Author Topic: Hacking the Rigol MSO5000 series oscilloscopes  (Read 1777015 times)
0 Members and 35 Guests are viewing this topic.
Offline 6SN7WGTB
Re: Hacking the Rigol MSO5000 series oscilloscopes
« Reply #3100 on: November 04, 2024, 04:21:23 pm »
What i want to ask is this
1. What Sig Gen are you using because at the same frequencies, i'm not getting the amplitude that you're getting, Say at 400MHz and 1GHz
I suppose my Sig Gen  WB-SG1 is likely not going to compare to your one
My rise and fall times are pretty much the same as yours
Appreciate your Q not directed at me, but FYI my results, attached again below, were achieved with:
  • Marconi/IFR/Aeroflex 2025
  • RS Pro RG58 BNC, specified as up to 1.5GHz (but no rolloff data)
  • RS Pro 50Ω inline terminator, specified as  DC-0.5GHz, ditto
The following users thanked this post: thm_w, MF-jockey, Odd-Job
Offline BTO
« Reply #3101 on: November 04, 2024, 04:51:49 pm »
No problem, You're welcome. Although i believe i've seen this graph before and you posted it earlier didn't you ?
it's not easy to forget when someone whips out a Marconi :P
QUESTION EVERYTHING!!!
Offline 6SN7WGTB
« Reply #3102 on: November 04, 2024, 05:25:08 pm »
I did, yes, but wasn't sure I'd detailed the kit.
Offline Odd-Job
« Reply #3103 on: November 05, 2024, 10:08:59 am »
Hi Kean & BTO
Sorry to disappoint you both but it is only a  cheapish unit (pic below) purchased from AliExpress about 8 months ago from memory, to check the validity of a batch of 25, MC12095 single modulus prescaler ic's for  frequency division of a 2.5 GHz input signal, datasheet below.
Kean, output voltage is set to approx 300mV  for the input of the chip (12095's) which work from sine waves.
It does create a nice sine form about 200Mhz up to 4.2 Gig that a collegues Oscilloscope kindly showed.
The highest my MSO would show freq counter wise was about 1.053 Ghz unreliably, about same as yours BTO.
Kean, in relation to the output from my Sig Gen as shown, it stays within 2.1dbmv from the 300Meg to ~1 Gig , as the set up was also plugged into my 3.2Gig Spec Analyzer.
I was stepping it at about 800mS/step & 50 Megs but took forever.
I suggest that if you watch the you tube link to the sweep below link to slow it to compare V/F.
I did find one screen shot I managed at 1.5Gig which you will have to count the divisions to believe me. Oh and I know you like your colour grad shot's BTO so have included one.
SOOO, to finalize , no  I don't  own some 30K$ wizz bang 10 Gig phosphor oscilloscope, 3.2Spec analyzer is as high as I need (want) to go these days.
Over
« Last Edit: November 06, 2024, 09:57:30 pm by Odd-Job »
Just a ghost, trying to control a skeleton riding a rock hurtling thru an  infinity of octal~fractal space
Offline BTO
« Reply #3104 on: November 05, 2024, 01:05:34 pm »
Hi Kean & BTO
Over
Hi Kean & BTO
... And here i am thinking that you actually some cool shit worth $30k or above :-DD
No, but on a serious note, what got me was...
- You have your Sig Gen and you're producing Sine waves pretty cleanly at around 1V/div
- Now me using my WB-SG1 ... I mean it goes to 8GHz  but the amplitude is low as hell, in the mV range even only 10s of mV's
so i'm wondering, How did you achieve that.  My unit says it does 3V pk/pk  BUT THERE'S A CATCH...
The unit has 2 Channels, Ch 1 does up to 200MHz  at 3.3V Pk/Pk  (however it doesn't always stay on 3.3V)
CH2 starts at 80MHz and makes it up to 8GHz  However it's not 3.3V Pk/Pk it's generally under 500mV
Unlike Traditional Sig Gen's that have multiple waveforms and the ability to select a Voltage up to a preset max, This Sig Gen, which i bought for the sole purpose of seeing
how high in frequency the scope can go, Only supports sine wave (Technically.. Square wave, then it builds on it to form a Sine then it goes back to Square and sometimes transitioning through Sawtooth)
so basically it only has 1 wave (Whichever if feels the need to do ) so you can't select the amplitude of waveform.
it's still ok though, but i think it would have been smarter if it was 5V and not 3.3 because unless it's 5V,  it's useless for things like TTL
so yeah that's why i thought you had a monster of a Sig Gen
- Thanks, that's good to know that it's the roughly the same
- LOL    No actually, let me just clarify this so there is no misunderstanding , I don't want anything thinking that i'm on some psychadelic trip
The shots i provided with color grade were just really to illustrate one thing i noticed.
