Six months later he found out he hadn't attached the power cable to the fan.
This doesn't mean that it doesn't matter if a fan is active or not.
He can also have unknowingly operated the device outside of the specifications, thus aging it faster.
Rarely is something done without reason, especially not in a cheap device, if a fan was not necessary, it would be omitted for cost reasons.
For example, I had replaced the fan in my SDS2504X-HD because the original one had a defect.
Now an even quieter fan from Noctua is installed and that does not really make me happy.
He is also weaker than the original.
That does not mean anything if reserves were planned in the thermal design, but I do not know that.
Most ICs are rated for maximum junction temperature of 125C
That´s mostly MIL-Spec, common ICs are rated for 85°C.
In both cases, this does not mean that they remain in the specifications(keyword derating) up to these temperatures, they just do not go defective until then.
I may be overly cautious, but in general I would not underestimate the issue.
