Author Topic: Program that can log/control many multimeters and other devices.  (Read 1680061 times)
0 Members and 276 Guests are viewing this topic.
Offline Taimer81
  • Country: ru
« Reply #4025 on: May 11, 2025, 09:22:03 am »
Hi HKJ,
I wrote a new device configuration file for the Fluke 8845A and 8846A DMMs.
As reported here the existing device file(s) did not work with DMMs with older firmware. Also it was a skeleton driver, LAN only, without Setup Menus.
This new configuration file supports all 884xA firmware versions. Also it supports all connection options of the 8845A/8846A: LAN, COM and GPIB. There are now full Setup Menu's:
For reading values the FETCH3? command is replaced by READ?, which is supported in all 884xA firmware versions. A further advantage of using READ? is that it functions the same as the READ? command used in HP/Agilent DMMs. This helps to get readings which are more synchronous with other DMMs. Especially important when logging slowly up- or down ramping signals with longer integration times (like 100NPLC).
I also paid extra attention to the NULL (offset) function. When switching on the NULL function, there has to be a reading in the meter buffer. This is the reading that will be subtracted from the following measurements. Now, when switching ON the NULL function, the meter also takes a measurement. So there is always a reading in the buffer for the Math.
This time no frequency response curve, as it is already in your collection :).
Please find the definition file here: Fluke8845A-8846A.zip
For people that want to use this definition before it is added to TestController: You have to remove the old drivers "Fluke8845A.txt" and "Fluke8846A.txt" from the main TestController/Devices folder. The usual over-ride function for drivers in Documents/TestController/Devices does not work properly because of the use of #metadefs in this definition.
Regards, Gertjan.
Hello! Please add support for the Tektronix DMM4040 which is similar to FLUKE's 8845. Thank you.
Offline Taimer81
  • Country: ru
« Reply #4026 on: May 11, 2025, 09:29:41 am »
The FLUKE 8845A profile doesn't fit.
Offline HKJTopic starter
    • Tests
« Reply #4027 on: May 11, 2025, 09:33:23 am »
You might be able to do it yourself.
If the protocol is exactly the same, only the *idn? is different it can be done by duplicating the #metadef section for 8845 and change the device name, handle and id.
    • Tests
« Reply #4028 on: May 11, 2025, 09:35:33 am »
I have a NI brand GPIB USB thing
GPIB-USB-HS
I got the NI driver for it. It says its on port 000009 in the device manager when I look through the detailed list of whatever it can dig up on it. It appears and disappeared from DM (as a NI device) when I plug it in and out of USB, so I know windows is seeing it
I assume this is COM 9.
I might not be com9, but even if it is a com port TC can only handle GPIB adapters it knows.
    • Tests
« Reply #4029 on: May 11, 2025, 09:37:04 am »
That is basically what I am talking about.
Copy everything from the first #metadef to the next #metadef, then modify these lines:
#idString FLUKE,8845A,
#name Fluke 8845A
#handle FL8845A
The following users thanked this post: Taimer81
Offline Taimer81
  • Country: ru
« Reply #4030 on: May 11, 2025, 10:49:43 am »
#name Fluke 8845A
#handle FL8845A
It worked, thank you.
Please tell me how to increase the sensitivity of the chart and histogram so that even minor deviations in the price can be seen.
Offline coppercone2
  • √Y√... 📎
« Reply #4031 on: May 11, 2025, 10:57:26 am »
GPIB-USB-HS
Are you saying the national instruments brand hardware is not supported?
I mean can you tell me the format its supposed to be in? Like the syntax of putting the name into the box. Do I just write com9? Or COM9? Or Com9? Or Com09, or Com00000009 or USB9 etc
Like what should I be writing here.
Is it supposed to auto detect the hardware and list it? Its completely unclear to me
What does it generally look like for a USB GPIB adapter? I mean the words in the text boxes when you click the GPIB button.
I don't know what the address is supposed to be. I only got the clue that its "9" from the driver information page. 'Com' was my guess. I saw the word Com thrown around in NI USB stuff before IIRC.
« Last Edit: May 11, 2025, 11:08:41 am by coppercone2 »
    • Tests
« Reply #4032 on: May 11, 2025, 11:15:08 am »
Please post your modified lines so I can add them to the file.
On the "Scales for charts" you adjust the scales, it can be either automatic or manual.  Be aware of the second auto checkmark, when checked it will include zero in the scale (David missed that).
For histograms you can adjust the bins setting below it.