BEFORE THE 500MHz upgrade and timebase going to 500ps  I ABSOLUTELY observed that my scope worked fine but when color grade was activated it just slowed the firetruck down
From when i bought it... had a poke around, then later i did my video course (Deep Dive) and i got to play with it quite a bit and still whenever on color grade it would chew up resources and
become really slow
AFTER THE UPGRADE TO 500MHz ,  i noticed a few things very quickly
1. the presence of the timebase going to 500ps
2. Colour grade could be switched on and not drag down the scope
3. I could then put it into deep memory , still won't bat an eyelid,  no pauses no nothing
4. to push my luck i could thn put in High Resolution acquistion mode.... Still .. all good
5. and i could do this on a fast timebase and as slow as perhaps 2s / Div
So i posted those shots to show that
It's not that i use color grade all the time, Although since it now works without a problem i can see how it would be useful from time to time.
Before it was more like..... Rigol, why the hell did you put this in if it causes the scope to be as slow as firetruck ?
that's what it was.
YOU KNOW WHAT, I'M GOING TO START A NEW POST
This post is doing to be dedicated to testing the bandwidth of the MSO5000
« Last Edit: November 07, 2024, 10:37:36 am by BTO »
Offline BTO
« Reply #3105 on: November 05, 2024, 01:36:29 pm »
OK , SO WE DON'T CLUTTER THIS TOPIC WITH IRRELEVANT STUFF
I HAVE CREATED ANOTHER TOPIC
I suggest we continue this testing conversation over there,
https://www.eevblog.com/forum/testgear/testing-the-rigol-mso5000-series-oscilloscope/new/#new
The following users thanked this post: Odd-Job, 3x
Offline Jeronimooooooo
  • Country: br
« Reply #3106 on: November 16, 2024, 07:50:15 pm »
Hello friends, can anyone help me?
I bought the MSO5074 some time ago, it already came in version 1.3.2.2 with some options installed over a period of time.
I followed the steps to unlock, made the backup, installed version 1.3.2.2, the options did not uninstall.
I updated to 1.3.3.0, the options didn't uninstall either.
I downgraded to 1.3.2.2 and they are still there!
I tried following step 16 "python Rigol_MSO_LicensingUtility_2.10b.py –u x.x.x.x" it appears that it has been uninstalled, but when I restart it it is still there! Can anyone help me?
│ OPTION CODE   │ STATUS   │ DESCRIPTION                                         │
│ 2RL           │ ----     │ 200Mpts Deep Memory Option                          │
│ COMP          │ 1528min  │ Computer Serial Triggering and Analysis(RS232/UART) │
│ EMBD          │ 1528min  │ Embedded Serial Triggering and Analysis(IIC, SPI)   │
│ AUTO          │ 1528min  │ Automotive Serial Triggering and Analysis(CAN/LIN)  │
│ FLEX          │ 1528min  │ FlexRay Serial Triggering and Analysis              │
│ AUDIO         │ 1528min  │ Audio Serial Triggering and Analysis(I2S)           │
│ AERO          │ 1528min  │ MIL-STD 1553 Serial Triggering and Analysis         │
│ DG            │ ----     │ Dual Channel WaveGen 25 MHz AWG                     │
│ PWR           │ ----     │ Integrated Power Analysis                           │
│ BW07T1        │ ----     │ 70MHz to 100MHz Bandwidth Upgrade Option            │
│ BW07T2        │ ----     │ 70MHz to 200MHz Bandwidth Upgrade Option            │
│ BW07T3        │ ----     │ 70MHz to 350MHz Bandwidth Upgrade Option            │
UNINSTALLING Activated Options......
....**DO NOT DISCONNECT POWER OR DATA CABLE** ....
UNINSTALLING... **** COMPLETED ****
REBOOTING...
Waiting for device to be back online..........................................................DONE - PREPARE FOR REBOOT
REBOOT COMPLETED
**** DEVICE ONLINE ****
Do I try to patch with these options enabled? Is there any risk?
Thanks
Offline hussamaldean
  • Country: iq
« Reply #3107 on: November 20, 2024, 03:44:01 am »
Hi all,
is it still possible to to hack RIGOL MSO5000?
