Author Topic: Hack of Sigllent spectrum analyzer ssa3021X?  (Read 647907 times)
0 Members and 71 Guests are viewing this topic.
Offline Bicurico
  • Country: pt
  • Broadcast Systems & Transport Stream Analysis
    • VMA-Broadcast
Re: Hack of Sigllent spectrum analyzer ssa3021X?
« Reply #325 on: February 24, 2017, 08:37:05 am »
Update:
I unpacked the FW file with my tool (linked somewhere in this thread).
The contents have changed a little, as there is no passwd folder anymore. Some files are the same (see CRC).
My guess is that this FW update is a "small" update, mainly exchanging the ecomb executable, which would explain why you need to install P08.01 before installing P08.02. Telnet probably works as before, with same root login and known password.
However, I did not try the update, yet, so the risk is on you.
Regards,
Vitor
« Last Edit: February 24, 2017, 08:38:43 am by Bicurico »
Offline rf-loop
« Reply #326 on: February 24, 2017, 09:21:08 am »
DO NOT try update directly to 8.02 from any FW7.x version!
(I do not know if there is security check for prevent to do it accidentally)
Only FW7.x to 8.01 update procedure can generate product model license key (etc)  what FW 7.x did not use at all.
One test. It works least with my individual unit.
There was 8.01 in my unit and  mod (as in instructions) and with this mod also no serial number.
First I removed mod following these instructions.
Instructions:   https://www.eevblog.com/forum/testgear/hack-of-sigllent-spectrum-analyzer-ssa3021x/msg1132969/#msg1132969
Then  restart and look all ok. Now there is also original serial number (if someone worry it)
Update to 8.02
(also it rebooting during update)
noted that all works ok.
mod again with instructions.
result. Ok.
« Last Edit: February 24, 2017, 09:33:47 am by rf-loop »
EV of course. Cars with smoke exhaust pipes - go to museum.
The following users thanked this post: videobruce, BlauerElefant
Offline Bicurico
  • Country: pt
    • VMA-Broadcast
« Reply #327 on: February 24, 2017, 09:39:30 am »
Thank you for the test!  :-+
This new FW is actually the answer of Siglent to a request I made (they didn't do it for me, of course - at least I wouldn't think so):
It allows SCPI commands through a regular telnet connection. This opens doors to people like me to program custom applications that use the SSA3021X remotely.
Without any promise, imagine this: a software similar to my "VMA Simple Spectrum Analyser" (made for the cheap ADF4350, ADF4351, MAX2870 range of devices, like the NWT4000 - discussed in a different thread) in a special version for the SSA3021X, offering all the "advanced" measurements, but based on measurements of a propper spectrum analyser!
Thumbs up for Siglent!
Regards,
Vitor
Offline nugglix
« Reply #328 on: February 24, 2017, 09:53:51 am »
Strange.
I could download the file without problems and did so a few times, just to check.
I downloaded the new EasySpectrum and Programming Manual, with no issues either.
I guess your ISP must be having some issues.
Try this link: https://mediacdn.eu/m/media/wysiwyg/siglent/Downloads/Firmware/SSA3000X-Firmware-Update.rar
It is from http://www.siglent.eu/Downloads
Regards,
Vitor
This link works fine, downloaded in a few seconds.
Guess it's something between europe and the americas.
Thanks for the link!
Offline rf-loop
« Reply #329 on: February 24, 2017, 10:21:24 am »
There is trumbles between europe and america.
« Last Edit: February 24, 2017, 10:23:46 am by rf-loop »
The following users thanked this post: nugglix
Offline nugglix
« Reply #330 on: February 24, 2017, 11:01:27 am »
Thanks for trump-eting that out    ::)
Offline videobruce
« Reply #331 on: February 24, 2017, 02:09:43 pm »
I corrected the link in my post for the file. It's a direct link now,  ;)
Offline BlauerElefant
  • Country: at
« Reply #332 on: February 26, 2017, 11:38:01 am »
Did the update to 1.2.8.2 as rf-loop stated. First backuped files, then removed mods, then updated (my device rebooted twice), then backuped files, then reapplied mod, then backuped files.
Worked without any problem.
Thanks rf-loop!
Offline michael2
« Reply #333 on: February 26, 2017, 04:33:34 pm »
Have gone from unhacked 7.03 with purchased TG to 7.07, activated all options (w/o 1Hz and 3MHz RBW), made a "clear and reboot", updated to 8.1, worked fine, updated to 8.2, works still fine. Never done the "werewolf" trick.
Have made some tar-archives of the whole filesystems at different state.
