors for testing
I thought maybe this kind of cirucit would just connect to the 2 test equipment and not need any power source etc?
« Last Edit: November 03, 2024, 10:36:17 pm by coppercone2 »
Offline TimFox
Re: high voltage current source
« Reply #1 on: November 03, 2024, 10:23:39 pm »
Have you considered using a vacuum tube circuit?
  • √Y√... 📎
« Reply #2 on: November 03, 2024, 10:24:57 pm »
no because it has supplies
I thought with a advanced piece of equipment like the HP current source that is precise, it might be possible to make something that just has 4 banana connectors, 2 into the keithley and 2 into the HP without any power or etc
simple. Stack them, plug it in, measure.
Can't a current mirror do this? It would not even need a bias resistor for the set side since its connected to a real current source .
like this guy here
https://www.digikey.com/en/products/detail/rochester-electronics-llc/2SC4636LS/12110428
5mA would be plenty.
« Last Edit: November 03, 2024, 10:32:31 pm by coppercone2 »
Online PCB.Wiz
« Reply #3 on: November 03, 2024, 10:39:01 pm »
.... it might be possible to make something that just has 4 banana connectors, 2 into the keithley and 2 into the HP without any power or etc
So you mean a high voltage battery inside the box ?  :-//
There are 4 terminal parts (no hidden batteries)  that take current in and deliver current out, called Photovoltaic isolators.
Of course they cannot give free energy, so the output power is a fraction of the input power.
eg TLP3906 has 10mA and 1.65V in and 9V OC and 30uA SC out
that's  16.5mW in and 216uW out.  Power transfer ratio = 1.3%
  • √Y√... 📎
Re: high voltage current source (mirror)
« Reply #4 on: November 03, 2024, 10:40:50 pm »
the current mirror always shows two things, left and right side.
left side = lab current source
right side = keithly + load
it looks like I don't need another thing for it on the most basic level. I am sure a HV capable current mirror has some problem but I thought maybe.
  • √Y√... 📎
« Reply #5 on: November 03, 2024, 10:43:09 pm »
Like this. I bet something bad would happen to the lower voltage supply though without more parts
« Last Edit: November 03, 2024, 10:45:18 pm by coppercone2 »
Offline inse
« Reply #6 on: November 03, 2024, 10:44:09 pm »
Maybe you can find some inspiration in my thread:
https://www.eevblog.com/forum/projects/high-voltage-constant-(low)-current-load/
If precisely adjustable current is required, add an OPAMP to drive the kaskode circuit
  • √Y√... 📎
« Reply #7 on: November 03, 2024, 10:46:42 pm »
I really don't want any components that require ANOTHER power supply.
I thought maybe this thing can get 5% accuracy from using only the keithley and HP
I will look at the thread but I don't want op-amps
If this can work its very elegant. A few transistors in a box that connects to two lab equipment to bias a resistor.
If it needs batteries and op amp power supplies and blah blah its not worth doing.
I thought discussing a current mirror would be worth while, no one really makes them for anything I know of, they are taught but its not popular to make for some reason.
Both the keithley and HP are full of high quality parts and are both very stable. They have range switching, potentiometers, low drift, etc. If I can only find some simple way to link them, I think it would be very nice.
« Last Edit: November 03, 2024, 10:58:01 pm by coppercone2 »
Online PCB.Wiz
« Reply #8 on: November 03, 2024, 10:57:49 pm »
If you want a grounded load, you are looking for a current mirror and a lever shifter.
Standard current mirrors do what the name says, they take a current fed to a common rail and reflect that using the same rail.
That means a high side load.
If you want no external low side power, then the circuit needs to power off the low side current source (see 4-20mA current loop designs for ideas)
  • √Y√... 📎
« Reply #9 on: November 03, 2024, 10:58:34 pm »
Well its for measuring the voltage drop of a passive component I don't care if its high or low side if thats what you mean? I.e. it has to be transistor supply side for simpler implementation? That is more then OK
I am not sure what you mean by the 4-20mA loop. I was just thinking about this from the perspective of a simple textbook current mirror (there is many types with varying amount of transistors). I don't know which would be appropriate to analyze for this idea.
« Last Edit: November 03, 2024, 11:01:22 pm by coppercone2 »
  • √Y√... 📎
« Reply #10 on: November 03, 2024, 11:05:05 pm »
I redrew it to what I think you mean
Offline tggzzz
« Reply #11 on: November 03, 2024, 11:05:19 pm »
Several examples are notes here: https://www.eevblog.com/forum/projects/high-voltage-constant-(low)-current-load/msg5299519/#msg5299519 and the reference goes into much more detail
Offline inse
« Reply #12 on: November 03, 2024, 11:05:41 pm »
Finding and sourcing a transistor capable of regulating 1.2kV at 10mA (12W max power dissipation in case of short circuit) might also be challenging.
