Author Topic: DSOX2000 and 3000 series - licence , have anyone tried to hack that scope ?  (Read 1674808 times)
0 Members and 14 Guests are viewing this topic.
Offline onesystem
Looks like this post has somewhat of a hint on how to flash NOR... Check in that area and see if it leads you anywhere good.
Mine was a pure 3000A.
But without any previous erasures...  :)
Since sajsoni provided his MAC address, here is a FULL dump of the NOR mem for sajsoni to flash.
This includes all the bootloaders and the env. vars and the correct MAC address, as taken from a 3000A dump.
I think it can't get any simpler. Use the SPEAR600 app to flash only this file from offset 0.
Offline analogRF
this is way too early in the boot process. even pboot has not started, forget about WinCE and nk.nb0 and all of that.
To me looks like either a RAM issue or NOR flash.
i think there was a dump of NOR flash somewhere in the forum but I dont have it
does it stop there every time you power on? or does it go further randomly sometimes?
Unfortunately, stops every time
This must not be a RAM issue because it worked before. Yesterday I bricked the scope trying to update it. I selected a wrong file and goodbye scope.
The bad part is that this scope isn't mine. I gotta save it at all costs.
The NOR flash dump, I have it here. A nice user sent it to me. But how to load it in NOR memory? I still haven't found a way to do that.
if you have a .bin dump just desolder the chip and program it. that's what I'd do.
all bootloaders (uboot,pboot,xboot) are included in the FW file but I dont think you can construct the correct NOR flash image just by having those 3 files.
you need to have a clone image of the flash
« Last Edit: April 11, 2025, 01:19:47 am by analogRF »
Online Bud
I think you can,  see this post
https://www.eevblog.com/forum/testgear/dsox2000-and-3000-series-licence-have-anyone-tried-to-hack-that-scope/msg3801974/#msg3801974
Online Bud
You can do it using ST Spear600 Flasher Utility through the USB port, should still be available on ST web site.
Online Bud
U-Boot 2010.03 (Sep 09 2010 - 14:47:56)Agilent P500
CPU:   SPEAr600
DRAM:  128 MiB
Flash: 512 KiB
NAND:  128 MiB
In:    serial
Out:   serial
Err:   serial
SerNum:serial number not programmed
Chip:  BD Board Rev: 4
Net:   smsc
And the scope locks up.
I think you have a problem with FPGA initialization. After Net: smsc the scope tries to initialize the FPGA, and maybe failing because never even getting to it due to corrupt NOR or other reason. My this guess is also consistent with where boot stops when you trying to boot manually from USB port.
You should probably go ahead with flashing the NOR by either desoldering and using a programmer or in-place using ST Flasher Util. Normally if FPGA programming failed there is a message in the log saying this.
Online Bud
I showed here how to check FPGA image, before getting to reflashing the NOR. Also read the posts after it on that page.
https://www.eevblog.com/forum/blog/eevblog-978-keysight-1000x-hacking/msg5746541/#msg5746541
It was for the 1000 scope but should work for 2000, just use the right FPGA image length.
Offline analogRF
CPU:   SPEAr600
DRAM:  128 MiB
Flash: 512 KiB
NAND:  128 MiB
In:    serial
Out:   serial
Err:   serial
Net:   smsc
yes from his other longer boot log I suspected the FPGA but in the normal UART boot log there is no message about FPGA yet
and FPGA failure normally does not stop the boot at that point. It goes on further and you can even stop autoboot and get into prompt and program the FPGA manually from a good copy and then proceed to normal recovery procedure. In his case there is still no message about FPGA and the process stops that's why I think Flash is more likely
But you are right this stopping point is just before the FPGA programming being done.
Offline tabajaralabs
  • Country: br
    • Tabajara Labs
Ok, reloaded the FPGA code with the FPGA2000A.BIN file. Size was the same.
