Author Topic: Hack of Sigllent spectrum analyzer ssa3021X?  (Read 651949 times)
Offline dembi
Re: Hack of Sigllent spectrum analyzer ssa3021X?
« Reply #1375 on: December 28, 2025, 08:16:49 pm »
Hey guys!
I'm about to buy SSA3021X Plus. Do I understand correctly, the coax cable rework inside is required to self auto-calibration so there's no need to calibration kit and manual calibration?
« Reply #1376 on: December 28, 2025, 11:31:14 pm »
Hey guys!
Welcome to the forum.
Not quite, the coax is missing to restrict simple VNA conversion from a SSA3kX+ to a SVA model.
A Cal kit is still required for precision measurements.
Avid Rabid Hobbyist
Offline dembi
« Reply #1377 on: December 29, 2025, 06:23:10 pm »
Thank you for such quick response. There's a promo for this SSA3021X Plus till the end of 2025 so I'm considering buying it.
Siglent provides multiple calibration kits. I found this one https://www.siglent.eu/product/2165861/siglent-f503fe-4-5-ghz-n-female-type-vna-calibration-kit. Would it be ok? Should I get another one? I saw some people have written about calibration kits with a bridge. Should I get this one too? I found this kits quite expensive. May I use other, cheaper, yet with same quality?
The big problem is, and this isn't mentioned, that the CAL file is unique to each device and that ultimately hacking it will give you a bad VNA, while if you buy a real SVA you'II have a much beter VNA at your disposal.
So, shouldn't it be calibrated with a calibration kit?
If this is not the case, isn't the original calibration info backed up with the command and later restored:
cp -R /usr/bin/siglent/usr/vnacalikitdata /usr/bin/siglent/usr/mass_storage/U-disk0/SA-vnacalikitdata
« Last Edit: December 29, 2025, 09:06:00 pm by dembi »
Offline willie.from.texas
« Reply #1378 on: December 29, 2025, 10:27:17 pm »
That is a cal kit for use with the VNA. As far as I know, there is nothing special about that kit except for the cost. Maybe it comes in a nice box. I initially used the cal kit that came with my NanoVNA, but ordered an N-type cal kit. There is a kit available on Amazon rated to 3GHz for $20 U.S., that I am sure would work for most anything the VNA is capable of measuring.
« Reply #1379 on: December 30, 2025, 01:31:15 am »
Yeah but……
To do the job properly you should be calibrating a VNA as close as possible to the DUT to remove any adapter or cabling effects.
Most don’t want to work with N type as SMA is generally much nicer to use and this is why many use SMA Female Cal kits.
Avid Rabid Hobbyist
Offline KungFuJosh
  • TEAS is real.
« Reply #1380 on: December 30, 2025, 02:28:53 am »
Don't buy the crappy and/or overpriced cal kits, just get the LibreCAL and search this forum for how to use it with the Siglent.
Best Continuity Tester Ever
« Reply #1381 on: December 30, 2025, 02:40:15 am »
Or get something tested and decent from member hendorog:
https://vnalab.net/collections/all
Avid Rabid Hobbyist
Offline KungFuJosh
  • TEAS is real.
« Reply #1382 on: December 30, 2025, 03:22:27 am »
Or both. ;)
For me, I would get the LibreCAL. I already have N and SMA standards (nothing special), but one of the big reasons the Siglent interests me is for the LibreCAL autocalibration. Which is also already tested by a forum member that set it up.
Offline dembi
« Reply #1383 on: January 05, 2026, 06:12:46 pm »
Just did the crossmod from SSA3021X Plus to SVA1032X + all options enabled without any issues. At least on the software side of things, haven't put the jumper in place yet. Still debating whether or not I'll put proper SMA-connectors in place or just hardwire some semi-rigid coax in place. Anyway, you guys are awesome!  :-+
UPDATE: I ended up just soldering some coax in place. All works as intended after calibration.  :clap: Also, I upgraded the FW to version 3.2.2.5.1R1 (official download from Siglent) and everything is still enabled and working.
My SA came with exactly the same version of software and hardware. I've managed to enable 3032 and all options successfully. @BalticLab, could you tell me which version of the firmware for SVA1032X did you use to crossflash? Was the 3.2.2.4.0 your first try?
I saw some reworks with the coax in the previous posts. What connectors did you use, guys? I saw the footprint for the connectors is different than usual. Where did you buy so short coax cable with plugs?
« Last Edit: January 05, 2026, 06:30:22 pm by dembi »
Offline marcopolo
« Reply #1384 on: January 12, 2026, 03:27:07 pm »
I updated my SSA3021X+ by following the Mandor procedure:
https://www.eevblog.com/forum/testgear/hack-of-sigllent-spectrum-analyzer-ssa3021x/msg5746107/#msg5746107
The VNA works correctly compared to a nanoVNA.
However, I have a problem with the spectrum analyzer part:
I have a defect that repeats every 1.25MHz.
This can be seen more clearly by connecting the tracking generator directly to the input:
Second problem: the output level of the tracking generator is incorrect:
If anyone has any ideas for solving these problems, I'm all ears :)
Thanks.
« Last Edit: January 12, 2026, 03:31:49 pm by marcopolo »
Offline Gerd_02
« Reply #1385 on: January 13, 2026, 12:38:31 pm »
Hello, I'm new here as a user, but I've been reading along for a long time. I find this forum, especially the SSA3000x section, very interesting and informative.
I have an original SSA 3032x Plus, with all the available options unlocked via a Python script. I haven't performed a VNA upgrade.
