Author Topic: R&S to launch MXO5  (Read 50266 times)
Tomki and 1 Guest are viewing this topic.
Offline Stranger_dangerTopic starter
R&S to launch MXO5
« on: September 18, 2023, 04:05:51 pm »
Buried in their website code is the name of the MXO5 Oscilloscope.  Cats out of the bag, 42 days early.   |O
https://www.rohde-schwarz.com/us/products/test-and-measurement/oscilloscopes/promotion/next-generation_255909.html
The following users thanked this post: egonotto, edavid
Re: R&S to launch MXO5
« Reply #1 on: September 18, 2023, 05:10:38 pm »
Specs:
- 4 and 8 channels
- 350, 500 MHz, 1 GHz, 2 GHz
- 12 bits
Pricing:
MXO54 500MHz $4,120
MXO54 1 GHz $9,680
MXO54 2 GHz $12,875
MXO58 350 MHz $9,040
MXO58 500 MHz $16,250
MXO58 1 GHz $25,520
MXO58 2 GHz $30,670
MXO5-k31.03 power analysis $2,470
« Last Edit: September 18, 2023, 05:15:06 pm by Stranger_danger »
Offline tv84
  • Country: pt
« Reply #2 on: September 18, 2023, 05:30:15 pm »
Bad image.
Offline Sighound36
« Reply #3 on: September 18, 2023, 06:24:44 pm »
Going after Siglent's new 7000 with that pricing
Offline gslick
« Reply #4 on: September 18, 2023, 06:37:49 pm »
Specs:
- 4 and 8 channels
- 12 bits
Pricing:
MXO54 500MHz $4,120
MXO54 1 GHz $9,680
MXO54 2 GHz $12,875
MXO58 1 GHz $25,520
MXO58 2 GHz $30,670
That starts at less than the least expensive MXO44 200MHz model. Will the MXO5 series be lower end than the MXO4 series?
Online Hydron
« Reply #5 on: September 18, 2023, 06:43:14 pm »
Huh, still not really hobbyist pricing but the lowest spec model is maybe edging into enticing-if-hackable territory.
« Reply #6 on: September 18, 2023, 06:50:14 pm »
Specs:
- 4 and 8 channels
- 12 bits
Pricing:
MXO54 500MHz $4,120
MXO54 1 GHz $9,680
MXO54 2 GHz $12,875
MXO58 1 GHz $25,520
MXO58 2 GHz $30,670
Found the pricing cached through Newark. Not clear if it's an option on top of base model or total price.  "MXO5-B245.03" was the option found.
Online Hydron
« Reply #7 on: September 18, 2023, 07:30:34 pm »
B245 sounds like an option code sadly :(. Assuming that the 8-channel option is a SW one it would also explain having a 350MHz option on 8-channels only - it's an option to bump channel number up rather than BW, given a base of 350MHz.
« Last Edit: September 18, 2023, 07:32:19 pm by Hydron »
Offline tautech
« Reply #8 on: September 18, 2023, 07:37:07 pm »
SDS7000A are 2-4 GHz models whereas SDS6000L 2GHz and 8ch is the better fit.
Avid Rabid Hobbyist
Offline Martin72
« Reply #9 on: September 18, 2023, 08:32:08 pm »
Pricing:
MXO54 500MHz $4,120
Hmm...That's hard to believe.
Offline Martin72
« Reply #10 on: September 18, 2023, 09:14:27 pm »
Specs:
- 4 and 8 channels
- 12 bits
Pricing:
MXO54 500MHz $4,120
MXO54 1 GHz $9,680
MXO54 2 GHz $12,875
MXO58 1 GHz $25,520
MXO58 2 GHz $30,670
Where do you get this?
« Reply #11 on: September 18, 2023, 09:16:28 pm »
Specs:
- 4 and 8 channels
- 12 bits
Pricing:
MXO54 500MHz $4,120
MXO54 1 GHz $9,680
MXO54 2 GHz $12,875
MXO58 1 GHz $25,520
MXO58 2 GHz $30,670
It's cached on Google.
Offline Martin72
« Reply #12 on: September 18, 2023, 09:21:17 pm »
I find nothing.. :-//
Offline 2N3055
  • Country: hr
« Reply #13 on: September 18, 2023, 09:41:01 pm »
Pricing:
MXO54 500MHz $4,120
Not if everything is option. 2500 € power analysis. Segmented mode XXXX€ , decoding even basic protocols XXXX€.. etc etc...
Same as RTB2004 basic is not much more expensive than some competition but has nothing on it if you don't buy options.
But as Hydron said, those could actually be upgrade options prices from a basic 350 MHz 4ch scope.
« Last Edit: September 18, 2023, 09:42:57 pm by 2N3055 »
Dr. Richard W. Hamming
Offline tv84
  • Country: pt
« Reply #14 on: September 18, 2023, 09:50:28 pm »
Google cache shows that all of that are upgrade options.
If not, Rigol could suffer a big blow.  :-DD
Unless the boot time is not pleasant...
