Author Topic: DSOX2000 and 3000 series - licence , have anyone tried to hack that scope ?  (Read 1683022 times)
Pilatus and 8 Guests are viewing this topic.
Offline jjcyril
Re: DSOX2000 and 3000 series - licence , have anyone tried to hack that scope ?
« Reply #3475 on: February 20, 2025, 10:22:34 am »
Hi
sorry to bother you could you send me the firmware 2.35 for the oscilloscope keysight or agilent
please
Offline dimmog
    • Hubequip
« Reply #3476 on: February 20, 2025, 11:56:07 am »
Hi
please
The link can be found on the previous page of this thread  :D
https://www.eevblog.com/forum/testgear/dsox2000-and-3000-series-licence-have-anyone-tried-to-hack-that-scope/msg5797997/#msg5797997
Hubequip.net :: test equipment parts and more
www.hubequip.net
Offline Lydia
  • Country: cn
It seems that oscilloscope will indicate this err every time you do SelfTest until you passed UserCal first.
I have a EDUX-1000A model and modified it to DSOX-1000G, so at some stage during work, this oscilloscope will stay in UserCal failed status.
During that time, I occasionally find that if system report it's uncaled, then it will never pass SelfTest and report "TrigComp".
But when I passed UserCal, SelfTest passed immediately even without a reboot.
So it seems that if your machine is reporting Uncal, then ignore SelfTest and finish UserCal, This message maybe not due to a hardware damage. :popcorn:
Disconnecting from this world...
Waiting for response...
Offline tabajaralabs
  • Country: br
    • Tabajara Labs
This is the SECOND scope I am trying to recover using the https://salvagedcircuitry.com/2000a-nand-recovery.html method and I fail miserably AGAIN :\ I must be doing something very stupid.
I'll enumerate my steps, please, someone help!
And this one was working! When I tried to install the upgrade file, I installed a wrong file and it stopped working, with memory corruption (leds flashing)
BTW: The firmwre was VERY old. 01.00.2011011301 when it was working.
1 - Connect the scope with CAL pressed. Run spearload.exe -t spear600 p500_ddrdriver.bin u-boot_image.bin and opens a serial port on pc. I'm using the USB port instead of the serial port since it is SO much faster.
2 - Open TeraTerm, I enter the P500> prompt. Set environment variables (server, gateway, ipaddr). Save it with "saves". Don't know why, ipaddr variable does not get saved, I have to SETENV IPADDR every time I boot the scope
3 - Prepared the NK.BIN/NK.NB0 files, the pendrive as usual. Yes, 1GB pen drive, fat32. Everything as said in the site.
4 - TFTPBOOT 0x00361000 NK.NB0 (or NK.BIN), the correct number of bytes is transfered
5 - GO 0x00362000 and the scope locks up, with just a pair of ## instead of ## Starting...
Tried TFTPBOOT, BOOTP, nothing.
And when it happened, I could see agilent image on boot and panel leds flashed. Now when I turn it on, it does nothing. If I  issue the BOOT command I get
p500> boot
## Booting kernel from Legacy Image at f8050000 ...
   Image Name:   PBOOT
   Created:      2010-10-19  12:09:59 UTC
   Image Type:   ARM Linux Kernel Image (gzip compressed)
   Data Size:    36687 Bytes = 35.8 KiB
   Load Address: 00000000
   Entry Point:  00000000
   Uncompressing Kernel Image ... OK
Starting kernel ...
Unfortuntely I have not even the minimal idea of what is happening.
please, help! :(
Update: Connected a ttl to usb serial on the comm port. This is what happens when I type go 0x0362000:
Windows CE Kernel for ARM (Thumb Enabled) Built on Jun 16 2009 at 10:08:15
Setting up for a Cold Reboot
Done Setting up for a Cold Reboot
Windows CE Firmware Init
BSP 1.0.0 for the SPEARHEAD600AB board (built Mar 16 2011)
Adaptation performed by ADENEO (c) 2005
+OALIntrInit
-OALIntrInit(rc = 1)
Initialize driver globals Zeros area...
pDrvGlobalArea 0xa0060000  size 0x800 (0xa0060800 -0xa0060000)
Initialize driver globals Zeros area...done
 OALKitlStart
Firmware Init Done.
