Author Topic: Dual impedance multimeter recommendations?  (Read 17137 times)
Offline rauldmTopic starter
  • Country: mx
« on: July 27, 2019, 02:04:14 am »
I need a meter with LoZ impedance, I have the 289, but I need another, my options are the Fluke 117 or GreenLee DM-830A. I know the greenlee is a brymen. I have another amprobe and keysigth meters, but the performance is not sorprendent like  the my Flukes. For example my U1282A, the bar graph when I work with Ohms is more slow than my Flukes, the bar graph performance in the u1282a only detects clicks on 40 Hz update mode. My Fluke 87V even on hi-res mode the bar graph is fast. Really brymen meters are fast? the money difference between Fluke 117 and DM-830A is not important, but DM-830A it has a interesting LoZ mode, for example, the LoZ for Fluke is 3 kOhms, for keysight is 2 kOhms up to 600 V for both, the brymen change the input impedance from 3 kOhms to 460 kOhms for 1000 V, sounds good but, is functional? the brymen responce is really more fast to Fluke 117? Regards.
Offline MarkF
Re: Dual impedance multimeter recommendations?
« Reply #1 on: July 27, 2019, 02:33:18 am »
+1 for the Fluke 117.
I have both a Fluke 117 and a Fluke 87V.  As far as the bar graph and other responsiveness, both Flukes are about the same.
Since you have a 87V, you can expect the Fluke 117 to be similar to the 87V as a comparison.
The following users thanked this post: rauldm
  • Country: mx
« Reply #2 on: July 27, 2019, 02:51:31 am »
Are you using the LoZ mode in your 117? I had a good experience with this function in my 289. Therefore I need another meter with this function, is essential on electrical installations. You can solve some problems on control area with this feature.  8)
The following users thanked this post: Marco1971
Offline MarkF
« Reply #3 on: July 27, 2019, 03:32:38 am »
I rarely use the LoZ mode.
However, I did just use it this week repairing a stove.
The 117 was showing a low AC voltage on normal AC V range with stove unplugged.
Switching to LoZ, it measured 0 VAC as expected.
Offline MarkF
« Reply #4 on: July 27, 2019, 04:07:02 am »
And, if you want to see inside:
Offline Fungus
« Reply #5 on: July 27, 2019, 10:05:50 am »
Yes.
Offline L_Euler
« Reply #6 on: July 27, 2019, 11:45:30 am »
Before i got a 289 I built a small adaptor box that was inserted between the probes and meter with a couple switchable resistors. (1000ohm, none, 10000ohm) and appropriate fusing for the resistor sizes.  It worked beautifully and was able to use with any multimeter.  I was checking a lot of PLC solid state outputs in industrial control systems.
« Last Edit: July 29, 2019, 11:17:01 am by L_Euler »
There's no point to getting old if you don't have stories.
  • Country: mx
« Reply #7 on: July 27, 2019, 09:02:57 pm »
Someone tested Auto-check on Brymen multimeters?
Offline Per Hansson
« Reply #8 on: July 27, 2019, 09:28:59 pm »
Before i got a 289 I built a small adaptor box that was inserted between the probes and meter with a couple switchable resistors. (100ohm, none, 1000ohm) and appropriate fusing for the resistor sizes.  It worked beautifully and was able to use with any multimeter.  I was checking a lot of PLC solid state outputs in industrial control systems.
Fluke does sell such an adapter, I use it myself and it works fine.
Of course it would be surprising if a resistor in a plastic box did not work well ;)
https://www.fluke.com/en-us/product/accessories/adapters/fluke-sv225
The following users thanked this post: 001, rauldm
Offline Electro Detective
« Reply #9 on: July 28, 2019, 12:00:09 am »
If you don't need the features and price of the 117, I can vouch the 114 does a good enough job in Low-Z as the 289.
The 114 is my go to 'idiot' meter, it has no current inputs or fuses to think about
and good enough for quickie troubleshoots
They go cheap used, people sell them off to upgrade to feature filled 117, 87V, Brymen, Keysights, etc
and miss the point of a simple meter with the basics Low-Z, AC, DC, Min Max, Ohms/Buzzer
and according to Mr. Smith's exhaustive tests, a fair 'resistance' to ESD styled  -BANGS!-   :o
fwiw I can be 'less careful' with using both the 114 and non Low-Z 101, flanked by two clamp meters,
gloves, glasses, rubber boots, diligence...  :D
and so far they've kept my pocket healthy
FYI for battlers that just want an entry level 'LOW-Z' capable meter that's affordable, and worked well for me before the Flukes rocked up, the Klein CL3200 won't break the bank,
and came with a nice zippered pouch, great leads and croc/alli adapters.
Still have it, doing tool box #3 duty nowadays   :clap:
« Last Edit: July 28, 2019, 12:03:52 am by Electro Detective »
  • Country: mx
« Reply #10 on: July 28, 2019, 02:53:08 am »
Really this adapter is good option for me, I can put in every meters,  thanks for the answer. I think with the price this adapter and the 117 I would buy the Brymen, but I have more Fluke products and accesorys.
