Author Topic: Hacking the Rigol DHO800/900 Scope  (Read 2409251 times)
0 Members and 17 Guests are viewing this topic.
Offline Billiboy
Re: Hacking the Rigol DHO800/900 Scope
« Reply #3000 on: November 29, 2024, 11:57:15 pm »
Thanks for your feedback.
I currently have a DS1954z with a hack.
Unfortunately, I'm always missing a logic analyzer. As I'm currently remodeling my space, a new device with a Vesa mount is perfect.
I use it more as a hobby. What other alternatives are there for logic analyzers?
Offline Fungus
« Reply #3001 on: November 30, 2024, 12:01:14 am »
What is it that you need to analyze?
The DHO900 is quite expensive once you add everything and the sample rate isn't very high and the screen is quite small.
The serial decoders in the DHO800 are much better than the DS1054Z.
(well, the entire 'scope is much better - it makes the DS1054Z look like an antique)
The following users thanked this post: AndyBig, ebourg
Offline norbert.kiszka
« Reply #3002 on: November 30, 2024, 12:08:08 am »
I had both and I think DS1054Z is much better and much less problematic.
From the beginning to this day, firmware in a DHO800/900 is a piece of sh*t, written by some interns. Only one positive side is hackable (even up to the 1 GHz) bandwidth.
Offline Fungus
« Reply #3003 on: November 30, 2024, 12:32:47 am »
You're entitled to your opinion, just know that everybody else disagrees with you.
« Reply #3004 on: November 30, 2024, 01:24:53 am »
No, it's just You in one single post. Since when all members from entire forum can make single post together?
The following users thanked this post: tmeub
Offline Billiboy
« Reply #3005 on: November 30, 2024, 10:04:23 am »
I don't want to analyze anything special. I now have an AZ Delivery Logic Analyzer. I would have liked to have something in one device. I already have enough stuff lying around. Unfortunately, the DHO800 series doesn't have one built in.
I had already been thinking about a DS1074Z-S back then, but at the time I had no use for a logic analyzer.
Offline ebastler
« Reply #3006 on: November 30, 2024, 10:48:13 am »
That seems like a rather distorted take on the DHO800. I had the DS1054Z for many years, and the DHO1074 (largely the same firmware as the 800) for a couple of months. While I eventually decided for the competing SDS814X HD from Siglent, I would certainly say that the DHO800 is better than the DS1000Z in many respects -- and I am not aware of a single aspect where it is worse:
12 bits; higher bandwidth option available; more memory; decoding from full memory; higher screen resolution; touch screen; dual flex encoders for parameter setting; HDMI output. I wish they would optimize the UI's use of screen real estate a bit more (like in mrisco's modified version), but again, I am not aware of a situation where the old DS1054Z displays more/better information on its lower-resolution screen.
So in which respects do you find the DS1054Z "better and less problematic"?
The following users thanked this post: AndyBig, RAPo, ebourg
Offline Fungus
« Reply #3007 on: November 30, 2024, 12:15:11 pm »
C'mon... give us one example of something you've analyzed before.
(or two...)
Offline sandor626
« Reply #3008 on: November 30, 2024, 01:18:42 pm »
on the ds1054z even if the track is much thicker, it seems less wavy ...
Offline ebastler
« Reply #3009 on: November 30, 2024, 01:25:39 pm »
In case you have not seen it, there is a relevant parallel thread which is active at the moment: https://www.eevblog.com/forum/testgear/what-to-buy-dedicated-logic-analyzer-vs-the-new-scopes-aka-sds824dho924(s)/msg5730101/#msg5730101
I'm not sure "something in one device" is necessarily better. If you could elaborate where your current DSO1054Z + cheap AZ Delivery logic analyser falls short of your needs, it would be easier to make suggestions.
Maybe you need a better scope (12 bits?); maybe you need a better USB/PC-based logic analyser (faster? more channels?); maybe you actually need to see analog and digital channels on the same screen. Please let us know what functionality you are currently missing.
« Reply #3010 on: November 30, 2024, 03:56:18 pm »
Measurements taking less space and using them takes much less time. Much less bugs. Faster boot is useful when You need scope 1-3 times per day to check something - which is often the case when You have repair workshop.
