Author Topic: $20 LCR ESR Transistor checker project  (Read 5355776 times)
0 Members and 264 Guests are viewing this topic.
Offline phantom
« Reply #9950 on: April 23, 2025, 12:34:07 pm »
i know this is a stupid question...but 399 pages are too much for me to find the answer!
i 've bough 4 years ago a tcr-t7h...never used...should i update the firmware? should i do some "hardware mods"?
how? thanks
Offline indman
  • Country: by
Offline Feliciano
  • Country: ve
« Reply #9952 on: April 23, 2025, 07:45:14 pm »
@snapper:
Yes, something like that. And for the software you can use WinAVR with the proper toolchain. On the FAQs made by indman and me you can find more information.
Offline proditaki
« Reply #9953 on: April 25, 2025, 07:15:30 am »
I've been reading this topic since my LCR-TC1 died.  (the controller is dead)
From the clone comparison i've gather that my model has the LGT8F328 controller.
The comparison doesn't mention upgrading it to an Atmel processor, but reading the forum makes me think it's possible.
I have some AtMega328p lying around, but i'm a bit confused about what to do.
From what i've read here you can replace the LGT8F328 with the ATMega328p but not without some adjustments.
But it's not exactly clear to me what adjustments are needed.
Can anybody help me out?
For clarity i added some pictures.
2553498-0
The following users thanked this post: elecdonia
Offline pupkinv
  • Country: ua
The following users thanked this post: proditaki
Offline proditaki
« Reply #9955 on: April 25, 2025, 10:00:13 am »
Offline pupkinv
  • Country: ua
« Reply #9956 on: April 25, 2025, 11:51:52 am »
Thanks a lot, the firmware link in the post doesn't work. Is there an alternative ?  ::)
Downloads only for registered users.
Offline indman
  • Country: by
« Reply #9957 on: April 25, 2025, 12:06:00 pm »
proditaki ,This firmware is in Russian. You can get the firmware in English from this post
https://www.eevblog.com/forum/testgear/$20-lcr-esr-transistor-checker-project/msg4899587/#msg4899587
Offline CaptainBucko
« Reply #9958 on: April 28, 2025, 05:47:54 am »
With a few minor PCB modifications, you can replace the LGT8F328 with the ATMega and add an ISP header as shown in the photos. This is small enough (in height) so you can still reassemble the unit in the factory case.
« Last Edit: April 28, 2025, 06:50:00 am by CaptainBucko »
Offline proditaki
« Reply #9959 on: May 07, 2025, 10:55:12 am »
I followed the instructions
Now it always gives me this.2561964-0
Offline madires
  • A qualified hobbyist ;)
« Reply #9960 on: May 07, 2025, 11:09:47 am »
The tester sees a permament voltage on probe #3.
Offline proditaki
« Reply #9961 on: May 07, 2025, 11:46:57 am »
Its weird.
I double checked all connections
I dont see /measure anything wrong
2561984-0
Offline madires
« Reply #9962 on: May 07, 2025, 12:38:22 pm »
Is D2 (SRV05-4, over-voltage protection) damaged? Please try again with D2 removed. When the MCU is toasted by a charged cap D2 is often toasted too.
Offline proditaki
« Reply #9963 on: May 07, 2025, 12:56:24 pm »
I get the same result with D2 removed, so i'm guessing that's not it :(
Offline madires
« Reply #9964 on: May 07, 2025, 01:15:02 pm »
Could you please take a DMM and measure the voltage at the ADC pin of probe/testpin #3 while the tester shows the error message?
Offline proditaki
« Reply #9965 on: May 07, 2025, 01:26:46 pm »
It's 7.2mv it's measuring.
Offline madires
« Reply #9966 on: May 07, 2025, 01:42:04 pm »
We're missing something.
Offline proditaki
« Reply #9967 on: May 07, 2025, 01:45:29 pm »
Yeah, it's very weird.
I got the error message you get when nothing is connected once or twice, but then the same reading on pin 3 again.
Offline indman
  • Country: by
« Reply #9968 on: May 07, 2025, 03:06:23 pm »
proditaki You need to make changes that are shown in the diagram in red. The tesa of these additions the tester will not work normally.
C32 does not have to install, the tester will work normally without this capacitor.
« Last Edit: May 07, 2025, 03:10:05 pm by indman »
Offline proditaki
« Reply #9969 on: May 07, 2025, 07:25:04 pm »
i added C31. The other mods i already had made. sadly it's still not working properly, same error
Offline indman
  • Country: by
« Reply #9970 on: May 07, 2025, 07:27:21 pm »
Contact 3 and 5 of the controller did you connect together?
Offline proditaki
« Reply #9971 on: May 07, 2025, 07:28:34 pm »
Yes i checked with the multimeter as well.
Offline indman
  • Country: by
« Reply #9972 on: May 07, 2025, 07:31:43 pm »
I do not see in the photo that you showed before this jumper.
Offline proditaki
« Reply #9973 on: May 07, 2025, 08:17:49 pm »
Offline indman
  • Country: by
« Reply #9974 on: May 08, 2025, 05:20:47 am »
proditaki, I can see the jumper now. But I also see that you have a lot of flux residue and dirt on the board.Remove them and also very carefully clean the ZIF panel contacts.If the problem does not disappear, we will think further how to solve it. ;)
