Author Topic: Program that can log/control many multimeters and other devices.  (Read 1775985 times)
0 Members and 222 Guests are viewing this topic.
Offline HKJTopic starter
    • Tests
« Reply #3725 on: November 17, 2024, 08:45:06 am »
I'm new to TC and not much of a programmer. I have an HP 3457A DMM, which is very similar to the 3458A. The main difference is it is only 6.5 digits, and lacks the high performance pulse measurement features and speed. Is it possible to configure the 3457a by copying the 3458a configuration file, and simply changing the two model numbers?
If not, can you assist in editing the configuration?
Yes, it is possible, but it would also be a good idea to remove non-existing modes from the definition and adjust the number of digits in the values.
The following users thanked this post: Knoonan
Offline gby
« Reply #3726 on: November 24, 2024, 08:42:50 pm »
Hi HKJ,
Quick question about
    #POPUPTEXT "prompt" varName {characters {"tip"}}
What is the format of the "characters" value?  I thought it meant set a limit on the number of characters in the input string.  But,
    #popupText "File name to save data" DataFile 10 "Saves to default dir with FileName.csv."
yields
   ;; #popupText "File name to save data" DataFile 10 "Saves to default dir with FileName.csv." failed due to 5
I then tried various other ideas and every one I tried yielded some form of error message.
For reference
with no "characters" or "tip" added seems to work fine.  But, I would like to have a "tip" which means I need an entry for "characters".
Second question, was a change made to the Chart channel selection code?  I ask because on V2.49 I can only activate 4 channels on the Chart plot.  In V2.44 and before I could have many more than 4 traces active.  For V2.49 I have the checking or not checking "Fast Charting" makes no difference.
« Last Edit: November 24, 2024, 10:16:46 pm by gby »
    • Tests
« Reply #3727 on: November 25, 2024, 01:02:06 pm »
yields
For reference
It is the maximum number of input characters.
When "Fast charting" is checked you are limited to four curves and the resolution is lower. The drop in resolution requires a high-res screen to see.
Offline gby
« Reply #3728 on: November 25, 2024, 01:36:03 pm »
HKJ,
Thanks for the quick answer.  You say #popupText "characters" parameter is
which is what I thought and what I first tried.  Given that why does the following script
   =var DataFile = "test"
   #popupInit "Test Setup"
   #popupText "File name to save data" DataFile 10 "Tip"
   #popupShow
always produce the below error?
;; #popupText "File name to save data" DataFile 10 "Tip" failed due to 5If I change the #popupText line to end at the number with no quoted text at the line end it works.  Whenever I add quoted text at the line end there is an error.
As for the number of channels to plot, yesterday I looked at the Configuration tab and "Fast charting" was not checked and I still could only do 4 channels.  This morning I checked the box and then un-checked the box and now I can plot more than 4 channels.  Is it possible that upgrading from 2.44 to 2.49 defaults to "Fast charting" due to a missing entry in a settings file but shows the box as unchecked on the Configuration tab?
    • Tests
« Reply #3729 on: November 25, 2024, 02:15:43 pm »
HKJ,
   #popupShow
There is a bug in the coding, it will be fixed in the next release, fo now use:
#popupText "File name to save data" DataFile 10 "Tip" "Tip"
You are mostly correct, but it was not supposed to show as unchecked and work as checked. The code showing the configuration and the code selecting uses the same variable.
Generally new settings are supposed to be completely transparent, but in this case I wanted the checked setting as default on, to make TC a bit faster on slow computers, i.e. make TC a better experience.
Offline TheDefpom
  • YouTuber Nerd - I Fix Stuff
    • The Defpom's Channel
« Reply #3730 on: November 29, 2024, 12:03:56 am »
I just created a definition file for the new Siglent SDP4000X series of power supplies, covers the SPD4121X, SDP4306X, SPD4323X, have attached it for inclusion.
I have one bug still in it which I could not solve, the CH3 OFF/ON buttons won't disable using the :enable: tag (line 535), it is referencing the cmd at line 319 for the Independent/Series/Parallel selection. This same variable is used with other controls that DO disable, so I know the variable being used for the enable itself is OK, odd thing is I am sure it was working early on when I was writing the definition, I am probably missing something stupid which is breaking it.
