Author Topic: My first multimeter,but which one ?  (Read 28321 times)
Offline kj7e
  • Damon Stewart
Re: My first multimeter,but which one ?
« Reply #25 on: January 04, 2016, 03:25:24 pm »
The Brymen bm869 will be the next handheld DMM in my collection.  It just does everything well.
« Last Edit: January 04, 2016, 03:33:55 pm by kj7e »
Offline joeqsmith
« Reply #26 on: January 04, 2016, 06:08:43 pm »
Anyone buying brymen in the USA?  any good place to get them? Kinda intriguing
I bought mine from here.  No problems.  Fast shipment, well packed.
http://www.tme.eu/en/details/bm869/portable-digital-multimeters/brymen/bm869s/
The following users thanked this post: gameru
Offline tautech
« Reply #27 on: January 04, 2016, 07:01:59 pm »
I am very curious about EEVblog DM1 and DM2 (which is only in the excel file) at the Wytnucls’ chart. :)
https://www.eevblog.com/forum/testgear/multimeter-spreadsheet/
As yet not released.  :popcorn:
Avid Rabid Hobbyist
Offline Wolfram.ChromeTopic starter
  • https://goo.gl/h2GXKY
« Reply #28 on: January 05, 2016, 06:52:43 am »
/*The Sanwa does not appear to be a BM86x meter. It shares similar features and is Brymen made, but internally it is night and day different.*/
So the sanwa is made by Brymen ?
Or is bryman really made by sanwa ???
im confused.
Like I said the Sanwa is made y Brymen but appears to be an older or cheaper make. Definitely not the same quality as the BM869S
Oki so now is clear to me ,brymen made sanwa and not viceversa.
At this point i simply must to decide which one ,fluke 87v or brymen 869s .... 8)
Offline fanOfeeDIY
  • Country: jp
    • YouTube Channel
« Reply #29 on: January 05, 2016, 07:56:43 am »
im confused.
May I clarify a bit? :)
The Sanwa PC7000 is probably ODM model of Brymen 867, since it has the same spec.
By watching the mjlorton's video referred by joeqsmith, PC7000 uses Brymen’s IC.
The quality of internal of PC7000 is pretty good.
But as PedroDaGr8 mentioned the PC7000 and the Brymen 867 do not have completely identical internals.
The Brymen is Taiwanese company and the Sanwa is Japanese company, and not the same company.
Making me feel like I should own both PC7000 and the Brymen. :)
Also, Sanwa has very long history of making multi meters.
Many of the analog multi meters were made by Sanwa and it was famous.
This is the link to the corporate history. The multi meter is called "Tester" in Japan.
http://overseas.sanwa-meter.co.jp/info/history.php
« Last Edit: January 05, 2016, 08:08:30 am by fanOfeeDIY »
Offline joeqsmith
« Reply #30 on: January 05, 2016, 11:44:24 am »
In that video PC7000 he shows that it uses MOVs for the primary clamp.     In this older link for the 510, according to the OP they were using GDTs.  I could not tell from the pictures.  Wonder why the switch.
https://www.eevblog.com/forum/reviews/sanwa-pc-510a-dmm-mini-review-teardown-pics/
« Reply #31 on: January 05, 2016, 12:01:51 pm »
Thanks you very much ,i need info's wise and like like your :)
Offline Robomeds
« Reply #32 on: January 05, 2016, 07:21:45 pm »
I'm not sure if all will agree with me here but this is my normal suggestion when people start diving into tools in general.  Start of slow, cheap and used when possible.  The only exception is if you just love tools for the same of tools or if you happen to find a killer deal.  With patients on ebay you can get some killer deals on both Fluke and non-Fluke multi-meters.
First, you should probably be realistic about how much accuracy and resolution you need.  While I love my Fluke 187 and my 87-5 this has more to do with being a tool monger than really needing both.  The 87-5 is actually not that great a meter for me (relatively speaking) because the extra safety and durability are lost on my bench focused applications.  I picked up a Greenlee DM-200A (Brymen based similar to the 257 meter) for just a few bucks.  It's actually the meter I use the most because I like the smaller size and don't mind beating it around.
I would strongly suggest looking for an Amprobe AM-270 or AM-130 if they exist in your market.  Those are Brymen 85x based meters and can be had new off Amazon for $120 these days.  I've found like new off ebay for about $50.  That's a meter that is almost as good as the Fluke 87-5, especially if the last bit of rugged build isn't important.  I also have a Greenlee DM-820A.  It's related to the Brymen 869 that everyone loves.  It's a good meter but I don't like it as well as the Fluke 87-5 even though on paper it should be as good and better in many ways.
