Author Topic: CFW for KSGER/Quicko STM32 Soldering Stations  (Read 693203 times)
Offline Wsander12
Re: CFW for KSGER/Quicko STM32 Soldering Stations
« Reply #3625 on: August 10, 2023, 09:38:50 am »
My question is this. Is the hakko t9 tip for the hakko fm2023. The same as the t12. Meaning could you use one t9 tip on these hakko clones. I could get my tweezers to work on two units one unit for each side of the tweezers. But my concern would be would the t9 tip work the same as the t12. Is there any difference between the tips other then size and dimensions. I don't mind running two stations for each tip. As long as it's compatible.
Online DavidAlfa
« Reply #3626 on: August 17, 2023, 06:23:22 pm »
I did the calibration, and the measurement calibration results are (...)
I did this on mine (T12 tips)
Setpoint / measured
200 212
250 250
300 299
350 356
400 398
450 444
As you see, adding more calibration steps would be pretty much useless.
Can anyone using JBC tips perform this test?
And if you used AliExpress JBC knockoffs before, kindly explain to anwfeb how terrible they are compared to genuine tips!
The following users thanked this post: asupsp700
Offline wickated
  • Country: ru
« Reply #3627 on: August 20, 2023, 06:42:43 am »
Setpoint / measured
200 212
250 250
300 299
350 356
400 398
450 444
those are some new type of calibration? (im still on 21y build)
knockoffs jbc get +100-150 C on same adc settings as genuine
Online DavidAlfa
« Reply #3628 on: August 20, 2023, 07:50:08 am »
No... Same as always.
Offline Chaoticoz
« Reply #3629 on: August 23, 2023, 01:05:18 pm »
Hi, I just received the KSGER T12 3.1s.
The chip is not STM32 but MM32SPIN, how bad is this?
Also I noticed the tip isn’t grounded, I think there might be a connection missing from PE on the power supply to PE on the control board?
Online DavidAlfa
« Reply #3630 on: August 23, 2023, 02:55:36 pm »
Search "MM32" in this thread!  ;)
Yeah you can just connect PE with a wire.
« Last Edit: August 23, 2023, 08:55:33 pm by DavidAlfa »
Offline Chaoticoz
« Reply #3631 on: August 23, 2023, 04:15:28 pm »
Did that, all it tells me is that people swap their MM32s for STM32s. My question is what are the downsides of the MM32.
Also the second question is about the not connected PE
Online DavidAlfa
« Reply #3632 on: August 23, 2023, 07:47:10 pm »
And why do people swap them? Because they are completely incompatible!
There're no "downsides", it just won't work with this CFW.
Offline ststefanov13
  • Country: bg
« Reply #3633 on: September 21, 2023, 07:04:31 am »
asupsp700 how to convert this 2.42 inch oled display from spi to i2c to work stably?
« Last Edit: September 21, 2023, 07:06:13 am by ststefanov13 »
Offline isabido
« Reply #3634 on: September 22, 2023, 11:52:42 pm »
Thank you David for sharing your fabulous work. As you can see, I had an original Ksger v3 that I successfully updated to v1.10.5.
Everything worked the first time without problem.
https://imgur.com/a/j9JdnwS
I wanted to experiment with original JBC C210 nibs. Do you recommend me to buy this handle?
Have you done any testing with JBC tips? Thanks and greetings from Spain!
https://vi.aliexpress.com/item/1005005719333730.html?spm=a2g0o.store_pc_groupList.8148356.1.9b433fbbCoduam&pdp_npi=3%40dis%21EUR%21%E2%82%AC%2023%2C99%21%E2%82%AC%2016%2C55%21%21%21%21%21%40211b88f016954258235514784e6c9d%2112000034109131586%21sh%21ES%21109409036
Online DavidAlfa
« Reply #3635 on: September 22, 2023, 11:57:37 pm »
Hi, can't say, every seller at Aliexpress is a bit like a lottery ticket, quality can vary a lot between them.
What I can truly say is to not buy clone tips, they're crap, even worse than $3 T12 tips, only use genuine JBC ones.
Offline isabido
« Reply #3636 on: September 23, 2023, 12:07:00 am »
Thank you for your prompt response, I wasn't planning to spend the money on Chinese tips, only the original ones. The link I have given you is the handle with the ksger connector. This seems like a good option to you, right? Will I have to make any internal modifications or is the pinout correct? Have you personally been able to test c210 tips with this firmware?
Online DavidAlfa
« Reply #3637 on: September 23, 2023, 12:44:44 am »
I use T12, tried C245 knockoff for a brief period of time (Terrible ***) , never tried C210 myself.
I'm pretty sure others here  use 210 and worked just fine after calibration.
C210 doesn't need any hardware mods like C245, it's very much like the T12, heater+thermocouple in series, just different calibration.
I guess the handle should right away, ksgers have no "optional" pins for secondary functions, nor different pinout versions.
Personally I'd go with the C245 instead.