Now boot works like this:
Windows CE Kernel for ARM (Thumb Enabled) Built on Jun 16 2009 at 10:08:15
Setting up for a Cold Reboot
Done Setting up for a Cold Reboot
Windows CE Firmware Init
BSP 1.0.0 for the SPEARHEAD600AB board (built Jan 13 2011)
Adaptation performed by ADENEO (c) 2005
+OALIntrInit
-OALIntrInit(rc = 1)
Initialize driver globals Zeros area...
pDrvGlobalArea 0xa0060000  size 0x800 (0xa0060800 -0xa0060000)
Initialize driver globals Zeros area...done
 OALKitlStart
Firmware Init Done.
OALIoctlHalEnterI2cCriticalSection init i2c cs
Exception 'Data Abort'(4) Thread-Id=00570002(pth=87fdd9cc) PC=8036b6fc BVA=00000
003, dwInfo = 00000001
 R0=84973960  R1=000006a0  R2=815a6a60  R3=00000020
 R4=00001000  R5=84973000  R6=00000004  R7=815a6a60
 R8=815a6238  R9=00000000 R10=00000000 R11=00000000
R12=00000000  SP=d00afe44  Lr=8036b45c Psr=2000001f
Exception 'Data Abort'(4) Thread-Id=00570002(pth=ffffc65c) PC=8038dc10 BVA=00000
 R0=815aa520  R1=00000001  R2=ffffffff  R3=815aa468
 R4=03f3f000  R5=83f3f000  R6=83f3f000  R7=d00afe64
 R8=d00afe60  R9=00000000 R10=00000000 R11=00000000
R12=8038db98  SP=ffffc7ac  Lr=8038dbec Psr=80000013
Exception 'Data Abort' (4): Thread-Id=00570002(pth=87fdd9cc), Proc-Id=00400002(p
prc=815a8308) 'NK.EXE', VM-active=01e00002(pprc=87f53000) 'udevice.exe'
PC=8038dc10(kernel.dll+0x0001bc10) RA=8038dbec(kernel.dll+0x0001bbec) SP=ffffc7a
c, BVA=00000000
Exception 'Data Abort'(4) Thread-Id=014c0002(pth=87f76000) PC=8038fd64 BVA=00000
 R0=00000000  R1=87f76000  R2=6000001f  R3=ffffc800
 R4=815aa704  R5=7fff0000  R6=00000000  R7=00000000
 R8=00100000  R9=d02be740 R10=d0292980 R11=00000000
R12=8038fd64  SP=d02be4e4  Lr=8038fd64 Psr=6000001f
Exception 'Data Abort'(4) Thread-Id=014c0002(pth=ffffc46c) PC=8038d5d0 BVA=00000
 R0=83f3f000  R1=00000001  R2=ffffffff  R3=815aa468
 R4=83f3f000  R5=00000000  R6=00000001  R7=815aa704
 R8=d05726a0  R9=00000001 R10=00000004 R11=00000000
R12=8038d504  SP=ffffc5bc  Lr=ffffc800 Psr=80000013
Exception 'Data Abort' (4): Thread-Id=014c0002(pth=87f76000), Proc-Id=00400002(p
prc=815a8308) 'NK.EXE', VM-active=00400002(pprc=815a8308) 'NK.EXE'
PC=8038d5d0(kernel.dll+0x0001b5d0) RA=ffffc800(???+0xffffc800) SP=ffffc5bc, BVA=
00000000
Exception 'Data Abort'(4) Thread-Id=00f30006(pth=8694a9e4) PC=8038fd64 BVA=00000
 R0=00000000  R1=8694a9e4  R2=6000001f  R3=ffffc800
 R4=815aa704  R5=7fff0000  R6=00000001  R7=0000fffe
 R8=00000001  R9=002a0000 R10=00000000 R11=00000000
R12=8038fd64  SP=d072fe20  Lr=8038fd64 Psr=6000001f
Exception 'Data Abort'(4) Thread-Id=00f30006(pth=ffffc27c) PC=8038d5d0 BVA=00000
 R8=00000000  R9=00000001 R10=00000000 R11=00000000
R12=8038d504  SP=ffffc3cc  Lr=ffffc800 Psr=80000013
Exception 'Data Abort' (4): Thread-Id=00f30006(pth=8694a9e4), Proc-Id=00400002(p
PC=8038d5d0(kernel.dll+0x0001b5d0) RA=ffffc800(???+0xffffc800) SP=ffffc3cc, BVA=
00000000
I *STILL* cannot boot automatically. If I turn off and on the scope, the same happens:
U-Boot 2010.03 (Oct 18 2011 - 14:28:06)Agilent P500
CPU:   SPEAr600
DRAM:  128 MiB
Flash: 512 KiB
NAND:  fsmc-ecc1 128 MiB
In:    serial
Out:   serial
Err:   serial
Net:   smsc
Then, if I go to the USB serial channel and type BOOT, the boot starts and stops on these lots of exception errors.
