Depends on the specific model, I guess. DHO914 is supposedly in stock at Batronix, and lead times for DHO800 are shorter than other DHO900 models.
So everybody is going for the DHO900? That's interesting...
Is it the color? The bandwidth? The Siggen?
How do you guys in the Europe get your DHO800/900? I ordered from Batronix and they tell me the ETA will be mid-December .
Depends on the specific model, I guess. DHO914 is supposedly in stock at Batronix, and lead times for DHO800 are shorter than other DHO900 models. Other dealers might have different stock? The socially accepted method in Europe is to check dealers' websites for stock/lead time info, or call them or send an email if that info is not provided online.
Are you really in China as your country flag suggests? Why would you order from Europe then?
I ordered DHO914S btw. Batronix has changed the lead time on the website several times, once it shows the stock is 3-7 days away, but then changed back to 21-40 days. DHO914 is exceptionally in stock currently it seems.
I think Rigol hugely underestimated the popularity of both the 800 and the 900 series .
Has anybody managed to install an FTP program on one of these? FTP access to screenshots is incredibly useful on my Micsig.
The scope is running an ftp server. You can
ftp scope-ip-address
I haven't tried that... I'll give it a go later.
Is the smell worse or better than 1054z?
I just noticed the stats are reset when the 'scope is running and you change the vertical scale or horizontal time base.
Add that to the long list of ways to reset the stats that are better than having to manually reset them on other 'scopes.
Thank you,hubert.
My DHO804 is DHO924 now.
Two extra drams are only for LA.It can be unpopulate if doesn't use the LA .
The bandwidth is increased successfully.it has 800ps rise time now.
And the memory depth is 50M now.
Hi,I have a 804 now,I want to crack but I don't know how to do that.Can you give us some operational procedures?Of course need x.bin but others.
100 MHz bandwidth can be unlocked as described in the post I linked to. There is, however, no known way (yet?) to go to 250 MHz bandwidth
Next up: WiFi.
Can anybody recommend a known model of WiFi dongle that works with these?
Aliexpress is fine.
Next up: WiFi.
Aliexpress is fine.This one should work... since rtl8188 works with most Android and Linux systems.
Floydfish already proved that previously.
Also, there are several versions with an external antenna exist... Aliexpress / Amazon.
One less cable is good, especially if I want to use it on the other side of the room.
how do you watch movie in your scope if its on the other room? or play tetris? over ftp?
Did i do something wrong? Is there another way? Or is the RTL8188CUS just not supported by the driver?