  • Country: mx
« Reply #11 on: July 28, 2019, 02:57:27 am »
In my country for some reason, the Fluke 117 is more popular than Fluke 114, I can find for the same price even new. Thanks for your answer.
« Reply #12 on: July 28, 2019, 10:53:52 am »
The Fluke Low-Z adapter was expensive for a 3k resistor so I just bought a new Klein CL3200 and a used 114 for the same 'boutique 3K resistor' money   :clap:
DIY adapter was an option too, so was laziness  ;D
Besides, I'd rather have the CAT ratings intact with a purpose built and rated Low-Z meter, rather than have addons
fwiw be careful as Low-Z mode can sometimes bring on BANGS!
and guaranteed RCD/GFCI trips
Offline Neomys Sapiens
« Reply #13 on: July 29, 2019, 05:00:30 pm »
If you consider buying used, there is also the Metrahit12/14 from GMC (look for a thread named 'show your multimeter', there you can see mine.)
Also, some of the newer GMC multimeters have such a feature.
« Reply #14 on: August 02, 2019, 11:03:45 pm »
FWIW: Here's cool brief PDF info sheet from Fluke that sold me to get a Low-Z 'Ghost Buster'  meter :scared:  (or two.. :-[)
Dual impedance digital multimeters— What's the point?
support.fluke.com/find-sales/Download/Asset/2718074_6116_ENG_A_W.PDF
Offline SG-1
« Reply #15 on: August 03, 2019, 12:35:33 am »
Fluke also offers the SV225,but you can buy an off brand meter for the same price.
Advice is a dangerous gift, even from the wise to the wise.
« Reply #16 on: August 06, 2019, 09:30:08 am »
For the money Fluke charge on long running money for jam flagship meters,
the encased boutique 3000 ohm resistor should be chucked in as a freebie  :popcorn:
« Last Edit: August 06, 2019, 10:20:31 am by Electro Detective »
Offline 001
  • Country: aq
« Reply #17 on: August 06, 2019, 10:32:49 am »
Can anybody told me why 3kOhm Fluke addon rated to 1000V? http://assets.fluke.com/manuals/sv225___iseng0000.pdf
It is only resistor, isnt`it? And by Ohm law  it must be heated with 333watts  :-//
Offline 2N3055
  • Country: hr
« Reply #18 on: August 06, 2019, 03:16:19 pm »
It is not a resistor.
It is a PTC, that heats up and increases resistance in few milliseconds... So current drops considerably...
Dr. Richard W. Hamming
Offline 001
  • Country: aq
« Reply #19 on: August 06, 2019, 05:41:47 pm »
Thanx a lot!
But why 3kOhm? 3kOhm at what voltage?  :-// How to clone it properly? Is simple 10kOhm resistor will work same way at 0-30V?
« Reply #20 on: August 06, 2019, 11:10:05 pm »
If the Fluke adaptor in question is the 'stray voltage test leads' that came with the original 27 (AN/PSM-45A), it was not a resistor, but a PTC thermistor.
The following users thanked this post: Electro Detective, umbro
« Reply #21 on: August 06, 2019, 11:45:33 pm »
So is that what they also use in the 114 to 117 series and Fluke 289?  :-//
IIRC they show up as 3K when tested with another meter's resistance range (in lazy Auto mode)
Does a PTC register as 3K instantly, or sort of ramps up to that value once the heat is on? ( >:D)
Why not a monster 3K resistor with heatsink and one of those orange current protection thingies, rattling around in a fuglee box with sockets and flying leads
Anyone got one of these boutiquey black box Fluke SV225
and a knack for cracking it open without trashing it?
  • Country: mx
« Reply #22 on: August 07, 2019, 01:19:33 am »
Hi, I bought a new Fluke 117,  I tested with AC and DC voltage on LoZ mode, the input impedance change with increment of voltage, for example I tested with 133.8 Vac, neglecting capacitive or inductive effects, I have around 15.7 kOhm, input impedance, with 20 Vdc I have around 3.3 kOhms, is not single resistor. With suggest from Per Hansson, I researched about SV225, on youtube exists a tutorial for repair this unit, and shows a resistor and PTC. Thanks for contributions, I hope buy SV225 too.
  • Country: mx
« Reply #23 on: August 07, 2019, 01:37:23 am »
The ghost voltage is common on electrical control  installations, some weeks ago, I was repairing a control system with contactors and power electronics, I was with 289 and 376 fc, high impdeance mode on 289 and 376 fc show voltage,   I remmenber the LoZ mode on 289 and surprise, is not real tension, the meters only show coupled voltage for capacitive efect on the control lines near power lines.
The motive for this post was I would want have at least other meter with this feature, I bought the 117 yesterday, but I want have Lo Z on my others meters. Thanks for SV225  suggest.
Online HKJ
    • Tests
« Reply #24 on: August 07, 2019, 04:55:52 am »
A typical LowZ PTC impedance curve:
This curve is from a Fluke289, but other meters are similar.
The following users thanked this post: shakalnokturn