Did I went forward?
Thanks you all for all the support, recovering this scope is VERY important to me
  • Country: br
    • Tabajara Labs
If I load NK.NB0 via
TFTPBOOT 0x0361000 NK.NB0
GO 0x0362000
I get the following result
Windows CE Kernel for ARM (Thumb Enabled) Built on Mar  8 2013 at 17:05:33
BSP 1.0.0 for the SPEARHEAD600AB board (built Jan 23 2024)
+OALIntrInit
 OALKitlStart
Firmware Init Done.
++SER_Init: context Drivers\Active\14
SER_Init, dwIndex:2
SER2 got sysintr:0x00000017
SER2 Serial Port, new baud rate:0x1c200  (UARTCLK:48000000 IBRD:0x1a FBRD:0x2)
OHCI\system.c, GCFG_USBH1_SW_RST
OHCI\system.c, GCFG_USBH2_SW_RST
Exception 'Data Abort'(4) Thread-Id=00580002(pth=87fdaa8c) PC=80378630 BVA=00000
 R0=849af730  R1=00000000  R2=00000000  R3=00000000
 R4=849af000  R5=81e3a454  R6=81e3a624  R7=00000000
 R8=00000000  R9=00000000 R10=00000000 R11=00000000
R12=00000000  SP=d00afe60  Lr=8038e4e0 Psr=0000001f
Exception 'Data Abort'(4) Thread-Id=00580002(pth=ffffc654) PC=8038e468 BVA=00000
 R0=81e3a520  R1=00000001  R2=ffffffff  R3=81e3a468
 R4=03f44000  R5=83f44000  R6=83f44000  R7=d00afe60
 R8=d00afe64  R9=00000000 R10=00000000 R11=00000000
R12=8038e3f0  SP=ffffc7a4  Lr=8038e444 Psr=80000013
Exception 'Data Abort' (4): Thread-Id=00580002(pth=87fdaa8c), Proc-Id=00400002(p
prc=81e38308) 'NK.EXE', VM-active=018c0002(pprc=87fc8eac) 'udevice.exe'
PC=8038e468(kernel.dll+0x0001c468) RA=8038e444(kernel.dll+0x0001c444) SP=ffffc7a
4, BVA=00000000
Exception 'Data Abort'(4) Thread-Id=00580002(pth=87fdaa8c) PC=8038e9f4 BVA=00000
 R0=00000001  R1=00000000  R2=000061af  R3=81e4006e
 R4=00000037  R5=81e3a520  R6=00003fff  R7=81e38010
 R8=00000004  R9=ffffffff R10=81e38308 R11=000000fb
R12=00580003  SP=ffffbd10  Lr=8038e9a8 Psr=8000001f
Exception 'Data Abort'(4) Thread-Id=00580002(pth=ffffc464) PC=8038de34 BVA=00000
 R0=83f44000  R1=00000001  R2=ffffffff  R3=81e3a468
 R4=83f44000  R5=00000000  R6=00000001  R7=81e3a704
 R8=84c5cb80  R9=00000001 R10=81e38308 R11=81e39dd0
R12=8038dd68  SP=ffffc5b4  Lr=ffffc800 Psr=80000013
PC=8038de34(kernel.dll+0x0001be34) RA=ffffc800(???+0xffffc800) SP=ffffc5b4, BVA=
00000000
Exception 'Data Abort'(4) Thread-Id=00580002(pth=87fdaa8c) PC=80386228 BVA=00000
030, dwInfo = 00000007
 R0=00000000  R1=00000000  R2=0000001b  R3=0000000b
 R4=00000004  R5=81e3a704  R6=81e38308  R7=00000001
 R8=00000003  R9=81e3a704 R10=04eb0000 R11=83080000
R12=00580003  SP=ffffc194  Lr=80386228 Psr=4000001f
Exception 'Data Abort'(4) Thread-Id=00580002(pth=87fdaa8c) PC=803789e4 BVA=00000
057, dwInfo = 00000007
R12=00580003  SP=ffffc104  Lr=80386228 Psr=4000001f
Exception 'Data Abort'(4) Thread-Id=00580002(pth=ffffc26c) PC=8037fbd8 BVA=00000
 R0=87f7c444  R1=ffffc800  R2=00000004  R3=00000000
