Author Topic: RuiDeng Riden RD6006 DC power supply  (Read 713468 times)
billclay and 29 Guests are viewing this topic.
Offline BravoV
  • +++ ATH1
Re: RuiDeng Riden RD6006 DC power supply
« Reply #425 on: November 30, 2020, 05:51:03 am »
That LT supply is nice, but pretty expensive at ~$200 and you still need an input DC source!
If you read the sub-sequent post after that review post, there was a post made by Linear Technology's staff (I believed), that the BOM cost was just < $50  ::) , they deliberately put a hefty price tag to wade off PSU hoarder like me  >:D, usually they gave these for free for their big customers for evaluation.
BTW I think what UniSoft has done with these is great, so hat's off  :-+
Yep, UniSoft 's great work made a trickling sensation teasing me to buy this Ruideng bench PS, I'm a bench PSU hoarder btw  :palm:, own many quality bench PSUs like HP, Kenwood, Kikusui, Thurlby Thandar, Nemic Lambda, but all of those are beefy big and heavy.  ::)
Just imagining "if" Ruideng made the linear pre-regulating series "good enough" , I'm intrigued what if this tiny little gadget coupled with high power density converter like made by Vicor, as I have plenty in my disposal  :P, may be the size of computer's optical drive with 500 Watt capable bench PSU ? or even smaller ?  :-//
« Last Edit: November 30, 2020, 06:08:29 am by BravoV »
Offline nikitasius
« Reply #426 on: November 30, 2020, 10:28:50 am »
Since there are no negative reviews and interesting ideas, then I can already release the final versions.
Here are versions for all 3 models.
Hi, last firmware you posted for 6006 is RD6006_Flasher_V1.32.12.zip , there are no the new one?
There are idlers that want to have money without working and fools that are ready to work without becoming rich.
Offline UniSoft
  • Country: kz
« Reply #427 on: November 30, 2020, 11:07:41 am »
this is latest release version...
New version on the way... now on beta testing...
If anyone want to join a beta testing, beta version(s) can be downloaded here:
https://monitor.net.ru/forum/threads/651114/post-6081567
« Last Edit: November 30, 2020, 11:16:52 am by UniSoft »
The following users thanked this post: nikitasius
Offline nikitasius
« Reply #428 on: November 30, 2020, 11:18:28 am »
Cool, my RD6006 is on the way too.
As a powersupply i will use few switch power supply modules (2x24/9 in serial) with 4-5 filters (4 pins inductors + caps) for different freqs.
It's cheap and handy.
The following users thanked this post: Pukker
Offline mawyatt
« Reply #429 on: November 30, 2020, 02:23:23 pm »
Back to my original request, could someone provide measurements on the output noise levels of these Ruideng power supplies?
Best & Thanks in Advance,
~Wyatt Labs by Mike~
Offline BravoV
  • +++ ATH1
« Reply #430 on: November 30, 2020, 02:27:40 pm »
Dave did it.
Offline BravoV
  • +++ ATH1
« Reply #431 on: November 30, 2020, 02:50:14 pm »
Also on above Dave's video, he made an addendum in the Youtube comment ...
"UPDATE: I screwed up the noise measurement. It's actually way better at about 60mVp-p no load and about 100mVp-p at 6A using a proper scope probe in X10. I was using a BNC cable with banana plugs and forgot the 50ohm series matcher. Oops. Will have to do another video showing this. Good excuse for a video on this topic anyway...."
The following users thanked this post: mawyatt, nikitasius
Offline mawyatt
« Reply #432 on: November 30, 2020, 02:57:21 pm »
Dave did it.
Just watched, the switching noise is really high, this is what I was worried about :P
Like that Dave used a "floating" battery DSO to measure, eliminating any ground induced measurement artifacts.
Everything about this looks encouraging except the noise output, hopefully the new "Hybrid" version will improve on this, but not sure that putting a post LDO will attenuate the switching noise much.
Anyway, looking forward to how well this Hybrid" version behaves, especially from the output noise perspective.
Thanks.
Best,
« Last Edit: November 30, 2020, 03:32:01 pm by mawyatt »
Offline mawyatt
« Reply #433 on: November 30, 2020, 03:46:16 pm »
When I was working we got all kinds of things "free", from expensive chips, components, boards, space on IC fab runs and so on. However, my time was limited and expensive so I couldn't take full advantage of these "offerings".
