dc19 : b701d0 staa CmdTableIndex
dc1c : 86ee ldaa #$EE
dc1e : b101d0 cmpa CmdTableIndex
dc21 : 2609 bne LDFAA ; branch if valid CmdChar
dc23 : bdd6c0 jsr subResetCmdFlags
dc26 : 7ee3a0 jmp LE768 ; set flagCmdParse bit6 and rts
[SOURCE LINES]
File: test.lst
9029 dc19
9030 dc1c
9031 dc1e
9032 dc21
9033 dc23
9034 dc26
...Been looking for an inverse assembler for the MC6800. Haven't found one yet, but thought it might be worthwhile to summarize what is available.
If you don't have a .R file, or the .S source to build the .R file, I don't know if there is a way to use any of these old IAL style inverse assembler files with the 16900 series logic analyzer software. The files as they are normally distributed are after the IALDOWN tool has done some sort of undocumented transformation of the .R files. Maybe that transformation could be reverse engineered so that a tool could be written to do an inverse transformation back in .R files. Or maybe even disassemble the files back into functionally equivalent .S source files.
For example, I have a 16702B with a 16752A card and I've been successful using it on a 6802 processor. I can successfully load i6800_p, the inverse assembler for general purpose (flying lead) probes.
/* definitions for the different unique bit patterns for each instruction
* in the different instruction groups -- used by the interpreter
/* instruction group 1 */
const u_int16 IF_OP = 4;
const u_int16 IF_BITS = 5;
const u_int16 ICASE_OP = 6;
const u_int16 ICASE_BITS = 7;
/* instruction group 2 */
const u_int16 IGO_TO = 4;
const u_int16 ICALL = 5;
const u_int16 ISTR_OUTPUT = 6;
const u_int16 INUM_OUTPUT = 7;
/* instruction group 3 */
const u_int16 ILOAD_ACC = 8;
const u_int16 IADD_ACC = 9;
const u_int16 ISUB_ACC = 10;
const u_int16 IAND_ACC = 11;
const u_int16 IOR_ACC = 12;
const u_int16 IXOR_ACC = 13;
const u_int16 ITAG_WITH = 14;
const u_int16 INP_ABS = 15;
/* instruction group 4 */
const u_int16 ISTORE_MEM = 4;
const u_int16 INC_MEM = 5;
const u_int16 IDEC_MEM = 6;
const u_int16 INP_ABSQ = 7;
/* instruction group 5 */
const u_int16 INP_REL = 2;
const u_int16 INP_RELQ = 3;
/* instruction group 6 */
const u_int16 IROT_LEFT = 8;
const u_int16 IROT_RIGHT = 9;
const u_int16 IEXT_BIT = 10;
const u_int16 IPOS_ABS = 11;
const u_int16 IPOS_REL = 12;
/* instruction group 7 */
const u_int16 INOP = 16;
const u_int16 ICOMP_ACC = 17;
const u_int16 ITWOCOMP_ACC = 18;
const u_int16 IRETURN = 19;
const u_int16 ION_TRACE = 20;
const u_int16 IOFF_TRACE = 21;
const u_int16 IABORT = 22;
const u_int16 IFNOT_MAP = 23;