OALIoctlHalEnterI2cCriticalSection init i2c cs
-EDeviceLoadEeprom 00:30:D3:14:9C:AE
Phy found addr 31 (ticks=2674)
WaitForLink Start (ticks=2676)
Link Detected (ticks=2678)
 GMAC Init : 100 Mbit/s FULL DUPLEX (MII)
Flushed Transmit Buffer
phyCfg->dwSpeed 0x64
<--EDeviceInitialize
GMAC DMA status register = 0x600004
GMAC Device enable interrupt
DriverStart
BALDWIN_DDI: cBaldwinHwIf::Init: Initializing...
BALDWIN_DDI: cBaldwinHwIf::Init: Scope successfully identified.
« Last Edit: April 09, 2025, 08:59:50 am by tabajaralabs »
Offline onesystem
Try using this method. It is quite easy and judging by your description scope boots far enough to load "windows". NOTE: you might have no such file as "infiniiVisionUpdateService.exe", in that case start the infiniiVision service file (I do not remember it's name, but it will be obvious), and there will be a weird looking scope interface with windows overlay mixed together - but it will let you use the scope's internal firmare update option!
I followed the instructions on this blog:
https://ripitapart.com/2018/10/15/gaining-access-to-the-windows-ce-desktop-and-doom-on-the-keysight-dsox1102g-oscilloscope/
Gained access to windows of the scope. Then in using command prompt navigated to Windows directory, found program called infiniiVisionUpdateService.exe, in command prompt typed infiniiVisionUpdateService.exe \usb\2000XSeries.02.66.20240123001.ksx, and scope updated to the 2.66 firmware and is runnig well now - no errors - serial output shows normal running.
So in summary:
1. FAT formatted USB
2. placed infiniivisionStartupOverride.txt in the root of usb (knowing it will stump scope from booting but looking at usb for some time before rebooting)
3. placed extracted content of ScopeLiberator-Release-2.0.zip into the usb flash drive root (without any folder structure)
4. placed 2000XSeries.02.66.20240123001.ksx file into usb root
5. connected keyboard to the back of the scope, plugged usb in front.
6. Turned on the scope and waited until lights started circling on buttons, then pressed Windows button + R, then typed \usb\a.bat and pressed Enter
7. Windows 98-like desktop showed up. Navigated to usb drive, started command prompt, in there switched to Windows directory, typed infiniiVisionUpdateService.exe \usb\2000XSeries.02.66.20240123001.ksx and update went through.
8. When scope was rebooting, I unplugged the flash drive and got a working scope.
  • Country: br
    • Tabajara Labs
Strange method, but interesting, I'll give a try. Thanks!
But...where do I find this scope liberator? And are you aware my scope is a DSO-X2000 series, not 1000 eh?
Offline onesystem
At the end of Reply #3460 you will find attachment. Yes I am aware yours is DSOX2000, mine was too. It will work with 2000 and 3000 for sure.
The following users thanked this post: tabajaralabs
  • Country: br
    • Tabajara Labs
Unfortunately, it didn't work.
Scope came to a point lights does not flash if via USB/Serial channel (back USB B connector) I do not issue a "boot" command.
After the BOOT command the internal serial shows lots of things happening, but stops on the BALDWIN_DDI: cBaldwinHwIf::Init: Scope successfully identified.
I did just as you said, prepared the pen drive, connected to the front of the scope. Issued the BOOT command. Connected the USB keyboard on the back A port (and ok, I tested the keyboard before connecting and disconnected the B port after boot). Keyboard does not flash lights. As I issued the BOOT command the lights started to flash in sequence and I typed the (windows)-R  \usb\a.bat command lots of times. No response whatsoever.
I have a theory that may or may not be connected to reality - please disregard my words after this point:
SEEMS that you have 2 partitions on boot. One is the PBOOT partition. This partition boots up the scope circuit and prepares to load the windows CE which sits on other partition. Most or all of these methods works, if somehow you have the windows CE installed on second partition. On my scope, SEEMS I have a problem on the second partition which is deep enough not to let the system boot with the methods described here
At least, this is what it SEEMS to be.
Actual state:
When I turn it on, nothing happens. No flash lights, no signal it is turned on beyond fan rotating.
If I type BOOT on the p500> prompt via serial USB B port, it boots up to the "baldin" line. No display, lights flashes.
Heeelp! =(
« Last Edit: April 10, 2025, 01:05:17 am by tabajaralabs »
  • Country: br
    • Tabajara Labs
Just out of curiosity...I have a DSO2002x working...
Can I copy the entire NAND of it thru usb/serial/whatever and restore this backup on the working scope?\
  • Country: br
    • Tabajara Labs
I think I have a better question, lets see if it is doable...