 R4=87f7c444  R5=81e3a704  R6=81e3a660  R7=00000000
 R8=00000001  R9=81e3a704 R10=04eb0000 R11=83080000
R12=00000000  SP=ffffc3bc  Lr=8037600c Psr=60000013
024, dwInfo = 00000007
Exception 'Data Abort'(4) Thread-Id=00580002(pth=ffffc000) PC=8037ea4c BVA=00000
 R0=00000004  R1=00000000  R2=87fffe98  R3=00000004
 R4=8037600c  R5=00000004  R6=87fdaa8c  R7=81e3a4b8
 R8=00000000  R9=ffffc800 R10=ffffc1e8 R11=8037fbd8
R12=00580003  SP=ffffc150  Lr=8037ea34 Psr=60000013
Exception 'Data Abort'(4) Thread-Id=00580002(pth=ffffbd94) PC=8037ea4c BVA=00000
 R4=8037ea34  R5=00000004  R6=87fdaa8c  R7=81e3a4b8
 R8=00000000  R9=ffffc800 R10=ffffbf7c R11=8037ea4c
R12=00580003  SP=ffffbee4  Lr=8037ea34 Psr=60000013
Exception 'Data Abort'(4) Thread-Id=00580002(pth=ffffbb28) PC=8037ea4c BVA=00000
 R8=00000000  R9=ffffc800 R10=ffffbd10 R11=8037ea4c
R12=00580003  SP=ffffbc78  Lr=8037ea34 Psr=60000013
Exception 'Data Abort'(4) Thread-Id=00580002(pth=ffffb8bc) PC=8037ea4c BVA=00000
 R8=00000000  R9=ffffc800 R10=ffffbaa4 R11=8037ea4c
R12=00580003  SP=ffffba0c  Lr=8037ea34 Psr=60000013
Exception 'Data Abort'(4) Thread-Id=00580002(pth=ffffb650) PC=8037ea4c BVA=00000
 R8=00000000  R9=ffffc800 R10=ffffb838 R11=8037ea4c
R12=00580003  SP=ffffb7a0  Lr=8037ea34 Psr=60000013
Exception 'Data Abort'(4) Thread-Id=00580002(pth=ffffb3e4) PC=8037ea4c BVA=00000
 R8=00000000  R9=ffffc800 R10=ffffb5cc R11=8037ea4c
R12=00580003  SP=ffffb534  Lr=8037ea34 Psr=60000013
ExceptException 'Data Abort'(4) Thread-Id=00580002(pth=87fdaa8c) PC=803789e4 BVA
=ffff105c, dwInfo = 00000007
Exception 'Data Abort'(4) Thread-Id=00580002(pth=ffff0e98) PC=80378484 BVA=ffff1
 R0=ffff105c  R1=00000004  R2=60000093  R3=ffffc800
 R4=81e36ae0  R5=000001af  R6=00000000  R7=00000001
 R8=81e366ac  R9=81e36724 R10=000001af R11=80368b00
R12=8037dfbc  SP=ffff0fe8  Lr=8036bf54 Psr=60000093
Exception 'Data Abort'(4) Thread-Id=00580002(pth=ffff0c2c) PC=8037ea4c BVA=00000
 R0=00000004  R1=00000000  R2=803736f8  R3=00000004
 R4=8036bf54  R5=00000004  R6=87fdaa8c  R7=81e3a4b8
 R8=00000000  R9=ffffc800 R10=ffff0e14 R11=80378484
R12=00580003  SP=ffff0d7c  Lr=8037ea34 Psr=60000093
Exception 'Data Abort'(4) Thread-Id=00580002(pth=ffff09c0) PC=8037ea4c BVA=00000
 R8=00000000  R9=ffffc800 R10=ffff0ba8 R11=8037ea4c
R12=00580003  SP=ffff0b10  Lr=8037ea34 Psr=60000093
Exception 'Data Abort'(4) Thread-Id=00580002(pth=ffff0754) PC=8037ea4c BVA=00000
 R8=00000000  R9=ffffc800 R10=ffff093c R11=8037ea4c
R12=00580003  SP=ffff08a4  Lr=8037ea34 Psr=60000093
Exception 'Data Abort'(4) Thread-Id=00580002(pth=ffff04e8) PC=8037ea4c BVA=00000
 R8=00000000  R9=ffffc800 R10=ffff06d0 R11=8037ea4c
R12=00580003  SP=ffff0638  Lr=8037ea34 Psr=60000093
 |O
