My DSOX2022a was working normally, but after not using it for three or four days, when I turned it on yesterday, it repeatedly cycled through restarts. Following the methods suggested by some experts, I used a USB-TTL converter and received the following information:
U-Boot 2010.03 (Jan 26 2011 - 12:37:34)Agilent P500
CPU: SPEAr600
DRAM: 128 MiB
Flash: 512 KiB
NAND: 128 MiB
In: serial
Out: serial
Err: serial
SerNum:serial number not programmed
Chip: BD Board Rev: 4
Net: smsc
Press space to stop autoboot: 0
## Booting kernel from Legacy Image at f8050000 ...
Image Name: PBOOT
Created: 2011-01-27 11:38:14 UTC
Image Type: ARM Linux Kernel Image (gzip compressed)
Data Size: 36703 Bytes = 35.8 KiB
Load Address: 00000000
Entry Point: 00000000
Uncompressing Kernel Image ... OK
Starting kernel ...
Debug serial initialized ........OK
Microsoft Windows CE Bootloader Common Library Version 1.4 Built Jan 27 2011 02:04:15
Microsoft Windows CE 6.0 Ethernet Bootloader for the Agilent P500 board
Adaptation performed by Agilent Technologies (c) 2008
System ready!
Preparing for download...
Loading image 1 from memory at 0xD0600000
O
BL_IMAGE_TYPE_BIN
X
XXXXXOOOOXOOOOOOOOXOXOOOOOOOOXOOOXOOOOXXOOOOOOOOOXOOOOXOXOXXXOOXOXXOXXXXXXOOOXXXOOOOOXOOXOXXXOOOXXOOOXXOOOOXOOXOOXXOOOXOOOOOXOOOXOOOXXXXXXOXOXXOXXXXXXXOXXXXOOOXOOOOXOXOOOXOOOOXOXOXOOOOOOXOOOOXOXOOOOOXXOOOOOXX
OOOOXXOOOOOOOOOXOXOOOXOOOOOOOXXOOOOOXXOOOOXOXOXOOXOXOOOXOOOXOOOXXXOXOOOXOXXXXOXOOXXOXXOXXOOOXXOXOXXOXXXXXOOXOXXXXOXOOXOXOOOOXOOOOXOOOXOOXOOXOOOXOOXXXXXXXXXXXXXXOXrom_offset=0x0.
XXImageStart = 0x80361000, ImageLength = 0x1248684, LaunchAddr = 0x80362000
Completed file(s):
[0]: Address=0x80361000 Length=0x1248684 Name="" Target=RAM
Loading image 1 succeeded.
ROMHDR at Address 80361044h
Preparing launch...
Launching windows CE image by jumping at address 0x 362000
Windows CE Kernel for ARM (Thumb Enabled) Built on Jun 16 2009 at 10:08:15
Setting up for a Cold Reboot
Done Setting up for a Cold Reboot
Windows CE Firmware Init
BSP 1.0.0 for the SPEARHEAD600AB board (built Apr 18 2012)
Adaptation performed by ADENEO (c) 2005
+OALIntrInit
-OALIntrInit(rc = 1)
Initialize driver globals Zeros area...
pDrvGlobalArea 0xa0060000 size 0x800 (0xa0060800 -0xa0060000)
Initialize driver globals Zeros area...done
OALKitlStart
Firmware Init Done.
OALIoctlHalEnterI2cCriticalSection init i2c cs
-EDeviceLoadEeprom 00:30:D3:20:D6:E4
Phy found addr 31 (ticks=2783)
WaitForLink Start (ticks=2784)
No Link (ticks=3787)
<--EDeviceInitialize
GMAC DMA status register = 0x0
BALDWIN_DDI: cBaldwinHwIf::Init: Initializing...
BALDWIN_DDI: cBaldwinHwIf::Init: Scope successfully identified.
BALDWIN_DDI: cBaldwinHwIf::Init: Success!
Running infiniiVisionInstallHelper
Failed to start/configure network.
Starting ProcessStartupFolder
running \Secure\Startup\infiniivision.lnk...
Ending ProcessStartupFolder
Before P/Invoke
Exception 'Data Abort' (4): Thread-Id=03530006(pth=837d0a5c), Proc-Id=03500006(pprc=837d0744) 'infiniivisionLauncher.exe', VM-active=03500006(pprc=837d0744) 'infiniivisionLauncher.exe'
PC=411b4c8c(infiniivisioncore.dll+0x004a4c8c) RA=411b5454(infiniivisioncore.dll+0x004a5454) SP=0002f200, BVA=10da7470
The exception 0xC0000005 occurred at address 0x411B4C8C
I created nk.nb0 using nkbintools, and then executed the command `p500> loady 0x0361000 115200`.In Tera Term go to File-> Transfer-> YMODEM->Send... and open the nk.nb0 that you have prepared beforehand. I couldn't upload the file. After a few dozen seconds, the upload interface disappeared. I tried several times, but the result was always the same.