I have the image of the Flash rom extracted from a dsx2000 working scope running V2.64. The NAND image looks correct comparing with some info I can get on uboot. I believe the flash image is OK, and - according to the uboot - it should be an entire jffs2 filesystem. I have no ways to browse this filesystem but it seems complete. Is there a way I can upload this entire 128K image to the Flash on the scope trying to revive it? I have the start address of the flash, maybe loading it on ram and CPing it to flash?
Online Bud
Connect a terminal to the UART port, boot normally (not with the Cal button trick) and post the log here.
Online Bud
Forget abput transplanting NAND image, you will lose factory cal.
  • Country: br
    • Tabajara Labs
If I just keep the UART connected, this is what happens:
U-Boot 2010.03 (Sep 09 2010 - 14:47:56)Agilent P500
CPU:   SPEAr600
DRAM:  128 MiB
Flash: 512 KiB
NAND:  128 MiB
If I connect the USB B connector on the back, and type BOOT at the P500> prompt, that is what happens in the UART
Debug serial initialized ........OK
Microsoft Windows CE Bootloader Common Library Version 1.4 Built Oct 19 2010 03:
38:36
Microsoft Windows CE 6.0 Ethernet Bootloader for the Agilent P500 board
Adaptation performed by Agilent Technologies (c) 2008
System ready!
Preparing for download...
 Loading image 1 from memory at 0xD0600000
O
BL_IMAGE_TYPE_BIN
X
XXXXXOOOOXOOOOOOOOXOXOOOOOOOOXOOOXOOOOXXOOOOOOOOOXOOOXOOXOXXXOOXOXOXXXXXXOOOXXXO
OOOOXOXOXXXXXXOOOOXXXOOOXXOOOOXOOXOOXXOOOXOOOOOXOOXOOOOXXXXXXOXXOXOXXXXXXXOXXXXO
OOXOOOOXXOOOOXOOOOXOXOXOOOOOOXOOOXOOXOOOOX
OXOOOOOXOOOOXXOOOOOOOOOXXOOOOXOOOOOOXXOXOOOOXOXOOOOXXOOXOOXXOXOOOXOOOXOOXXOXOXOO
OXXXXOXXOOOXXOXXXOXXOOXXOOXXOXXXXXXOOOXXXOXOOXOXOOOOXOOOOXOOOXOOXOOXOOOXOOXXXXXX
XXXXXXXXXrom_offset=0x0.
XXImageStart = 0x80361000, ImageLength = 0x1237530, LaunchAddr = 0x80362000
Completed file(s):
  • : Address=0x80361000  Length=0x1237530  Name="" Target=RAM
 Loading image 1 succeeded.
ROMHDR at Address 80361044h
Preparing launch...
Launching windows CE image by jumping at address 0x  362000
BSP 1.0.0 for the SPEARHEAD600AB board (built Jan 13 2011)
+OALIntrInit
 OALKitlStart
Firmware Init Done.
Phy found addr 31 (ticks=2653)
WaitForLink Start (ticks=2654)
Link Detected (ticks=2657)
DriverStart
Anything else I can help? Maybe this other info is important:
If I press space when booting (of course, sending BOOT in the USB UART) and ask for testing the two avaiable images, it says image 2 is not valid, here you are the log
38:36
P500 Boot Loader Configuration :
Mac address .......... (00:30:D3:14:9C:AE)
Ip address ........... (192.168.0.204)
Subnet Mask address .. (255.255.255.0)
DHCP ................. (Enabled)
Boot delay (seconds).. (0)
Load image 1 at startup
Image addresses. (0xdxxxxxxx for NAND, 0x8xxxxxxx for RAM)
        1 (0xd0600000)
        2 (0xd1600000)
l) Load flash resident image now
d) Download from ethernet now
u) Start u-boot by resetting
v) Verify Images
********* Image 1  *******************O
BL_IMAGE_TYPE_BIN
X
Completed file(s):
Valid Image at 0xd0600000
********* Image 2  *******************
BL_IMAGE_TYPE_UNKNOWN
Image at 0xd1600000 is not valid
        1 (0xd0600000)
        2 (0xd1600000)
v) Verify Images
Thanks for all the help!
Offline onesystem
Did you also prepare a flash drive with bootable structure on it and plugged it in before starting with step #5?
  • Country: br
    • Tabajara Labs
Yep, that was step 3.
