Yours or one on loan ?
I wanted to use the webserver via LAN, but i don't have a router in the room. Do i need a crossover cable to connect the PC and the scope?
I wanted to use the webserver via LAN, but i don't have a router in the room. Do i need a crossover cable to connect the PC and the scope?You shouldn't need one - modern network ports on a PC have auto-sensing and swap the lines if necessary.
You can't use the DHCP feature though (because without router there's usually no DHCP server), so you have to configure the ethernet settings manually.
You can't use the DHCP feature though (because without router there's usually no DHCP server), so you have to configure the ethernet settings manually.Correct, connection is very possible but a bit of a PITA to get all the IP stuff set into the scope correctly.
Open a CMD window and 'ipconfig' the PC's settings. Mirror them into the scope and just +1 for the scopes IP. Then Save.
Should work fine.
I see. Still, it worked and i was able to control the scope from the webserver
Unfortunately my knowledge of netwroks is sub-zero so i can only say i'm glad this workaround works
If I understand the manual right, it´s got a free definable and moveable measuring-gate (A, B, AB).
If it´s so, it will be very interesting for our testdepartement since we know, that lecroy doesn´t have this very useable feature anymore on their modern scopes.
If it´s so, it will be very interesting for our testdepartement since we know, that lecroy doesn´t have this very useable feature anymore on their modern scopes.Hm. Even the lowish WS3000 features gates for measurements. The current 12bit HDO line has gates for sure, all the previous Wavesurfers and Waverunners I ever used in the last ten years had movable gates. On "my" 6zi at work you can drag the gate cursors with the touch screen.
For sure it's nice that the SDS5000 seems to have inherited the gate feature from LeCroy. AFAIK no HP/Agilent/Keysight scope I ever used had this feature and they usually measure from the screen buffer anyway.
tektronix style, you move X and Y is tracking the waveform
If there is one thing i miss from the rigol is the cursors that track measurements..
And there are some measurements missing i forgot to ask if/when they wil be added, basically slew rate
Hm, you mean the gating cursors could be moved together in the past?
Never really missed it to be honest
Even the 2004 WS 422 don´t have it anymore
X-Stream?