Anyway, if you are patient and if your market is like the US market you should be able to find a nice meter in the $100-150 used range that should serve you very well.
Offline Lightages
  • Canadian po
« Reply #33 on: January 05, 2016, 09:29:54 pm »
Sorry to be pedantic, but I need to correct this. The AM-270 is a derivative of the BM815. The AM-130 is a derivative of something else that I don't know. They are not derivatives of the BM85X series.
Offline naragon1
« Reply #34 on: January 05, 2016, 10:28:30 pm »
Lightages, would you happen to know which Greenlee models correspond to which Brymen models. Is there a page or a link somewhere?
Offline Lightages
  • Canadian po
« Reply #35 on: January 05, 2016, 10:58:53 pm »
Sorry, but I can't refer to any specific list of comparisons. Many have been cross referenced here on the forums. I suppose I can do a quick list. Give me a day  :)
Online djacobow
  • takin' it apart since the 70's
« Reply #36 on: January 05, 2016, 11:30:11 pm »
You worry too much. It's very unlikely they will drift, they're designed not to. Most people will never see any drift at all of a good multimeter.
Yes. I have a CIE 8002 I purchased for $40 in 1993. Never been calibrated, but still seems to perform within spec, at least as far as I can tell comparing it to my 87V and 34401A. Of course, it is only a 2000 count meter, but then again, I have done a lot of electronics hobby work with it over the years and can't recall ever wishing for more.
You normally only need calibration if you make devices that need a legal certification or something.
It seems a lot of people on this forum are really volt-nuts. Which is fine, I get it -- though I'm more of a time-nut myself. But from a practical perspective for hobby electronics work, you can get by with some pretty garbagy stuff.
For most users, more important than accuracy/cal is easy of use, battery life, size and contrast of display, how nicely the continuity works, etc.
And, of course, if you're measuring high voltage, low impedance sources, SAFETY.
« Last Edit: January 06, 2016, 12:45:36 am by djacobow »
Offline kleblanc
« Reply #37 on: January 06, 2016, 12:43:22 am »
I agree with djacobow about go to meters. I use my Fluke 101 and 107 Chinese models more than my personal Fluke 289, 87V, 28, 375 clamp, Flir CM85 Clamp and an IBM/Fluke 8060AA (bought it because...).  The main reason being for my uses the 101/107 are good enough most the time and relatively inexpensive compared to the TRMS/Low Pass filter meters. If I really need accuracy I use my 34401a that I picked up used for $300.
Any more accuracy than that, I could just use our work meters (Calibration lab).
I guess the take away is
A good/cost effective go to meter that will cover 90% of your uses. Then a bench meter to cover the remaining uses. It's always helpful to have that second,third meter when needed.
Offline Robomeds
« Reply #38 on: January 06, 2016, 03:03:22 am »
Are you sure about that?  They appear to be almost identical on the outside and in specs.
Am-270
http://www.ebay.com/itm/New-Amprobe-AM-270-Industrial-Multimeter-with-Bar-Graph-Display-/361410139868?hash=item5425b916dc%3Ag%3ALCkAAOSwA4dWITHr&nma=true&si=cMjxQ3AgXfOjQrnpoFDR2MkWNI8%253D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
AM-130
http://www.ebay.com/itm/Amprobe-AM-130-TRMS-Tester-True-RMS-Digital-Multimeter-PC-Connection-Temp-/191756048225?cmd=ViewItem&hash=item2ca58d1761%3Ag%3AUzYAAOSwBahVeJ3z&nma=true&si=cMjxQ3AgXfOjQrnpoFDR2MkWNI8%253D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
Even the Amprobe brochure makes it sound like one is just a rebadge of the other.
« Last Edit: January 06, 2016, 03:08:26 am by Robomeds »
Offline Lightages
  • Canadian po
« Reply #39 on: January 06, 2016, 03:20:52 am »
Yes I am sure. The AM-120,130 and 140 are not current models and I do not know what Brymen they originated from. They might have been only available from Amprobe with those features. The AM-270 is a BM815 in a different housing.
Offline Robomeds
« Reply #40 on: January 06, 2016, 03:46:46 am »
I know they aren't current but if you look at both the interior construction (I think there are some old threads about this).  If you look at this data sheet it's clear they all but copied the AM-130 specs for the 270 and they even said Am-130 at one point when they should have said the newer meter.  I can believe it's an updated PCB but I have trouble seeing it as much more than that.  If you look at my AM-120 teardown you can see it's related to the same family of meters (but not the same as the 270 or 130)
https://www.eevblog.com/forum/testgear/amprobe-%28bryman%29-am130-teardown/
This isn't like say the AM-570 family which is clearly not related to the 270 inside or out.