Please note where the exceptions begins... OHCI/System.c - USB initialization. Maybe a problemm with the pendrive I made? Of course, I got a NEW 4GB Pen Drive from Sandisk, same error. Maybe the structure is somewhat wrong? I did it just like https://salvagedcircuitry.com/2000a-nand-recovery.html site
UPDATE: If I plug the USB pen drive off, no errors beyond the OHCI\System.C lines:
+OALIntrInit
 OALKitlStart
Firmware Init Done.
SER_Init, dwIndex:2
-EDeviceLoadEeprom 00:30:D3:14:9C:AE
Phy found addr 31 (ticks=3199)
WaitForLink Start (ticks=3201)
Link Detected (ticks=3203)
 GMAC Init : 100 Mbit/s FULL DUPLEX (MII)
Flushed Transmit Buffer
phyCfg->dwSpeed 0x64
phyCfg->bFullDuplex 0x1
<--EDeviceInitialize
GMAC DMA status register = 0x600004
GMAC Device enable interrupt
DriverStart
LIN: Data Valid
BALDWIN_DDI: cBaldwinHwIf::Init: Initializing...
BALDWIN_DDI: cBaldwinHwIf::Init: Scope successfully identified.
« Last Edit: April 11, 2025, 03:11:17 am by tabajaralabs »
Online Bud
Man, i am totally lost with you starting the scope and getting something on the UART port, then switching to USB serial to type "boot", and with some USB pen drive plugged in (to where?). Can you get rid of the damn pen drive and just stick to normal boot, i also having problems understanding why you are using the internal UART and USB at the same time. What is going on here?
Online Bud
How did you reload? What does that mean size was the same, the same as what?
  • Country: br
    • Tabajara Labs
Ok, sorry. Here we go.
Internal UART, turn the scope on:
CPU:   SPEAr600
DRAM:  128 MiB
Flash: 512 KiB
In:    serial
Out:   serial
Err:   serial
Net:   smsc
No prompt, no nothing. This is what appears, I can do nothing beyond that. If I turn it off, on again, that is what happens.
Online Bud
And then input/output switches itself to the USB port? Is this why you from this point use USB console?
  • Country: br
    • Tabajara Labs
Yes. I can only access the p500> prompt and enter commands if I use the USB B port on the back of the scope. Even if in the boot appears the in/out/err with serial besides it:
CPU:   SPEAr600
DRAM:  128 MiB
Flash: 512 KiB
In:    serial
Out:   serial
Err:   serial
Net:   smsc
Offline onesystem
Maybe it will help if you tell us what exactly you loaded into that scope, and which way it was done (via regular update function, or using some other method)
  • Country: br
    • Tabajara Labs
A long time ago, when the 2.41 patched firmware was released, I created a package with 3 files - the patched firmware, the "v241 link install" and the remote front panel cab
I was tired, installed the second file (v241 link install) instead of the first file (the complete patched firmware) via file explorer on scope.