Now I'm retired with lots of available "free" time, there are no "offerings"  :-\
Best,
Offline alex34
  • Country: ru
« Reply #434 on: November 30, 2020, 03:48:03 pm »
I messed with the noise of RD6006W. I measured about 20mV on a 50 Ohm probe (If I remember correctly). Decoupling with ceramic caps soldered right to the output terms on the PCB does not eliminate the noise. More of that, there is a ceramic cap in RD6006W. I managed to decrease the noise by placing a ceramic cap right on the OUTPUT of the jack (directly to the probe's input). Seems, terminals form a kind of antenna.
I plan to design a PCB with ferrite beads on it + aluminum and ceramic caps. It should attenuate the noise.
PS: I designed a PCB with a 5V standby supply and relays. I can share it as soon as I check it.
Offline Tatanka1961
« Reply #435 on: November 30, 2020, 04:21:42 pm »
Dave did it.
If you mention this, you should also check the video where he explains what happened:
So the noise is actually quite acceptable...
Offline mawyatt
« Reply #436 on: November 30, 2020, 05:36:47 pm »
Looks as if Dave actually flubbed up both the standard DSO and the Battery Powered DSO measurements :o
Agree this is much better noise performance, and getting near acceptable.
Thanks for the update.
Best,
Offline mawyatt
« Reply #437 on: November 30, 2020, 05:51:13 pm »
Awhile back we tried a similar approach with a cheap eBay 32V 5A supply, result was not much improvement. This supply put out so much noise everywhere, on the AC input, input ground and output, you would have thought it was some sort of Electronic Warfare Jammer :P
Finally gave up on trying to improve the noise and now only use it for motors and such, pretty much useless for any lab work.
Maybe it would be a good source for EMI susceptibility, if things work when powered with this supply they should work with anything  :palm:
Good luck taming those noise spikes.
Best,
The following users thanked this post: unicornio
Offline nikitasius
« Reply #438 on: November 30, 2020, 10:58:21 pm »
Best,
But if you shield switching supply and put électrolytes, it should remove noise upto 10k, then you can place 10kHz, 60kHz and 250kHz filters to remove noise on those freqs (using 4 pin inductors and ceramic caps). Wires from ACDC to rd6006 should be threaded and shielded too. Am i right? Have a good friend who helps me with advices 😁
On the image there are 10mH inductors (4 pins each) and différent caps. For almost 40dB (39.37).
Offline mawyatt
« Reply #439 on: December 01, 2020, 01:46:58 am »
One shouldn't have to go to all that trouble just make a supply useable that was advertised as a "Lab Supply" :palm:
All the shielding, filtering and what not on the inputs and outputs isn't worth the effort and additional cost IMO, and likely won't achieve a respectable noise level anyway. I'll just get another supply that will support lab use, and hoping maybe this new Ruideng "Hybrid" mentioned just might be acceptable  ::)
Anyway, thanks for the note.
Best,
« Last Edit: December 01, 2020, 01:58:29 am by mawyatt »
Offline Simon_RL
« Reply #440 on: December 01, 2020, 06:41:03 am »
Best,
Totally agree.
I found out the other day, the power supply for my RD6006 is putting out a shit tonne of EMI. I hadn't used it for ages, needed 4 amps input (my regular power supply is a DP832). On testing the DUT I got a lot of noise on my scope. I disconnected my probes from the DUT and the noise/EMI was still there (please see below).
After a bit of searching, including powering down my device, the RD6006 was found to be the culprit. When I disconnected the probe from my scope the noise disappears, so I am guessing my probe cables are acting like an antenna.
I haven't had a chance to read through all previous post yet, but I am guessing the problem is the actual power supply and not the actual RD6006. Can somebody please confirm if I confirm if this is correct?
Forgot to mention that the EMI still occurs when the RD6006 is off but the PSU is on. I just answered my question:palm: :-DD
« Last Edit: December 01, 2020, 08:22:47 am by Simon_RL »
Offline alex34
  • Country: ru
« Reply #441 on: December 01, 2020, 02:40:21 pm »
I think there is a lot of lab tasks which does not require a pure clean PSU. (Unless you powering some preamp or RF circuit).In that case it's better to have a low power pure linear PSU. So, RD6006 is a good choice for all other tasks. In fact. 30V 3A (which most PSUs have)  is not near enough for my lab.
