Author Topic: R&S to launch MXO5  (Read 51480 times)
Online KungFuJosh
  • TEAS is real.
Re: R&S to launch MXO5
« Reply #175 on: August 20, 2025, 12:27:06 am »
Or you'll get it done very slowly.
I think that's happening anyway. ;)
Best Continuity Tester Ever
Offline Bernd_2
« Reply #176 on: August 20, 2025, 06:27:38 pm »
Hello,
I may have a point for the roadmap here.
Either it's a bug in the firmware or I'm doing something wrong when trying to set the prefix for Date/Time to Europe.
When I open the menu, the setting is set to Africa.
2642355-0
I change it to Europe,
2642359-1
press Apply,
and suddenly it's back to Africa.
2642363-2
Best Regards
Bernd
The following users thanked this post: pdenisowski
Offline tooki
« Reply #177 on: August 20, 2025, 09:18:50 pm »
Hello,
The new firmware version 2.6.2.4 includes a practical new feature: measurement result lines.
Indeed. If anything, it's kinda shocking that it took this long, given that my freaking $400 Rigol from 10 years ago did this. The MXO implementation also slows down the waveform rate a lot; I hope that a future update moves this to hardware acceleration (as they did with XY mode). One of the things I love about the LeCroy I have at work alongside the MXO4 is the measurement result lines that keep up with the waveform display.
Offline Bernd_2
« Reply #178 on: November 19, 2025, 04:46:38 pm »
Hello,
Four weeks ago, Paul posted on youtube two videos on the topic of understanding and decoding ARINC 429. Thank you very much for that.
Unfortunately, used aeronautical devices with ARINC 429, such as altimeters, are still very expensive. Too expensive to just try out the decoder in the MXO. But there is an Arduino sketch on Github that generates an ARIC 429 signal. It's not very stable, but I've managed to get a few error-free transmissions from time to time.
For anyone who wants to try it out, I have attached an Arb file for the MXO function generator. It contains 5 words, but is not symmetrical ±5V or ±10 V, as would be correct according to ARINC 429, but only positive.
However, it still works with the correct settings: Gen1 output 3Vpp, 0V offset, Protocol settings, Polarity A Leg, Bit rate mode High, Min Gap Time standard 4 bit, Upper Threshold 2.5V, Lower Threshold 0.5V.
Another suggestion for the MXO roadmap: for the polarity settings, include not only A Leg and B Leg but also A-B.
Images 2 and 3 were created with the ARINC 429 signal from Gen 1.
Best Regards,
Bernd
« Last Edit: November 19, 2025, 04:48:41 pm by Bernd_2 »
The following users thanked this post: egonotto, 2N3055, pdenisowski, Martin72
Offline pdenisowski
  • Product Management Engineer, Rohde & Schwarz
    • Test and Measurement Fundamentals Playlist on the R&S YouTube channel
« Reply #179 on: November 21, 2025, 03:41:22 pm »
You'll never guess what I'm doing some presentations / videos on literally right now :)
Test and Measurement Fundamentals video series on the Rohde & Schwarz YouTube channel:  https://www.youtube.com/playlist?list=PLKxVoO5jUTlvsVtDcqrVn0ybqBVlLj2z8
The following users thanked this post: tooki, jjoonathan
Offline pdenisowski
« Reply #180 on: November 21, 2025, 03:42:23 pm »
Thanks!  Really appreciate the additional testing / waveforms!
And I haven't forgotten about Manchester - just had some urgent issues / requests that I have to take care of first :)
The following users thanked this post: Bernd_2
Offline pdenisowski
« Reply #181 on: November 21, 2025, 03:44:40 pm »
If you have too much on your plate at once, you won't get anything done.
The story of my life  :)
But I prefer the old saying about "good, fast, and cheap - you can only have two"
Offline pdenisowski
« Reply #182 on: November 21, 2025, 04:18:26 pm »
« Last Edit: November 21, 2025, 04:21:55 pm by pdenisowski »
Online KungFuJosh
  • TEAS is real.