const u_int16 IMARKLINE_O_NA = 24;
const u_int16 IMARKLINE_S_NA = 25;
const u_int16 IMARKLINE_O_A = 26;
const u_int16 IMARKLINE_S_A = 27;
const u_int16 IMARKSTATE_DISP = 28;
const u_int16 IMARKSTATE_SUP = 29;
const u_int16 INEWLINE = 30;
const u_int16 IFETCH_POSITION = 31;
/* conditional instruction -- bit 15 is set */
/* instruction = (opcode >> 13) */
100x xxxx xxxx xxxx IF_OP = 4
101x xxxx xxxx xxxx IF_BITS = 5
110x xxxx xxxx xxxx ICASE_OP = 6
111x xxxx xxxx xxxx ICASE_BITS = 7
/* transfer/output instruction -- bit 14 is set */
/* instruction = (opcode >> 12) */
0100 xxxx xxxx xxxx IGO_TO = 4
0101 xxxx xxxx xxxx ICALL = 5
0110 xxxx xxxx xxxx ISTR_OUTPUT = 6
0111 xxxx xxxx xxxx INUM_OUTPUT = 7
/* set immediate instruction -- bit 13 is on */
001x xxxx xxxx xxxx
/* math instruction -- bit 12 is on */
/* instruction = (opcode >> 9) */
0001 000x xxxx xxxx ILOAD_ACC = 8
0001 001x xxxx xxxx IADD_ACC = 9
0001 010x xxxx xxxx ISUB_ACC = 10
0001 011x xxxx xxxx IAND_ACC = 11
0001 100x xxxx xxxx IOR_ACC = 12
0001 101x xxxx xxxx IXOR_ACC = 13
0001 110x xxxx xxxx ITAG_WITH = 14
0001 111x xxxx xxxx INP_ABS = 15
/* single variable instruction -- bit 11 is on */
0000 100x xxxx xxxx ISTORE_MEM = 4
0000 101x xxxx xxxx INC_MEM = 5
0000 110x xxxx xxxx IDEC_MEM = 6
0000 111x xxxx xxxx INP_ABSQ = 7
/* input relative instruction -- bit 10 is on */
0000 010x xxxx xxxx INP_REL = 2
0000 011x xxxx xxxx INP_RELQ = 3
/* single operand instruction -- bit 9 is on */
/* instruction = (opcode >> 6) */
0000 0010 00xx xxxx IROT_LEFT = 8
0000 0010 01xx xxxx IROT_RIGHT = 9
0000 0010 10xx xxxx IEXT_BIT = 10
0000 0010 11xx xxxx IPOS_ABS = 11
0000 0011 00xx xxxx IPOS_REL = 12
/* implied operand instruction - bits 15-5 off, bit 4 on */
0000 0000 0001 0000 INOP = 16
0000 0000 0001 0001 ICOMP_ACC = 17
0000 0000 0001 0010 ITWOCOMP_ACC = 18
0000 0000 0001 0011 IRETURN = 19
0000 0000 0001 0100 ION_TRACE = 20
0000 0000 0001 0101 IOFF_TRACE = 21
0000 0000 0001 0110 IABORT = 22
0000 0000 0001 0111 IFNOT_MAP = 23
0000 0000 0001 1000 IMARKLINE_O_NA = 24
0000 0000 0001 1001 IMARKLINE_S_NA = 25
0000 0000 0001 1010 IMARKLINE_O_A = 26
0000 0000 0001 1011 IMARKLINE_S_A = 27
0000 0000 0001 1100 IMARKSTATE_DISP = 28
0000 0000 0001 1101 IMARKSTATE_SUP = 29
0000 0000 0001 1110 INEWLINE = 30
0000 0000 0001 1111 IFETCH_POSITION = 31
I should spend some time looking at the 16900 series Analysis AddIn Tool. It might contain enough information to write a tool to decode a .R file back into something that could be assembled again with the IAL assembler.
