Author Topic: Hacking the Rigol MSO5000 series oscilloscopes  (Read 1752299 times)
0 Members and 126 Guests are viewing this topic.
Offline J-R
Re: Hacking the Rigol MSO5000 series oscilloscopes
« Reply #3225 on: August 26, 2025, 05:52:09 pm »
My understanding is that there are two methods to unlocking the scope, the one in this thread and the new one in the other thread.  If you already went through the process using the new method, changing the model number is pretty straightforward since you'll already be familiar with much of the process.  If not, then I think you'll want to read BTO's documentation to fill in some of the gaps.
Offline Elektro
« Reply #3226 on: August 28, 2025, 11:31:51 am »
@J-R: Yes I have used the new method to update the scope to 350MHz.
With a few changes to the original instructions (Reply #2981), I was able to switch the oscilloscope from 350 MHz to 500MHz and reactivate all options.
Without the extension “--model <your_desired_model>”, the Python script will terminate with an error message, as shown in “Reply #3220” (except in step 5).
The problem appears to be independent of the Python version (tested with Python 3.13.7 and 3.10.11).
For Step 5 the python script "Rigol_MSO_LicensingUtility_2.10b.py" was used.
#1 -> save current sysvendor
python rigol_mso_util_2.13b.py --save-sysvendor <rigol_ip_address> --model < your_desired_model>
#2 -> find the device xxtea key
python rigol_mso_util_2.13b.py --sysvendor-key <rigol_ip_address> --model < your_desired_model>
On the screen: DEVICE XXTEA KEY [COPY WHAT IS BETWEEN THE SQUARE BRACKETS]
#3 -> change sysvendor model in sysvendor file (can also be used on --mac and --serial)
python rigol_mso_util_2.13b.py --offline --sysvendor-file <file_saved_at_step_1> --use-sysvendor-key <only_the_key_from_step_2> --model <your_desired_model>
#4 -> write modified sysvendor to device
python rigol_mso_util_2.13b.py --write-sysvendor --write-sysvendor-file <file_from_step_3> <rigol_ip_address> --model <your_desired_model>
From this point on, the oscilloscope runs at 500 MHz, but without options.
Step 5 with “rigol_mso_util_2.13b.py” with and without the extension “--model <your_desired_model>” does not work.
Reboot the device two times.
Set it to default
#5 -> reactivate licenses
python Rigol_MSO_LicensingUtility_2.10b.py --regen <rigol_ip_address>
All options are activated.
The oscilloscope with options seems to be functioning properly.
Hint:
Be carefull.
I couldn't find any instructions on how to reinstall the backup files on the Oszi (means NAND, dump, ...)
(and no command instructions in the Python script either).
« Last Edit: August 28, 2025, 12:16:53 pm by Elektro »
The following users thanked this post: mwb1100, w.v.s.
Offline Retired2
« Reply #3227 on: August 28, 2025, 06:42:46 pm »
Set it to default
Hint:
Be carefull.
MSO5354 Attempt to Change Model Failed with additional Issues
After trying to apply 5504 to this model:
As of today 08-11-2025
-= NEW sysvendor.bin =-sysvendor.bin data:
  size=248 ok! | crc32=60C0FE53 [1623260755] ok!
│   key_size │ key_data        │   value_size │ value_crc   │   value_str_size │ value_decrypted_data   │
│         15 │ E_CFG_MODEL_RAW │           56 │ 4B9626E7    │                4 │5504                │
│         12 │ E_CFG_SN_RAW    │           52 │ E59DF54E    │               13 │           │
│          9 │ E_CFG_MAC       │           56 │ 2AD8E37E    │               17 │      │
Saved sysvendor.bin_mod to 'rigol_sysvendor.bin_mod_17549309591026.data'
sysvendor file has been modified!
PS C:\Users\pspan\MSODump> python rigol_mso_util_2.13b.py --write-sysvendor --write-sysvendor-file rigol_sysvendor.bin_mod_17549309591026.data 192.168.1.4
│ Model   │ Serial        │ Version        │ MAC               │ Lic Model   │
│ MSO5354 │ │ 00.01.03.03.00 │ │ MSO5000     │
│ Code   │ Status   │ Description                                         │
│ 2RL    │ Forever  │ 200Mpts Deep Memory Option                          │
│ COMP   │ Forever  │ Computer Serial Triggering and Analysis(RS232/UART) │
│ EMBD   │ Forever  │ Embedded Serial Triggering and Analysis(IIC, SPI)   │
│ AUTO   │ Forever  │ Automotive Serial Triggering and Analysis(CAN/LIN)  │
│ FLEX   │ Forever  │ FlexRay Serial Triggering and Analysis              │
│ AUDIO  │ Forever  │ Audio Serial Triggering and Analysis(I2S)           │
│ AERO   │ Forever  │ MIL-STD 1553 Serial Triggering and Analysis         │
│ DG     │ Forever  │ Dual Channel WaveGen 25 MHz AWG                     │
│ PWR    │ Forever  │ Integrated Power Analysis                           │
checking /rigol/tools/fram ...done!