Poof. There things went south :(
Online Bud
CPU:   SPEAr600
DRAM:  128 MiB
Flash: 512 KiB
In:    serial
Out:   serial
Err:   serial
Net:   smsc
This is weird, can’t remember this ever mentioned by anyone.
What do you get if enter printenv in p500.?
  • Country: br
    • Tabajara Labs
CPU:   SPEAr600
DRAM:  128 MiB
Flash: 512 KiB
In:    serial
Out:   serial
Err:   serial
Net:   smsc
Output from printenv:
p500> printenv
ramboot=dhcp 0x4000000 nk.bin;bootm 0xf8050000
baudrate=115200
usbtty=cdc_acm
splashdata=0xd0000000
dispParm1=0x300 0x400 0x2625A00 0x1 0x3
dispParm2=0x20 0x4c 0x1 0x2 0x3
boardversion=4
ps=0
rtc=0
erase_env=protect off 1:4;erase 1:4
store_uboot=protect off 1:1-3;erase 1:1-3;cp.b 0x800000 0xF8010000 ${filesize};protect on 1:1-3;imi 0xF8010000
get_uboot_eth=dhcp 0x800000 u-boot_image.bin;run store_uboot
get_uboot_uart=loadb 0x800000 115200;run store_uboot
serialnum=serial number not programmed
ethact=smsc
bootaddr=0x700
loadaddr=0x00800000
chipversion=BD
fpgadata=0xd0060000
pbootdelay=0
bootCeFlash=bootm 0xf8050000
uart2=115200
bootcmd=run keyrst;run bootCeFlash
keyrst=mw d8100400 6 1;mw d8100008 0 1;mw d8100008 2 1
infiniiVisionCabFile=
infiniiVisionHostname=
infiniiVisionNetworkAdapter=
infiniiVisionInstallStatus=installing cab file
fpgasize=0x45480
ethaddr=00:30:d3:14:9c:ae
preboot=set stdin usbtty;set stdout usbtty;set stderr usbtty
bootdelay=-1
bootfile=nk.nb0
filesize=1AC8668
blocksize=0x1ad0000
fileaddr=800000
gatewayip=192.168.0.1
netmask=255.255.255.0
serverip=192.168.0.200
dnsip=181.213.132.2
image2=0xd1600000
pimage=1
fimage=1
nimages=1
fsstart=0x2c00000
numfilesystems=1
lengthfilesystem1=0x5400000
lengthfilesystem2=0x0
image1=0xd0600000
image2=0xd1600000
verify=n
ipaddr=192.168.1.146
stdin=usbtty
stdout=usbtty
stderr=usbtty
Environment size: 1365/16380 bytes
p500>
Online Bud
Get rid of preboot variable, set stdin,stdout and stderr to serial, set bootdelay=3, then reboot and watch the output on the UART. Your scope is currently switching to USB console at some point and you may be missing some error messages while your computer USB connection is enumerated.
  • Country: br
    • Tabajara Labs
Ok, thanks for the tip. Now it boots as before (turn on, UART activity, buttons flash on front).
I used the pendrive + NK.NB0 from version 2.43 as before.
bootp 0x0361000 nk.nb0
(loads data thru network)
go 0x0362000
Log:
## Starting application at 0x00362000 ...
+OALIntrInit
 OALKitlStart
Firmware Init Done.
