We had a similar discussion here: https://www.eevblog.com/forum/dodgy-technology/is-the-market-flooded-with-fake-dangerous-solar-cable/
You seem to also be buying from random ebay sellers, who are likely just drop-shippers or importers.
If you provide the requested very relevant information up front instead of holding back, its going to make it easier for others to help out:
- Links to the items you purchased
- Advertised diameter and measured diameter
I have to repeat myself...
It was never my intention to prove anything. I was trying to get the extend of this fraud from other countrys/people too. As your link prooves, its not just something i came across.
Its a really dissapaointing, that most people cant answer a simple question (see original post), and are instead still questioning the findings of others, that are likely not a case of a simple calculation error, as i tried to make clear.
So I bought a few meters of single-strand cable advertised as 0.75 sq.mm.
Actual measured diameter was between 0.97 mm and 0.98 mm which means 0.739..0.754 sq.mm.
Hope this helps!
Hope this helps!
I could imagine, that they wont try scamming people on this kind of wire, since it is easy to find out if its scam or not.
What value is it to just post "Yes I was defrauded by cable thickness" without going into any details? Its meaningless data.
Ten people might have bought 1m from one single ebay seller, or one person might have bought 1,000m from hundreds of authorized distributors. The context matters.
Posting the store you purchased from is a normal thing. The fact that you are so secretive with your data and suppliers makes everyone rightfully suspicious.
People can write where they got the cable from. I can not now, as i have not documented my findings. I could get me in trouble. But i might do this on one occasion if i have the mood for it.
This thread is also intented, to raise awareness about this fraud. This can even get dangerous, if cables are not crimped right, because of wrong crosssections.
Where were the cables made? Undersizing of wire and cables made in China has been widely reported on this and other sites. A lot of the wire is also reported to be made some kind of junk alloy that isn't solderable. I've learned to not trust the ratings of anything made in China.
Specifically, the most common one you'll encounter is CCA, copper-covered aluminium. Less common is CCS, copper-covered steel. Another variant is CCC, copper-covered-copper, where they coat a thin veneer of copper over a garbage alloy of recovered scrap that may contain copper. They'll look like they're the right size but won't have anywhere near the current-carrying capacity, as well as breaking if you bend them too much when installing them.
Neighbour of mine was happy about the bargain he got on some cabling, until I pointed out what it was that he'd just finished installing...
Get in trouble from who and how?
Go grab the cable, measure OD and wire ID and write the info and seller details here, should take 5 minutes.
We
always question the findings, whether ours or from others.
Healthy thing to do, especially when the data provided is incomplete.
Nope. You did not make that clear. If you want to make that clear, please provide a simple measurement report/data everybody can check...
No doubt many chinese wires are out of spec.
No doubt also you made some inacuracies in your measurements.
We always question the findings, whether ours or from others.
There were some inaccuracys, but i questioned and answered my findings until they proved to be right...
You also did not answer my original question...
New cable order:
From the vendor i had previously bought good cables:
- Measured length. -> 10m
- Has "LEONI P" written on it every 13 cm.
- At 4A and a bit of wiggle, the lowest value of Voltage drop i could achieve was 300mV.
- With my caliber, i measured 0.22mm to 0.23mm (on the most inner side) and up to 0.24mm , when pulling it out.
- After the voltage drop did not speak for a 2.5mm2 cable, i went to the microscope (see picture)
- I counted (2 times) 50 strands. And then again i did that again, and made damn sure, i did not cut/lose any strands.
- Using this
https://www.redcrab-software.com/de/Rechner/Elektro/Spannungsverlust it didnt add up.
- The specs on the site of the vendor says: "Leiteraufbau gemäß ISO 6722 (50 x 0,0531mm²)" (Which is 50x0.26mm)
2.5mm2 would be 50 x 0.252mm.
