Hi BTO!
Thank you for your detailed answer.
To my shame, I didn't read the thread carefully and didn't know that the 2.10b version of the script was specifically created for the MSO5000 series.
I got the desired 500 MHz and a model change to MSO5504 and I am very happy) Special thanks to @reztek
Have a nice day, guys!
NO PROBLEM MATE.
This thread is so long now that , in all fairness it's hard for newcomers to absorb it all.
A lot of us have contributed to this and i myself have tried to make things easier and posts shorter.
i remember back in the DS2000A days we had "The Monster Post" and then i created "The Short Post"
and then the short post became another monster post. what are you gonna do ?
Same thing here. My idea for creating this post
https://www.eevblog.com/forum/testgear/hacking-the-rigol-mso5000-dr-mefisto-licensing-method/was that everyone would just go to the first page, Post 1 and read that an activate their scope.
As you get deeper, people start to forget about page 1 and comment 1.
So i've put in effort to keep repeating it every now and then.
Ultimately, most people activate without issue, a few people stumble up here and there.
Example : you activated your first scope without issue and the second one tripped up
(and it is interesting, Because you would have used the same script 2.13b on both scopes, it's interesting from a firmware point of view
as to why 1 scope went through without issue but the second failed) this is largely firmware based
At the end of the day, We escalated from the DS2000A post and went to the MSO5000 this post (no one thought about 7000 and 8000 series at that point).
we had around 11 versions of the script before we settled on 2.10b the first 5 versions or so involved the same process but it was longer
and you had to wait maybe 1-2 mins for activation.
Most of the waiting time was the script reading through irrelevant parts of memory until it got to the XXTEA key and modified it.
that long wait time did 2 things
1. it confused people as to.... is my scope bricked and is this still working ?
2. it increased the change of.... if a power loss happened your scope would be bricked.
so we decided to just focus on jumping to the specific memory address and changing the key, this reduced the activation time from minutes to seconds.
after that , no one had freezing issues anymore.
Once the MSO5000 script was finished, we added some cosmetic things , I added some things like ***** Please Wait and ***** Restarting now
and things like that to keep people in the loop of what was happening and i added the stars so as to remove doubt of freezing or not.
we made it look a little prettier, we added more detail
we added some back end troubleshooting stuff in case we needed it , which we rarely did.
we added some SSH stuff etc etc
so the 2.10b had a lot of work put into it
after that we focused on 7000 and 8000 series because this person created an MSO8000 post and wanted an activation.
but then we tried to see how much bandwidth we could actually squeeze out of it as well and to see if other features like Power analysis and Eye Analysis
could be squeezed out of it, Unlike with the patch method, where that was added but not actually supported by the scope, we realized
Eye Analysis is not actually possible from the MSO500 series.
so.. it has been an interesting journey indeed and i have learned a lot from it.
that's what i like about EEV Blog (I have a lot of knowledge about Electronics, I.T. and Telecomnunications)
but i always find myself learning more . and.... AT MY AGE 52 that is a very welcomed thing.
so yeah... Glad to hear you've activated both scopes.
NOW YOU CAN HEAD OVER (if you like) TO LEARN EVERYTHING ABOUT YOUR SCOPE
AND DOWNLOAD THE VIDEO SERIES THAT I CREATED
The "Deep Dive"
https://www.eevblog.com/forum/testgear/post-hacking-rigol-mso5000-post-hacking-tutorial-deep-divethe idea here is...
If you want to get beyond just knowing the basic functions of your scope
If you want to know your scope in depth
then this course is for you. it's a long course and do it in your own time, but it's definitely informative.
BE COOL