Thank you for your informations!  8)
Offline arturfra
« Reply #334 on: February 27, 2017, 01:37:15 pm »
@michael2
Do u want to say that you've a 8.02 with all option ON with the original serial number? I've updraded to 8.02 as well and i've a regular TG licence, but i can't activate the remains options without loosing the serial... Do u've an advise for me?
Offline DL4RAJ
« Reply #335 on: February 27, 2017, 02:32:10 pm »
Hi Michael2
Please read the PM I've sent you.
Regards
Offline lz1pro
  • Country: bg
« Reply #336 on: March 03, 2017, 07:05:26 pm »
Hello,
v8.01 is still upgradable to 3032 whit serial and all option without need to open the machine. All you need to do is remove contains firmdata0 and backup without calib dir and edit NSP_system_info.xml whit wanted serial and copy all files from arhive to firmdata0 and backup folder.
Good luck,
Yanko
The following users thanked this post: Dima
Offline xenonfire
« Reply #337 on: March 04, 2017, 11:12:08 pm »
Did you get 3MHz BWD on your 8.01 machine?
/Daniel
Offline tautech
« Reply #338 on: March 04, 2017, 11:18:30 pm »
/Daniel
See replies #326 and 333.
Avid Rabid Hobbyist
Offline Dima
« Reply #339 on: March 05, 2017, 09:06:45 pm »
It looks like RBW is 10 Hz to 1 Mhz!
Offline arturfra
« Reply #340 on: March 06, 2017, 07:33:26 pm »
@lz1pro
and the 8.02 ??
thanks in advance for reply
Offline bozidarms
  • Country: at
« Reply #341 on: March 06, 2017, 07:54:11 pm »
with 8.02 definitely is possible to get all options enabled.
« Last Edit: March 06, 2017, 07:55:59 pm by bozidarms »
Best regards / Mit freundlichen Grüßen / 敬具 / 此致敬礼
Offline arturfra
« Reply #342 on: March 06, 2017, 08:10:18 pm »
hi,
I wanted to say "activate all option" in 8.02 without loosing the serial number as the previous firmware version 7.03 / 8.01
thanks for help
« Last Edit: March 06, 2017, 08:12:56 pm by arturfra »
Offline giorgiofox
« Reply #343 on: March 11, 2017, 02:20:23 pm »
I have a full option SSA 3021X with 100.01.02.07.07, and I want to "upgrade" it to 3.2 Ghz: what is the best way?
Upgrade it to 8.02 and then do the hack or do the hack and then upgrade?
Thank in advance for the info
Giorgio
Offline KeBeNe
« Reply #344 on: March 13, 2017, 09:26:20 am »
first hack, then upgrade
Offline Andy Granis
« Reply #345 on: March 14, 2017, 12:43:36 pm »
Tried mod on my 8.2 upgraded SSA, but no luck, exactly the same after reboot. What did I do wrong?
« Last Edit: March 14, 2017, 06:37:04 pm by Andy Granis »
Offline rf-loop
« Reply #346 on: March 14, 2017, 01:28:05 pm »
Tried Mr Li's mod on my 8.2 upgraded SSA, but no luck, exactly the same after reboot. What did I do wrong?
"Mr" ?
"What did I do wrong?"
If here is some clairvoyant maybe he can try but for most peoples better is first know what you have done before it can even try answer.
Do you have putty (or what ever telnet client you use) log record what you have done?
« Last Edit: March 14, 2017, 01:33:07 pm by rf-loop »
Offline Andy Granis
« Reply #347 on: March 14, 2017, 02:56:43 pm »
Tried the V05 mod again, and now it worked :),  All options and up to 3.2 GHz  :)
« Last Edit: March 14, 2017, 05:11:49 pm by Andy Granis »
Offline B1nary
« Reply #348 on: March 17, 2017, 08:53:10 pm »
Already have the 3032 - surprise gift from the wife - came with 7.07 - yes really! Used Telnet to take a look at the NSP_info file under Firmdata0. The current file is identical to the one currently there and suggested for updating with all options. The SSA is still operating under the 48 hour window for all options and as of now the options are enabled. How would replacing the NSP_info file change options that are enabled currently to being enabled permanently - I see others have done this swap with within just a few minutes of opening their SSA and it seems to work. Swapping out the NSP_info file seems easy enough to do but I am curious how replacing one file with an identical file causes all options to become permanent; and yes I do have a backup.
Offline Pinkus
« Reply #349 on: March 18, 2017, 11:06:14 am »
you lucky b*st*rd. Maybe I should show this to my wife ("THIS is true love" etc. etc.  -you all know this).
but wait, before this is being used against me - let me first ask you, what  suprises are YOU presenting to your wife  ;D