IA File: i68000_i
IA Description: "68000 IA FOR INTERFACE 1_0"
IA Field Option: B
IA File: i68000_p
IA Description: "68000 IA FOR GP PROBES 1_0"
IA Field Option: B
IA File: i68008_i
IA Description: "68008 IA FOR INTERFACE 1_0"
IA Field Option: B
IA File: i68008_p
IA Description: "68008 IA FOR GP PROBES 1_0"
IA Field Option: B
IA File: i6800_i
IA Description: "6800/02 IA FOR INTERFACE 1_0"
IA Field Option: A
IA File: i6800_p
IA Description: "6800/02 IA FOR GP PROBES 1_0"
IA Field Option: B
IA File: i68010_i
IA Description: "68010 IA FOR INTERFACE 1_0"
IA Field Option: B
IA File: i68010_p
IA Description: "68010 IA FOR GP PROBES 1_0"
IA Field Option: B
IA File: i68020_i.p
IA Description: "68020 INVERSE ASSEMBLER 1_0"
IA Field Option: C
IA File: i6809e_p
IA Description: "6809E IA FOR GP PROBES 1_0"
IA Field Option: B
IA File: i6809_i
IA Description: "6809/9E IA FOR INTERFACE 1_0"
IA Field Option: A
IA File: i6809_p
IA Description: "6809 IA FOR GP PROBES 1_0"
IA Field Option: B
IA File: i80186e_.i
IA Description: "80186 ENHANCED IA 1_0"
IA Field Option: B
IA File: i80186_i
IA Description: "80186 IA FOR INTERFACE 1_0"
IA Field Option: B
IA File: i80188e_.i
IA Description: "80188 ENHANCED IA 1_0"
IA Field Option: B
IA File: i80188_i
IA Description: "80188 IA FOR INTERFACE 1_0"
IA Field Option: B
IA File: i80286_i
IA Description: "80286 IA FOR INTERFACE 1_0"
IA Field Option: B
IA File: i80386_8.7
IA Description: "80386 IA WITH 80X87 1_0"
IA Field Option: D
IA File: i80386_i
IA Description: "80386 IA FOR INTERFACE 1_0"
IA Field Option: D
IA File: i8085_ip
IA Description: "8085 INVERSE ASSEMBLER 1_0"
IA Field Option: A
IA File: i8086_i
IA Description: "8086 IA FOR INTERFACE 1_0"
IA Field Option: B
IA File: i8088_i
IA Description: "8088 IA FOR INTERFACE 1_0"
IA Field Option: B
IA File: insc800_.i
IA Description: "NSC800 IA FOR INTERFACE 1_0"
IA Field Option: A
IA File: iz80_i
IA Description: "Z80 IA FOR INTERFACE 1_0"
IA Field Option: A
I finished up the .R extractor and ran it on all the files in invasm.zip. Attached is invasm_v3.zip which has the results as well as the previous output from configtxt.
Title: 8085 CONFIG FOR INTERFACE 1_0
Pod assigments (? = disabled)
Label 0: ADDR (16 bits): A2: ******** ********
Label 1: DATA ( 8 bits): A1: ........ ********
Label 2: STAT ( 4 bits): A1: ....**** ........