In noticed the latest version is 01.03.03.00.
Is this version hackable or not?
Offline BTO
« Reply #3108 on: November 21, 2024, 02:22:56 am »
Hi all,
Weird Question......
i can only assume you're reading very old posts.
it has been possible to (as you call it) "HACK"   the correct term is UNLOCK or LICENSE  the MSO5000 on version 1.3.3.0
for a very very very long time now
this version is ABSOLUTELY Hackable
i think the more appropriate question is..... WHAT METHOD ARE YOU USING ?
So, you should understand
1. The first Method, which we called THE PATCH METHOD did have issues on version 1.3.3.0
    it also didn't license the scope correctly and it also had the downfall of...  You have to keep repatching on every single upgrade version.
We no longer have that problem, that's a thing of the past now
3. The current Method is the FULLY LICENSED METHOD
so now... You don't need to worry about
- Which version you are on
- Patching
- Whether you're going to be able to upgrade your scope in the future
THAT'S ALL SORTED
What you do now is this....
go here
https://www.eevblog.com/forum/testgear/hacking-the-rigol-mso5000-dr-mefisto-licensing-method/
Go to the cloud
Download the 1.3.3.0 GEL file and if your scope is not already on that version, then just upgrade it before you start.
Grab the PDF and follow the instructions
Grab the python script  2.10b
that's all you're going to need
we have developed the script now to a point where
- it's much faster than it was
- There are less steps involved for you
- There is very very little risk of you bricking your scope, Unless you do something really really dumb. and you'd have to try hard to do that at this poin in the game.  ;D
You're going to find that you just need to run the script
and then before you know it, your scope will be upgraded and properly licensed and you'll be happy as a cucumber .
this method will get your scope unlocked to 350MHz
get that done first.
we do have a Method to unlock the scope to 500MHz
this method has more risks associated with it and is more technical , but can certainly be done
Just get it to 350MHz first and see how you go and if you need more than that
BUT YES IT'S ABSOLUTELY POSSIBLE TO UNLOCK THE SCOPE WITH VERSION 1.3.3.0
and.. After doing all this, You will NEVER have to hack your scope again,
when future firmware updates come out.  YOU JUST DOWNLOAD THEM AND UPGRADE THE SCOPE AS PER THE NORMAL RIGOL PROCEDURE.
Nothing to worry about .  it will all be there and survive the upgrade.
So.. it looks to me like you are a few years behind the 8 ball
The following users thanked this post: DLJ, richierich
  • Country: iq
« Reply #3109 on: November 21, 2024, 11:53:34 am »
Just wanted to refresh my memory.
On last question, let say during the process, the oscilloscope shut down for power outage or ethernet communication lost and bricked my oscilloscope. Is it possible to bring it back to life?
Offline BTO
« Reply #3110 on: November 21, 2024, 02:16:02 pm »
No problem
- IF  very very very very very ........very very BIG "IF" your scope was actually bricked
well, it depends
IF..... You did your backups, Sure we POSSIBLY  could restore it
but then there is also a chance you couldn't.
it depends what was affected, Firstly the term "Bricked" is not a term that should be used with Oscilloscopes.
In short, if we were writing to the FRAM and there was a critical piece of it being written to that was responsible for the basic startup of the scope
then.... NO. you wouldn't be able
if it was something else... then you would be able to
and there is of course the small chance that even if it couldn't start up, we could re flash it.
so on this special of MYTHBUSTERS   we are going to call it   PLAUSIBLE     ;D
But understand a few things
- i have personally helped approx 300 odd people get over the line , some got close to stuffing things up.  BUT NO ONE EVER BRICKED THEIR SCOPE.
i had a few people tell me they bricked it, but it wasn't actually bricked
- these problems occurred more frequently when there was a 2min or so wait time for writing to the FRAM because anything could happen.
a Lightning storm, Power outage, whatever.   Now .. it takes seconds for the actual critical writing process
- that in turn brings the likelihood of bricking down drastically
- Then i have also included reminder messages in the upgrade process to remind you.. check the power, check the ethernet connection etc etc.
there really is only a small window when you can royally stuff your scope
i am yet to see a person who has actually done it..