« Reply #183 on: November 21, 2025, 08:56:39 pm »
How about some XY music? I'd love to see how this appears on the MXO4/5:
Offline pdenisowski
« Reply #184 on: November 22, 2025, 01:54:16 am »
There are some other R&S people who are the "scope music" specialists - I'll ask :)
The following users thanked this post: jusaca, KungFuJosh
Offline Bernd_2
« Reply #185 on: November 24, 2025, 05:37:03 pm »
Thank you very much.
Thanks to MarkL, Manchester decoding is now working. My mistake was that I hadn't set the gap time correctly.
Best Regards,
Bernd
« Last Edit: November 24, 2025, 05:38:49 pm by Bernd_2 »
Offline Bernd_2
« Reply #186 on: November 24, 2025, 05:50:58 pm »
Hello,
Today I will show you how to decode the SENT protocol. (SENT Fast only, no embedded messages)
First, a very brief description of the SENT legacy protocol SAE J2716 (not SENT SPC).
The SENT protocol (Single Edge Nibble Transmission) is a serial interface for data transmission in the automotive industry that transmits sensor data from a sensor to a control unit. It was developed to improve the transmission of sensor data in the often noisy environment of a vehicle and to offer a cost-effective alternative to conventional analog interfaces. As long as the falling edges of the pulses can be clearly detected it is less susceptible to noise than conventional analog interfaces in vehicles.
Structure and function
Single-wire transmission: Data is transmitted unidirectionally via a single signal line.
Pulse-coded transmission: Data is transmitted as a sequence of pulses, with the duration of the pulses encoding the data. The data is measured by the time intervals between the falling edges of the pulses.
Ticks: The time base for signal measurement is a “tick” (Ttick), the length of which is calibrated by a synchronization pulse. The time length of the sync pulse is 56 Ticks
Data nibbles: A nibble corresponds to four bits and is used as a unit of data transmission. The minimum nibble width of 12 Ticks represents the value 0000b, 0h and the maximum nibble width of 27 Ticks results in the value 1111b, Fh.
A typical SENT data frame consists of:
Synchronization pulse: Used to synchronize and calibrate the time base. 56 x Tick-Time, here 56 x 30 µs = 1.68(6) ms.
Status and communication nibble: Contains information about the sensor or the type of message. here 9h
Data block: Up to six nibbles containing the actual sensor data. here: N1: 1h, N2: 2h, N3: 3h, N4:Ah, N5:Bh, N6: Ch
Checksum nibble: This is a 4-bit CRC of the six data nibbles only. here 8h
Optional pause pulse: Can be used to separate message frames.
Figure 1 shows the configuration of the decoder for the SENT signal in this example.
Figure 2 shows the decoded signal from the function generator from the Arb file attached in the appendix.
Figure 3 shows the decode layer. I wonder if it is also possible to display both honeycomb displays simultaneously. Perhaps a point for the firmware roadmap.
Figure 4 shows that it also works with the SDS2000X+.
« Last Edit: November 24, 2025, 06:55:55 pm by Bernd_2 »
The following users thanked this post: egonotto, pdenisowski, Elio
Offline m-e-t
« Reply #187 on: July 04, 2026, 01:52:29 pm »
hello
i ve found a MXO 5 but it does not boot :-)
someone erase a file and i cannot succeed to bot it up
do you ever copy/save the microSDHC card inside?
regards
sebastien Corradi
Offline Bernd_2
« Reply #188 on: July 04, 2026, 07:13:55 pm »
As far as I know the MXO5 boots from the 256 GB M.2 SSD on the backside.
The SSD contains the
● Operating system and instrument firmware
● Firmware options and applications
● Instrument states and setups
● Waveform data
● Measurement results and screen images
Maybe that some files on your SSD are missing or corrupted. A replacement SSD can be bought from Batronix at 761,60 Euros.
