No!
I repeat for 10th time, the C115 sensor output gives negative voltage, contrary to the positive voltage outputted by T12, T210, T245, T470.
You can't magically measure negative voltage without heavy hardware modification, not just cutting a trace.
This could be wrong, as I haven't tested myself.
You don't need t remove the mosfet, simply enable and enter the Debug screen, settign the setpoint to 0ÂșC.
Or disabling the button and shake inputs from waking up the station in the settings, thus once you set the station int sleep nothing will turn the output on.
There're really small C210 tips, you can use these with zero modifications, connection is the same as T12.
