Author Topic: Line drivers  (Read 935 times)
David Hess and 1 Guest are viewing this topic.
Offline keithjeffTopic starter
Line drivers
« on: October 13, 2026, 07:40:42 am »
Greetings,
I'm looking for a line driver that will drive about 1 metre of coaxial cable with TTL level signals at frequencies up to 10MHz. This means that it must be capable of significant current sourcing. I've tried the usual system of parallel 7404 units. Unfortunately, low jitter and non inversion is required.......
The unit I was looking at was the 7417 type; however it's only available in TSSOP and is open collector.
Thanks all,
Keith
Offline Manul
  • Country: lt
Re: Line drivers
« Reply #1 on: October 13, 2026, 07:59:48 am »
How low jitter? If you want low jitter you also need well regulated supply voltage and good bypassing. As you said, currents will be high.
Re: Line drivers
« Reply #2 on: October 13, 2026, 08:17:06 am »
I can live with up to about 10nS jitter. Good bypassing, yep, although the bypass caps will supply some of the current required to feed the line. Well regulated, yes. In this circuit there are two PSUs. One to drive a Xtal oven at 10MHz, the other to power a PicDIV to give a 1Hz output with varying duty cycle and the line drivers. Lots of electrolytics and SMT caps about the place. The 10Mhz doesn't need to be hugely accurate. A GSPDO would be overkill.
You'd think this would be simple. Ah well c'est la vie.
Keith
Offline moffy
Re: Line drivers
« Reply #3 on: October 13, 2026, 08:56:04 am »
I built this for signaling over CAT5 it might be of interest: https://www.eevblog.com/forum/projects/cat5-fast-cheap-digital/msg6305732/#msg6305732
Online voltsandjolts
Re: Line drivers
« Reply #4 on: October 13, 2026, 09:22:04 am »
For ideas, try searching for 10MHz distribution amplifiers, e.g.
http://www.wriley.com/An%20Octal%2010%20MHz%20Distribution%20Amplifier.pdf
Re: Line drivers
« Reply #5 on: October 13, 2026, 10:13:12 am »
It is of interest. Thank you very much....
Keith
Offline MarkF
Re: Line drivers
« Reply #6 on: October 13, 2026, 10:39:45 am »
Instead of chips with a standard TTL output drive, look at chips with higher bus driving capabilities.
I've used 74244 and 74245 line drivers with higher (typical 20mA) source and sink outputs in
the standard or H series.
The basic logic chip only can source 0.8mA and sink 16mA.
You also might look at the SN74LVC1G17 buffer chip which has 32mA outputs.
Offline mtwieg
Re: Line drivers
« Reply #7 on: October 13, 2026, 01:16:04 pm »
What is the load impedance on the receiver side? Is there a broadband 50ohm load termination, or just the input capacitance of the receiver devices?
What sort of rise/fall times do you need at the receiver?
Depending on the answers, you might not need any fancy driver, just a basic logic gate with series termination.
Offline PCB.Wiz
Re: Line drivers
« Reply #8 on: October 13, 2026, 08:14:56 pm »
Greetings,
10ns of jitter is a lot, so not a problem.
What did you try exactly? Did you use 74LVC04?
10MHz and 1m is also not difficult, especially if you only take off the far end. (so the near end step is unimportant)
Then you just need appx source matching, so something like a 74LVC14 with 1 gate as inverter driving 5 parallel gates driving a resistance of ~ (Zo-5) ohms
would be a reasonable starting point.
examples : https://www.ecircuitcenter.com/Circuits/tline1/tline1.htm
Good decoupling would be needed as you have short ~50mA pulses (~10ns) into the cable.
« Last Edit: October 13, 2026, 08:20:04 pm by PCB.Wiz »
Offline Andree Henkel
Re: Line drivers
« Reply #9 on: Yesterday at 12:39:29 pm »
you need 50mA drive current: 5V source, source termination 50Ohm, receiver termination 50Ohm; 100Ohms in total, 50mA current
gives in theorie 2.5V High level at termination; TTL level means you need 2V High level at Termination; so there is margin for some cable losses, tolerances of source/load resistors, 5V supply tolerances and fact that driver output is less than supply
a triple lvc buffer at 5V: SN74LVC3G17; 130Ohm at each output, connected together after the 3 resistors will work just fine
this buffer is push pull, not open collector
some more drive power you get with an 74ABT245 at 5V, four, or even all eight channels and suitable current share resistors
« Last Edit: Yesterday at 12:49:57 pm by Andree Henkel »
Offline jonpaul
  • Analog, magnetics, Pwr high voltage, Audio, Cinema
    • IEEE Spectrum
Re: Line drivers
« Reply #10 on: Yesterday at 03:55:53 pm »
check RS-485 line drivers.
exactly whats needed
j
The Internet Dinosaur..
passionate about analog electronics since 1950s