SER_Init, dwIndex:2
Exception 'Data Abort'(4) Thread-Id=00580002(pth=87fdaa8c) PC=80378628 BVA=00000003, dwInfo = 00000001
 R0=84999a10  R1=00000000  R2=00000000  R3=00000000
 R4=84999000  R5=81e3a454  R6=81e3a624  R7=00000000
Exception 'Data Abort'(4) Thread-Id=00580002(pth=ffffc654) PC=8038e468 BVA=00000003, dwInfo = 00000001
 R4=03f3f000  R5=83f3f000  R6=83f3f000  R7=d00afe60
Exception 'Data Abort' (4): Thread-Id=00580002(pth=87fdaa8c), Proc-Id=00400002(pprc=81e38308) 'NK.EXE', VM-active=018c0002(pprc=87fc8eac) 'udevice.exe'
PC=8038e468(kernel.dll+0x0001c468) RA=8038e444(kernel.dll+0x0001c444) SP=ffffc7a4, BVA=00000000
Exception 'Data Abort'(4) Thread-Id=00580002(pth=87fdaa8c) PC=8038ead8 BVA=00000003, dwInfo = 00000001
 R0=00000001  R1=00000000  R2=000061af  R3=0000ffff
 R4=000012d4  R5=81e3a520  R6=00003fff  R7=81e38010
R12=00580003  SP=ffffbd10  Lr=8038e9a8 Psr=2000001f
Exception 'Data Abort'(4) Thread-Id=00580002(pth=ffffc464) PC=8038de34 BVA=00000003, dwInfo = 00000001
 R0=83f3f000  R1=00000001  R2=ffffffff  R3=81e3a468
 R4=83f3f000  R5=00000000  R6=00000001  R7=81e3a704
 R8=84c44b80  R9=00000001 R10=81e38308 R11=81e39dd0
PC=8038de34(kernel.dll+0x0001be34) RA=ffffc800(???+0xffffc800) SP=ffffc5b4, BVA=00000000
Exception 'Data Abort'(4) Thread-Id=00580002(pth=87fdaa8c) PC=80386228 BVA=00000030, dwInfo = 00000007
Exception 'Data Abort'(4) Thread-Id=00580002(pth=87fdaa8c) PC=803789e4 BVA=00000057, dwInfo = 00000007
Exception 'Data Abort'(4) Thread-Id=00580002(pth=ffffc26c) PC=8037fbd8 BVA=00000057, dwInfo = 00000007
Exception 'Data Abort'(4) Thread-Id=00580002(pth=87fdaa8c) PC=803789e4 BVA=00000024, dwInfo = 00000007
Exception 'Data Abort'(4) Thread-Id=00580002(pth=ffffc000) PC=8037ea4c BVA=00000024, dwInfo = 00000007
Exception 'Data Abort'(4) Thread-Id=00580002(pth=ffffbd94) PC=8037ea4c BVA=00000024, dwInfo = 00000007
Exception 'Data Abort'(4) Thread-Id=00580002(pth=ffffbb28) PC=8037ea4c BVA=00000024, dwInfo = 00000007
Exception 'Data Abort'(4) Thread-Id=00580002(pth=ffffb8bc) PC=8037ea4c BVA=00000024, dwInfo = 00000007
Exception 'Data Abort'(4) Thread-Id=00580002(pth=ffffb650) PC=8037ea4c BVA=00000024, dwInfo = 00000007
Exception 'Data Abort'(4) Thread-Id=00580002(pth=ffffb3e4) PC=8037ea4c BVA=00000024, dwInfo = 00000007
ExceptionException 'Data Abort'(4) Thread-Id=00580002(pth=87fdaa8c) PC=803789e4 BVA=ffff105c, dwInfo = 00000007
Exception 'Data Abort'(4) Thread-Id=00580002(pth=ffff0e98) PC=80378484 BVA=ffff105c, dwInfo = 00000007
Exception 'Data Abort'(4) Thread-Id=00580002(pth=ffff0c2c) PC=8037ea4c BVA=00000024, dwInfo = 00000007
Exception 'Data Abort'(4) Thread-Id=00580002(pth=ffff09c0) PC=8037ea4c BVA=00000024, dwInfo = 00000007
Exception 'Data Abort'(4) Thread-Id=00580002(pth=ffff0754) PC=8037ea4c BVA=00000024, dwInfo = 00000007
Exception 'Data Abort'(4) Thread-Id=00580002(pth=ffff04e8) PC=8037ea4c BVA=00000024, dwInfo = 00000007
  • Country: br
    • Tabajara Labs
Just out of curiosity, I tried booting with the pendrive + Nk.NB0 file generated from version 1.10.2011031600 which is the lowest version I could find (and the original software of the scope was an even lower version). Here is the log:
BSP 1.0.0 for the SPEARHEAD600AB board (built Mar 16 2011)
+OALIntrInit
 OALKitlStart
Firmware Init Done.