Reading FRAM data ...done!
Patching FRAM binary....done!
Rebooting device...Waiting for device to be back online................................................................done
OK then after reboot I got:
PS C:\Users\pspan\MSODump> python rigol_mso_util_2.13b.py --regen 192.168.1.4
Traceback (most recent call last):
  File "C:\Users\pspan\MSODump\rigol_mso_util_2.13b.py", line 1052, in <module>    main()
  File "C:\Users\pspan\MSODump\rigol_mso_util_2.13b.py", line 881, in main    k_model = helpers.model_to_license_str(model)
File "C:\Users\pspan\MSODump\rigol_mso_util_2.13b.py", line 128, in model_to_license_str
    m = re.match(r'([A-Za-z]+)(\d+)([A-Za-z]*)$', model)
File "C:\Users\pspan\AppData\Local\Programs\Python\Python313\Lib\re\__init__.py", line 167, in match
    return _compile(pattern, flags).match(string)
TypeError: expected string or bytes-like object, got 'NoneType'
NOW
I have issues: NO Model shown in Web Control screen , Cannot login to Web Control with default Login / password but can use VNC viewer. l cannot enable SSH either. Bandwidth is still 350Mhz.
It appears all other scope functions work.
How can this be fixed?
Thank you for reading this and in advance for your help.
Offline Elektro
« Reply #3228 on: August 29, 2025, 11:13:18 am »
@Retired2:
Did you have used my additional instructions according to  Reply #3226 or the original instructions according to Reply #2981 by user "BTO"?
Because it seams you don't use the extention "“--model <your_desired_model>”.
If you have followed my additional instructions in Reply #3226,
please read ALL the instructions I wrote in  Reply #3226!
I wrote:
   "For Step 5 the python script "Rigol_MSO_LicensingUtility_2.10b.py" was used."
and
   "Step 5 with “rigol_mso_util_2.13b.py” with and without the extension “--model <your_desired_model>” does not work."
   Set it to default
Check the IP address. After restarting, the device may be assigned a new IP address.
   Hint:
   Be carefull.
(That was my process!)
For Step 5 you have used "rigol_mso_util_2.13b.py"!
I also received error messages with the version “rigol_mso_util_2.13b.py”.
However, my oscilloscope was already at 500 MHz from step 4 onwards, but without any options.
I therefore suspect that the error lies further up.
I don't know why your oscilloscope is still set to 350MHz.
I mean, this topic is described in this chat.
I also mean that there is no solution for it.
« Last Edit: August 29, 2025, 02:11:09 pm by Elektro »
Offline Fluffhamster
  • Country: aq
« Reply #3229 on: November 02, 2025, 07:10:58 pm »
I had eye and jitter options activated i menu before. Is there a way to reactivate them? (not that eye option was working but jitter worked)
Offline sorenkir
« Reply #3230 on: November 03, 2025, 08:40:14 am »
I have reapplied the "patch method" to my version v00.01.03.03.00 ( https://www.eevblog.com/forum/testgear/hacking-the-rigol-mso5000-series-oscilloscopes/msg4856702/#msg4856702 ) and jitter & eye options have reappeared!
Michel.
The following users thanked this post: Fluffhamster
Offline monz
« Reply #3231 on: November 11, 2025, 12:48:01 am »
Hello, thanks for the guide. However, I'm running in to some trouble. I successfully converted a MSO5104 to a MSO5354.
I cannot complete the last step to activate options.
I've tried this under 3.10.x 3.12.x and 3.14.x versions of python from windows and 3.12.x from a machine running linux. Modules it needs installed via pip.