WOULD YOU LIKE TO BE THE FIRST............. WE'LL MAKE YOU A TROPHY  :-DD
because.. if you pulled that off... Honestly. that's an achievement
The following users thanked this post: hussamaldean, Protegimus
Offline Maol
« Reply #3111 on: December 09, 2024, 05:06:44 pm »
python rigol_mso_util_2.13b.py --offline --sysvendor-file sysvendor.bin --use-sysvendor-key rigol_dec_sysvendor_7767455A7645643701770077456876A8_17301535015725.data --model MSO5504
python rigol_mso_util_2.13b.py --offline --sysvendor-file sysvendor.bin  use-sysvendor-key rigol_dec_sysvendor_7767455A7645643701770077456876A8_17301535015725.data --model MSO5504
python rigol_mso_util_2.13b.py --sysvendor-key 10.1.1.140
python rigol_mso_util_2.13b.py --offline --sysvendor-file sysvendor.bin  use-sysvendor-key COPY YOUR KEY HERE --model MSO5504
Hello BTO,
Thank you for all your work.  :)
I tried your method here :
https://www.eevblog.com/forum/testgear/hacking-the-rigol-mso5000-series-oscilloscopes/msg5657031/#msg5657031
Then I tried the update here :
https://www.eevblog.com/forum/testgear/hacking-the-rigol-mso5000-series-oscilloscopes/msg5698755/#msg5698755
It doesn't work for me  :-[
Here is the result of --save-vendor :
Reading sysvendor.bin ...done!
Saved sysvendor to 'rigol_sysvendor_17337623951672.data'
Here is the result of --sysvendor-key --sysvendor-key-slow :
Looking for sysvendor.bin key... --== Don't poke the bear. Please be patient ==--failed!
Here is the result of --sysvendor-key --sysvendor-key-fast :
Looking for sysvendor.bin key... --== Don't poke the bear. Please be patient ==--done!
Timers - memory dump: 0.0716 sec | download dump: 0.0314 sec | find key: 0.1679 sec
Device XXTEA key [B8A754A897A647B801770073432E3542] was found after checking 46404 possible keys
Saving decrypted sysvendor.bin locally...done!
sysvendor.bin data:
  size=260 ok! | crc32=1BE11195 [467734933] ok!
Traceback (most recent call last):
  File "C:\Users\manse\Documents\Hobbies\Electronique\RIGOL MSO5000\changeModel\rigol_mso_util_2.13b.py", line 1052, in <module>
    main()
  File "C:\Users\manse\Documents\Hobbies\Electronique\RIGOL MSO5000\changeModel\rigol_mso_util_2.13b.py", line 947, in main
    rigol_sysvendor.print_data(svd, act_key)
  File "C:\Users\manse\Documents\Hobbies\Electronique\RIGOL MSO5000\changeModel\rigol_mso_util_2.13b.py", line 671, in print_data
    decdata = xxtea.decrypt(vdata, xxtea_key, padding=False)
ValueError: Data length must be a multiple of 4 bytes and must not be less than 8 bytes
Both files are created but I can't use the third command.
With dashes:
Error: --use_sysvendor_key must be hexWithout dashes :
rigol_mso_util_2.13b.py: error: one of the arguments --cfram-file --sysvendor-file is required
BTW I was unsure it was a good idea to send the third comman because I didn't find the "before you start make sure you add sshd at boot" howto. :o
Can you please help me ?
And give a link to the sshd method.  ;)
Regards,
Olivier
Offline Bill3745
« Reply #3112 on: December 09, 2024, 10:12:27 pm »
Has any work been done on "decoding" the various calibration files (cal.hex, adccat.hex, dgCal.hex, etc.)?  I'm wondering if it would be possible to tune the output of my built-in AWGs to be a little more accurate and meet their flatness specifications.  I did an initial search of the forum and nothing jumped out, so apologies if this has already been discussed.
Bill
A charter member of Test Gear Hoarders Anonymous and owner of a variety of Tektronix, Rigol, Siglent, HP, Wavetek and Fluke gear.
Offline BTO
« Reply #3113 on: December 09, 2024, 11:27:37 pm »
No, no problem at all. to my knowledge we haven't tweaked or even touched the AWG.
we have just been pre occupied with the unlocking part of it.
Although now it seems that things have gotten really quite surrounding the MSO5000
Offline Maol
« Reply #3114 on: December 10, 2024, 12:51:07 am »
Well, I figured out that I didn't read correctly your guide.