Exception 'Data Abort'(4) Thread-Id=00570002(pth=87fdd9cc) PC=8036b6f8 BVA=00000003, dwInfo = 00000001
 R0=84955520  R1=00000ae0  R2=815a6a60  R3=00000020
 R4=00001000  R5=84955000  R6=00000004  R7=815a6a60
Exception 'Data Abort'(4) Thread-Id=00570002(pth=ffffc65c) PC=8038dc10 BVA=00000003, dwInfo = 00000001
Exception 'Data Abort' (4): Thread-Id=00570002(pth=87fdd9cc), Proc-Id=00400002(pprc=815a8308) 'NK.EXE', VM-active=01e00002(pprc=87f52000) 'udevice.exe'
PC=8038dc10(kernel.dll+0x0001bc10) RA=8038dbec(kernel.dll+0x0001bbec) SP=ffffc7ac, BVA=00000000
Exception 'Data Abort'(4) Thread-Id=014c0002(pth=87f76000) PC=8038fd64 BVA=00000003, dwInfo = 00000001
 R8=00100000  R9=d02be740 R10=d02a4220 R11=00000000
Exception 'Data Abort'(4) Thread-Id=014c0002(pth=ffffc46c) PC=8038d5d0 BVA=00000003, dwInfo = 00000001
 R8=80375708  R9=00000001 R10=00000004 R11=00000000
Exception 'Data Abort' (4): Thread-Id=014c0002(pth=87f76000), Proc-Id=00400002(pprc=815a8308) 'NK.EXE', VM-active=00400002(pprc=815a8308) 'NK.EXE'
PC=8038d5d0(kernel.dll+0x0001b5d0) RA=ffffc800(???+0xffffc800) SP=ffffc5bc, BVA=00000000
Exception 'Data Abort'(4) Thread-Id=00f30006(pth=868f7a08) PC=8038fd64 BVA=00000003, dwInfo = 00000001
 R0=00000000  R1=868f7a08  R2=6000001f  R3=ffffc800
Exception 'Data Abort'(4) Thread-Id=00f30006(pth=ffffc27c) PC=8038d5d0 BVA=00000003, dwInfo = 00000001
Exception 'Data Abort' (4): Thread-Id=00f30006(pth=868f7a08), Proc-Id=00400002(pprc=815a8308) 'NK.EXE', VM-active=00400002(pprc=815a8308) 'NK.EXE'
PC=8038d5d0(kernel.dll+0x0001b5d0) RA=ffffc800(???+0xffffc800) SP=ffffc3cc, BVA=00000000
Online Bud
Man, just post the log as it is , without interjecting. Does the scope now spit everything to UART console after you set input/output?
  • Country: br
    • Tabajara Labs
Yes, now the scope directs all info to serial port. And the logs are as is, I just copied from the teraterm output and pasted here. Anything else I should do?
Online Bud
Where is the start part before it gets to p500 prompt. Do you still interrupt the boot to get to the prompt or does the scope stops by itself, which it should not if you changed the bootdelay variable. I want to see everything from the moment you turn the scope on, no pressing Cal buttons, no hitting space bar, no pen drive. Just let it roll.
Offline analogRF
no it cannot be like that. the normal UART boot log does not look like the last post.
you should not have played with the env vars. you have to go back to exactly the stock env vars before any change whatsoever and let the UART
do its thing without ANY interruption, no USB memory, no USB connection, no key press nothing at all.
but the env vars need to be restored to their original stock content.