I get the following error:
python.exe" Rigol_MSO_LicensingUtility_2.10b.py --regen 192.168.216.159 --model MSO5354
(Summary table of options/info is displayed here)
  File Rigol_MSO_LicensingUtility_2.10b.py, line 740, in <module>
    main()
  File Rigol_MSO_LicensingUtility_2.10b.py", line 681, in main
    opt_sign, key_hex, prev_key = sign_option({
  File Rigol_MSO_LicensingUtility_2.10b.py", line 81, in sign_option
    bb.extend(opt['model'].encode())
AttributeError: 'NoneType' object has no attribute 'encode'
Offline monz
« Reply #3232 on: November 11, 2025, 05:04:56 am »
I managed to get this working by hard coding some variables in the script.
I changed:
    model = m.group(1).decode()
    ser = m.group(2).decode()
    ver = m.group(3).decode()
    mac = m.group(4).decode()
To
    model = "MSO5354"
    ser = "MS51234xyz"
    ver = "00.01.03.03.00"
    mac = "00-19-AF-AA-BB-CC"
The values for model, ser, ver, and mac were found by going to:
http://scope-ip/cgi-bin/welcome.cgi
For some reason the script isn't parsing this info.
SERIAL_PAT's regex probably just needs to be fixed, not sure how to fix that so I just hard coded it for mine to get it to run.
The following users thanked this post: thm_w, mwb1100
Offline jhobbyist
« Reply #3233 on: November 28, 2025, 03:50:02 pm »
Web Control is broken after using the changepwd exploit, which the Python utility uses. You can restore it with a simple curl command:
curl --location 'http://<scope-ip>/cgi-bin/changepwd.cgi' \
    --form 'pass0=""' \
    --form 'pass1="rigol"'
Long story short, the script takes advantage of CVE-2023-38378 to execute arbitrary commands as root, which "corrupts" the password file used by web control. The above curl command restores the password using the same exploit.
The following users thanked this post: w.v.s.
Offline jhobbyist
« Reply #3234 on: November 28, 2025, 04:45:53 pm »
NOW
Thank you for reading this, and in advance for your help.
My previous post resolves your Web Control login issue. For SSH, you can either use the Python script or directly invoke sshd using the same exploit. You will need to execute this on every boot to re-enable access, and you will need to restore the Web Control password after each execution. For simplicity, here is a single command that will enable ssh and restore the default Web Control password:
    --form 'pass0=""' \
    --form 'pass1=";/usr/bin/sshd; echo admin:rigol"'
You will now be able to log in as root:
ssh root@<scope-ip>Password: Rigol201
Now that you have SSH access, there are ways to enable SSH at startup. I haven't taken the time to learn the startup process for the Linux implementation on the scope, so I'll leave that for this community.
Note: For those who are curious about the Web Control password, you can SSH in and cat the password file before restoring the password and see that it contains the output from the last command executed.
cat /rigol/default/user.conf
« Last Edit: November 28, 2025, 05:11:00 pm by jhobbyist »
Offline rpro
« Reply #3235 on: November 28, 2025, 06:10:59 pm »
If you haven’t tried it yet, VNC is worth a look. The scope has a built-in running VNC server, and you can connect with a viewer like RealVNC with no password needed. You’ll also find it has much less latency than the web-control option.
The following users thanked this post: jhobbyist
Offline jhobbyist
« Reply #3236 on: November 28, 2025, 07:32:26 pm »
I was using VNC, I just do not like having features that do not work :D. After some digging through this thread, I see this has been addressed by BTO previously in 2.13b; my above responses were based on the 2.10 Python utility. The curl API method I posted still works for starting SSH, but here are the Python commands to start SSH on boot and fix the Web Control password:
Enable SSH on boot:
python rigol_mso_util_2.13b.py --ssh --start-sshd-on-boot <scope-ip>
Reset Web Control Password:
python rigol_mso_util_2.13b.py --reset-web-pwd <scope-ip>
Offline retronexus
« Reply #3237 on: April 04, 2026, 08:37:07 pm »
Sorry to ask, but what guide should I follow here now in best case? this is a massive amount of threads I am not sure which one to start with
Offline BTO
« Reply #3238 on: April 05, 2026, 07:06:05 am »
Sorry to ask,
HOW DARE YOU ASK, I MEAN .. What were you thinking  :-DD
Sorry, couldn't help myself.
All the instructions are on page 1, First post of this thread
https://www.eevblog.com/forum/testgear/hacking-the-rigol-mso5000-dr-mefisto-licensing-method/
You need to download Python
You need instructions on installing the necessary libraries etc
You need rufus to burn the files,
All of that is on the 1st page
but if you want to just jump in
HERE IS THE DIRECT LINK TO MY CLOUD SERVER
https://mega.nz/folder/A8cEgQRI#5FSoMrCurJi71T7VkRPgYQ
DOWNLOAD THE PDF FILE              (These are your step by step instructions)
DOWNLOAD THE PYTHON FILE  .py (This is your script to unlock and properly license the scope)
Now, Depending on which firmware you have will determine IF you need to download the file.