I haven't dared to make a backup of this SSD yet because I don't know if doing so might damage it, and I don't know if I'd ever be able to get the expensive firmware options back.
In Shariar's teardown video, I was also shocked to see that there's an SD card on the Complex board.
Unfortunately, he didn't say anything about what it's used for.
The question is how much data is written to this SD card during operation and how often, and whether it’s a simple standard card that, in the worst case, will fail after 3,000 write cycles, or whether a high-endurance card is installed that can withstand up to 100,000 write cycles.
Despite all the high-quality components built into the device, this SD card could ultimately determine the oscilloscope's lifespan.
It would be great if Paul or Daniel from R&S could shed some light on this and, if they're allowed to, say a few words about how the SD card works and any potential risks of failure associated with it.
Best Regards,
Bernd
Offline tv84
  • Country: pt
« Reply #189 on: July 05, 2026, 04:15:38 pm »
hello
regards
sebastien Corradi
How did "someone" erase the file? Just put the file back from a FW package.
About the "microSDHC card" you're seeing: that should be a Javacard, not a SD card. As such, no straightforward copy/save as you might be expecting.
Offline Bernd_2
« Reply #190 on: July 05, 2026, 08:02:25 pm »
In Shariar's MXO5 teardown video, starting around the 2:04 mark, it looks to me like there's an SD card slot with an SD card inserted on the lower left edge of the Complex board.
Could this be a smartSD card running JavaCard applets?
Do you have any idea what this card is used for in the MXO5? I didn't see a card like this in the teardown videos for the MXO3 and MXO4.
Best Regards,
Bernd
Offline tv84
  • Country: pt
« Reply #191 on: July 05, 2026, 08:58:30 pm »
Yes, it can be a Secure SD running a JavaCard OS.
That card holds the licensing/scope ID info.
The following users thanked this post: egonotto, pdenisowski, Bernd_2
Offline Bernd_2
« Reply #192 on: July 16, 2026, 04:18:31 pm »
Hello,
The new firmware version 2.10.2.0 introduces a useful new feature: Channel Label
Figure 1 (Excerpt from the User Manual)shows the settings available in the Settings -> Appearance -> Grid menu. In addition to the channel name and label, it can also display the X- and Y-values, thereby replacing a cursor measurement in some cases.
Figure 2
shows an example where I use the channel label display for eight consecutive oscillograms, which saves me the trouble of having to add new annotations to each graph. However, since I need to take cursor measurements here, the display of the X and Y positions is turned off.
Anyone interested in the details of what can be seen in Figure 2 can read about it in the thread, "Investigating starting methods for 3-phase asynchronous motors using an oscilloscope."
https://www.eevblog.com/forum/projects/investigating-starting-methods-for-3-phase-asynchr-motors-using-an-oscilloscope/msg6308950/#msg6308950
Please read Post #24 on Page 1 first.
Best Regards,
Bernd
The following users thanked this post: egonotto, Martin72, rusoaie, Elio
Online KungFuJosh
  • TEAS is real.
« Reply #193 on: July 16, 2026, 05:41:52 pm »
I was going to tease about something as fancy as channel labeling coming to an R&S product, but I really like how they implemented it. ;)
Offline Bernd_2
« Reply #194 on: July 16, 2026, 06:52:50 pm »
I have to make a correction here.
The input field for the channel label was already available in the Channel menu, and the text was—and still is—displayed in the header of the respective channel icon in the lower-left corner of the screen.
Firmware version 2.10.2.0 now includes a major improvement.
Best Regards,
Bernd
« Last Edit: July 16, 2026, 07:22:57 pm by Bernd_2 »
Offline Bernd_2
« Reply #195 on: September 19, 2026, 10:22:10 am »
Hello,
here is a solution to generate coefficient files for user defined filters on MXO oscilloscopes.
