The latest addition to my X-Ray equipment inventory is a new or 'as new' Trophy (now Kodak Carestream) high resolution Digipan X-Ray camera array.
The Digipan camera array is a cartridge that is used in place of the film cassette in panoramic Dental X-Ray machines. Thankfully the version I bought is flat and not the curved version. The array has an active surface of approximately 120mm x 240mm which is twice the width of my MX-20 array
From what I can discover, the Digipan contains two 120mm x 120mm X-Ray imaging arrays, most probably Hamamatsu panels, but I have yet to discover what resides inside the cassette so this is all supposition.
There is the problem of driving the camera array but if the modules are, as I expect, COTS products, I may be able to find enough data to drive them with a PC. Some of what I have discovered about the unit suggests that it is USB communications to the Host PC, but again, I need to confirm this myself.
These cost around £10K so it was a decent buy for me for just £100
Once I have the unit in my hands, the investigation will begin. I have a working Gendex dental X-Ray generator to illuminate the Digipan if the MX-20 beam is too confined.
Fraser
