Author Topic: CFW for KSGER/Quicko STM32 Soldering Stations  (Read 1435789 times)
0 Members and 15 Guests are viewing this topic.
Offline DavidAlfa
Re: CFW for KSGER/Quicko STM32 Soldering Stations
« Reply #3901 on: January 19, 2024, 02:02:14 am »
No, uses different screen and mcu.
Offline sebbi1983do
« Reply #3902 on: January 19, 2024, 04:18:30 am »
Also not the sescond one with the tweezers?
Offline DavidAlfa
« Reply #3903 on: January 19, 2024, 06:20:03 am »
Sorry, missed that one. I have no idea what's inside that station.
You might ask the seller for internal pictures?
Offline ksjh
« Reply #3904 on: January 19, 2024, 07:58:54 am »
By coincidence I was reading another thread on the EEVblog forum yesterday and searched on AliExpress for those tweezers. I am not sure if all that is stated in this listing is true, but a seller of an identically looking soldering station (also with Handskit branding) describes the model as version 2.1 and mentions the chip as an stm32 in the specification table:
https://www.aliexpress.com/item/1005005027433673.html
So, there is a chance that it could be true and DavidAlfas excellent firmware might work.
Offline sebbi1983do
« Reply #3905 on: January 19, 2024, 10:25:15 am »
I Ordered the set. I think in two weeks, we know more
Offline ststefanov13
  • Country: bg
« Reply #3906 on: January 19, 2024, 01:17:27 pm »
Need to change MCU , Handskit use clone MCU.  STM32F103C8T6 , STM32F103CBT6  or CKS32F103C8T6 , CKS32F103CBT6 . I have Handskit tweezers .
« Last Edit: January 19, 2024, 01:20:26 pm by ststefanov13 »
Offline oleg401169
  • Country: ua
« Reply #3907 on: January 19, 2024, 03:16:08 pm »
Hello, David! I changed the display on my custom station, installed an OLED display with a diagonal of 1.54 inches, i2c interface, ch1116 controller, white - I confirm that it worked immediately, I only had to adjust the screen position along the x axis in the station menu!
The following users thanked this post: DavidAlfa
Offline ksjh
« Reply #3908 on: January 19, 2024, 04:29:32 pm »
Hi David, I can also confirm that this Makita battery powered QUICKO T12-G station
https://www.aliexpress.com/item/1005005809199459.html
works perfectly with your firmware. Not problems whatsoever, original STM32.
Thank you again for your implementation.
« Last Edit: January 19, 2024, 04:32:10 pm by ksjh »
Offline DavidAlfa
« Reply #3909 on: January 19, 2024, 04:39:07 pm »
If you find any board not in the board list, please attach a picture!
Offline sebbi1983do
« Reply #3910 on: January 19, 2024, 10:47:12 pm »
How can I change the mcu und what I need to buy?
Offline lordstein
  • Country: co
« Reply #3911 on: January 20, 2024, 04:27:26 am »
Hello, I have 3 ksger v2.1s stations and, I did tests for detect couterfakes ics on 2 of those stations on the "original" ic that came on the factory pcb, when doing the test to find out if it was fake it gave me the result 20036410, so I bought 3 ic from an Aliexpress seller and 2 from another AliExpress seller, because I imagined that some of the ones that would arrive would be fake, but oh surprise I soldered them all to the boards and I tested them and it showed the value 2003610, i do the test on 6 stm32 chips so i dont know if they are all fake, they are all original, or the counterfeiters have a way of writing this value in the IC, by the way I have already been testing the software in one of the soldering irons and I really liked it, thank you very much for your work.
Offline Hunghanh2009
  • Country: vn
« Reply #3912 on: January 20, 2024, 02:07:32 pm »
Hello! As David said, even if you pass the clone test and flash test, your MCU could still be fake. Like my MCU passed all the tests but the error still appeared. hardfault in some software versions. I replaced another MCU and it works in all software versions. Daivd said he still hasn't figured out how to test the clone chip.
Offline DavidAlfa
« Reply #3913 on: January 20, 2024, 03:09:44 pm »
On some clones, they only difference I cold find was the flash size register returning 65535 instead 64/128/etc.
Run the Flash test !
« Last Edit: January 20, 2024, 03:13:50 pm by DavidAlfa »
Offline Polf
  • Country: ru
« Reply #3914 on: January 21, 2024, 04:18:56 pm »
Dear David,  In firmware 1.13.4 for KSGER V.3 the instability of the buzzer appeared. When the set temperature is reached, the signal sounds constantly or does not sound at all. This happens if the temperature does not change after switching on. If you change the temperature after switching on, the buzzer will work correctly. But the next time you turn it on, there will be a continuous signal again. In the firmware for the KSGER V.2, the buzzer works correctly.
The following users thanked this post: ststefanov13
  • Country: bg
« Reply #3915 on: January 21, 2024, 04:40:57 pm »
I have same problem.
Offline DavidAlfa
« Reply #3916 on: January 21, 2024, 04:55:39 pm »
The buzzer? And it's not happening in previous versions?
The handling code is exactly the same for all, only the stm32 pins change.  ???
Offline bozo
  • Country: hr
« Reply #3917 on: January 21, 2024, 05:21:24 pm »
1.13.4 KSGER V.3 I have no problem with the buzzer.
Offline DavidAlfa
« Reply #3918 on: January 21, 2024, 07:08:08 pm »
How about v1.13.5?
The following users thanked this post: Polf, ststefanov13, oleg401169
Offline Polf
  • Country: ru
« Reply #3919 on: January 21, 2024, 08:49:52 pm »
How about v1.13.5?
David, everything is fine now!
Offline oleg401169
  • Country: ua
« Reply #3920 on: January 21, 2024, 11:55:54 pm »
Hello David! I updated to firmware version 1.13.5 and it started up normally for the first time since version 1.13.0. Now I’m using it on a station operating in the c245 mode. I had a question - I had the following situation: I flashed a station with a pretty low battery , set the settings I needed (c245, etc.) and then turned off the station. When I needed it for work, I first saw the settings recovery screen, and then I saw that the station switched to T12 mode. After completely resetting the station, setting the settings I needed settings, but at the same time disabling battery mode in the settings, everything works fine. For me this is not critical, but I would like to know what this is connected with, I would like to use this function of your firmware. Once again, this is not critical, but still I would like it to be possible to save the parameters of your stings both with and without a battery. Thank you for your work!
Offline DavidAlfa
« Reply #3921 on: January 22, 2024, 04:49:10 am »
Then simply disable the battery! The last settings will be stored elsewhere.
Did you read the Readme and the operation manual? This is explained extensively.
Offline oleg401169
  • Country: ua
« Reply #3922 on: January 22, 2024, 05:08:12 am »
Please don’t worry, I removed the battery both physically and virtually and I always read the documentation. This doesn’t bother me at all, because in principle everything works, and this is a working situation. If a comparison is appropriate in this situation - any medicine has side effects  effects, some have more, others have less. The firmware works and that’s the main thing.
  • Country: bg
« Reply #3923 on: January 22, 2024, 07:02:33 am »
Everything is fine now in KSGER v.3 and v.2. and Handskit (KSGER v.2).
Offline DavidAlfa
« Reply #3924 on: January 22, 2024, 09:39:03 am »
oleg401169, I don't think we're understanding each other.
If you have battery, enable the option, if you don't, disable it.
This only chooses where the last temperature/tip/profile is saved, there's no real difference.
But if you enable the option and there's no battery (Or it's discharged) the value will always be forgotten and the low battery error shown at boot.
The following users thanked this post: asupsp700, oleg401169