So the 3rd command is :
python rigol_mso_util_2.13b.py --offline --sysvendor-file rigol_sysvendor_17337880371446.data --use-sysvendor-key B8A754A897A647B801770073432E3542 --model MSO5504BTW, the result is :
sysvendor.bin data:
    main()
  File "C:\Users\manse\Documents\Hobbies\Electronique\RIGOL MSO5000\changeModel\rigol_mso_util_2.13b.py", line 854, in main
I understand that my key length must be a multiple of 4 bytes and must not be less than 8 bytes and ... wait! It IS a multiple of 4 bytes and it IS 32 bytes!
With two spaces instead of -- I have the following error message :
C:\>[...]\python rigol_mso_util_2.13b.py --offline --sysvendor-file rigol_sysvendor_17337880371446.data  use-sysvendor-key B8A754A897A647B801770073432E3542 --model MSO5504rigol_mso_util_2.13b.py: error: unrecognized arguments: B8A754A897A647B801770073432E3542
Any advice ?
For those who need the sshd on boot activation command, it is :
python3 rigol_mso_util_2.13b.py --ssh --start-ssh-on-boot <rigol_ip_address>
Regards,
Olivier
The following users thanked this post: Protegimus
Offline exider
  • Country: ie
« Reply #3115 on: December 10, 2024, 02:01:04 am »
@BTO
Hi mate,
I have a quick question as I’ve run into some problems with the whole downgrade/upgrade process.
I was experiencing freezing issues and decided to downgrade/upgrade, but the GEL file (03.02.02) was rejected. Could you please confirm if my hash is correct? I downloaded all firmware versions from your Mega folder.
Here’s the hash I got:
00.01.03.02.02> sha256sum.exe .\DS5000Update.GEL
3823b61b45bf7d79fed4980fc692e121dc4df2454461d85f75d3c6cc05a4f079 *.\\DS5000Update.GEL
Is this the correct hash?
If the hash is correct, could the rejection be due to the model number? I’m using the 5504 in this case.
Thanks in advance for your help!
Offline Bill3745
« Reply #3116 on: December 10, 2024, 02:27:21 am »
Thanks for the quick reply.  I know some work was done on one of the files (lfcal.hex, I think) way back when people were experiencing overshoot issues, but I didn't find any details on the file format posted.  Out of curiosity, have you looked at how well your AWGs maintain amplitude flatness over frequency?  The spec states +/-0.5 db from a 1 KHz reference.
Bill
Offline mwb1100
« Reply #3117 on: December 10, 2024, 04:51:41 am »
I am not @BTO but that hash matches the one I have from a firmware package I downloaded in January 2023 from:
  - https://supportcn.rigol.com/Public/Uploads/uploadfile/files/ftp/Firmware/MSO5000(ARM)Updatev00.01.03.02.02.zip
(note that the URL is now 404).  I haven't tried to downgrade so I can't confirm anything other than the hash matches.
The following users thanked this post: exider
Offline BTO
« Reply #3118 on: December 24, 2024, 11:10:50 am »
@BTO
Hi mate,
OK, let's compare it
i downloaded my 1.3.2.2 just now
Used powershell to generate the hash, this was the output
Algorithm         Hash        Path
SHA256          3823B61B45BF7D79FED4980FC692E121DC4DF2454461D85F75D3C6CC05A4F079
it doesn't look like they match up
Your hash   3823b61b45bf7d79fed4980fc692e121dc4df2454461d85f75d3c6cc05a4f079
My   hash   3823B61B45BF7D79FED4980FC692E121DC4DF2454461D85F75D3C6CC05A4F079
EDIT : My mistake.. Other than the uppercase/lowercase thing which causes the offset in length, they actually do match up
I used this link
https://mega.nz/folder/A8cEgQRI#5FSoMrCurJi71T7VkRPgYQ
to run my hash i opened powershell 7.4.6
i entered
Get-FileHash -Path "C:\Users\Martin.Kuliza\Downloads\UPGRADING TO 350MHz (1.3.2.2)\Step 2. GEL File - Scope Firmware - 00.01.03.02.02\DS5000Update.GEL"
basically
Get-FileHash[SPACE]-Paththen just drag the file into powershell and the file path will Autocomplete
Does that help you ?