In the posted chart you have checked the "Log" options, be careful with that.
« Last Edit: May 11, 2025, 11:22:13 am by HKJ »
    • Tests
« Reply #4033 on: May 11, 2025, 11:19:24 am »
I support on NI adapter. All GPIB is handled on the GPIB popup where you can also see the names of the supported adapters.
You generally have to type the port name (i.e. com9), but on the "Load devices" page you can also right click while in editing mode and TC will list detected serial ports (This do not work on the GPIB page).
Offline Gertjan
« Reply #4034 on: May 11, 2025, 11:38:33 am »
I know that the Tektronix DM4040 and DM4050 are very similar to the Fluke 8845A and Fluke 8846A.
Soon I will have a Tek DM4050 for testing. Then I will add them to the Fluke 884xA driver, or create a separate Tek DM40x0 driver.
regards, Gertjan.
Offline Kris0725pl
    • My Youtube Channel
« Reply #4035 on: May 11, 2025, 12:07:10 pm »
i have better for zoyi 703s :)
2564372-0
Offline Taimer81
  • Country: ru
« Reply #4036 on: May 11, 2025, 03:27:33 pm »
#name Fluke 8845A
#handle FL8845A
Please tell me how I can include 6 characters.
    • Tests
« Reply #4037 on: May 11, 2025, 04:36:19 pm »
This is controlled from the #value lines, but they are already configured to show all digits. This means the meter do not send more digits on the interface.
You can temporary change the number of digit by right clicking on a table column and adjust the format.
Offline Taimer81
  • Country: ru
« Reply #4038 on: May 11, 2025, 05:37:06 pm »
Yes, it helped. 8 characters show. Thank you.
    • Tests
« Reply #4039 on: May 11, 2025, 06:27:49 pm »
The format you select in the table can also be specified in the #value definition.
Offline Taimer81
  • Country: ru
« Reply #4040 on: May 11, 2025, 07:27:02 pm »
This is a bit more complicated.An integer variable is specified and its range is from 0-6 characters. Where it's defined isn't clear to me. Should I just use "Si8" instead of "Si"?
    • Tests
« Reply #4041 on: May 11, 2025, 07:47:19 pm »
If you want SI8 format then yes, other are X8 or D8.
SI means use SI prefix like m, the number puts a limit on the total number of digits that can be shown.
X means up to number of digits after point
D means always use number of digits after point.
The following users thanked this post: KungFuJosh, Taimer81
Offline Taimer81
  • Country: ru
« Reply #4042 on: May 11, 2025, 08:57:02 pm »
Thank you.
It remains to deal with "Math". )))
Offline bicycleguy
« Reply #4043 on: May 11, 2025, 10:33:25 pm »
On your opening page:
I have been working ...
Read more about it and download it from here: http://lygte-info.dk/project/TestControllerIntro%20UK.html
Please change the above link to https:
Besides scaring the # out of me with warnings and making me wonder if the code is safe, it could lead to a person going to a mirrored site and downloading malicious code as perhaps https://www.eevblog.com/forum/testgear/program-that-can-log-from-many-multimeters/msg5891476/#msg5891476 did.
Offline rthorntn
« Reply #4044 on: May 12, 2025, 06:42:08 am »
Noob question, I see the Keysight U1272A DMM in the supported list but how does it connect to Test Controller?
I only have the Keysight U1177A IR-to-BT adapter, will that work, or do I need a Keysight U1173B IR-to-USB?
Thanks!
Offline Taimer81
  • Country: ru
« Reply #4045 on: May 12, 2025, 06:45:17 am »
Please tell me how to correctly write the formula in Match.
((TEKDMM4040.Volt DC-1)/1)*100
    • Tests
« Reply #4046 on: May 12, 2025, 06:54:07 am »
Done.
The following users thanked this post: bicycleguy
    • Tests
« Reply #4047 on: May 12, 2025, 06:54:47 am »
You need the cable, this will create a serial port on the PC.
The following users thanked this post: rthorntn
    • Tests
« Reply #4048 on: May 12, 2025, 06:58:56 am »
The issue is the spae in the names (That is sort of a bug that TC did not fix it).
Change your formula to:
((TEKDMM4040.Volt_DC-1)/1)*100
I.e. add a _
This will probably fix it.
Offline Taimer81
  • Country: ru
« Reply #4049 on: May 12, 2025, 07:03:40 am »
I.e. add a _
Yes, it helped. Thank you.