I replicated the settings shown in the screenshots and haven't found any errors on my device except for the sawtooth pattern. The sawtooth pattern is also present on my device with extreme settings, every 1.26 MHz, but I think that could be due to the ADC's sampling window. However, it's not visible, or barely noticeable, in most measurements, so it's not a problem for me.
The following users thanked this post: marcopolo
« Reply #1386 on: January 15, 2026, 06:09:30 pm »
Interesting. I measure something very similar but with a higher amplitude. My instrument is the SVA1032X converted from the SSA 3021X Plus.
Offline Gerd_02
« Reply #1387 on: January 16, 2026, 09:31:20 am »
Yes, that's really interesting. I took the noise level screenshot back in 2024. Unlike yours, mine was taken without a signal and with a vertical resolution of 1 dB/div. I've now taken another one with TG activated at -20 dBm and 0.1 dB/div, using exactly the same settings as yours. It looks different on my instrument compared to yours.
Offline Gerd_02
« Reply #1388 on: January 16, 2026, 09:35:34 am »
I'm sorry, the attachment failed to load.
Offline dembi
« Reply #1389 on: January 25, 2026, 07:04:55 pm »
Guys, could anyone point to the SMA connector part number which fits into the PCB? I tried 2, one with too big raster/spacing, another one with too big diameter of the signal pin.
Offline S13
« Reply #1390 on: January 25, 2026, 07:30:15 pm »
Because of that exact problem i just put an SMB connector in there:
https://mou.sr/4sQ8Ulg
And the mating part:
https://mou.sr/4qG4mwx
And then some RG316 cable in between.
Offline dembi
« Reply #1391 on: February 08, 2026, 07:10:47 pm »
Finally I managed to get connectors and some free time. What solder iron do you recommend to solder connectors to GND? My 50 watts one can't cope with the ground plane.
Offline Lunasix
« Reply #1392 on: March 16, 2026, 08:59:14 pm »
I just received this day my brand new SSA3021X-Plus.
Software version 6.3R2 and Hardware version 02.00.10
I took time to do a backup, with telnet (port 23, login : root password : ding1234) and with the SSA3000X+_backup_11411.ADS file.
I generated keys with the python script and entered the 3032 key and the ALL key, without any problem.
Next step (in few days) will be to convert it to VNA, but I need to clarify some points.
Small detail, the logo has been changed and is more elegant...
« Last Edit: March 16, 2026, 09:39:48 pm by Lunasix »
« Reply #1393 on: March 16, 2026, 09:39:07 pm »
FYI Version: V6.3R16 is the latest, also the same SW version for SVA models.
Avid Rabid Hobbyist
Offline Lunasix
« Reply #1394 on: March 16, 2026, 10:10:19 pm »
Sorry, it was late, I considered 6.3R2 was newer than 6.3R16 !! Mistake. R16 is newer... So, all is ok.
Next step, SVA, but I will wait having the cable and will read until all is clear.
« Last Edit: March 16, 2026, 11:04:39 pm by Lunasix »
Offline vespaman
« Reply #1395 on: March 17, 2026, 04:51:37 pm »
Hi all,
I have had my SSA3021X PLUS for a couple of years. I thought I had "upgraded" it to a SVA, but to today, I was going to do some antenna measurement (never done before), so I pulled the instrument to my lab bench and powered it on, only to see that it says it is a SSA3031X PLUS (6.2R5). I do have VNA option though, and I can bring up a Smith diagram.
So, I wonder what did actually do when I "upgraded"? Did I never do the SVA cross flash stuff? If not why do I see the VNA option? I wish I wrote something down, but not so...
Or is this already done, just the model text SSA3032X PLUS that is not correct?
Offline techneut
« Reply #1396 on: March 17, 2026, 07:09:52 pm »
It is just the model text that is not right. You mist the last step
The following users thanked this post: vespaman
« Reply #1397 on: March 17, 2026, 07:48:32 pm »
Hi all,
What model does System Info report ?
If SVA1032X, have you installed the SVA firmware ?
Avid Rabid Hobbyist
Offline vespaman
Q
« Reply #1398 on: March 18, 2026, 06:47:42 am »
Hi all,
System info says SSA3032X PLUS (machine is SSA3021X Plus) with all options, that's why I am confused. But I get the Smith. My unit is early enough to have the cable (I remember checking this when I did the upgrade).
Quite possibly (I hope!) did I never do the last step as pointed out by @techneut.
Unless this is some half-way-missed-something-else shoddy work. But that would not be typical of me.
If it is only the text, I should probably try to fix this, and also update to the last FW rev.
Edit: Now I have done my antenna matching network, so I suppose it is working  :)
I tried to connect, to change the system info stuff, but I cannot connect to the device through telnet, nor through web (I receive 400) when browsing to it.
80/tcp   open  http
111/tcp  open  rpcbind
871/tcp  open  supfilesrv
5024/tcp open  scpi-telnet
5025/tcp open  scpi-raw
5900/tcp open  vnc
Maybe this is why it is not changed - I guess I might have had this problem also the last time..  :-//
« Last Edit: March 18, 2026, 03:02:20 pm by vespaman »
Offline Lunasix
« Reply #1399 on: April 01, 2026, 07:19:25 pm »
just a short question.
This is step 6 :
6. Crossflash (SSA to SVA)
https://mega.nz/file/7sViFCyY#FCM4FJbRaQU5l6GcqHofCAndgWm8qccJ_sW-v7fcjSQ
Load SVA1032X_V3.2.2.4.0_11411.ADS to USB drive
Load file to siglent device
What will be the result of this file loading ? Will the analyzer end with "succes", or will it hang (perhaps whith a failure message) ? Will it need a reboot before next step ?
All previous steps are done and I am almost ready to continue.
And last, the version of the newest firmware has no relationship with the previous ssa version ?
