1. Now load some version of the oscilloscope using loader 1.1.3. 0.26v7 - latest.
2. Turn on the oscilloscope, go to the menu and enable startup with options. (peco, FEL, Fnirsi)
3. Turn off and on the oscilloscope to save the changes.
4. Access the SD card and delete the directories and info_firmware.txt related to the firmware (delete the directories that have firmware in the name)
5. Using loader 1.1.3, only UPDATER_1013d.bin is loaded and nothing else. {{But it is necessary to have PECO in the firmware, enabled start with the selection of startup options (peco, FEL, Fnirsi) we did this, see step 2}}
6. After turning on the oscilloscope, select the UPDATE option.
7. The oscilloscope will create folders and a txt file.
8. Press USB off - it will turn green, copy scope.bin to the SD card folder (Atlan & PECO firmware).
9. Correctly remove the disk through the Windows menu
10. Click the EXIT button on the oscilloscope (USB will turn off) and the oscilloscope will update the folder contents, the found DSO firmware file should be displayed in green text.
11. Press Upload for DSO firmware
NOTE: The contents of the folders are checked when entering the UPDATER interface or when leaving USB mode by pressing EXIT in UPDATER mode
