Author Topic: New Zoyi multimeter+oscilloscopes - ZT-70xS, up to 50MHz/250MSps (nov 2022)  (Read 602728 times)
008nothing and 40 Guests are viewing this topic.
Online cncjerry
I'm testing my 703s and had a board sitting here with three, 3.0uf electrolytic caps on it.  My ZOYI smart tweezers, pretty amazing device for the money, reads them perfectly but the 703s won't read them at all.  I assume it is because of how the 793s reads the caps vs the 703s which uses an A/C signal?
Overall, the 703s is doing what I needed it to do.  I can trace SPIDF signals fine and some other things for which I would normally drag out a larger scope.
Jerry
Offline Edmiri
  • Country: al
The test leads are to long. Try shorter ones. Also whait a bit and it will show the values.
Online cncjerry
tried very short leads, no luck.  None of my other meters, except for the zoyi tweezers, will read the caps in-circuit on this board reliably.  Sometimes my agilent U1252B will.  Overall, still impressed with the 703s for the money.
Offline csuhi17
  • Country: hu
How much does it not measure them, what's the difference?!
I quickly measured two 4.7u electrolytes and the Zoyi tweezer measured around 4.7uF at 100Hz, the ZT-703s measured around 5.1uF.
The factory Zoyi test leads were bad for me, I had to replace them.
Fnirsi oscilloscope = waste&regret
or maybe I was wrong
Online cncjerry
it just counts up to OL.  The caps are 3uf, approx.  I don't have a problem with caps out of circuit.  there is a wide range of voltages used by the meters I'm testing.  Something is clearly conducting on this board when the voltage gets above about .3v but I don't see any diodes or transistors. The tweezers use AC sine wave and work perfectly.  I'm using the 703s, agilent and a new SHS820X and none of them will read the caps except the tweezers.
Online cncjerry
I'm trying to save a file and pressing the hold/save key, I get a 'save failed' message.  Doing something wrong?
Thanks
Jerry
Offline xKertx
Offline r6mf49t2
  • Country: ru
Firmware V1.5.5 has appeared, has anyone checked it?
Offline xKertx
V1.5.5 Version Upgrade details:
1. The measurement speed of AUTO has been optimized
Offline OLderDan
The icon for run mode is different and the trace seems to be less filtered at first glance, but I haven't recalibrated yet to see if that changes the jitter now shown. There is noticable glitching of the display when changing v\div and simply moving through the menu that wasn't there before. They didn't fix triggering slow signals being lost below 500ns and they didn't fix the cursor icon colour not changing to show which trace is selected or that cursors lose position if you change modes. I'm going back to previous firmware.
« Last Edit: April 05, 2025, 06:11:17 pm by OLderDan »
Offline xfint34
Auto is faster now. It struggles to detect at lower then 15hz.
Offline Luca_Techy
    • My youtube channel
The Single mode trigger bug is still present <=250ns. Anything you trigger in single mode at 250ns or faster won't trigger at the selecter trigger point. You need to scroll right a good deal (a few pages) to find the correct trigger point after the trigger. I'm amazed nobody has noticed this rather major bug - I wonder if it's only mine at this point!
https://youtube.com/shorts/XRGxF6oBQFs
Offline indman
  • Country: by
And if you read the previous posts in the thread more carefully or search the topic?
https://www.eevblog.com/forum/testgear/new-zoyi-multimeteroscilloscopes-zt-70xs-up-to-50mhz250msps-(nov-2022)/msg5664291/#msg5664291
https://www.eevblog.com/forum/testgear/new-zoyi-multimeteroscilloscopes-zt-70xs-up-to-50mhz250msps-(nov-2022)/msg5765033/#msg5765033
The following users thanked this post: Luca_Techy
Offline xfint34
The output settings got buggy in v1.5.5. Sometimes it jumps to the previous setting. The 5khz sine wave can sometimes be glitchy. Like the amplitude is jumping all over the place.
Overall it appears each firmware version is a small step forward and some steps back with new bugs. I wonder if they don't have enough unit testing to catch regressions.
Online cncjerry
https://www.eevblog.com/forum/testgear/new-zoyi-multimeteroscilloscopes-zt-70xs-up-to-50mhz250msps-(nov-2022)/msg5632455/#msg5632455
Format is removed on version 1.4.2 and FFT is added on that button.  So if that is what you were referring to, I can't do a format.  Maybe the latest firmware corrected it.
Online cncjerry
unless I am doing something wrong, the new firmware, 1.5.5? doesn't fit.  No format button on the menus.
Offline dn1983
  • Country: ua
You can restore factory settings, after it flash disk will be repaired.
Offline dn1983
  • Country: ua
I payed attention, that new menu appeared.
Menu -> SAMPLE: HD or PEAK.
Somebody knows, what does it mean?
The following users thanked this post: mebel
Offline BOPOH
  • Country: ua
1.4.2 / 1.5.5
menu -> MoreApps -> menu (ImgView) ->  (There is nothing about Fn keys on the screen) F3 -> F3 (format)
« Last Edit: April 08, 2025, 09:48:51 am by BOPOH »
The following users thanked this post: indman, mebel, zenon, Solvalou19
Offline indman
  • Country: by
1.4.2 / 1.5.5
This is in the style of Chinese logistics - hide the function important and warn others nothing about it! :-DD
The following users thanked this post: cncjerry
Online cncjerry
Don't know how you found that menu.  Just pressing function keys hoping for the best I guess.  Thanks
p.s.: 1.5.6 is up there.  Adds switchable Russian interface. Kak raz to, chto mne nuzhno.
« Last Edit: April 08, 2025, 03:21:15 pm by cncjerry »
Offline indman
  • Country: by
It's really true! :-//
What's the point of their new versions 1.5.6...1.5.7...1.5.8 if they don't fix old the gross bugs in the software? :palm:
The following users thanked this post: RAPo, FixyMixy
Offline wedgehog
Anyone got a link to ver 1.55 please?
Offline RAPo
Thank you.
