Author Topic: Patch wires recommendations  (Read 673 times)
Offline tony359Topic starter
« on: October 06, 2026, 11:53:02 am »
I'm kind of struggling to find GOOD QUALITY patch wires for my projects. For a project of mine I needed 0.5mm2 wire and I ended up buying a 2-core jacket cable from a local supplier, remove the jacket and use the wires. It was cheaper than buying a roll of 0.5mm2 wire and the one I extract from the cable are good quality.
Aliexpress is a lottery. I got a few reels for small patches but there are literally 7 strands inside, it breaks just by looking at it.
Elsewhere I might be able to find something decent but often at very high prices.
I understand materials are expensive - particularly now - but so far I haven't found a good source of decent wire which is not an arm and a leg.
I'm looking at AWG 18 to 22 I guess. Flexible, good amount of strands, possibly that doesn't melt down immediately when you solder.
Can someone recommend me something please? I am in the UK so if outside of the UK it needs to be from something like Mouser/Digikey etc.
Thank you!
Online mbeldyga
Re: Patch wires recommendations
« Reply #1 on: October 06, 2026, 12:11:47 pm »
I use Remington Industries wire sets at work, in a whole range of gauges. Can't really complain
Offline themadhippy
« Reply #2 on: October 06, 2026, 12:13:34 pm »
i use this stuff from cpc,
https://cpc.farnell.com/concordia-technologies/6009412/cable-equipment-wire-7-0-20mm/dp/CB18998
use a sharpie to add colour bands for id.
7 strands is a common cable construction used on the tiniest  hook up wire to the  large industrial cable,the stuff above is 7 strands,each strand being 0.2mm.
« Reply #3 on: October 06, 2026, 12:59:39 pm »
thanks @mbeldyga - it looks like Remington Industries is not available in the UK.
@themadhippy
Thanks - I need to check but the wires I got from Aliexpress are considerably lower quality compared to what I find coming with Delta fans from Mouser/Digikey. I need to count the strands/diameters. I do know the strands are actual copper, they don't burn when heated with a lighter.
The CPC stuff looks good and I see they have bigger lengths as well at low price. I might give that a go, thanks!
EDIT
I looked closely at the stuff I got from Ali and the wire used by DELTA. They're both AWG 24 and 11 strands. BUT, Delta uses 0.2mm diameter strands, the Ali stuff is more 0.1mm - probably between 0.1 and 0.15mm. They cheaped out as usual! :D
I'd like to find some 11 strands though. I feel 7 are too little. I'll look into CPC, if someone has some recommendations, please shout :)
« Last Edit: October 06, 2026, 01:32:49 pm by tony359 »
Offline themadhippy
« Reply #4 on: October 06, 2026, 03:02:00 pm »
if the number of cores are the same,but the cross sectional area of the cores is  different they will be a different  awg,11/0.2 is about 22awg,11/0.1 is  more like  28awg. All having more cores for a given csa achieves, is greater flexibility, a bit of 511 x 0.05 will take bending and twisting much better than the equivalent single core 1mm cable
Offline jc101
« Reply #5 on: October 06, 2026, 04:14:06 pm »
Rapid normally has a selection of hook up wires available too: https://www.rapidonline.com
« Reply #6 on: October 06, 2026, 05:59:23 pm »
indeed @themadhippy
I was reading what the jacket says. I'm positive both say 24AWG. As you say, they cannot be both 24.
Though for 24AWG I only seem to be finding 7 strands on online suppliers which makes me question the cable used by DELTA for their fans! :D