Edit: I also searched the cache and, now, I'm not so sure...  :-// It seems the prices are for the base models:   :o
MXO5-B245         $4,120.00    Upgrade 500MHz
MXO5-B2410       $9,680.00    Upgrade 1 GHz
MXO5-B2420     $12,875.00    Upgrade 2 GHz
MXO5-B282         $3,890.00   Upgrade 200 MHz
MXO5-B283         $9,040.00   Upgrade 350 MHz
MXO5-B285       $16,250.00   Upgrade 500 MHz
MXO5-B2810     $25,520.00   Upgrade 1 GHz
MXO5-B2820     $30,670.00   Upgrade 2 GHz
MXO5-B110         $3,090.00    Memory upgrade 1Gpts
MXO5-B6             $1,440.00    Waveform generator
MXO5-K31           $2,470.00    Power Analysys
MXO5-K36           $2,470.00    Bode Plot
MXO5-K520         $2,885.00    CAN, CAN-FD, CAN-XL decoder
(from the Newark cached pages, as above)
« Last Edit: September 19, 2023, 03:20:20 pm by tv84 »
Offline Martin72
« Reply #15 on: September 18, 2023, 10:33:57 pm »
Who pays anything for the options... :-X
If that wasn't a misprint and the scope isn't the very worst snot, this could get interesting if a third party throws their hat into the ring of barely affordable 12-bit scopes.
« Reply #16 on: September 18, 2023, 11:09:14 pm »
Google cache shows that all of that are options.
MXO5-B245.03        $4,120.00    500MHz
MXO5-B2410.03      $9,680.00    1 GHz
MXO5-B2420.03     $12,875.00   2 GHz
MXO5-B282.03       $3,890.00
MXO5-B283.03       $9,040.00   350 MHz
MXO5-B285.03       $16,250.00  500 MHz
MXO5-B2810.03     $25,520.00  1 GHz
MXO5-B2820.03     $30,670.00  2 GHz
MXO5-B110.03        $3,090.00
MXO5-B6.03            $1,440.00
MXO5-K31.03           $2,470.00
MXO5-K36.03             $2,470.00
MXO5-K520.03          $2,885.00
If I look at how they price the MXO4. There is a base 200MHz 4-channel model. To upgrade from 200MHz to 350MHz is option B243 (Base-200MHz-4channel-350MHz).
To upgrade to a 1 GHz the MXO4 goes MXO4-B2410 (200MHz-4channel-1.0GHz).
So looking at the options you found, most of those are 200MHz, 8 channel or 4 channel, to 350MHz, 500MHz, 1.0 GHz and 2.0 GHz. We're missing the Base model pricing.
Scope total price = Base + Bandwidth
Otherwise Newark lists configured prices and bundles for the MXO4. For instance MXO44-2410 is a MXO4 4 channel with the 200MHz to 1 GHz bandwidth option.  But search for MXO5-2820, all I see cached is the option, not the configured option price.
The following users thanked this post: tv84
Offline Sighound36
« Reply #17 on: September 19, 2023, 07:30:07 am »
Considering the MX04 has enjoyed upto 48% off RRP in the last tweleve months on certain model configurations. The MX05 is either a 'budget model' or that pricing is like Dave's experinace with pathway software some what screwed  :-DD
The 1.5Ghz MX04 here in the UK with discounts can be had for around £18.5K plus vat so pretty sure R&S arn't going to release the next model up for less  :-//
« Last Edit: September 19, 2023, 10:21:13 am by Sighound36 »
Offline tv84
  • Country: pt
« Reply #18 on: September 19, 2023, 10:21:39 am »
That logic makes sense but, then, what is the MXO5-B282.03 upgrade (in the list)?
Offline Someone
    • send complaints here
« Reply #19 on: September 19, 2023, 11:57:25 am »
4 to 8 channel soft upgrade?
Offline Spectral_Duck
« Reply #20 on: September 19, 2023, 06:25:29 pm »
Looks like Newark also accidentally posted early.  Sadly, all the pages now lead to a 404.  I typed the following into google to find it.
site:"newark.com" mxo5
Offline pdenisowski
  • Product Management Engineer, Rohde & Schwarz
    • Test and Measurement Fundamentals Playlist on the R&S YouTube channel
Test and Measurement Fundamentals video series on the Rohde & Schwarz YouTube channel:  https://www.youtube.com/playlist?list=PLKxVoO5jUTlvsVtDcqrVn0ybqBVlLj2z8
Online exe
  • self-educated hobbyist
« Reply #22 on: October 25, 2023, 10:29:25 am »
Is there any 70MHz version with a price tag below 1k to compete with DHO804? I'd buy one  :-DD
Offline Martin72
« Reply #23 on: October 25, 2023, 10:55:02 am »
Only ~5 more days to go!
I had registered via the company address.
Instead of the advertised benefits such as early news about the scope, I get only promotional garbage.... ::)
The following users thanked this post: Someone, egonotto
Online jusaca
« Reply #24 on: October 30, 2023, 12:39:17 pm »
500 Mpoints per channel (Opt. upgrade to 1 Gpoints)
Well, that's something I could work with :D
Not that I could afford such a scope, but...
Source: https://assets.testequity.com/te1/Documents/pdf/rs/RS_Fact_Sheet_MXO5_v1.00_1023.pdf
The following users thanked this post: ddrl46, egonotto, DaneLaw, Martin72