For the configuration text, have you looked at trying to decode the Master and Slave clock specifications, and the Normal, Demultiplex, or Mixed Clocks modes for each pod?
LABEL_0015
GOTO LABEL_0016
LABEL_0015
GOTO LABEL_0026
"IAL"
IF TASK = 3 THEN GOTO LABEL_0010
IF TASK = 4 THEN GOTO LABEL_0015
IF TASK = 5 THEN GOTO LABEL_0015
OUTPUT "Illegal Task Request"
ABORT
OUTPUT "Data Error"
ABORT
LABEL_000D
POSITION ABS,1
OUTPUT "Illegal Opcode"
ABORT
LABEL_0010
LOAD ID_CODE
IF 7,0 = VAR_0048 THEN GOTO LABEL_0016
GOTO LABEL_0026
LABEL_0015
GOTO LABEL_0016
LABEL_0016
LOAD INPUT_TAG
IF 17,16 = 0 THEN GOTO LABEL_0043
LOAD INPUT_STATUS
IF 2,2 = 1 THEN GOTO LABEL_0043
LOAD INPUT_TAG
CASE_OF 1,0
GOTO LABEL_01A2
GOTO LABEL_0043
GOTO LABEL_0054
NOP
CASE_END
RETURN
LABEL_0026
LOAD INPUT_STATUS
IF 3,0 = 9 THEN GOTO LABEL_005B
LOAD INPUT_DATA
POSITION ABS,3
OUTPUT ACCUMULATOR,FORMAT=8,HEX,2
POSITION REL,1
LOAD INPUT_STATUS
CASE_OF 3,0
OUTPUT "operand fetch"
OUTPUT "stack read"
OUTPUT "stack write"
OUTPUT "stack read"
OUTPUT "halt"
OUTPUT "vector"
OUTPUT "unused"
OUTPUT "opcode fetch"
OUTPUT "DMA read"
OUTPUT "DMA write"
OUTPUT "memory write"
OUTPUT "memory read"
OUTPUT "out of synch"
OUTPUT "interrupt ack"
CASE_END
SET RETURN_FLAGS,0
RETURN
LABEL_0043
LOAD INPUT_DATA
POSITION ABS,3
POSITION REL,1
LOAD INPUT_STATUS
CASE_OF 2,0
OUTPUT "non valid cycle"
OUTPUT "dma or halt"
CASE_END
SET RETURN_FLAGS,0
RETURN
LABEL_0054
LOAD INPUT_DATA
POSITION ABS,3
POSITION REL,1
OUTPUT "unused cycle"
SET RETURN_FLAGS,0
RETURN
LABEL_005B
SET RETURN_FLAGS,1
INPUT REL,0
LOAD INITIAL_DATA
CASE_OF 7,7
GOTO LABEL_0062
GOTO LABEL_0103
CASE_END
LABEL_0062
CASE_OF 7,4
GOTO LABEL_006C
GOTO LABEL_008C
GOTO LABEL_009F
GOTO LABEL_00C4
GOTO LABEL_00E2
GOTO LABEL_00E2
GOTO LABEL_00E2
GOTO LABEL_00E2
CASE_END
LABEL_006C
CASE_OF 3,0
GOTO LABEL_000D
OUTPUT "NOP"
GOTO LABEL_000D
GOTO LABEL_000D
GOTO LABEL_000D
GOTO LABEL_000D
OUTPUT "TAP"
OUTPUT "TPA"
OUTPUT "INX"
OUTPUT "DEX"
GOTO LABEL_007F
GOTO LABEL_0081
GOTO LABEL_007F
GOTO LABEL_0081
GOTO LABEL_007F
GOTO LABEL_0081
CASE_END
RETURN
LABEL_007F
OUTPUT "CL"
GOTO LABEL_0082
LABEL_0081
OUTPUT "SE"
LABEL_0082
IF 2,1 = 1 THEN OUTPUT "V"
IF 2,1 = 2 THEN OUTPUT "C"
IF 2,1 = 3 THEN OUTPUT "I"
RETURN
LABEL_008C
CASE_OF 3,0
OUTPUT "SBA"
OUTPUT "CBA"
GOTO LABEL_000D
GOTO LABEL_000D
GOTO LABEL_000D
GOTO LABEL_000D
OUTPUT "TAB"
OUTPUT "TBA"
GOTO LABEL_000D
OUTPUT "DAA"
GOTO LABEL_000D