The current version is 1.3.3.0   .  if your version is slower, then download that zip file
if it's the same then you don't need to download that.
GOOD LUCK
MAY THE FORCE BE WITH YOU
LET ME KNOW HOW IT GOES
If you have any problems .... Let me know
EDIT : and as always, After you unlock your scope, to learn how to use it properly
i have made a series of videos for you to follow.
Do them in your own time.
https://www.eevblog.com/forum/testgear/post-hacking-rigol-mso5000-post-hacking-tutorial-deep-dive/msg5419790/#msg5419790
« Last Edit: April 19, 2026, 03:41:46 am by BTO »
QUESTION EVERYTHING!!!
Offline BTO
« Reply #3239 on: April 05, 2026, 07:17:00 am »
JUST A BIT OF A SHORT RANT
After addressing this last post i started thinking... My God where has the time gone.
the activations for MSO5000 have certainly slowed down in number and frequency.
So i decided to look it up.
MSO5000  was released in 2018  , So it's already been 8 years... WOW !!!
DS2000A was released in 2014, So that's now been 12 years
and the 1054Z  i mean i didn't even bother to look it up
But WE STARTED ALL THIS HACKING STUFF i think it started with MADCROW , with the DS1052E back in 2010 (16 years)
Time flies huh !
Anyway.. that's my rant.
The following users thanked this post: egonotto, mwb1100, jhobbyist
Offline sdouble
« Reply #3240 on: April 05, 2026, 12:35:30 pm »
Time flies huh !
nice, consistency is the key  ;)
The following users thanked this post: BTO
Offline budronator
  • Country: kz
« Reply #3241 on: April 17, 2026, 10:06:06 am »
Hello everyone!
I bought two Rigol MSO5074. One for me and a friend.
One Rigol MSO5074 flashed the MSO5504 model with the script without any problems. My friend was very pleased with the device)
The second Rigol MSO5074 upgraded to 350 MHz without any problems. Errors occurred when reading the XXTEA key and preparing sysvendor.bin for the MSO5504. I've attached the command line log.
I tried resetting the device to default settings several times when booting. I downgraded the firmware to 00.01.03.02.02 and updated it to the current 00.01.03.03.00. The errors persist.
I read about a similar error in Maol posts
https://www.eevblog.com/forum/testgear/hacking-the-rigol-mso5000-series-oscilloscopes/msg5741637/#msg5741637
https://www.eevblog.com/forum/testgear/hacking-the-rigol-mso5000-series-oscilloscopes/msg5742123/#msg5742123
I read the solution proposed by Protegimus by editing the script
https://www.eevblog.com/forum/testgear/hacking-the-rigol-mso5000-series-oscilloscopes/msg5779377/#msg5779377
I modified the script, but the error is the same.
C:\EEV>python rigol_mso_util_2.13b.py --save-sysvendor 192.168.10.188 --model MSO5504
│ MSO5074 │ MS5A275XXXXXX │ 00.01.03.03.00 │ 00-19-AF-7B-XX-XX │ MSO5504     │
│ BW07T1 │ Forever  │ 70MHz to 100MHz Bandwidth Upgrade Option            │
│ BW07T2 │ Forever  │ 70MHz to 200MHz Bandwidth Upgrade Option            │
│ BW07T3 │ Forever  │ 70MHz to 350MHz Bandwidth Upgrade Option            │
Reading sysvendor.bin ...done!
Saved sysvendor to 'rigol_sysvendor_17764172013367.data'
C:\EEV>
C:\EEV>python rigol_mso_util_2.13b.py --sysvendor-key 192.168.10.188 --model MSO5504
Looking for sysvendor.bin key... --== Don't poke the bear. Please be patient ==--done!
Timers - memory dump: 0.0340 sec | download dump: 0.0387 sec | find key: 0.1741 sec
Device XXTEA key [89898788977A57160077007A77D8788A] was found after checking 46468 possible keys
Saving decrypted sysvendor.bin locally...done!
sysvendor.bin data:
  size=268 ok! | crc32=C1455897 [3242547351] ok!
