ANY QUESTIONS ?
At least not at this very moment! Your dedication is awesome, a thousand thanks go out to you for these answers!
I've found the BACKUP DUMP reference in STEP 8 of the PDF, and I'll work further with your latest post and the PDF to understand more of all this. And then I'll be watching the 13 videos you've prepared
: is the router absolutely needed ? A direct ethernet connection would not work ?I would like to thanks all of you guys for the effort you put into that work.
I ordered some MSO5074s and plan to upgrade them.
A stupid question though: is the router absolutely needed ? A direct ethernet connection would not work ?
Best
Dear BTO,
Thanks for your thorough response.
As you kindly noted, my experience with networking is limited. I frequently use high speed ethernet switches to connect various equipment (including relatively fast digitizers), but clearly, network technology is far from my area of expertise (which is primarily experimental nuclear physics).
Is it a problem if I don't have a internet connection ?
Don't jump on me, just kidding.
I mentioned that fact that i'll be getting MSO5074s very soon. Actually I'll get a set of 4 with the current option bundle at work.
Big lab, no available router there. Or, to be more precise, not allowed to connect to any of the routers there.
I may bring a router from home for the very purpose of upgrading the scopes though.
QuoteI frequently use high speed ethernet switches to connect various equipment (including relatively fast digitizers), but clearly, network technology is far from my area of expertise- Fair enough, we all start somewhereQuote(which is primarily experimental nuclear physics).- Soooo.... You're saying..... You don't really have that much experience
I would love to be less "experienced"OK, AND... OSCILLOSCOPES ARE NOT ALLLOWED TO BE HACKED...........................................WHAT'S YOUR POINT
2. If you merely connect to the ethernet port , WHO'S GONNA KNOW and... What if you do , You literally need to be connected for 2 - 5mins
If i were you, i'd connect and upgrade it like you stole it
3. if you must wimp out and "FOLLOW THE ROOLZ" then... Yes you can bring a router from home,
After all it just needs power and ethernet cable. No internet required.
==>>I would love to be less "experienced"
QuoteOK, AND... OSCILLOSCOPES ARE NOT ALLLOWED TO BE HACKED...........................................WHAT'S YOUR POINT==>> Yep, being in the grey zone I guess....Quote
==>> I caught you being very wrong here. I would not do that knowing , that I don't want to be fired within hours... My lab is pretty closed...Quote
==>> No internet required, for sure
Hello!
Thank you for your work. Successfully updated my MSO5072 according to your instructions. Used the PyCharm terminal on MacOS with downgraded to V 1.3.2.2 and updated to V 1.3.3.0. I can't find what is included in self test ( 3 test ) ? Is this Key, Screen, Touch test? Thanks again.
Hello,
I don't understand where lies the problem.
My python setup is ok, all the modules are ok as well.
I'm on the MacOS Swquoia 15.0
py --version
Python 3.11.2
-h argument works well, but the -i doesn't
I have problems running the script:
py Rigol_MSO_LicensingUtility_2.10b.py –i 192.168.1.89
usage: Rigol_MSO_LicensingUtility_2.10b.py [-h] [-d] (-i | -e | -r | -a | -f | -p | -u | --reboot | --cfram-file rigol_fram_XXXXXXXXXXXX.data) [-k {1,2}] [-m MSO5074] [-s MS5A123456789] [-o AUTO,AERO,AUDIO]
[--sys-vendor-file rigol_vendor_XXXXXXXXXXXX.data] [--no-reboot] [--with-config] [--no-color]
ip_addr
Rigol_MSO_LicensingUtility_2.10b.py: error: one of the arguments -i/--info -e/--ssh -r/--regen -a/--activate -f/--save-fram -p/--save-pk -u/--uninstall --reboot --cfram-file is required
Hello,
py --version
Python 3.11.2
ip_addr
If you are not successfully executing the -i switch then you have a networking issue.
Mac is notorious for security and blocking things
if you can't -i then it's likely it won't activate either
i would suggest checking the security features of your mac and the network as something is blocking the python program
did you also install python as per the instructions i gave in the pdf or did you already have it installed ?
Hello,
py --version
Python 3.11.2
ip_addr
The problem is that the "minus" sign is not realy minus but a Uicode char. Just replace it.
I mean the problem is in el314 command and not in the script. "–i" is not the same as "-i" even if some fonts make it look the same.
I won't look up what unicode chars are each. Its not worth that effort.
I copied and pasted the "-i" text from the error posted by user el314 into a text editor, and looked at it in hex view
A minus sign is 0x2D in ASCII
The long-dash/hyphen in the command/error posted by el314 is utf-8 0xE28093 - this is a unicode en-dash https://decodeunicode.org/en/u+2013
Thus it is not properly recognised by python command parsing
This is a common issue when copy/pasting command lines from a word processing document (or PDF created from one) as the word processor "helpfully" converts to nice unicode symbols.
Other than minus/hyphen symbols, it often also happens to double quotes - changing to unicode opening and closing quotes.
BTO, you need to spend more time reading/comprehending posts and less time replying. Please... as you are someone who talks about others disrespect...
so we need to ask, what is this user doing different that everyone else did not do ?
The problem is that it is visually hard to spot, and the programs/scripts don't give helpful errors when parsing unicode parameters.
I haven't checked, but I suspect this (unicode paste) may be more of an issue on Linux and Mac terminal than Windows command line.
I know I've seen this issue on Linux when writing up documents with step-by-step instructions for clients. I make an effort to revert any changes that Word makes to quote and hyphen symbols so that copy/paste still works.
Edit to add: Also, for short commands not everyone will use copy & paste. And I suspect some users when they get an error, will try again by manually retyping the command, not knowing about command history.
QuoteThe problem is that it is visually hard to spot, and the programs/scripts don't give helpful errors when parsing unicode parameters.
I haven't checked, but I suspect this (unicode paste) may be more of an issue on Linux and Mac terminal than Windows command line.- OK so it appears to be a thing with Terminal. I suspected it had to be something like that. Although other mac users have not had the same issue.
I guess.. is there another terminal they could download and use in place of Terminal, Perhaps if they used a windows based terminal in Wine or something.
I know wine isn't the most reliable thing but hey if it'll get past this step perhaps it's a viable option.QuoteI know I've seen this issue on Linux when writing up documents with step-by-step instructions for clients. I make an effort to revert any changes that Word makes to quote and hyphen symbols so that copy/paste still works.- I make an effort whenever copying things from word to put it in a text editor like Notepad or Notepad++ before pasting
The user el314 might have copied the command from your pdf, page 14 step 13.
There is a simple fix for this but it requires discipline from the documentation producer: use a proper font/text style for commands and code snippets.
MS Word 2010 that produced that pdf has, if I remember correctly, such style already defined with a monospace font. It is practical and aesthetically pleasing and avoids that dreaded "helpful flufishness" entirely.
As for me I am not unlocking any scope. Just noticed the error in a moment of procrastination.
