Author Topic: Fume Extractor advice  (Read 12733 times)
Offline furnacemikeTopic starter
  • Chemist & Lab. Metrologist, Electronics Hobbyist
« on: July 02, 2022, 10:32:42 pm »
I'm currently looking at 2 fume extractors on Amazon and I'm torn. My basic use is soldering and desoldering. I do a lot of desoldering to salvage components, which can include vacuum gun, hot air, and hot plate. Hot plate desoldering of power boards can be especially bad, since it can produce an especially noxious acrid smoke (you probably know exactly what I mean). I live in an apartment and do not currently have a dedicated workspace, so I am looking for something desktop and portable. This also means venting to outside can be problematic. The specs on both units are similar:
BAOSHISHAN Fume Extractor Soldering 3 Stage Filters Desktop Smoke Absorber
https://www.amazon.com/gp/product/B08P1T4WV5/ref=ewc_pr_img_1?smid=A1WF5PLAB10LN6&psc=1
KOTTO Strong Suction Hose Fume Smoke Absorber for Soldering, Electric Iron Welding, 3d Printing Extractor Absorber Remover DIY Extractor Carbon or HEPA Filter
https://www.amazon.com/gp/product/B07ZHH5H7N/ref=ask_ql_qh_dp_hza
Both feature a combination HEPA/Carbon filter (though the KOTTO it is optional), and both use 40W fans. I've read the reviews and watched YouTube reviews on the KOTTO (non are to be found on the BAOSHISHAN), and the seem pretty favorable. The BAOSHISAN also features a "pre-filter". The BAOSHISAN is quite a bit more money than the KOTTO, though I am not deterred by that outright. Both feature flexible hoses with a snorkel head.
Overall, the BAOSHISAN seems to be a better quality build. The only hang up I have is the price of the filters. The filters for the BAOSHISAN are very expensive.
So my questions are:
Anyone have any experience with these units? Any thoughts?
Is the pre-filter really worth it?
Is it worth the extra expense in filters to go with the BAOSHISAN?
Thanks!
Mike, New Jersey, USA.
Offline --Oz--
Re: Fume Extractor advice
« Reply #1 on: August 21, 2022, 01:18:33 am »
IMO neither are worth it.
I use a 12v brushless fan (120mm or 5") scavenged from a dead pc power supply, then run it at 6 to 10v (from a $2 dcdc buck converter). Here is the kicker, the fume extractors that have a funnel feeding the tube (shroud that feeds the fan) is killing the sucking (working area) distance, its like they have no clue what they are doing, then charge $80 or more. With my simple and free fan I can easily get 8~12" distance of fume extraction and the fan is on low, this also is low noise. Need more distance, just turn it up a little. If you want you can add the charcoal filters to the front for a couple bucks. Also, after some hot air rework I set my board behind the fan to cool down quicker if I am in a hurry.
Offline thm_w
  • Non-expert
« Reply #2 on: August 22, 2022, 09:26:28 pm »
"Charcoal filters" for a couple of dollars are going to be worse than the ones the OP linked, and close to useless.
Get proper branded HEPA filters (Levoit, Honeywell, etc.), which will be <$30 if you keep an eye out on amazon.
Online jpanhalt
« Reply #3 on: August 22, 2022, 09:39:59 pm »
Let me check what I have.  I am a retired chemist and over the years saved a lot lot of stuff from the dumpster.  Since you are in the USA, I may have something of interest, but it is 42 miles away at my second home.  Nothing has any ducting.  They are just fans in boxes.  If interested, let me know.  Cost is actual shipping cost.
Offline Keri Szafir
  • Vacuum Tube Witch
    • youtube
« Reply #4 on: August 23, 2022, 03:58:03 pm »
I just use a centrifugal fan, no filters whatsoever. It's there for drawing fumes away from my face and mixing them with the surrounding air, reducing the concentration to safe levels.
...its loveliness increases, it will never pass into nothingness
Keritech Electronics - building vacuum tube amps and restoring vintage gear since 2004!
