Author Topic: NanoVNA Custom Software  (Read 1000627 times)
0 Members and 310 Guests are viewing this topic.
Offline m3vuv
Re: NanoVNA Custom Software
« Reply #1275 on: September 02, 2021, 02:04:02 pm »
has the nano vna been made to work at 2.4ghz yet,ie for wifi antenna tuning?
Offline joeqsmithTopic starter
« Reply #1276 on: September 03, 2021, 12:13:06 pm »
If there is, it's nothing I would use.  The performance really suffers as you move above 300MHz.  The following section compares my original NanoVNA against a vintage PNA while looking at a GHz filter.  Results are very poor as we would expect.  I do like the OWOs V2P4 that is shown.   If you are looking for a low cost VNA to work above 300MHz, it's a good choice.   The video is a review for it.
https://youtu.be/XaYBpPCo1qk?list=PLZSS2ajxhiQD2gftdurGQoyGpUM_HobNI&t=2733
« Reply #1277 on: September 03, 2021, 12:18:26 pm »
I'm experimenting with this right now.
And how did that turn out?
Offline harrimansat
« Reply #1278 on: September 03, 2021, 08:42:39 pm »
Hi, this not seems a CW
Offline harrimansat
« Reply #1279 on: September 03, 2021, 08:46:01 pm »
Joe, thanks a lot again. Got it to work. Using your software recording breathing and heartbeat with RADAR using a NanoVNA V2+4. I transmitted CW 2.4 GHz using my makeshift Vivaldi antenna at port 1, receiving the reflected wave (doppler effect for movement of my chest wall) with a simple stub at port 2. Calculated phase of S21 with atan2(i,r). Range was about 1 m.
Pics:
Setup
Unfiltered moving in, three breath, holding breath, three breath, moving out.
filtered with a 3 Hz lowpass, showing the heartbeat. Same data.
This is a CW
There´s some firmware for plus with CW?
Can you please tell me wich?
Thanks
« Reply #1281 on: September 03, 2021, 10:59:13 pm »
I started with VSWR too, was fun to try-and-error a Vivaldi out of copper tape. When the Smith chart shows a bit too much inductance, cut some tape and make the coupling capa larger... Works like a charm, got the SWR below 1.2 in the entire 2.4 G ISM band  (need  directional antennas for the radar). Now I have the rough shape, will cut it out of copper sheet and put it in a can (side lope suppression) to reduce direct path reception.
Its amazing what this little thing can do, but your software is definitively the icing on the cake. Reference subtraction, all the options for stimulus, automatic marker placement, ... incredible.  :-+ :-+ :-+ :clap:
For fun I attempted to use the picture of your antenna to replicate it.   Also, for fun I thought I would show the VSWR with the V2P4 uncalibrated (yellow trace) and then calibrated (1G - 3GHz range).     Also shown are a few other Vivaldi antennas I had made.
« Reply #1282 on: September 07, 2021, 11:19:45 pm »
Swag at a new antenna.
« Reply #1284 on: October 12, 2021, 12:28:33 pm »
There is a new version now in the works.   Most of the changes are for the TDR measurements but I have added some other features as well.
Offline DC1MC
« Reply #1285 on: October 12, 2021, 01:45:09 pm »
What hardware variant/trusted seller do you recommend that gives the best results for the software, I've seen a (most likely fake clone of fake clone) NanoVNA of a friend that was frankly speaking a piece of junk, never producing 2 similar measurements in a row  |O.
So is there a trusted reliable seller somewhere, preferably in EU, best in DE, but wherever it is if it ships in DE is OK.
 Many thanks for your software,
 DC1MC
« Reply #1286 on: October 12, 2021, 02:50:51 pm »
 DC1MC
I see that question posted a lot.  I really don't have a lot of experience with the different manufactures.  I bought the V2Plus and V2Plus4 directly from OWOs company.   The H4 appears to be well put together kit, but I have no idea who produced it.   I am also not sure where my friend bought the two original NanoVNAs.
As far as making a recommendation on what to buy, it depends on how much you want to spend and how you plan to use it.  The firmware has been by far the biggest problem I have ran into.
If you do not need narrow band measurements and plan to work above 300MHz, the V2Plus4 would be my pick out of the low cost VNAs.  If you want to work below 300MHz and need barrow band, or if you want to make PDN measurements, get the original NanoVNA.    If you need both, I would buy both products.
If you're the typical radio hobbyist and want to measure your antennas SWR out to three places beyond the decimal, stop kidding yourself and buy an SWR meter.
As far as your friends comment, its hard to say.  They would need to post some actual data, their setup.... before I could offer any input.    You read some of the things people post, like using a couple of VNAs and Ts to make full 2-port measurements  or connecting their VNA directly to their radios PA and you get the idea that many users are just starting to learn some basics.   I wouldn't look to them for advice.    (All actual posts BTW.  You can't make this stuff up.)
I've shown a lot of tests using these low cost VNAs  and have been pretty impressed with the data I have pulled from them.  Obviously working at higher frequencies will require more care to avoid measurement errors.    If your friend has a blog where they are posting their test results, provide a link and I will have a look at it.
« Last Edit: October 13, 2021, 03:45:52 am by joeqsmith »
Offline galileo
  • Country: cs
« Reply #1287 on: October 13, 2021, 04:17:26 am »
 DC1MC
This is the manufacturer (Hugen) of Nano H and H4, TinySA etc: https://nanovna.com/?page_id=121
I would suggest that you get the H4 as it is a more capable device with standards that have been characterized (search for Kurt Poulsen's calibration data).
