Author Topic: New Rigol DS1054Z oscilloscope  (Read 2764352 times)
0 Members and 127 Guests are viewing this topic.
Offline rolycatTopic starter
Re: New Rigol DS1054Z oscilloscope
« Reply #1250 on: April 02, 2015, 01:00:58 pm »
Hi
I had no clear, install with DSER in DS1074Z, without enabling 500uV Vertical , then I can install the DSBA option to enable or must be disabled?
No, do not enable it, it doesn't work.
Offline rosbuitre
  • Country: ar
« Reply #1251 on: April 02, 2015, 01:04:57 pm »
Hi
Thanks !!
My instruments: DMM Keysight 34461A / Tektronix DMM916 / Fluke 12, Rigol DS1074Z, Deer DE-5000, Siglent SDG805 / SDP3303D, Dayton Dats2
Offline sakos
« Reply #1252 on: April 03, 2015, 01:22:35 pm »
Hello,
I received my DS1054Z some weeks ago. I has to wait more than two months. Great device, I really like it.
What are your experince with "Multi-level intensity grading display"? Should it show less frequent signal paths with lower intensity like an analogue scope? I tested with pseudo-random signal but I think only two intensity levels are shown: normal and a darker. Not a big deal but I expected more.
Offline electr_peter
  • Country: lt
« Reply #1253 on: April 03, 2015, 01:33:19 pm »
64 intensity levels are present which is more than enough in most cases. With very simple signals all you get is few grades if you think about it.
For stable signals, intensity graded display has a little benefit. However, for unknown or unstable signals it is much better. And it really shines in situations where analog signal is modulated.
In short, I would have to be pressed hard to go back to non-intensity graded display.
« Reply #1254 on: April 03, 2015, 01:37:22 pm »
Hello,
Take a look at Dave's summary review (EEVBlog #703) where he demonstrates the feature, describing it as one of the best on the market.
Offline aveekbh
  • Country: in
« Reply #1255 on: April 03, 2015, 01:47:45 pm »
Yes, intensity grading mimics the intensity control of an analogue scope. See Dave's review on it - https://youtu.be/W2qdtQkBKhc?t=1921 (EEVBlog #704).
[Edit - added the time (32:01) and episode title to the URL.]
« Last Edit: April 03, 2015, 01:50:23 pm by aveekbh »
Offline sakos
« Reply #1256 on: April 03, 2015, 07:07:54 pm »
Hmmm. Made some tests. It seems that the behaviour depends on the horizontal time base and the memory depth settings. The higher refresh rate of the signal the more grades of intensity levels.
On low frequency signals (like audio) I can differentiate only two levels. The display persistency time settings has no effect on it except 0.
Thanks for the responses. Now I understand better. This is an amazing DSO for its price.
Offline aveekbh
  • Country: in
« Reply #1257 on: April 04, 2015, 04:15:50 am »
The waveform update rate drops at long time bases, so I suppose intensity grading will not make sense without persistence. I should try this out with a low frequency signal.
Offline hopeANDhope
  • Country: gr
« Reply #1258 on: April 04, 2015, 09:19:27 pm »
Model DS1054Z. I can confirm that the trick to unlock all features still works for Software version: 00.04.02.sp4
Firstly, i used the  DSFR option, then i re-entered new codes with the DSER on. I do not have spotted any problems so far. I think it works fine, all options are available.
Now, it Works as if i have a DS1104Z.
Offline gandel
« Reply #1259 on: April 09, 2015, 08:40:37 pm »
I sent you a pm with it
       hi, can I get "eevblog discount code" for ds1054z on tequpment.com? Thanks
Offline plazma
    • Homepage
« Reply #1260 on: April 09, 2015, 08:48:10 pm »
Btw. are there any discount codes for European resellers like Batterfly or Batronix?
Offline ManicMaurice
« Reply #1261 on: April 09, 2015, 09:29:28 pm »
I sent you a PM with the code. :)
Offline gandel
« Reply #1262 on: April 09, 2015, 10:46:24 pm »
      Thank you! One more question--how can I apply that code on tequipment.com?
Offline XFDDesign
« Reply #1263 on: April 09, 2015, 11:09:51 pm »
Get through the checkout process, and on the second-to last step, there is a box for a coupon code. If you're having to enter your payment information, you've gone too far.
Offline gandel
« Reply #1264 on: April 10, 2015, 12:32:42 am »
   Thank you!
Offline Jakelin
« Reply #1265 on: April 10, 2015, 03:39:47 am »
This has taken me out of lurker land.  Would it possible for me to get a code too?  About to pull the trigger and pick one of these up!
Offline tve
« Reply #1266 on: April 10, 2015, 07:10:26 am »
This is probably a FAQ by now, but I can't readily find an answer: Any suggestions for "must have" accessories to a DS1054Z scope? A better probe?
Online ebastler
« Reply #1267 on: April 10, 2015, 07:49:39 am »
The probes are good enough for me. Some of them have issues with the 1x/10x switch in the 1x position, which are measurable with a resistance meter, but don't seem to affect scope measurements under normal circumstances. Of course, if you have special requirements (differential probes, HV, current measurement or whatever), those might imply the need for additional probes.
A couple of good 50 Ohm pass-through terminators are important in my view, since the scope does not have built-in 50 Ohm termination at its inputs.
Offline Galenbo
« Reply #1268 on: April 10, 2015, 02:11:21 pm »
... After testing it I unlocked the options. ...
I used the code generator at http://gotroot.ca/rigol/riglol/ with...
Who is the owner of this website?
How to be sure that your scopes don't start playing sponsored promo videos as from 2016 ?
If you try and take a cat apart to see how it works, the first thing you have on your hands is a nonworking cat.
Offline 4cx10000
« Reply #1269 on: April 10, 2015, 02:27:21 pm »
  :-DD
Think it is a trusted website, but who knows what happen when we finally get there   :-//
"Messen ist Wissen, aber messen ohne wissen ist kein wissen"
Offline Galenbo
« Reply #1270 on: April 10, 2015, 02:30:09 pm »
I just got an email with a link to a pdf with new and old prices:
http://www.batronix.com/pdf/Priceadjustment_Rigol.pdf
Offline ruffy91
« Reply #1271 on: April 10, 2015, 02:54:09 pm »
I am super confident this won't happen as the DS1xxxz scopes don't even have an RTC. Maybe on the DS2xxx series :-D
« Reply #1272 on: April 10, 2015, 02:56:25 pm »
So the DS1054Z is going up by from 299 to 339 euros. Given that US dollars and euros are almost at parity at the moment it will be interesting to see if this will affect the rather higher $399 list price in the States.
Offline elgonzo
« Reply #1273 on: April 10, 2015, 03:49:15 pm »
Remember that those Euro prices are without VAT.
Considering that the DS1054Z appeals to hobbyists/private buyers, for many the effective price difference will be larger than EUR40 (depending on national VAT rates...)
« Reply #1274 on: April 10, 2015, 05:07:00 pm »
PM Sent. Enjoy. :)