Speaking of RD6006 noise - how about use a ferrite beads on a cable? Cheap and handy :)
Offline nikitasius
« Reply #442 on: December 01, 2020, 07:30:08 pm »
hi, i just thinking about improving a little bit the ACDC which will feed the RD6006. Not about placing RD6006 into range of 500€ lab tools.
Filters will cost for me maximum 20€ to do.
hi, but if we place ferrite rings on output contacts and shield front plastic panel with permalloy it should help with EMI or reduce it at least?
As i said, i don't want to place rd6006 in the same range with 500€ lab tools, i just want to get the best from it.
Switching power supply is a temporary, before i will order two toroidal transformers (they will compensate EMI of each other).
And all this will be inside a nice shielded woodbox, rétro style  ;D
The following users thanked this post: Simon_RL
Offline BlueTronic
  • Country: at
« Reply #443 on: December 02, 2020, 10:40:02 pm »
Hi Unisoft
I have tested your Beta versions V1.31.6c and V1.31.6d (RD6012) and I found two bugs:
1. Under Menu/Home/Layout 1 -> "SHOW IIME" (it should be "TIME" - the letter "T") - same bug in German and Chinese language.
    I know, you mentioned it before, that at the moment there is no update for German language (you use English words for new settings),
    thats why there is the same bug in different languages.
2. I´m not sure if its a bug, maybe you programed this purposely!?  :-//
   When I program Menu/Power Settings -> "OTP (ext)" for example to "40°C" it will affect only in the current session.
   Turning my RD6012 off and on, the "OTP (ext)" will be set to "OFF" again.
   If I want to set a value in the "OTP (ext)" forever, I had to set it in MENU/Battery Charger -> "CuttOff temp."
   (changing at "CutOff temp." will automaticly set the same value in "OTP (ext)")
The following users thanked this post: UniSoft
Offline UniSoft
  • Country: kz
« Reply #444 on: December 03, 2020, 02:25:36 am »
1. Under Menu/Home/Layout 1 -> "SHOW IIME"...
   When I program Menu/Power Settings -> "OTP (ext)" ... will be set to "OFF" again.
1, 2: Yes small BUGs will be fixed in next beta...
Thanks
Offline mawyatt
« Reply #445 on: December 03, 2020, 03:00:03 am »
Agree the RD6006 likely will not perform well enough for replacing a proper Lab Supply, but the new "Hybrid" version mentioned might just be good enough for low end Lab Supply use, hopefully soon we'll find out ::)
Best,
Offline Simon_RL
« Reply #446 on: December 03, 2020, 12:21:00 pm »
Hi nikitasius,
My problem is the SMPS that is powering my RD6006. Not the actual RD6006, as I said the noise is still there when the RD6006 is switched off and my scope probes not connected to anything. I couldn't be bothered trying to resolved the issue in a cheap SMPS, it was just easier to order a 48v Meanwell and be done with it.
Offline Tatanka1961
« Reply #447 on: December 03, 2020, 05:48:09 pm »
Hi nikitasius,
The best solution is to use a linear power supply as source. A decent toroidal and some caps...
Offline Simon_RL
« Reply #448 on: December 03, 2020, 08:37:07 pm »
Hi nikitasius,
Hi Tatanka, I agree but I don’t want to go to that much trouble for a PSU that isn’t used very often.
Offline BlueTronic
  • Country: at
« Reply #449 on: December 03, 2020, 09:44:33 pm »
Hi Unisoft
Found some bugs in Beta V1.31.6e (RD6012)
1. If you scroll back and forward from Layout 0 to Layout 1, settings jump a few pixel up and down.
   You will see it, when you set Layout 1 equal to Layout 0 and jump between them.
Layout-0-and-1" border="0
2. Pressing "up" and "down" in main window, will change the "Status Info" in the right bottom corner.
   When you press only the "down" button, all setting will rotate endlessly. Pressing "up" button a few times the settings will stuck at "default".
3. It´s not a bug, only a beauty mark.
   Changing "Status Info" in the right bottom corner between two (Ah and Wh) and one line (Int. Temp.) the value will jump up and down a little.
Bottom" border="0