The C245 has either small tips for precision jobs, and larger tips for heavy stuff, but the C210 have way less power, so not suitable for heavy soldering work.
Also the C245 tips are ususally cheaper, you can get them for 25-30€, while the C210 tend to be more expensive, around 40€.
It's been a long time sicnce I last checked their prices, might have changed.
Offline knoway
  • Country: bg
« Reply #3638 on: September 23, 2023, 02:02:30 pm »
Hello.
Admiration for your contribution, David!  :-+
I am considering of getting the Quicko T12-955 soldering station and mod it with your firmware to use C245 handle and tips.
Do you think that unit is suitable for this purpose?
They state the the power supply is 120W, which is not enough for full utilization of the C245 tips, but still decent enough for the purpose I will be using the soldering station for.
It can also be powered with external 24V power supply which can unlock the full potential.
I am mostly concerned if the MOSFETS and the PCB traces can handle the higher current.
How much power do you think this board can handle stock and will changing the MOSFETS to beefier ones be enough?
Best regards.
p.s.
sorry if that was already asked.. i searched through the thread, but it's way too long to read all the pages
here are two pictures of the unit taken from the listing
« Last Edit: September 23, 2023, 07:41:44 pm by knoway »
  • Country: bg
« Reply #3639 on: September 24, 2023, 04:49:22 pm »
To: knoway
Need to change MCU to original !!!!!! STM32F103C8T6 , STM32F103CBT6  or CKS32F103C8T6 , CKS32F103CBT6  . The thickness of the tracks and MOSFETS is not a problem for the JBC c245, but to fit a larger 1.7 or 2.42 inch display, the 3.3v needs to be modified in particular (SPX2954AM3-3.3). Аnd add 10 M ( 2M2 ) resistor to input of operating amplifier . This power power supply is 80w.
« Last Edit: September 24, 2023, 05:46:04 pm by ststefanov13 »
  • Country: bg
« Reply #3640 on: September 24, 2023, 05:43:13 pm »
То:Wsander12
Connect the two soldering tips properly in parallel and you should have no problem. Tried by myself with Handkit soldering tweezers. but the power x2.
« Last Edit: September 24, 2023, 05:45:10 pm by ststefanov13 »
Offline knoway
  • Country: bg
« Reply #3641 on: September 24, 2023, 07:01:23 pm »
So are they straight lying for advertising the power supply as 120W?
The MCU is already STM32 and as far as I can see, the PCB is this one(KSGER v2):
https://github.com/deividAlfa/stm32_soldering_iron_controller/blob/master/BOARDS/KSGER/v2/Schematic/STM32_T12_oled_v2.0.jpg
Do I need to change the display for bigger one?
  • Country: bg
« Reply #3642 on: September 24, 2023, 07:42:10 pm »
99% FAKE stm32.
The STM32 has a precise laser-etched label visible well with a microscope.
https://github.com/deividAlfa/stm32_soldering_iron_controller/blob/master/Readme_files/Programming.md#clone-detection
SWD PINOUТ:
« Last Edit: September 24, 2023, 08:10:10 pm by ststefanov13 »
Offline asupsp700
  • Country: ua
« Reply #3643 on: September 25, 2023, 04:46:54 pm »
Sorry for the long answer!  Here are the photos.  I hope you can figure them out.  If anything is not clear, write to dmitriy.kompaniets@gmail.com
The following users thanked this post: ststefanov13
Offline asupsp700
  • Country: ua
« Reply #3644 on: September 25, 2023, 04:55:37 pm »
To remove image artifacts, I added ferrite rings to the wires... And installed 2 kOhm resistors on the sda ​​and scl display lines...
« Last Edit: September 25, 2023, 05:01:17 pm by asupsp700 »
  • Country: bg
« Reply #3645 on: September 25, 2023, 07:27:53 pm »
Have resistor from  +3.3v for reset capacitor ?
Online DavidAlfa
« Reply #3646 on: September 25, 2023, 07:54:33 pm »
What are you talking about?
Graphical artifacts a are normally caused by DIY PCB designs or using long wires.
Lower i2c pullups will often help, but ferrite beads not much.
Neither it needs nRST pullup, this is internally supplied by the stm32, it would reset itself if it was too weak.
The only cause for a station to reset it's a bad LDO design (Getting too hot and triggering thermal protection) or the PSU getting overloaded because of using a different tip than T12 (Like JBC).
Offline asupsp700
  • Country: ua
« Reply #3647 on: September 26, 2023, 05:41:09 am »
Yes, I have. Circled in red...
Offline asupsp700
  • Country: ua
« Reply #3648 on: September 26, 2023, 05:42:29 am »
I wrote for the reset circuit for the screen!
I added ferrite rings because I had them :)
« Last Edit: September 26, 2023, 05:45:11 am by asupsp700 »
Online DavidAlfa
« Reply #3649 on: September 26, 2023, 08:35:14 am »
Ah, you're talking about the SPI->I2C conversion? In that case yeah!