That’s why I mentioned my thread
Offline tggzzz
« Reply #13 on: November 03, 2024, 11:07:32 pm »
It is relatively easy to distribute the voltage and power across multiple HV MOSFETS; see https://www.eevblog.com/forum/projects/high-voltage-constant-(low)-current-load/msg5299519/#msg5299519
Online PCB.Wiz
« Reply #14 on: November 03, 2024, 11:07:39 pm »
Sure, you can just connect two of those 2SC4636LS parts as a classic current mirror.  The load goes between the collector and 1700V.
Emitter resistors can reduce matching errors and give you some gain choices.
5% will be a serious challenge, look at the Ib/Ic curves on that part, and you see for a given Ib, Ic varies significantly with voltage.
  • √Y√... 📎
« Reply #15 on: November 03, 2024, 11:10:35 pm »
Ok. How about increasing the number of transistors to make the improved mirrors? I remember a text book had many.
What situations is it dangerous for the 6181C though? Because I don't want to fry it. Though, for the start I can use some 9V powered 317 regulator current source, I don't care if it breaks, just needs a good setup to ensure HV safety (neat), for first developments
I can set the voltage on the keithley to 1V accuracy BTW, so that is kind of 'ranging' I think. So I can set the supply of the mirror to any voltage.
I thought to put a MOV across the current source too, so if the HV gets into the left side, it should be limited to the MOV voltage and prevent it from getting dangerously energized by the HV supply? And a neon light to show HV fault (it won't glow unless its zapped)
I think I will try it. All the resistors and switches etc... I need to see how accurate it is in the most basic form, I had enough wires for the rest of this year... I was hoping all the hardware inside of those test equipment might let me get away with making this part simpler. I will make a plastic rod to adjust the LM317 with in the test prototype for safety reasons
« Last Edit: November 03, 2024, 11:26:53 pm by coppercone2 »
Online PCB.Wiz
« Reply #16 on: November 03, 2024, 11:38:13 pm »
Here is a starting point, to give you some ballparks.
You can get a rough fix-up for the slope of Ic/Vce, using a resistor, that varies by part, so you need to experiment.
Here I chose 3 high voltage parts on LTSpice.
The worst NPN part corrects to to 2.4% 10-200V, with R7 = 1Meg. With No R7 varies appx 5.3%
Finer trim of R7 = 1.17M balances the 'parabola' and corrects to ~1.72%
« Last Edit: November 04, 2024, 02:38:56 am by PCB.Wiz »
  • √Y√... 📎
« Reply #17 on: November 03, 2024, 11:40:20 pm »
Ok I bought 6x 2SC4636 for fun. I never did anything with a HV transistor before
The purpose of this was to find dodgy resistors that don't like HV
My old thread was about trying to do this with just the keithley, but someone hypothesised it would only get to maybe 30% accuracy on the constant current source. Maybe by adding the mirror, it could get alot nicer. This idea started when I realized you can test a power diode with just a beefy current limited power supply with pretty high confidence.
« Last Edit: November 03, 2024, 11:53:16 pm by coppercone2 »
Online PCB.Wiz
« Reply #18 on: November 03, 2024, 11:57:36 pm »
Any slip to 1700V will be risky.
Because the source is current, you can add series R's and Zener clamps - 1k of total series will drop 10V at 10mA, and can source 1.7A on a oops.
So the zeners/TVS/TSS need to be good enough to sink 1.7A ballpark.
Offline tggzzz
« Reply #19 on: November 04, 2024, 12:02:59 am »
13 pages of high quality circuits in the refs in
https://www.eevblog.com/forum/projects/high-voltage-constant-(low)-current-load/msg5299519/#msg5299519 plus other pages in TAoE.
Or you could reinvent an elliptical wheel.
  • √Y√... 📎
« Reply #20 on: November 04, 2024, 12:07:20 am »
Ok I am just gonna try the basic one first that circuit in the picture looks very complicated , perhaps I will figure out why it was made when I see the deficiencies of the first one
Offline tggzzz
« Reply #21 on: November 04, 2024, 12:30:44 am »
The strengths and weaknesses of each circuit are clearly explained.
Just get TAoE and TAoE x-chapters. You won't regret it.
Online SiliconWizard
« Reply #22 on: November 04, 2024, 12:42:24 am »
Cascade several FETs. Yes I think it's been talked about before.
Then call Electroboom before you turn it on.
  • √Y√... 📎
« Reply #23 on: November 04, 2024, 12:46:26 am »
ok I will try it with 2 bjt before we make it into the manhattan project with mosfet cascodes
I have TO220 sockets to make this easy
« Last Edit: November 04, 2024, 12:48:25 am by coppercone2 »
Online PCB.Wiz
« Reply #24 on: November 04, 2024, 02:42:52 am »
I've updated #16 with a couple of 3-element current mirrors, that allow either MOSFET or BJT main active part and use (matched) small signal NPN as compare elements.
This improves thermal tolerance as the power device is no longer a reference element, and the output impedance effects are corrected by the feedback.
More voltage is needed across the current source.