« Last Edit: December 24, 2024, 11:16:57 am by BTO »
Offline Protegimus
« Reply #3119 on: January 11, 2025, 05:30:40 pm »
@Maol
Error running change model with my MS5104
traceback:
  File "rigol_mso_util_2.13b.py", line 1052, in <module>
    main()
  File "rigol_mso_util_2.13b.py", line 858, in main
    nsvd = rigol_sysvendor.change_data(svd, dev_key, act_key, {"E_CFG_MODEL_RAW": args.model, "E_CFG_SN_RAW": args.serial, "E_CFG_MAC": args.mac_address})
  File "rigol_mso_util_2.13b.py", line 703, in change_data
    calc_crc32 = binascii.hexlify((self.crypto.calc_crc32(val_data[8:]) % (1<<32)).to_bytes(4)).decode('latin1').upper()TypeError: to_bytes() missing required argument 'byteorder' (pos 2)
Issue
line 662, existing:
note missing argument , byteorder='little'
correct to:
calc_crc32 = binascii.hexlify((self.crypto.calc_crc32(val_data[8:]) % (1<<32)).to_bytes(4, byteorder='little')).decode('latin1').upper()
line 703, existing:
correct to:
With the above corrections, rigol_mso_util_2.13b.py was able to successfully write the modification to the local (on disk) file:
Saved sysvendor.bin_mod to 'rigol_sysvendor.bin_mod_17366154674889.data'
sysvendor file has been modified!
then per the attached screenshot I was able to complete the model change and unlock the additional timebase option.
[edit]
Quick question, for sshd on boot, what is the command to stop it?
answer: the script modifies
/rigol/shell/start.sh
by appending
/usr/sbin/sshd &
I used vi to remove the above line and prevent sshd from running once I was finished with it. Be careful to verify your edit to avoid any issue!
« Last Edit: January 12, 2025, 01:36:59 pm by Protegimus »
  • Country: iq
« Reply #3120 on: February 14, 2025, 02:54:05 pm »
Just ordered mine.
Can't wait to get it and hack it.
« Last Edit: February 14, 2025, 02:55:45 pm by hussamaldean »
Offline BTO
« Reply #3121 on: February 16, 2025, 03:45:37 pm »
Just ordered mine.
Not long now, huh
Remember :
1. When you get it, Do an immediate Backup
2. Don't worry too much about the upgrade, that part is easy
3. Just ensure that you do the Licensing Method and NOT the Patch Method.
that's about it,
Beyond that.. Enjoy it
and after the upgrade, Check out the video series i have inlcuded for you guys to get more familiar with your scopes
https://www.eevblog.com/forum/testgear/post-hacking-rigol-mso5000-post-hacking-tutorial-deep-dive
« Last Edit: February 16, 2025, 03:50:38 pm by BTO »
Offline django
« Reply #3122 on: February 21, 2025, 01:06:47 pm »
Although I've been reading and browsing this forum for a while, it is my first post  :)
I got lucky and found a used MSO5074 in perfect condition for less than $400. I've just received it. It currently runs with the 3.2.2 firmware. I can't wait to hack it, thanks for your great work about this hack and thank you all for this forum which is a knowledge gold mine to me !
I'll keep you informed.
Regards
Offline BTO
« Reply #3123 on: February 21, 2025, 01:17:16 pm »
Regards
it is my first post
CONGRATULATIONS.... You broke your cherry....  LOL
You are now one of us
OK, Now regarding your scope.
Well done on the score, that's really cheap
so do this...
AFTER YOU'VE UPGRADED YOUR SCOPE
to get to know it in detail, here are 13 Videos to get you really familiar with your scope
https://www.eevblog.com/forum/testgear/post-hacking-rigol-mso5000-post-hacking-tutorial-deep-dive/
As for upgrading
1. Understand there are 2 Methods
- The Patch Method (YOU DON'T WANT THIS.. THIS IS OUTDATED)
- The Correctly Licensed Method
You want the latter
the former means you have to re patch every single time to update,   that method is a few years old now.
the latter means you never have to worry about hacking it again.
Go to this link
 You need the PDF
the 2.10b  script
the 1.3.3.0  zip file
 with the zip file
You do the backup stage  Stage 1
You get the GEL file from (Stage 2)
You skip Stage 3,  You don't do patching
Just follow the PDF
But before you do all that.
Just use the 1.3.3.0 file to upgrade your scope, Regardless of whether it has features activated or not.
Just get onto version 1.3.3.0
then follow the pdf
Let me know if you have any issues, but i reckon you likely won't have any
The following users thanked this post: django
Offline django
« Reply #3124 on: February 21, 2025, 01:59:24 pm »
Yes thanks a lot, I've already read some stuff on this post about those methods. In fact, that's the reason why I chose to buy this cheap MSO5074 ;D
I'll do it in a few hours !
« Last Edit: February 21, 2025, 02:19:20 pm by django »
