Author Topic: New Zoyi multimeter+oscilloscopes - ZT-70xS, up to 50MHz/250MSps (nov 2022)  (Read 667229 times)
0 Members and 47 Guests are viewing this topic.
Offline Randy222
Re: New Zoyi multimeter+oscilloscopes - ZT-70xS, up to 50MHz/250MSps (nov 2022)
« Reply #125 on: January 12, 2024, 03:37:00 pm »
Related to the charging part.
I got my 703S
Icon in screen is like already said, when on charger the icon toggles between charge icon and batt level icon.
However, in the manual it says the lighted power button will go dark when it's done charging. My batt icon shows the full 4 bars ("full") but power button is still red. Will let it charge for a bit to see what happens.
Given today's cots IC's for batt charging & management, I suspect the batt can't overcharge, but perhaps the logic implemented for icon and light is not 100%.
Update: the longer I leave it on charger the more the power buttons starts to flicker. Initially a very faint flicker, but 30min later the flicker is more obvious. My guess, bad implentation of a comparator, or the full-charge threshold is set wrong.
Is there a hidden menu to see current firmware version?
« Last Edit: January 12, 2024, 05:35:04 pm by Randy222 »
Offline ahakman
« Reply #126 on: January 12, 2024, 07:34:47 pm »
I wouldn't say it's "hidden", other than that horizontally scrolling the menu wasn't obvious to me initially either until I glanced at the manual
Press "menu", press "right" 3 times, version is the right most entry.
If you press F4 (the soft key under version), I get
Serial Num:
xxxxxxxx
Boot:
V1.0.13
APP:
V1.0.9
The following users thanked this post: Randy222
Offline Randy222
« Reply #127 on: January 12, 2024, 09:11:13 pm »
My 703 says:
boot v1.0.14
app v1.1.0
My 703 boots to either Meter volts, or Scope. Whichever side was used last is what it boots to.
It does have the 100ns issue like all the others.
And if I change freq outside of 1kHz the unit won't allow me to even go down to 100ns.
Offline Randy222
« Reply #128 on: January 12, 2024, 11:03:29 pm »
Did Zoyi advertise the 703 as also a 50Mhz generator.
In the more-apps area there;s the Gen app, but seems I can only get around 325kHz.
There's definitely some odd bugs in my 703. After making some manual changes on scope settings, like signal type from the side port, I simply go back and hit AUTO. With the std 1kHz sq. wave the AUTO appears to step through some time divisions and then settles on one. But sometimes the whole scope part seems to crash / lockup, I then have to power off - on.
Offline Altair8800
« Reply #129 on: January 13, 2024, 04:21:21 am »
With the ZT-703S it seems like one of the differences between the older 702S model is that the 702S has a thermocoupler function.  In the newer 703S this function no longer exist but they add in its place a new function called UART in Multimeter Mode.  This is in Multimeter Mode you click the MENU button and it will then display (Language, Auto Off, Bk Light, Uart).
UART if you switch it to ON is supposed to display Multimeter readings through the COMM port.
Has anybody got this to work, and can you please explain how you were able to do it?
I tried a few times but couldn't get this to work on my Windows computer (it will not recognize or show the Comm port)
Offline ahakman
« Reply #130 on: January 13, 2024, 05:38:18 am »
Are you connecting the signal generator output to a usb to serial adapter (or a real serial port)? It's not through the USB port, it's through the signal generator port.
I don't have a TTL USB to Serial adapter here to try it with, but if I measure that port in multimeter mode on AC voltage, I can see a slight increase in AC voltage when I turn the UART function on, and it goes back to zero when I turn UART off.
Yes, it's dumb they didn't do it through a built in usb-serial adapter.
The following users thanked this post: Altair8800, gtv
Offline Altair8800
« Reply #131 on: January 13, 2024, 08:01:43 am »
Thanks ahakman,
That explains some of the puzzle.
Yes, I was kind of expecting that when you plug the 703S via a USB cable it would show up on the Windows computer with a newly assigned COM port, similar to when you connect and Arduino or ESP32 device.
So I sacrifice an old USB cable and stripped it and connected the 2 USB data wires to the Multimeter Signal Generator Output Port.  Having UART=ON, when I plug into the male end of the USB cable to Windows machine, it does not show as a COM port in Device Manager.  But I did hear Device Manager give a Ding, like it recognized something (I could not easily find the change).
Things didn't work, its late, will try another day...
PS1:  I have visions I might have to use old 9 pin RS-232 cable and hook up to old WinXP computer (that has the old serial ports)...  Or maybe I can use a Serial Port to USB port cable...  Please "Say it isn't so, Joe"
PS2:  In Windows Device Manager if you do not see COM Ports, you might have to click View Menu > Show hidden devices.
Offline winkot
  • Country: kz
« Reply #132 on: January 13, 2024, 09:08:03 am »
Could you take screenshots of the meander with a frequency of 1 MHz and higher?
Offline winkot
  • Country: kz
« Reply #133 on: January 13, 2024, 09:46:02 am »
What did batt icon and power button show next?
Offline wasedadoc
« Reply #134 on: January 13, 2024, 10:50:54 am »
Thanks ahakman,
I do not have a 703 but my understanding is that it will output serial UART data at 3.3 or 5 Volts. That cannot be connected directly to a USB port. It might work if connected to the RxD pin of a PC 9 pin serial port. If the PC has only USB ports you will need a "USB  to TTL" type interface.
Offline ahakman
« Reply #135 on: January 13, 2024, 11:04:33 am »
Yes, you need to use a TTL RS232 to USB adapter if your computer doesn't have native serial ports. The meter will be outputting raw TTL RS232 - you can't connect that directly to a USB cable - they're not the same protocol at all.