Offline Fungus
« Reply #3011 on: November 30, 2024, 04:43:55 pm »
Sounds like you need one of those Zeeweii 'scopes:
https://www.eevblog.com/forum/testgear/another-dsodmm-zeeweii-dso3d12-claimed-120mhz250msps/
Leave the Rigol for the pros.
« Reply #3012 on: November 30, 2024, 04:58:25 pm »
Second time when I see offensive trolling from You. Do You have some kind of problems?
Offline AndyBig
  • Country: ru
« Reply #3013 on: December 01, 2024, 07:07:13 am »
As you know, the new firmware version 00.01.04.00.02 supports the new DHO824 model with a bandwidth of 200 MHz and a memory depth of 50M, so you can change your DHO8xx to 824, and not to 924 with its non-working logic analyzer panel.
I recompiled (for Windows) the utility from zelea2, adding the DHO824 model to it.
Other community members also added the 824 model to this utility:
- for Mac OS - https://www.eevblog.com/forum/testgear/rigol-dho800900-new-firmware-v00-01-04-00-02-2024111/msg5729989/#msg5729989
- for Android, to run directly on the oscilloscope - https://www.eevblog.com/forum/testgear/rigol-dho800900-new-firmware-v00-01-04-00-02-2024111/msg5732037/#msg5732037
* rigol_vendor_bin_824.zip (13.94 kB - downloaded 225 times.)
« Last Edit: December 01, 2024, 07:33:23 am by AndyBig »
The following users thanked this post: carlosedp, s
Offline neskor
  • Country: cs
« Reply #3014 on: December 01, 2024, 01:11:22 pm »
just tried to dowload this zip file, but my pc is blocking dowload  :-//
virus detected: Trojan:Script/Wacatac.B!ml
« Reply #3015 on: December 01, 2024, 01:14:04 pm »
And You are using Windows as OS?
Offline Fungus
« Reply #3016 on: December 01, 2024, 01:14:59 pm »
There's an exe file inside that zip
« Reply #3017 on: December 01, 2024, 01:30:49 pm »
clamscan Pobrane/rigol_vendor_bin_824.zip
Loading:    16s, ETA:   0s [========================>]    8.70M/8.70M sigs
Compiling:   3s, ETA:   0s [========================>]       41/41 tasks
/home/ramzes/Pobrane/rigol_vendor_bin_824.zip: OK
----------- SCAN SUMMARY -----------
Known viruses: 8700659
Engine version: 1.0.7
Scanned directories: 0
Scanned files: 1
Infected files: 0
Data scanned: 0.04 MB
Data read: 0.01 MB (ratio 3.00:1)
Time: 21.139 sec (0 m 21 s)
Start Date: 2024:12:01 14:27:11
End Date:   2024:12:01 14:27:32
Offline neskor
  • Country: cs
« Reply #3018 on: December 01, 2024, 01:42:55 pm »
Yes,  I'm using Windows.
Microsoft Defender is blocking the download.
« Reply #3019 on: December 01, 2024, 01:44:43 pm »
This is one of the reasons why Im not using Windows. I don't have time for such problems.
The following users thanked this post: neskor
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #3020 on: December 01, 2024, 02:07:23 pm »
install avast (free version if you tight arse) defender overridden, avast can be disabled at will and download any virus you want...
« Reply #3021 on: December 01, 2024, 02:45:11 pm »
Avast on a Linux?
Offline AndyBig
  • Country: ru
« Reply #3022 on: December 01, 2024, 04:26:51 pm »
My Symantec is silent. On VirusTotal the result is 3 out of 72. So your antivirus is clearly paranoid :)
Offline dmulligan
« Reply #3023 on: December 01, 2024, 04:35:46 pm »
Avast on a Linux?
Avast Linux isn't free.  Most Linux users looking for malware protection choose ClamAV.
Offline Fungus
« Reply #3024 on: December 01, 2024, 08:12:01 pm »
Speaking as a developer: Antivirus is a pain in ass these days.
I get people calling me all the time saying "It says it's a virus!!!" when they try to install things.
Such is life.