You can use the following short Python script to generate coefficient files for bandpass and bandstop filters with various window functions.
import numpy as np
import scipy.signal as signal
numtaps = 99          # even for Bandpass, odd for Bandstop
fs = 5.0e9              # Samplerate (5 Gs/s)
f_low = 200.0e6
f_high = 300.0e6
beta = 6.0 # for Type Kaiser
output_filename = "mxo5_bandstop_hamming.csv"
nyq = fs / 2
coefficients = signal.firwin(
    numtaps,
    [f_low / nyq, f_high / nyq],
    pass_zero=True, # True = Bandstop, False = Bandpass
    fs=fs,
    window='hamming'
#   window=('kaiser', beta),
with open(output_filename, mode='w', encoding='utf-8') as f:
    for coeff in coefficients:
        f.write(f"{coeff:.12e},")
print(f"Success! File '{output_filename}' with {len(coefficients)} Taps created")
It is important that the sampling rate for the filter matches the sampling rate set on the oscilloscope.
I have tested it with the following window methods:
- Hamming
- von Hann
- Blackman
- Kaiser (with different beta values)
The beta value allows you to flexibly adjust the stopband attenuation of the Kaiser filter to your needs.
You can adjust the filters using the following parameters:
  • numtaps:   Number of coefficients — even for bandpass, odd for bandstop
  • fs:             Sample rate
  • f_low:        Lower cutoff frequency
  • f_high:       Upper cutoff frequency
  • beta:          Beta value for the Kaiser window
  • pass_Zero: True for bandstop, False for bandpass
All tests were performed with a sampling rate of 5 Gs/s, a lower cutoff frequency of 200 MHz and an upper cutoff frequency of 300 MHz. The input signal comes from the Bodnar LBE-1322 pulse generator.
The filters were calculated using 100 taps (bandpass) or 99 taps (bandstop). Next, we can examine how the filter length affects the selectivity for each windowing method.
Next.... images with the results
Best Regardds,
Bernd
« Last Edit: September 19, 2026, 10:29:34 am by Bernd_2 »
The following users thanked this post: egonotto, jjoonathan, Martin72
Offline Bernd_2
« Reply #196 on: September 19, 2026, 10:39:24 am »
Hello,
Here are the results for the various bandpass filters.
Part I: Blackman, Hamming, von Hann
I don’t know enough about the subject to provide a sophisticated interpretation of the filter curves. Maybe someone here would like to take that on.
To make it easy to try them out quickly, I’ve also uploaded the corresponding coefficient file for each image. To be able to upload the CSV files, I added the .txt extension. This must be removed before uploading to MXO oscilloscope.
Best Regards,
Bernd
« Last Edit: September 19, 2026, 10:42:29 am by Bernd_2 »
The following users thanked this post: jjoonathan, Martin72
Offline Bernd_2
« Reply #197 on: September 19, 2026, 10:48:52 am »
Hello,
here comes Bandpass Part II: Kaiser with various Beta Values.
Best Regards,
Bernd
Next ... Results for Bandstop Filters
« Last Edit: September 19, 2026, 10:53:59 am by Bernd_2 »
Offline Bernd_2
« Reply #198 on: September 21, 2026, 05:21:13 pm »
Hello,
Here comes Part I with the results for the various band-stop filters. As with the bandpass filters with f_low = 200 MHz, f_high = 300 MHz, but with 99 taps.
The first image shows a band-stop filter created using the Equation Editor by combining a high-pass filter and a low-pass filter. Since only the brick-wall type is available for the high-pass filter, I also selected brick-wall for the low-pass filter.
For the user-defined filters, the CSV files are again attached to each image.
Best Regards,
Bernd
« Last Edit: September 21, 2026, 05:24:46 pm by Bernd_2 »
Offline Bernd_2
« Reply #199 on: September 21, 2026, 05:29:03 pm »
Hello,
Here comes Part II with the results for the band-stop filters with kaiser window with various values for beta. Again with the  with f_low = 200 MHz, f_high = 300 MHz, but with 99 taps.
Best Regards,
Bernd
Next.....Multiband Filters