  File "C:\EEV\rigol_mso_util_2.13b.py", line 1052, in <module>
    main()
  File "C:\EEV\rigol_mso_util_2.13b.py", line 947, in main
    rigol_sysvendor.print_data(svd, act_key)
  File "C:\EEV\rigol_mso_util_2.13b.py", line 671, in print_data
    decdata = xxtea.decrypt(vdata, xxtea_key, padding=False)
ValueError: Data length must be a multiple of 4 bytes and must not be less than 8 bytes
C:\EEV>
C:\EEV>python rigol_mso_util_2.13b.py --offline --sysvendor-file rigol_sysvendor_17764172013367.data --use-sysvendor-key 89898788977A57160077007A77D8788A --model MSO5504
sysvendor.bin data:
    main()
  File "C:\EEV\rigol_mso_util_2.13b.py", line 854, in main
I attached the script that I used and the dump
How can I make the script work without errors?
« Last Edit: April 18, 2026, 04:16:55 pm by budronator »
Offline reztek
  • Country: br
« Reply #3242 on: April 18, 2026, 12:10:09 pm »
I'm not a coder, but using Claude I've got this
Got the root cause. The outer `xxtea.decrypt` of the file itself worked fine (size=268, CRC ok). The crash is inside `print_data` at line 671 — when it loops through individual key-value entries and tries to XXTEA-decrypt each `vdata = val_data[12:]`. With a 268-byte sysvendor file, at least one entry is short enough that after stripping the 12-byte per-value header, the remainder is either fewer than 8 bytes or not a multiple of 4, both of which xxtea rejects.
The fix is to guard that decrypt call — if `vdata` doesn't satisfy xxtea's constraints, fall back to showing the raw bytes instead of crashing:**Root cause:** The outer file decrypt worked fine (268 bytes, CRC ok). But inside `print_data`, the loop decrypts each key-value's `vdata = val_data[12:]` individually with `act_key`. With a 268-byte sysvendor file, at least one entry is short enough that after stripping the 12-byte per-value header (`crc32` + `dsize` + `asize`), the remainder violates xxtea's two hard constraints — must be ≥ 8 bytes **and** a multiple of 4.
**The fix** (lines 670–678 in the patched file): guard the decrypt with a length/alignment check before calling xxtea. If `vdata` is too short or misaligned, the raw bytes are shown directly instead of crashing. This is safe because that code path is display-only — `change_data` has its own separate decrypt loop that isn't affected.
Note that there's a second `xxtea.decrypt(vdata, act_key, ...)` at line 714 inside `change_data` that has the same latent bug, but it only runs if you pass `--model`/`--serial`/`--mac` flags to actually modify the file. If you hit that path later, the same guard would need to be applied there too.
The following users thanked this post: budronator
Offline budronator
  • Country: kz
« Reply #3243 on: April 18, 2026, 03:16:49 pm »
@reztek - hi! Thanks for the answer!
Can I ask you to fix the broken code on line 714 using Claude?
Maybe the code in other places in the script needs to be adjusted?
C:\11\12>python rigol_mso_util_2.13b.py --sysvendor-key 192.168.10.188 --model MSO5504
│ MSO5074 │ MS5A275XXXXXX │ 00.01.03.03.00 │ 00-19-AF-XX-XX-XX │ MSO5504     │
Timers - memory dump: 0.0314 sec | download dump: 0.0276 sec | find key: 0.1647 sec
sysvendor.bin data:
│          0 │                 │            0 │ 00000000            │                0 │                        │
│         15 │ E_CFG_MODEL_RAW │           60 │ 0C31C276 / 76C2310C │                7 │ MSO5074                │
│         12 │ E_CFG_SN_RAW    │           52 │ B181465C / 5C4681B1 │               13 │ MS5A275XXXXXX          │
│          9 │ E_CFG_MAC       │           56 │ D6117D6A / 6A7D11D6 │               17 │ 00:19:AF:XX:XX:XX      │
C:\11\12>python rigol_mso_util_2.13b.py --offline --sysvendor-file rigol_sysvendor_17765172894893.data --use-sysvendor-key 89898788977A57160077007A77D8788A --model MSO5504
sysvendor.bin data:
  File "C:\11\12\rigol_mso_util_2.13b.py", line 1057, in <module>
    main()
  File "C:\11\12\rigol_mso_util_2.13b.py", line 863, in main
    nsvd = rigol_sysvendor.change_data(svd, dev_key, act_key, {"E_CFG_MODEL_RAW": args.model, "E_CFG_SN_RAW": args.serial, "E_CFG_MAC": args.mac_address})
  File "C:\11\12\rigol_mso_util_2.13b.py", line 714, in change_data
    decdata = xxtea.decrypt(vdata, act_key, padding=False)
Offline reztek
  • Country: br
« Reply #3244 on: April 18, 2026, 03:45:46 pm »
Same root cause, second location — the `change_data` loop hits the phantom zero-size entry first and crashes identically. Need the same guard at line 714.Now I can see the full picture. The phantom entry has `val_size=0` so `val_data` is empty — `crc32`, `dsize`, `asize` all come back as zero, and then `xxtea.decrypt(b'', ...)` crashes. The entry also needs to be re-serialised correctly into `pfvd`, otherwise the output file will be malformed. The fix skips decrypt/re-encrypt for any entry where `val_size == 0` and just passes it through verbatim:Now let's verify both patches look right and do a dry-run simulation of the full `change_data` path against the real file:Pipeline is solid. Copy to outputs:Two patches applied, both verified against your actual file:
**`print_data` (line ~671)** — same guard as before: if `vdata` is too short/misaligned, show raw bytes instead of calling xxtea.