Offline Gyro
« Reply #5 on: August 23, 2022, 04:45:17 pm »
If you're simply looking to disperse the fumes away from your face, a small quiet axial fan blowing sideways across your work area is very effective. You can get away with a lot less fan noise.
« Last Edit: August 23, 2022, 06:00:02 pm by Gyro »
Best Regards, Chris
The following users thanked this post: mairo
Online NiHaoMike
    • Facebook Page
« Reply #6 on: August 23, 2022, 10:47:15 pm »
Have you considered venting out the window or into the bathroom with the exhaust fan running?
Offline tinfever
  • I like to make life harder for myself
« Reply #7 on: August 26, 2022, 10:06:54 pm »
Clearly you need a three stage overhead air filtration system.
MERV 11 prefilter > 12" Activated Carbon Filter > 24" x 24" 12" HEPA filter
Don't ask how long it took me to build or how much it cost. I don't want to think about it.
Offline thm_w
  • Non-expert
« Reply #8 on: August 26, 2022, 10:31:40 pm »
lol
overkill taken to a new level.
Next project for you is to convert the whole room into a laminar flow hood.
Offline tinfever
« Reply #9 on: August 26, 2022, 10:40:17 pm »
There ain't no kill like overkill!  >:D
Next project might actually be to add an ERV (energy recovery ventilator) to get some outside air circulation without too much energy loss. No amount of air filtration will take care of high CO2 levels and I've decided to draw the line at an algae CO2 scrubber system.
The following users thanked this post: thm_w, Ian.M, tooki
Offline lfldp
« Reply #10 on: January 15, 2023, 11:02:11 pm »
hi
everything is ok with this filter except gas stage filter you will never adsorb most harmfull soldering flux fumes by standalone activated carbon filter for this need to mix activated alumina impregnated by kmn04 with activated carbon then you get reall chemicall filter comparable to high-end soldering fume extractors , it is enough to mix 5kg of activated alumina with 1,2kg can filters activated carbon (lite version) to get excellent result for small air-flow 200m3/h - 300m3/h , activated alumina with kmn04 isnt cheap but at last whole cost for 5kg activated alumina + 1,2kg can-lite carbon + M5 prefilter + F8 prefilter + hepa h13 filter will cost you just half price of bofa or weller replacement filters and you propably get more better result with it , ive designed many soldering fume extractors in past and i getting stucked with gas stage filters still having a hope i create very big carbon filter (over 15kg of coconut activated carbon loadded to 4 cartridges and... ive never gets even 1/2 of gas adsorbtion result of formaldehyde and rest of flux stuff , activated carbon filter alone is complete waiste of money , activated alumina with kmn04 is also used in 3d printer fume extractors
The following users thanked this post: tinfever
Online tatel
« Reply #11 on: January 16, 2023, 04:41:30 am »
Could you give any links to purchase that activated alumina with kmn04 thing?
I could use it while printing ABS
Offline JDubU
« Reply #12 on: January 16, 2023, 05:59:53 am »
I've been using the KOTTO one for several years and, for soldering, it actually works surprisingly well.
Offline james_s
« Reply #13 on: January 16, 2023, 06:55:26 am »
I have the Kotto, I bought it a few years ago. It's a bit noisy on the higher speeds but aside from that it works very well. You do have to screw the hose in pretty hard to get it all to stay together though. Keeps the smoke out of your face and really makes a big difference in the smell, it has an activated charcoal filter in it. I'd buy it again.
