Author Topic: Keithley 2000 / 2015 / 2016 / 2010 VFD to LED Display Conversion  (Read 14886 times)
Offline Hydron
Re: Keithley 2000 / 2015 / 2016 / 2010 VFD to LED Display Conversion
« Reply #50 on: October 14, 2025, 10:31:21 pm »
Looks really good, much nicer than the pure blue. Now you're tempting me to buy a K2000 meter to add to my keithley pile :palm:
The following users thanked this post: KungFuJosh, dimmog
Offline KungFuJosh
  • TEAS is real.
« Reply #51 on: October 15, 2025, 12:54:34 am »
Same! It makes me want a 2010.  :-DD
Best Continuity Tester Ever
The following users thanked this post: dimmog
Offline dimmogTopic starter
    • Hubequip
Hubequip.net :: test equipment parts and more
www.hubequip.net
The following users thanked this post: syau, the Chris, BennoG
    • Hubequip
« Reply #53 on: October 20, 2025, 11:04:47 pm »
A few photos for you to enjoy  :D
This is the production version of the display.
« Last Edit: October 20, 2025, 11:07:46 pm by dimmog »
www.hubequip.net
The following users thanked this post: syau, KungFuJosh, the Chris
    • Hubequip
« Reply #54 on: October 26, 2025, 10:16:15 pm »
All preorders have been shipped ahead of schedule!
I currently have 10 displays remaining from the first batch, ready to ship immediately.
The next batch will be available in about two weeks.
The display available here for $79: https://hubequip.net/products/keithley-2000-2015-2016-2010-vfd-display-replacement-led-display-conversion-kit
and on ebay for $89 https://www.ebay.com/itm/326836185343
« Last Edit: August 19, 2026, 06:54:04 pm by dimmog »
www.hubequip.net
Offline yyudin
« Reply #55 on: October 28, 2025, 08:48:13 pm »
Dimmog, can you recommend the specific nail polish remover brand you have verified? Most regular ones are almost 100% acetone. We don't want to ruin the lens.
    • Hubequip
« Reply #56 on: October 28, 2025, 09:13:20 pm »
Modifying the display window is straightforward and takes about 20–30 minutes.
The process is explained in detail in the instructions, which also list the recommended products.
A printed step-by-step manual is included with the kit.
Please check the attached file.
www.hubequip.net
    • Hubequip
« Reply #57 on: October 30, 2025, 04:25:44 pm »
It appears that this display is also compatible with the Keithley 2182 and 2182A nanovoltmeters.
www.hubequip.net
The following users thanked this post: Shimonu
Offline BennoG
« Reply #58 on: October 30, 2025, 05:36:39 pm »
I received my units today, now wait for the nail-polish remover and see how the end result will be.
Will post some photo's when done.
Benno
The following users thanked this post: minsik, dimmog
Offline BennoG
« Reply #59 on: November 01, 2025, 08:53:58 am »
Some photo's of the new display
Online voltsandjolts
« Reply #60 on: November 01, 2025, 09:33:53 am »
Looks good and bright enough as-is; do you need the nail polish remover?
Offline BennoG
« Reply #61 on: November 01, 2025, 12:51:09 pm »
Yes you do need it, the new display is wider than the original.
If you put a LED cob light under the display you can see what you have removed, that works a lot better than nothing.
Edit added photos of led backlight so you dont use too much aceton.
« Last Edit: November 01, 2025, 03:46:15 pm by BennoG »
The following users thanked this post: voltsandjolts, dimmog
    • Hubequip
« Reply #62 on: November 02, 2025, 12:41:08 am »
How do you feel about it, do you like it?
www.hubequip.net
Offline BennoG
« Reply #63 on: November 02, 2025, 11:12:04 am »
It is far better readable, the digits are a lot bigger and brighter then the original. (mine was worn out)
added bonus I can now read it without reading glasses, this helps a lot when probing under the microscope and then you look at the meter to read the value.
Benno
The following users thanked this post: voltsandjolts, dimmog, the Chris, Shimonu
Offline KungFuJosh
  • TEAS is real.
« Reply #64 on: November 11, 2025, 03:31:06 am »
It also appears that the display is only partially compatible with models like the 2700, 2701, and 2750, as they have slightly different annunciators.
Will you be making a mod or another version for full compatibility with the 2701?
Thanks,
Josh
    • Hubequip
« Reply #65 on: November 11, 2025, 03:36:56 am »
No, this series is pretty rare, and with the current low demand for the 2000 display, it just wouldn't be worth making.
www.hubequip.net
Offline KungFuJosh
  • TEAS is real.
« Reply #66 on: November 11, 2025, 03:42:42 am »
What exactly isn't compatible? Does it work at all?
There's no mod you could do to make this one work?
    • Hubequip
« Reply #67 on: November 11, 2025, 04:02:19 am »
It will work. The only difference is in the annunciators.
www.hubequip.net
Offline KungFuJosh
  • TEAS is real.
« Reply #68 on: November 11, 2025, 04:17:04 am »
You mean the smaller words around the panel to display specific functions/alerts?
Is it possible to remove the plastic layer with the words on them? If you have the design with the correct coordinates, I have a laser. I could potentially make an alternate acrylic sheet with different wording.
    • Hubequip
« Reply #69 on: November 11, 2025, 04:27:33 am »
Yes, a few words around the digits are different, and some are positioned differently. But electronically, it's the same display.
It's not just plastic layer. It's a diffuser with a black mask.
www.hubequip.net
Offline KungFuJosh
  • TEAS is real.
« Reply #70 on: November 11, 2025, 05:26:13 am »
The diffuser/mask is what I would use the laser for. Are they layered in a way that can be separated, or all they all glued togother?
Offline minsik
« Reply #71 on: November 11, 2025, 09:14:33 am »
All received and fitted as best possible, without the polish (at this point, to be a future clean up)
Either way its bright and bold! First picture does not do it justice. My eye is a better camera!
Now it attracts regular use by being so beautiful and bigger!
Minsik.
« Last Edit: November 11, 2025, 11:54:32 pm by minsik »
Years of working with electronics. Now its just for fun.
    • Hubequip
« Reply #72 on: November 11, 2025, 10:12:04 pm »
The top diffuser film attached to the plastic display housing seems to have a double-sided print.
www.hubequip.net
Offline KungFuJosh
  • TEAS is real.
« Reply #73 on: November 11, 2025, 10:42:49 pm »
Interesting! I wonder if I can find that film. If so, it's probably doable if you have a SVG or something of the layout.
Thanks,
Josh
    • Hubequip
« Reply #74 on: November 11, 2025, 10:50:26 pm »
Thanks,
Josh
Sorry, I'm not able to provide any dimensions or drawings.
www.hubequip.net