Updated file is included a few posts below this one...
« Last Edit: December 02, 2024, 08:14:12 am by TheDefpom »
Cheers Scott
The following users thanked this post: KungFuJosh, Furna
    • Tests
« Reply #3731 on: November 29, 2024, 01:22:39 pm »
Thanks, they will be included in the next release.
Are you sure the :enable: is covered by a :update: tag when it has to change?
Also with multipage configuration you need the pagename on variables and :updates:
There is a trick to see what variables are defined at a specific point in a definition, this can be useful if you are unsure about the exact name.
Offline jiri
  • Country: cz
« Reply #3732 on: December 01, 2024, 07:47:03 am »
Hi, I'm new here. I apologize in advance for my bad English.
I have a problem with communication between a PC with W10prof 64b and HP34401A. The connection between the PC and the HP is an RS232-USB cable and a null modem connected as shown in the picture.
https://cdn.shopify.com/s/files/1/0267/5366/3039/files/dd577314b803a2ebc27b2307185a01ac_480x480.jpg?v=1607953427
TC shows that the connection is established, but when clicking on any button in TC reports HP error -410 (return communication error)
I loaded SW TC about a week ago on a PC with W7Prof64b and it behaves the same.
Could I ask for some advice?
    • Tests
« Reply #3733 on: December 01, 2024, 09:55:15 pm »
I am do not know if you cable is correct or not, but the handshake connections are used by the HP.
Also you must set the correct communication parameters on the HP (9600N82).
Also read the notes included with the definition.
Many people uses TC with this meters, i.e. it works.
Offline TheDefpom
« Reply #3734 on: December 02, 2024, 01:13:43 am »
I realised I should update TC as I hadn't actually done that for a couple of years  :-//
Now the issue I had with some items not disabling is fixed, I guess it was a bug in an old version  |O
Attached are some updated files for inclusion, ignore the last one I did for the SPD4xxxX as a newer one is attached.
« Last Edit: December 04, 2024, 07:42:12 am by TheDefpom »
Cheers Scott
The following users thanked this post: tautech, Furna
Offline KungFuJosh
  • TEAS is real.
« Reply #3735 on: December 02, 2024, 02:42:28 am »
Hi Scott,
Please compare your SDM30xxx.txt with mine. Mine has SDM3055X-E added (in place of 3045X, some people might want to keep that part original), and it removes the *rst command from #finalCmd.
Using *rst fully resets the device to default, which is annoying. You can hit the Shift key to take back local control on the meters instead of using the annoying reset command.
Thanks,
Josh
Best Continuity Tester Ever
Best Continuity Tester Ever...Got Betterer!
Offline TheDefpom
« Reply #3736 on: December 02, 2024, 08:11:27 am »
Does the 3055X-E really ID itself as the 3045X ?
I think I was the one that pointed out you can go to local mode from the front panel to not do the reset on exit as I found that annoying too, maybe that change got lost in the updates at some point, have changed the latest file to include those changes.
Cheers Scott
    • Tests
« Reply #3737 on: December 02, 2024, 11:51:44 am »
Thanks, they will be included in next release.
I can see you have included the 3055X-E. I wonder with that model, it is a China only model, but the 3045 can be hacked to it, do original and hacked version return the same id string?
Offline KungFuJosh
  • TEAS is real.
« Reply #3738 on: December 02, 2024, 03:52:16 pm »
Well, the improved version certainly does.
I thought it was you but I couldn't remember for sure. Not getting any younger over here. 😉
I doubt the China only model has the same ID, but I don't have one to check to confirm either way.
Maybe it would be a good idea to have both ID versions, and leave the hacked version commented out with a note about it using the same ID as the 3045X.
Thanks,
Josh
    • Tests
« Reply #3739 on: December 03, 2024, 12:44:45 pm »
Maybe call it "Siglent SDM3055X-E (3045)" and then create a "Siglent SDM3055X-E" with the 3055 id string?