Offline lfldp
« Reply #14 on: January 16, 2023, 08:37:04 am »
well you have few options there , can buy directly from camfil activated alumina with kmn04 - 8% 20kg bag (this is best and cheaper option by buying directly from manufacture company) , other option you may try activated alumina made from china but it usually have less effectivity than camfil or purafil just 4 - 6% of kmn04 but from my experiments 5kg load of 6% is enough for small ariflow another thing you may to consider - when alumina is mixed with pelletised carbon you would propably inhale chemicall smell outgoing from filter itself (this is usually happend in air cleaners like IQAIR HEALTHPRO) - some people notice dirty chemicall odour outgoing from filters itself , solution for this is to mix activated alumina with high quality granulated carbon (not pelletised) like for example can-lite activated carbon 50% to 50% of alumina will give you result 5kg of alumina with 1,2kg of can carbon
« Last Edit: January 16, 2023, 09:01:52 am by lfldp »
Offline lfldp
« Reply #15 on: January 16, 2023, 08:41:30 am »
ABS and soldering flux fumes - have very small gas size counted in molecular weight while odours have large , activated carbon is mainly effective against large gas particles thats why for smallest you need activated alumina + kmn04 impregnation which doubling its efficiency , for example you will maybe achieve same filtering result 5kg of activated alumina kmn04 8% < > over 50kg of activated carbon itself thats why small ammount of activated alumina is added to high end soldering/printing fume extractors
Online tatel
« Reply #16 on: January 16, 2023, 09:43:07 am »
That would be the link?
https://www.camfil.com/pl-pl/produkty/filtracja-molekularna/media-adsorpcyjne/activated-alumina
It doesn't seem like they are selling bags of raw material
Probably I'll be getting filters for respiratory equipement...
Offline lfldp
« Reply #17 on: January 16, 2023, 09:59:18 am »
they selling can sell 20kg bag of activated alumina kmn04 8% it called campure 8 ;) ill include part of my invoice there
Offline lfldp
« Reply #18 on: January 16, 2023, 10:01:10 am »
campure 8 will cost you around of 10 euro per 1kg so is cheaper than chinese alumina available in small quantities and more effective becoz it has 8% of kmn04 impregnation but however you must pay at last for 20kg bag ;)
Offline lfldp
« Reply #19 on: January 16, 2023, 10:12:17 am »
also depending all for your needs , for 3d printer fumes is enough to mix alumina 4% with activated carbon , but for soldering fumes better is to use 8% there is also 12% alumina but it is very expensiff and used only in this shit commerciall soldering fume extractors (12% is used there where you want to have very small filter and achieve similiar efficiency to larger filter) so for example you will need 2,5kg of activated alumina 12% to get similiar result to 5kg of 8% alumina ;)
Online tatel
« Reply #20 on: January 16, 2023, 10:37:37 am »
Thank you very much for this information
Offline joeyjoejoe
« Reply #21 on: May 26, 2023, 05:43:06 pm »
Would the Hakko FA-430 qualify as a high end extractor?
I have been venting outside, but I get lazy in setting this up for quick soldering jobs. Ignoring the price, my concern is
1. How effective is FA-430
2. If effective, will the charcoal degrade over time without use, and to what degree.
Hobby use only so I won't use it a lot, so buying a really expensive replacement charcoal layer often is not really a great use of funds.
Offline EE4all
« Reply #22 on: May 26, 2023, 05:55:59 pm »
I made a setup using a "Tjernlund M-6 Inline Duct Booster Fan," along with appropriate hoses, splitter, reducers, and open cone ends. The exhaust goes through a wall bulkhead I installed out the attic to a soffit vent. It's a bit wasteful of inside HVAC air sure, but it's nice for any accidental magic smoke releases, that I can turn it up to high and clear it out quickly.
« Last Edit: May 26, 2023, 05:59:10 pm by EE4all »
Offline joeyjoejoe
« Reply #23 on: May 26, 2023, 05:57:09 pm »
That's my current setup, but via a window, so open/close and put the panel in as needed. I have found myself not doing that, notably when it is colder then -20 outside.
Offline tinfever
« Reply #24 on: May 26, 2023, 07:47:35 pm »
hi
That's very interesting. You mention never reaching 1/2 gas adsorption using activated carbon. Is that assuming a single pass through the filter? With enough passes, such as for a whole room air filter where the air would recirculate through the filter, would the adsorption increase significantly enough?
I'd also be interested to know more about the makeup of soldering smoke. I assume we have the particulate matter and various gasses. The particulate matter I think would be taken care of by a HEPA filter, leaving just the gasses like formaldehyde it sounds like?
