Greetings,
I'm looking for a line driver that will drive about 1 metre of coaxial cable with TTL level signals at frequencies up to 10MHz. This means that it must be capable of significant current sourcing. I've tried the usual system of parallel 7404 units. Unfortunately, low jitter and non inversion is required.......
The unit I was looking at was the 7417 type; however it's only available in TSSOP and is open collector.
Thanks all,
Keith