Offline TheDefpom
« Reply #3740 on: December 04, 2024, 05:36:31 am »
I think the hacked version uses the same ID as the 3045, so I'm not sure how that will be handled?
Anyway, on the SPD4xxxX I have done a couple of review videos, Part 2 which I will be publishing in a couple of days time shows the definition I wrote for the SPD4306X in use, as well as a link to this forum thread so others can get it if they don't already have TC.
Cheers Scott
Offline KungFuJosh
  • TEAS is real.
« Reply #3741 on: December 04, 2024, 05:41:58 am »
I suggest copying my definition for the upgraded version, and leave it commented out with a note for people that have upgraded their 3045X to 3055X-E.
Thanks,
Josh
Offline tautech
« Reply #3742 on: December 04, 2024, 06:13:47 am »
It don't.
See model parsing:
https://www.eevblog.com/forum/testgear/siglent-sdm3045x-enough-is-enough/msg3909011/#msg3909011
Avid Rabid Hobbyist
Offline TheDefpom
« Reply #3743 on: December 04, 2024, 07:28:23 am »
It don't.
See model parsing:
Post: https://www.eevblog.com/forum/testgear/siglent-sdm3045x-enough-is-enough/msg3929159/#msg3929159
On screen the 3045X and (hacked) 3055X-E both showed as having a product ID of 3045X, this is returned as the *IDN? which TC uses to know what it is talking to, which would mean it won't know if it is a 3045X or a 3055X-E, as both would return as 3045X.
Cheers Scott
Offline TheDefpom
« Reply #3744 on: December 04, 2024, 07:45:16 am »
HKJ, edited the SDM 30xxx and attached, have commented out the (hacked) 3055X-E version, also renamed the file slightly to add a space to change it from "SiglentSDM30xxx" to "Siglent SDM30xxx", so it matches the naming conventions of other units, watch out if you just drop it into the folder as you may end up with 2 versions.
Cheers Scott
Offline KungFuJosh
  • TEAS is real.
« Reply #3745 on: December 04, 2024, 02:50:44 pm »
Scott is correct; there's a reason my definition for the 3055X-E had the 3045X ID. 😉
    • Tests
« Reply #3746 on: December 04, 2024, 04:07:21 pm »
I will include this.
Note: #idString and #handle do not need to be unique, it do give some minor issue when they are not:
Duplicate #idString means TC cannot automatic identify the device and cannot completely verify it is the correct device, neither of these issue is usually a problem.
Duplicate #handle can be a problem when loading .csv files, because the handle is used to find the column units. This will not be a problem with two fairly similar devices that have the same columns and units, but is more a issus when widely different devices has matching handles.
#name must be unique, TC will only load one device type of each name.
Offline KungFuJosh
  • TEAS is real.
« Reply #3747 on: December 04, 2024, 05:47:09 pm »
When TC auto-discovers a device, it adds the serial number. Won't that help separate them anyway?
Side question: Is there a way to get TC to do that auto-discovery when the device list isn't empty? I like the way that works better than manually adding devices.
    • Tests
« Reply #3748 on: December 04, 2024, 06:30:09 pm »
TC only uses serial numbers when you make your own handles with the "Remap handles" page or with LXI devices without IP address listed.
Not really.
The #DISCOVER? command will do a discovery, but will not add the devices found.
https://lygte-info.dk/project/TestControllerScriptCommands%20UK.html##DISCOVER?_{filter}
A "Search Socket" device will do a *idn? command on specified address and try to match it to all known devices (The device do not need to be loaded).
Devices that uses LXI connection do not need a IP address, that will force a discovery for that device. If a IP address is present TC will connect directly.
Note: Discovery is part of the LXI protocol and is not supported on non-LXI devices and I believe I have seen a LXI device that did not support discovery.
Help page for connecting devices: https://lygte-info.dk/project/TestControllerLoad UK.html
Help for remap: https://lygte-info.dk/project/TestControllerRemap%20UK.html
    • Tests
« Reply #3749 on: December 04, 2024, 06:36:00 pm »
I forgot one detail:
Discovery do not return the same name as *idn?, in TC I get around that by doing a sort of fuzzy comparison of the names. There is no guarantee it will always work.