Offline DC1MC
« Reply #1288 on: October 13, 2021, 07:23:45 am »
 DC1MC
Thanks for the tip, the H4 variant is also called "Hugen 3.4 with a 4" screen"?
"This VNA is the latest official 3.4 Hugen version, it has a TFT touch screen available in 2 sizes 2.8 "(7.1cm) and 4" (10.1cm), power supply by USB-C cable (supplied) or internal battery included 650mAh or 1950mAh (H4)."
Cheers,
DC1MC
« Reply #1289 on: October 13, 2021, 11:00:33 am »
 DC1MC
Cheers,
DC1MC
I have some "NanoVNA-H4" that never sees any use due to the lack of stable firmware for it.   It appears to have similar problems that I saw with the original Nanovna a few years ago.   It cost about $100 USD.  I bought it after someone here was posting about having problems when trying to use my software with it.   While some newer firmware allows it to support more data points,  it's plagued with problems.   The focus seems more on adding features than fixing problems.  If you  are planning to run headless, why pay for the larger LCD.   I would save the $50 and get the original if you are working below 300MHz, need narrow band or want to measure PDNs.
You may even be better off with a spectrum analyzer and tracking generator.  It really depends.  I assume you are posting here because you want to use my software for some reason.
If you are a beginner and just wanting to learn some basics, I wouldn't worry too much about the standards or cables.  Of course, your goals may be different.  I had someone post me about trying to use one of these low cost VNAs to look at a metrology grade Beatty standard with 10 samples or some such nonsense because it apparently improves the edge rates.    There is a lot you could learn a lot from just reading the papers published by HP.
First 10 minutes or so discusses the VNAs I have and their shortcomings.
Offline galileo
  • Country: cs
« Reply #1290 on: October 15, 2021, 02:51:57 am »
Cheers,
DC1MC
Yes that's the one. AFAIK only the 4" version gets the new hardware updates (new lower noise DC-DC converter, microsd slot etc).
Offline galileo
  • Country: cs
« Reply #1291 on: October 15, 2021, 03:03:55 am »
I haven't had any issues with H4 and DisLord firmware (I believe that all H4 in production come with his firmware) but I only use NanoVNASaver.
Anyway please post your issues at https://github.com/DiSlord/NanoVNA-D/issues or https://groups.io/g/nanovna-beta-test/
Hugen has raised the price recently, I got my H4 last November, from his store, for less than $60. Current price is ~$80 (with shipping).
« Reply #1292 on: October 15, 2021, 03:41:14 am »
I have no plans to invest any more time into the H4.   If you're interested, you may find the discussion about some of the problems I mention with the H4 here:
https://www.eevblog.com/forum/rf-microwave/nanovna-custom-software/msg3577360/#msg3577360
Offline galileo
  • Country: cs
« Reply #1293 on: October 15, 2021, 10:09:26 pm »
Browsed the next few pages, his English proficiency certainly did not help with diagnosing the issue.
Anyway can you link to the firmware that works for you, if I get some free time I would like to compare
the results that I get with it and with the latest firmware from DisLord.
« Reply #1294 on: October 16, 2021, 01:53:31 am »
I never found a version of firmware that would work with my H4.  If I did, we wouldn't be having this conversation.
For the original NanoVNA, I am still using the version that some of the locals here had worked on to correct some of the problems.   That version is stored with the software.   For the V2Plus4, I am using the firmware that was supplied with it.  That's been stable from the start.
Offline galileo
  • Country: cs
« Reply #1295 on: October 17, 2021, 01:50:49 am »
I was referring to firmware for the 2.8" version. Where is that file stored again? I browsed your github page and listed
the files in the multi part archives (haven't seen a multi part archive in years  ;) ) but nothing there resembles the firmware
for the nano.
« Reply #1296 on: October 17, 2021, 02:06:38 am »
As I mentioned, the spanned ZIP is because Github limits the file sizes.   Take the time to read the README file or a least the first few sentences.  That should get you started.   You do not need to DL the entire LV runtime to get the firmware.
If you like, you can also post the location and version of the firmware you feel is working and I can run it through my simple regression test.
The updates to the software is pretty much finished and tested.  I need to get the manual updated as well.  The plan is to again make a short video to demonstrate the changes.
If there is something specific anyone would like to see demo'ed, feel free to ask and I'll try to include it.
« Reply #1297 on: October 17, 2021, 11:50:40 pm »
Preview of the latest release.
« Reply #1298 on: October 23, 2021, 05:14:45 pm »
So I was close to cutting it loose, but someone had asked about adding additional features for characterizing amplifiers.
https://nanorfe.com/forum/Preview-of-my-latest-software-updates.html
For just adding the B factory mentioned, it's a simple enough thing to do.  Maybe use the two scales off the main plot.    Adding the stability circles may be more difficult depending what people would want to see.  Also seems like other stability factors may be useful...   I think I would end up just adding a whole new tab to the advanced menu specifically for amplifier design.
With these low cost VNAs not being a 2-port analyzer,  we are back to needing a transfer relay.   Or OWO needs to move ahead...  :-+
Just curious if anyone here has any interest in such a feature.  If so, any thought on how to present the data?  Any tools you are currently using?
« Reply #1299 on: October 23, 2021, 06:24:11 pm »
Adding something like this on a separate tab would be simple enough.  Maybe allow user to select between gain and stability circles on the same graphs...  I try to keep the basics on that main menu and jamming it onto that may be a bit much.