OUTPUT "ABA"
GOTO LABEL_000D
GOTO LABEL_000D
GOTO LABEL_000D
GOTO LABEL_000D
CASE_END
RETURN
LABEL_009F
OUTPUT "B"
CASE_OF 3,0
OUTPUT "RA"
GOTO LABEL_000D
OUTPUT "HI"
OUTPUT "LS"
OUTPUT "CC"
OUTPUT "CS"
OUTPUT "NE"
OUTPUT "EQ"
OUTPUT "VC"
OUTPUT "VS"
OUTPUT "PL"
OUTPUT "MI"
OUTPUT "GE"
OUTPUT "LT"
OUTPUT "GT"
OUTPUT "LE"
CASE_END
LABEL_00B2
INCREMENT INPUT_ADDRESS
LOAD INPUT_ADDRESS
ADD 1
STORE VAR_003E
INPUT ABS,INPUT_ADDRESS
IF INPUT_ERROR <> 0 THEN GOTO LABEL_017C
LOAD INPUT_DATA
POSITION ABS,6
IF 7,7 = 1 THEN INCLUSIVE_OR VAR_0046
ADD VAR_003E
AND VAR_0042
IF_NOT_MAPPED THEN OUTPUT ACCUMULATOR,FORMAT=16,HEX,4
RETURN
LABEL_00C4
CASE_OF 3,0
OUTPUT "TSX"
OUTPUT "INS"
GOTO LABEL_00D7
GOTO LABEL_00D7
OUTPUT "DES"
OUTPUT "TXS"
GOTO LABEL_00D7
GOTO LABEL_00D7
GOTO LABEL_000D
OUTPUT "RTS"
GOTO LABEL_000D
OUTPUT "RTI"
GOTO LABEL_000D
GOTO LABEL_000D
OUTPUT "WAI"
OUTPUT "SWI"
CASE_END
RETURN
LABEL_00D7
IF 2,2 = 0 THEN OUTPUT "PUL"
IF 2,2 = 1 THEN OUTPUT "PSH"
CASE_OF 0,0
GOTO LABEL_00FF
GOTO LABEL_0101
CASE_END
RETURN
LABEL_00E2
CASE_OF 3,0
OUTPUT "NEG"
GOTO LABEL_000D
GOTO LABEL_000D
OUTPUT "COM"
OUTPUT "LSR"
GOTO LABEL_000D
OUTPUT "ROR"
OUTPUT "ASR"
OUTPUT "ASL"
OUTPUT "ROL"
OUTPUT "DEC"
GOTO LABEL_000D
OUTPUT "INC"
OUTPUT "TST"
GOTO LABEL_00F5
OUTPUT "CLR"
CASE_END
GOTO LABEL_00F9
LABEL_00F5
CASE_OF 5,5
GOTO LABEL_000D
OUTPUT "JMP"
CASE_END
LABEL_00F9
CASE_OF 5,4
GOTO LABEL_00FF
GOTO LABEL_0101
GOTO LABEL_016B
GOTO LABEL_0170
CASE_END
LABEL_00FF
OUTPUT "A"
RETURN
LABEL_0101
OUTPUT "B"
RETURN
LABEL_0103
CASE_OF 3,0
OUTPUT "SUB"
OUTPUT "CMP"
OUTPUT "SBC"
GOTO LABEL_000D
OUTPUT "AND"
OUTPUT "BIT"
OUTPUT "LDA"
GOTO LABEL_0116
OUTPUT "EOR"
OUTPUT "ADC"
OUTPUT "ORA"
OUTPUT "ADD"
GOTO LABEL_011E
GOTO LABEL_0126
GOTO LABEL_0138
GOTO LABEL_0141
CASE_END
GOTO LABEL_0150
LABEL_0116
IF 7,4 = 8 THEN GOTO LABEL_000D
IF 7,4 = 12 THEN GOTO LABEL_000D
OUTPUT "STA"
GOTO LABEL_0150
LABEL_011E
IF 7,4 >= 12 THEN GOTO LABEL_000D
OUTPUT "CPX"
IF 5,4 = 0 THEN GOTO LABEL_0161
GOTO LABEL_0156
LABEL_0126
IF 7,4 = 9 THEN GOTO LABEL_000D
IF 5,4 = 0 THEN GOTO LABEL_0136
OUTPUT "JSR"
IF 5,4 = 2 THEN GOTO LABEL_016B
IF 5,4 = 3 THEN GOTO LABEL_0170
LABEL_0136
OUTPUT "BSR"
GOTO LABEL_00B2
LABEL_0138
OUTPUT "LD"
CASE_OF 6,6
OUTPUT "S"
OUTPUT "X"
CASE_END
GOTO LABEL_0156
LABEL_0141
OUTPUT "ST"
CASE_OF 6,6
OUTPUT "S"
OUTPUT "X"
CASE_END
GOTO LABEL_0156
LABEL_0150
IF 6,6 = 0 THEN CALL LABEL_00FF