Offline Robomeds
« Reply #41 on: January 06, 2016, 03:05:25 pm »
So here im ,the judment moment is coming out !!!
I haven't too much money so i will go with hioki 4256 ,because i think it will be an good multimeter for an hobbist radio beginner like me.
In the future if i will be need i will buy something more serious ,maybe an second hand keithley....
However i don't really like fluke 87V, because i know about he's problems so it's not very good for an expensive meter like that to have this kind of problems........Read also my comment under this video ,im Gregan.Dark :
Guys im a little bit worried about this buy,so wish me the best about the hioki 4256...  :-DMM
Thanks to all.
I'm not sure if faded displays are unique to Fluke 87s.  Do keep in mind that Flukes with faded displays are often 20 years old.  In general 87s are very dependable.  But given the price and I presume your intent to use this on the bench, the extra durability of the 87 over much of the competition is likely not added value.  I guess this is my way of saying, go for it if someone else is paying.
« Reply #42 on: January 06, 2016, 06:39:05 pm »
Fluke 87V has numerous problems not just 1 or 2.
Actually i haven't too much cash ,so i can't afford for my self something of very expensive in range of 300 euros and more.
In any case if in the future i will have some spare cash i will buy for my self hioki 4281-82 ,because i really like he's basic precision and the set of functions included in it.
Offline Lightages
  • Canadian po
« Reply #43 on: January 06, 2016, 07:03:18 pm »
Why would you buy the Hioki 4256 when for less money you can get the Brymen BM867? It beats the Hioki in so many specifications and costs even less at $150. Even the BM869 is only $10 more at around $210 from tme.
Offline Robomeds
« Reply #44 on: January 06, 2016, 07:29:32 pm »
Which problems are you thinking of.  It's a great meter but also a very expensive meter.  While I don't like my Greenlee DM820a better, it's hard to argue the Brymen based meters like my Greenlee isn't a better value.  In the US the 820a can be had off eBay in near new condition for just over $100.
Offline Lightages
  • Canadian po
« Reply #45 on: January 06, 2016, 09:26:39 pm »
Actually the BM257S is probably a better meter than the Hioki 4256. It can be purchased from iloveelectronics here for $135 shipped, or from tme for $110 plus shipping. Then there is the BM827 which is better than the Hioki and costs $122 plus shipping from tme. To me it makes absolutely no sense to spend that much on the Hioki.
Offline Deckert
    • TechBench
« Reply #46 on: January 06, 2016, 09:40:17 pm »
Totally agree here. The Brymen BM867 is my "base standard" in terms of an accurate meter in my lab. I took it for re-cal at a cal-lab in Johannesburg after owning it for two years. The guy at the cal-lab told me they check the Brymen meters before calibrating them, since they drift so little. He said they only re-cal if they see the meter is out of spec, which happens rarely. They do the same with the Flukes.
With the money you save, you can even add the smaller BM257 (or the upcoming EEVblog Brymen meters) as a second meter for field use later on.
Also, the Hioki 4256 doesn't have a uA range and only measures down to 1 nF. What's up with that?
--deckert
Offline Fungus
« Reply #47 on: January 06, 2016, 10:36:29 pm »
Maybe they've improved them now.
(But it will take 20 years to find out the truth...  :popcorn: )
« Reply #48 on: January 08, 2016, 07:03:33 pm »
So here im :)
After some moments of deep thinking i've decide to wait ,get more money and go with fluke 87v or hioki 4282  :-DMM
Thanks to all for your help.
Offline Performa01
  • Country: at
« Reply #49 on: January 09, 2016, 01:15:02 am »
Only noticed this thread now, that you’ve already made up your mind. Still thought I’ll throw in my 2 cents…
I have more meters than I can count and at least half of them are bench meters.
The best handheld meter that I have is a Metrix MX54 that is more than 20 years old. It has 50000 counts and its measurement ranges and accuracies are about as good as it gets for a handheld meter (especially back then). It never has been calibrated, but still is within spec (and yes, I do have the calibration sources and calibrated precision meters to verify that). So this confirms what others have said already – a quality meter needs not be calibrated for private use, where you don’t have to comply with ISO9000 standards and the like.
While I personally don’t have any need for a new handheld meter – as I rarely use them nowadays anyway, because bench meters are so much more practical for a lab – if I were to buy a new handheld, it would certainly be the HIOKI DT4282 – for the same reasons I chose the MX54 some 25 years ago…
