Sorry about the delay between releases, been super busy of late.... Here is the latest binary... Not too many ground breaking changes, mostly just tying up loose ends and other bug fixes.
PR18 Download:
http://jmp.sh/k0tTgXgWhat's New:-----------------------------------------------------------
1. Fixed a bug where not able to turn grid off in Phosphor mode.
2. Implemented simple waveform brightness support for 64bit operating systems.
3. Increased Output Window height so first measurement item is visible.
4. Implemented the Probe main menu items for CH1, CH2 and Math Channel.
5. Fixed a bug where a channel might not fully clear when changing to None in
Demo Mode.
6. Changed Phase Offset units from Radians to Degrees.
7. Fixed an inconsistency in cursor over levers and dragging levers witch might
cause a situation where a lever won't move even when the cursor changes
suggesting you can.
8. Added an alternative rendering option in case AlphaBlend() fails, some 32 bit
systems don't work well with AlphaBlend() apparently, especially in systems
with multiple display configurations.
9. Reordered some Time Division menu items.
10. Added Dynamic option to Reference Channel's Function Generator (works like Demo Mode).
11. Implemented initial support of saving/restoring GUI settings on close/restart.
12. Increased Trigger Information render width to prevent voltages from rendering off
screen.
13. Implemented hiding of Bottom Pane voltage labels when respective channel is hidden.