IF 6,6 = 1 THEN CALL LABEL_0101
LABEL_0156
CASE_OF 5,4
GOTO LABEL_015C
GOTO LABEL_0166
GOTO LABEL_016B
GOTO LABEL_0170
CASE_END
LABEL_015C
POSITION ABS,6
OUTPUT "#"
CALL LABEL_0175
RETURN
LABEL_0161
POSITION ABS,6
OUTPUT "#"
CALL LABEL_017E
RETURN
LABEL_0166
POSITION ABS,6
CALL LABEL_0175
RETURN
LABEL_016B
POSITION ABS,6
CALL LABEL_0175
OUTPUT ",X"
RETURN
LABEL_0170
POSITION ABS,6
CALL LABEL_017E
RETURN
LABEL_0175
LOAD INPUT_DATA
RETURN
LABEL_017C
OUTPUT "**"
ABORT
LABEL_017E
LOAD INPUT_ADDRESS
STORE VAR_003C
IF INPUT_ERROR <> 0 THEN GOTO LABEL_0192
LOAD INPUT_DATA
ROTATE LEFT,8
AND VAR_0044
STORE VAR_0034
IF INPUT_ERROR <> 0 THEN GOTO LABEL_019D
LOAD INPUT_DATA
AND VAR_004A
INCLUSIVE_OR VAR_0034
RETURN
LABEL_0192
OUTPUT "**"
LOAD VAR_003C
STORE INPUT_ADDRESS
IF INPUT_ERROR <> 0 THEN GOTO LABEL_01A0
LOAD INPUT_DATA
ABORT
LABEL_019D
LOAD VAR_0034
ROTATE RIGHT,8
LABEL_01A0
OUTPUT "**"
ABORT
LABEL_01A2
SET VAR_0040,0
LABEL_01A3
LOAD INPUT_STATUS
IF 1,0 = 3 THEN GOTO LABEL_01AE
TAG_WITH 2
INCREMENT VAR_0040
INPUT REL,VAR_0040
IF INPUT_ERROR <> 0 THEN GOTO LABEL_005B
GOTO LABEL_01A3
LABEL_01AE
LOAD INPUT_DATA
CASE_OF 7,0
GOTO LABEL_000D
LOAD 56
GOTO LABEL_000D
GOTO LABEL_000D
GOTO LABEL_000D
GOTO LABEL_000D
LOAD 56
LOAD 56
LOAD VAR_004C
LOAD VAR_004E
LOAD 56
LOAD 56
LOAD 56
LOAD 56
LOAD 56
LOAD 56
LOAD 56
LOAD 56
GOTO LABEL_000D
GOTO LABEL_000D
GOTO LABEL_000D
GOTO LABEL_000D
LOAD 56
LOAD 56
GOTO LABEL_000D
LOAD 56
GOTO LABEL_000D
LOAD 56
GOTO LABEL_000D
GOTO LABEL_000D
GOTO LABEL_000D
GOTO LABEL_000D
LOAD VAR_0050
GOTO LABEL_000D
LOAD VAR_0052
LOAD VAR_0054
LOAD VAR_0056
LOAD VAR_0058
LOAD VAR_005A
LOAD VAR_005C
LOAD VAR_005E
LOAD VAR_0060
LOAD VAR_0062
LOAD VAR_0064
LOAD VAR_0066
LOAD VAR_0068
LOAD VAR_006A
LOAD VAR_006C
LOAD VAR_006E
LOAD VAR_0070
LOAD VAR_0072
LOAD VAR_0074
LOAD VAR_0076
LOAD VAR_0078
LOAD VAR_007A
LOAD VAR_007C
GOTO LABEL_000D
LOAD VAR_007E
GOTO LABEL_000D
LOAD VAR_0080
GOTO LABEL_000D
GOTO LABEL_000D
LOAD VAR_0082
LOAD VAR_0084
LOAD 56
GOTO LABEL_000D
GOTO LABEL_000D
LOAD 56
LOAD 56
GOTO LABEL_000D
LOAD 56
LOAD 56
LOAD 56
LOAD 56
LOAD 56
GOTO LABEL_000D
LOAD 56
LOAD 56
GOTO LABEL_000D
LOAD 56
LOAD 56
GOTO LABEL_000D
GOTO LABEL_000D
LOAD 56
LOAD 56
GOTO LABEL_000D
LOAD 56
LOAD 56
LOAD 56
LOAD 56
LOAD 56
GOTO LABEL_000D
LOAD 56
LOAD 56
GOTO LABEL_000D
LOAD 56
LOAD VAR_0086
GOTO LABEL_000D
GOTO LABEL_000D