**`change_data` (line ~709)** — the more important fix. The logic is split into two branches:
- **Normal entries** (`vdata ≥ 8 bytes, multiple of 4`): decrypt → optionally substitute new value → re-encrypt → rebuild entry. Everything including `pfvd +=` and `i += val_size` lives inside the branch.
- **Phantom entry** (`val_size=0`): skip decrypt/re-encrypt entirely, serialise back the original zero-size entry verbatim into `pfvd`, and advance `i`.
The dry-run confirmed the full pipeline: phantom passed through → `E_CFG_MODEL_RAW` patches to `MSO5504` → SN and MAC preserved → CRC correct → dev_key re-encrypt/decrypt roundtrip clean.
The following users thanked this post: w.v.s., budronator
Offline budronator
  • Country: kz
« Reply #3245 on: April 18, 2026, 04:13:44 pm »
Great job @reztek !
Special thanks to Claude AI !
Everything looks great on the scope now))
│ MSO5504 │ MS5A275XXXX │ 00.01.03.03.00 │ 00-19-AF-XX-XX-XX│ MSO5504     │
Offline mwb1100
« Reply #3246 on: April 18, 2026, 04:51:37 pm »
In lines 662 and 708 of "rigol_mso_util_2_13b_fixed (1).py" the calls to
to_bytes(4) have been changed to
to_bytes(4, byteorder='little')
That changes the behavior (the default byteorder is 'big').
I don't know if those changes do anything harmful, but it would be good to understand why they were made.
Offline reztek
  • Country: br
« Reply #3247 on: April 18, 2026, 10:14:34 pm »
Exactly the same as the "original" script (the one on budronator post).
https://www.diffchecker.com/z99cn39N/
Offline mwb1100
« Reply #3248 on: April 19, 2026, 12:46:49 am »
Then maybe budronator can comment?  The original "rigol_mso_util_2.13b.py" file is found in this message:
  - Hacking the Rigol MSO8204 / MSO8000 Reply #8
Note: I don't know if it's a problem - I just noticed the change in a diff and wondered why "byteorder='little'" was added.  I can understand why the "byteorder" named parameter was added if python earlier than v3.11 is used - the parameter did not have a default until v3.11.  SDo if run on older python interpreters those lines would cause an error. But when the default was added in python 3.11, it was 'big' so this will change the behavior.  The changed behavior may or may not matter.
« Last Edit: April 19, 2026, 12:51:34 am by mwb1100 »
Offline BTO
« Reply #3249 on: April 19, 2026, 03:52:10 am »
Great job @reztek !
Hi mate, Apologies, been flat out with work.
1. I'm glad you got your 2 scopes activated.
2. I'll have a look at Line 714 ,, thanks for that
3. I noticed, for some weird reason that the link in the original post to my cloud server was now broken, i've updated the link, it now works.
4. As a first attempt YOU SHOULD BE USING the 2.10b script  not the 2.13b  , Generally speaking both will work and have worked.
   But we have found that the 2.10b is more reliable.  the 2.13b was created when decided to see if we could unlock, not just MSO5000 but MSO7000 and MSO8000
   so there may be a difference between the MSO5000 and the MSO8000 when it comes to the bit length of the file.
Here is the direct link to the cloud which has the 2.10b script
For Everyone's convenience i have attached both 2.10b  and 2.13b here
Try the 2.10b  first