It needs to go.
meter --> ttl rs232 to usb adapter -> usb port on computer
Even if you have native serial ports, you'd probably need a level shifter - I'm guessing the meter is outputting 3.3V signals, and a real serial port is expecting +/- 12V. Maybe some modern serial ports work directly with TTL, but even if so, 3.3V might be too low for reliable communication.
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #136 on: January 13, 2024, 03:34:08 pm »
The ZT-702S oscilloscope does not show the end of charging on the display. The battery icon does not change. How to determine that charging has ended?
While charging, the On/Off button of my ZT-702S glows red. When the DMM is fully charged, the button simply powers off. The battery indicator shows as fully charged.
Offline winkot
  • Country: kz
« Reply #137 on: January 13, 2024, 04:32:36 pm »
How long does it take to fully charge?
Offline rsjsouza
  • Eternally curious
« Reply #138 on: January 14, 2024, 03:31:13 am »
Unfortunately I rarely let it go to 0%, thus I don't remember the time for a complete charge.
Today it took about 1/2 hour to charge it from about three bars to full.
Offline kwass
« Reply #139 on: January 14, 2024, 07:50:32 am »
It needs to go.
Yes, a TTL RS232 to USB adapter works just fine.  The meter outputs a 3.0 volt signal as you can see from the scope capture.
Here's are some sample output lines,  note that there is no <CR> nor <LF> marking the line ends this is my edit.  The meter sends about 3 lines per second so the delay between records can be used as a break.  Also, the output doesn't specify AC or DC, this seems to be an oversight.  Finally current is called "electricity"!
Voltage:-23.211 mV
Voltage:0.0003 V
Resistance:0.L KOM
Resistance:002.15 OM
beep:. OM
beep:000.04 OM
Diode:. V
Diode:00.001 V
Electricity:0.0000 A
-katie
Offline winkot
  • Country: kz
« Reply #140 on: January 14, 2024, 06:03:50 pm »
What does it mean Coupling?
Offline Altair8800
« Reply #141 on: January 15, 2024, 04:08:34 am »
Katie/KWASS:
Could you please tell what exact Baud settings you used?
Baud Rate:  115200
Data bits: ??[5, 6, 7, or 8]
Parity: ?? [even, odd, none, mark, space]
Stop bits: ??[1, 1.5, or 2]
Flow control: ??[hardware, software, none, Xon / Xoff]
Handshaking: ??[none, XON/XOFF, RTS/CTS, DSR/DTR]
Language:  ??[ASCII, utf-8, other]
Delay:  ??[some serial communication programs have this...]
I know that standard setting is Parity=N, Data bits=8, Stop bit=1, Flow control=None, but not sure with this company Zoyi since no exact documentation. I'm not sure they even used standard settings...
I was able to use a USB to TTL RS232 9-pin adaptor, but in the serial output programs I use the message is always garbled.  So some setting(s) is(are) wrong.
Offline ahakman
« Reply #142 on: January 15, 2024, 05:00:59 am »
I don't think I've ever seen a TTL usb to serial adapter have a 9 pin connector on them. Usually they have loose wires (flying leads), or raw solder pads that you solder your own wires to. Having a 9pin connector typically means it's a full RS232 voltage adapter, and NOT TTL.
You're probably getting garbled communications because 3V is not enough to reliably signal the USB to Serial adapter you have because it's not actually a TTL level adapter.
The settings will be 115200, 8, N, 1
No flow control
No handshaking
ASCII
and no delay (character delay is usually only for transmission - it introduces a slight delay between characters - it does nothing for reception)
Offline kwass
« Reply #143 on: January 15, 2024, 05:27:26 am »
No flow control
No handshaking
ASCII
That's exactly what I used for settings.  For hardware, I used something like this from Amazon.  It only has RX, TX and GND so there's no way to mess up the handshaking options! ;) https://www.amazon.com/DSD-TECH-3-5mm-Cable-Interface/dp/B07XXVF4RM
« Last Edit: January 15, 2024, 01:16:20 pm by kwass »
-katie
Offline naiclub
  • Country: th
« Reply #144 on: January 15, 2024, 09:32:21 am »
I just purchased it last year.
Offline wasedadoc
« Reply #145 on: January 15, 2024, 12:05:13 pm »
Katie/KWASS:
Baud Rate:  115200
If your adaptor has a 9 pin plug to fit a 9 pin SER socket on a PC, connecting that to the Zoyi will never work.  For "TTL serial" a logical 1 is signalled by positive voltage and a 0 by zero (or close to zero) voltage. But true RS232 is different. A 1 is negative voltage and a 0 by positive voltage. That is why RS232 interface chips '188 and '189 are inverting.
Offline Randy222
« Reply #146 on: January 15, 2024, 03:41:04 pm »
Too bad it's not a dfu device using STM chipset, the STM driver is a simple USB to virtual COM.
Offline Randy222
« Reply #147 on: January 15, 2024, 03:50:07 pm »
No flow control
No handshaking
ASCII
Did you cut off the 1/8" end and wire it to a USB-C male end? My 703 only has USB-C
Is there a 1/8" female to USB-C adapter made for just the serial lines?
The following users thanked this post: gtv
Offline Veteran68
« Reply #148 on: January 15, 2024, 06:14:11 pm »
As noted earlier in this thread, the 703's UART communication occurs over the signal generator output. Not the USB-C port.
Offline Randy222
« Reply #149 on: January 15, 2024, 08:42:15 pm »
What port / jack is the "generator output" port?
My 703 has one usb-c, and two BNC's at the top.