LOAD VAR_0088
LOAD VAR_008A
GOTO LABEL_000D
LOAD VAR_008C
LOAD VAR_008E
LOAD VAR_0090
LOAD VAR_0092
LOAD VAR_0094
GOTO LABEL_000D
LOAD VAR_0096
LOAD VAR_0098
LOAD VAR_009A
LOAD VAR_009C
LOAD VAR_009E
GOTO LABEL_000D
GOTO LABEL_000D
LOAD VAR_00A0
LOAD VAR_00A2
GOTO LABEL_000D
LOAD VAR_00A4
LOAD VAR_00A6
LOAD VAR_00A8
LOAD VAR_00AA
LOAD VAR_00AC
GOTO LABEL_000D
LOAD VAR_00AE
LOAD VAR_00B0
LOAD VAR_00B2
LOAD VAR_00B4
LOAD 52
LOAD 52
LOAD 52
GOTO LABEL_000D
LOAD 52
LOAD 52
LOAD 52
GOTO LABEL_000D
LOAD 52
LOAD 52
LOAD 52
LOAD 52
LOAD VAR_00B6
LOAD VAR_00B8
LOAD VAR_00BA
GOTO LABEL_000D
LOAD VAR_00BC
LOAD VAR_00BE
LOAD VAR_00C0
GOTO LABEL_000D
LOAD VAR_00C2
LOAD VAR_00C4
LOAD VAR_00C6
LOAD VAR_00C8
LOAD VAR_00CA
LOAD VAR_00CC
LOAD VAR_00CE
LOAD VAR_00D0
LOAD VAR_00D2
GOTO LABEL_000D
LOAD VAR_00D4
LOAD VAR_00D6
LOAD VAR_00D8
LOAD VAR_00DA
LOAD VAR_00DC
GOTO LABEL_000D
LOAD VAR_00DE
LOAD VAR_00E0
LOAD VAR_00E2
LOAD VAR_00E4
LOAD VAR_00E6
LOAD VAR_00E8
LOAD VAR_00EA
LOAD VAR_00EC
LOAD VAR_00EE
LOAD VAR_00F0
LOAD VAR_00F2
LOAD VAR_00F4
LOAD VAR_00F6
LOAD VAR_00F8
LOAD VAR_00FA
GOTO LABEL_000D
LOAD VAR_00FC
LOAD VAR_00FE
LOAD VAR_0100
LOAD VAR_0102
LOAD VAR_0104
LOAD VAR_0106
LOAD VAR_0108
LOAD VAR_010A
LOAD VAR_010C
LOAD VAR_010E
LOAD VAR_0110
LOAD VAR_0112
LOAD 52
LOAD 52
LOAD 52
GOTO LABEL_000D
LOAD 52
LOAD 52
LOAD 52
GOTO LABEL_000D
LOAD 52
LOAD 52
LOAD 52
LOAD 52
GOTO LABEL_000D
GOTO LABEL_000D
LOAD VAR_0114
GOTO LABEL_000D
LOAD VAR_0116
LOAD VAR_0118
LOAD VAR_011A
GOTO LABEL_000D
LOAD VAR_011C
LOAD VAR_011E
LOAD VAR_0120
LOAD VAR_0122
LOAD VAR_0124
LOAD VAR_0126
LOAD VAR_0128
LOAD VAR_012A
GOTO LABEL_000D
GOTO LABEL_000D
LOAD VAR_012C
LOAD VAR_012E
LOAD VAR_0130
LOAD VAR_0132
LOAD VAR_0134
GOTO LABEL_000D
LOAD VAR_0136
LOAD VAR_0138
LOAD VAR_013A
LOAD VAR_013C
LOAD VAR_013E
LOAD VAR_0140
LOAD VAR_0142
LOAD VAR_0144
GOTO LABEL_000D
GOTO LABEL_000D
LOAD VAR_0146
LOAD VAR_0148
LOAD VAR_014A
LOAD VAR_014C
LOAD VAR_014E
GOTO LABEL_000D
LOAD VAR_0150
LOAD VAR_0152
LOAD VAR_0154
LOAD VAR_0156
LOAD VAR_0158
LOAD VAR_015A
LOAD VAR_015C
LOAD VAR_015E
GOTO LABEL_000D
GOTO LABEL_000D
LOAD VAR_0160
LOAD VAR_0162
CASE_END
LABEL_02B1
STORE VAR_0036
AND 3
STORE VAR_003A
IF 1,0 = 3 THEN GOTO LABEL_005B
TAG_WITH VAR_003A
LABEL_02B8
INCREMENT VAR_0040
INPUT REL,VAR_0040
LOAD INPUT_STATUS
IF 2,2 = 1 THEN GOTO LABEL_02B8
LOAD VAR_0036
ROTATE RIGHT,2
GOTO LABEL_02B1