The pen drive preparation process has a lot of question marks, but I did my best. I don't know if capital letters are different (I assume not), if I gotta put a CR/LF on the end of the two created files etc. I assume not because of windows CE. anyways, I see the pen drive flash, but doesn't work. Of course, I tried 4 different pendrives. All of them below 8GB.
Offline onesystem
Okay. Regarding the version of the firmware - you mentioned that it was version 01.00.2011011301. is nk.bin file also from that version?
Maybe you can try several different nk.bin from not only the version 01.00.2011011301, but also maybe from the version that you tried to load...
« Last Edit: April 10, 2025, 06:10:20 pm by onesystem »
  • Country: br
    • Tabajara Labs
tried 8 versions, from 2000XSeries.01.10.2011031600.cab to 2000XSeries.02.65.20210307001.ksx. Unfortunately it didn't work. The version 01.00.2011011301 as far as I could find is unavaiable on the net...
Offline onesystem
Wait. You said you are using USB in the back of the scope. I did those procedures using the UART header on the circuit board of the scope (you would have to open it up to get to it). And I know it takes a long time - but could you try it? This way we know that procedure when done exactly as on that website, still fails.
This parts gets me a little confused:
There is no server, gateway, ipaddr on that UART port - so I guess you are using network card? I never used that, only used UART to load the files.
« Last Edit: April 10, 2025, 08:10:27 pm by onesystem »
Offline analogRF
just connect the UART and DO NOT connect ANYTHING else to any other place
and post what exactly shows up on the UART header on the board.
you did not have to use USB connection to PC at all. if it is indeed a nand corruption
only the UART connection is enough and a LAN card can be helpful but not mandatory
I have repaired at least 14-15 of these scopes from NAND corruption so far and never connected USB-B to PC.
but there are issues other than nand corruption that can occur. the exact UART log is important
The following users thanked this post: onesystem
  • Country: br
    • Tabajara Labs
That is exactely what I did:
(just the uart, no USB connection:)
CPU:   SPEAr600
DRAM:  128 MiB
Flash: 512 KiB
NAND:  128 MiB
Only that text, nothing else.
And yes, I have the vga/network adapter connected. And yes, the boot without the network adapter is the same
Thanks for the help!
  • Country: br
    • Tabajara Labs
I did it both ways:
- Just the UART and the network adapter
- Uart + USB and the network adapter
I cannot believe I cannot use the networking card to load the NK.NB0 file (after all it is just a difference on the media to transfer the files to memory) but of course, I know nothing. If you want I can try transfering thru the UART.
Offline analogRF
CPU:   SPEAr600
DRAM:  128 MiB
Flash: 512 KiB
NAND:  128 MiB
I dont get it. If that is all you get on the UART port how did you get into the p500> prompt and changed variables and such!?
if that's all you get on the uart and nothing else, the problem may not be nand corruption at all. It is stopping way too early
before any attempt at loading kernel or anything. Looks more like a RAM issue or even some power supply on board is bad etc...
  • Country: br
    • Tabajara Labs
Ok, now I am using internal UART
Firstly, I moved all stdin/out/err to serial
setenv stdin serial
setenv stdout serial
seterr stdout serial
saveenv
and rebooted. Disconnected the network adapter and the back usb port. Now I am using ONLY the internal UART
Turn scope off, then on. This is what I get:
CPU:   SPEAr600
DRAM:  128 MiB
Flash: 512 KiB
NAND:  128 MiB
In:    serial
Out:   serial
Err:   serial
SerNum:serial number not programmed
Chip:  BD Board Rev: 4
Net:   smsc
And the scope locks up. Does not accept any input from anything. If I boot the scope with spacebar pressed, does nothing. Same thing as above
Anything else I should try?
Offline analogRF
this is way too early in the boot process. even pboot has not started, forget about WinCE and nk.nb0 and all of that.
To me looks like either a RAM issue or NOR flash.
i think there was a dump of NOR flash somewhere in the forum but I dont have it
does it stop there every time you power on? or does it go further randomly sometimes?
  • Country: br
    • Tabajara Labs
Unfortunately, stops every time
This must not be a RAM issue because it worked before. Yesterday I bricked the scope trying to update it. I selected a wrong file and goodbye scope.
The bad part is that this scope isn't mine. I gotta save it at all costs.
The NOR flash dump, I have it here. A nice user sent it to me. But how to load it in NOR memory? I still haven't found a way to do that.
